[GRASS-SVN] r41465 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Wed Mar 17 07:00:18 EDT 2010
Author: martinl
Date: 2010-03-17 07:00:17 -0400 (Wed, 17 Mar 2010)
New Revision: 41465
grass/branches/develbranch_6/gui/wxpython/gis_set.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
bugfix #1004
Modified: grass/branches/develbranch_6/gui/wxpython/gis_set.py
--- grass/branches/develbranch_6/gui/wxpython/gis_set.py 2010-03-17 10:37:01 UTC (rev 41464)
+++ grass/branches/develbranch_6/gui/wxpython/gis_set.py 2010-03-17 11:00:17 UTC (rev 41465)
@@ -212,6 +212,7 @@
if location == "<UNKNOWN>" or \
not os.path.isdir(os.path.join(self.gisdbase, location)):
location = None
if location:
# list of locations
self.UpdateLocations(self.gisdbase)
@@ -221,10 +222,10 @@
self.lblocations.EnsureVisible(self.listOfLocations.index(location))
except ValueError:
print >> sys.stderr, _("ERROR: Location <%s> not found") % \
- (location)
+ (utils.UnicodeString(location))
# list of mapsets
- self.UpdateMapsets(os.path.join(self.gisdbase,location))
+ self.UpdateMapsets(os.path.join(self.gisdbase, location))
mapset = self.GetRCValue("MAPSET")
if mapset:
try:
@@ -234,10 +235,8 @@
except ValueError:
self.lbmapsets.Clear()
print >> sys.stderr, _("ERROR: Mapset <%s> not found") % \
- (mapset)
- # self.bstart.Enable(True)
+ (utils.UnicodeString(mapset))
def _do_layout(self):
label_style = wx.ADJUST_MINSIZE | wx.ALIGN_CENTER_HORIZONTAL
@@ -587,6 +586,7 @@
disabled = []
idx = 0
for mapset in self.listOfMapsets:
+ mapset = utils.UnicodeString(mapset)
if mapset not in self.listOfMapsetsSelectable or \
os.path.isfile(os.path.join(self.gisdbase,
locationName,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2010-03-17 10:37:01 UTC (rev 41464)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2010-03-17 11:00:17 UTC (rev 41465)
@@ -842,13 +842,15 @@
# Run command on line when <return> is pressed
# find the command to run
- line = str(self.GetCurLine()[0]).strip()
+ line = self.GetCurLine()[0].strip()
if len(line) == 0:
return
# parse command into list
- # TODO: shell commands should probably be passed as string
- cmd = shlex.split(str(line))
+ try:
+ cmd = shlex.split(str(line))
+ except UnicodeError:
+ cmd = shlex.split(utils.EncodeString((line)))
#send the command list to the processor
self.parent.RunCmd(cmd)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2010-03-17 10:37:01 UTC (rev 41464)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2010-03-17 11:00:17 UTC (rev 41465)
@@ -599,8 +599,7 @@
if os.path.isdir(mapset) and \
os.path.isfile(os.path.join(dbase, location, mapset, "WIND")) and \
os.path.basename(mapset) != 'PERMANENT':
- listOfMapsets.append(os.path.basename(mapset))
+ listOfMapsets.append(EncodeString(os.path.basename(mapset)))
ListSortLower(listOfMapsets)
listOfMapsets.insert(0, 'PERMANENT')
@@ -628,3 +627,19 @@
return string.encode(enc)
return string
+def UnicodeString(string):
+ """!Return unicode string
+ @param string string to be converted
+ @return unicode string
+ if isinstance(string, unicode):
+ return string
+ enc = locale.getdefaultlocale()[1]
+ if enc:
+ return unicode(string, enc)
+ return string
