[GRASS-SVN] r41446 - grass/trunk/vector/v.out.ascii
svn_grass at osgeo.org
Mon Mar 15 08:42:57 EDT 2010
Author: martinl
Date: 2010-03-15 08:42:56 -0400 (Mon, 15 Mar 2010)
New Revision: 41446
grass/trunk/vector/v.out.ascii/args.c
v.out.ascii: 'output' is not required
Modified: grass/trunk/vector/v.out.ascii/args.c
--- grass/trunk/vector/v.out.ascii/args.c 2010-03-15 12:38:21 UTC (rev 41445)
+++ grass/trunk/vector/v.out.ascii/args.c 2010-03-15 12:42:56 UTC (rev 41446)
@@ -24,6 +24,7 @@
output_opt->description =
_("Path to resulting ASCII file ('-' for standard output) "
"or ASCII vector name if '-o' is defined");
+ output_opt->required = NO;
output_opt->answer = "-";
column_opt = G_define_standard_option(G_OPT_DB_COLUMNS);
