[GRASS-SVN] r41444 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Mar 15 08:37:30 EDT 2010
Author: martinl
Date: 2010-03-15 08:37:30 -0400 (Mon, 15 Mar 2010)
New Revision: 41444
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
bugfix #928
(merge r41442 from relbr64)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2010-03-15 12:33:03 UTC (rev 41443)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2010-03-15 12:37:30 UTC (rev 41444)
@@ -102,7 +102,7 @@
aborted = False
time.sleep(.1)
# set default color table for raster data
if UserSettings.Get(group='cmd', key='rasterColorTable', subkey='enabled') and \
args[0][0][:2] == 'r.':
@@ -122,7 +122,7 @@
time = requestTime,
pid = requestId,
onDone = onDone)
# send event
wx.PostEvent(self.parent, event)
@@ -401,7 +401,7 @@
self.Map = curr_disp.GetRender()
except:
curr_disp = None
# command given as a string ?
try:
cmdlist = command.strip().split(' ')
@@ -417,7 +417,7 @@
fileHistory.write(cmdString + '\n')
finally:
fileHistory.close()
# update history items
if self.parent.GetName() == 'LayerManager':
try:
@@ -428,7 +428,7 @@
if cmdlist[0] in globalvar.grassCmd['all']:
# send GRASS command without arguments to GUI command interface
# except display commands (they are handled differently)
- if cmdlist[0][0:2] == "d.":
+ if self.parent.GetName() == "LayerManager" and cmdlist[0][0:2] == "d.":
# display GRASS commands
@@ -448,7 +448,9 @@
'd.rhumbline' : 'rhumb',
'd.labels' : 'labels'}[cmdlist[0]]
except KeyError:
- wx.MessageBox(message=_("Command '%s' not yet implemented in the GUI. Try adding it as a command layer instead.") % cmdlist[0])
+ wx.MessageBox(caption = _("Message"),
+ message=_("Command '%s' not yet implemented in the GUI. "
+ "Try adding it as a command layer instead.") % cmdlist[0])
return None
# add layer into layer tree
@@ -460,11 +462,12 @@
layerType = 'vector')
else:
lname = None
- self.parent.curr_page.maptree.AddLayer(ltype=layertype,
- lname=lname,
- lcmd=cmdlist)
+ if self.parent.GetName() == "LayerManager":
+ self.parent.curr_page.maptree.AddLayer(ltype=layertype,
+ lname=lname,
+ lcmd=cmdlist)
else:
# other GRASS commands (r|v|g|...)
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-03-15 12:33:03 UTC (rev 41443)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-03-15 12:37:30 UTC (rev 41444)
@@ -910,7 +910,7 @@
if cmd == None or len(cmd) < 2:
return
- if cmd[0][0:2] != "d.":
+ if self.standalone or cmd[0][0:2] != "d.":
# Send any non-display command to parent window (probably wxgui.py)
# put to parents
# switch to 'Command output'
@@ -927,7 +927,7 @@
# Send any other command to the shell.
else:
gcmd.Command(cmd)
# update buttons status
for btn in (self.btn_run,
self.btn_cancel,
