[GRASS-SVN] r41500 - grass/trunk/lib/gis
svn_grass at osgeo.org
Sat Mar 20 14:53:19 EDT 2010
Author: glynn
Date: 2010-03-20 14:53:19 -0400 (Sat, 20 Mar 2010)
New Revision: 41500
grass/trunk/lib/gis/parser.c
Remove unnecessary casts
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2010-03-20 18:52:38 UTC (rev 41499)
+++ grass/trunk/lib/gis/parser.c 2010-03-20 18:53:19 UTC (rev 41500)
@@ -152,7 +152,7 @@
/* Allocate memory if not the first flag */
if (st->n_flags) {
- flag = (struct Flag *)G_malloc(sizeof(struct Flag));
+ flag = G_malloc(sizeof(struct Flag));
st->current_flag->next_flag = flag;
else
@@ -160,19 +160,19 @@
/* Zero structure */
- G_zero((char *)flag, sizeof(struct Flag));
+ G_zero(flag, sizeof(struct Flag));
st->current_flag = flag;
st->n_flags++;
if (st->n_items) {
- item = (struct Item *)G_malloc(sizeof(struct Item));
+ item = G_malloc(sizeof(struct Item));
st->current_item->next_item = item;
else
item = &st->first_item;
- G_zero((char *)item, sizeof(struct Item));
+ G_zero(item, sizeof(struct Item));
item->flag = flag;
item->option = NULL;
@@ -206,14 +206,14 @@
/* Allocate memory if not the first option */
if (st->n_opts) {
- opt = (struct Option *)G_malloc(sizeof(struct Option));
+ opt = G_malloc(sizeof(struct Option));
st->current_option->next_opt = opt;
else
opt = &st->first_option;
- G_zero((char *)opt, sizeof(struct Option));
+ G_zero(opt, sizeof(struct Option));
opt->required = NO;
opt->multiple = NO;
@@ -235,13 +235,13 @@
st->n_opts++;
if (st->n_items) {
else
item->option = opt;
item->flag = NULL;
@@ -265,7 +265,7 @@
module = &st->module_info;
- G_zero((char *)module, sizeof(struct GModule));
+ G_zero(module, sizeof(struct GModule));
/* Allocate keywords array */
define_keywords();
@@ -353,8 +353,7 @@
i++;
- opt->opts =
- (const char **)G_calloc(cnt + 1, sizeof(const char *));
+ opt->opts = G_calloc(cnt + 1, sizeof(const char *));
i = 0;
while (tokens[i]) {
@@ -366,8 +365,7 @@
if (opt->descriptions) {
delm[0] = ';';
- opt->descs =
+ opt->descs = G_calloc(cnt + 1, sizeof(const char *));
tokens = G_tokenize(opt->descriptions, delm);
i = 0;
@@ -402,12 +400,12 @@
/* Copy answer */
if (opt->multiple && opt->answers && opt->answers[0]) {
- opt->answer = (char *)G_malloc(strlen(opt->answers[0]) + 1);
+ opt->answer = G_malloc(strlen(opt->answers[0]) + 1);
strcpy(opt->answer, opt->answers[0]);
for (i = 1; opt->answers[i]; i++) {
- opt->answer = (char *)G_realloc(opt->answer,
- strlen(opt->answer) +
- strlen(opt->answers[i]) + 2);
+ opt->answer = G_realloc(opt->answer,
+ strlen(opt->answer) +
+ strlen(opt->answers[i]) + 2);
strcat(opt->answer, ",");
strcat(opt->answer, opt->answers[i]);
@@ -688,8 +686,8 @@
if (st->n_keys >= st->n_keys_alloc) {
st->n_keys_alloc += 10;
- st->module_info.keywords = (const char **) G_realloc(st->module_info.keywords,
- st->n_keys_alloc * sizeof(char *));
+ st->module_info.keywords = G_realloc(st->module_info.keywords,
+ st->n_keys_alloc * sizeof(char *));
st->module_info.keywords[st->n_keys++] = G_store(keyword);
@@ -702,8 +700,9 @@
void G_set_keywords(const char *keywords)
- st->module_info.keywords = (const char**)G_tokenize(keywords, ",");
- st->n_keys = st->n_keys_alloc = G_number_of_tokens((char **)st->module_info.keywords);
+ char **tokens = G_tokenize(keywords, ",");
+ st->module_info.keywords = (const char **)tokens;
+ st->n_keys = st->n_keys_alloc = G_number_of_tokens(tokens);
@@ -914,9 +913,8 @@
/* Allocate memory where answer is stored */
if (opt->count++) {
- strlen(opt->answer) + strlen(string) +
- 2);
+ strlen(opt->answer) + strlen(string) + 2);
strcat(opt->answer, string);
@@ -1152,8 +1150,8 @@
static void split_opts(void)
struct Option *opt;
- char *ptr1;
- char *ptr2;
+ const char *ptr1;
+ const char *ptr2;
int allocated;
int ans_num;
int len;
@@ -1167,7 +1165,7 @@
if ( /*opt->multiple && */ opt->answer) {
/* Allocate some memory to store array of pointers */
allocated = 10;
- opt->answers = (char **)G_malloc(allocated * sizeof(char *));
+ opt->answers = G_malloc(allocated * sizeof(char *));
ans_num = 0;
ptr1 = opt->answer;
@@ -1178,7 +1176,7 @@
ptr2++, len++) ;
if (len > 0) { /* skip ,, */
- opt->answers[ans_num] = (char *)G_malloc(len + 1);
+ opt->answers[ans_num] = G_malloc(len + 1);
memcpy(opt->answers[ans_num], ptr1, len);
opt->answers[ans_num][len] = 0;
@@ -1186,9 +1184,8 @@
if (ans_num >= allocated) {
allocated += 10;
- opt->answers =
- (char **)G_realloc((char *)opt->answers,
- allocated * sizeof(char *));
+ opt->answers = G_realloc(opt->answers,
+ allocated * sizeof(char *));
opt->answers[ans_num] = NULL;
