[GRASS-SVN] r41503 - in grass/trunk/raster: r.gwflow
r.solute.transport
svn_grass at osgeo.org
Sat Mar 20 20:55:29 EDT 2010
Author: huhabla
Date: 2010-03-20 20:55:27 -0400 (Sat, 20 Mar 2010)
New Revision: 41503
grass/trunk/raster/r.gwflow/main.c
grass/trunk/raster/r.solute.transport/main.c
Modified gui section support
Modified: grass/trunk/raster/r.gwflow/main.c
--- grass/trunk/raster/r.gwflow/main.c 2010-03-21 00:37:47 UTC (rev 41502)
+++ grass/trunk/raster/r.gwflow/main.c 2010-03-21 00:55:27 UTC (rev 41503)
@@ -203,13 +203,9 @@
_("The leakage coefficient of the drainage bed in [1/s]");
param.dt = N_define_standard_option(N_OPT_CALC_TIME);
- param.dt->guisection = _("solver");
param.maxit = N_define_standard_option(N_OPT_MAX_ITERATIONS);
- param.maxit->guisection = _("solver");
param.error = N_define_standard_option(N_OPT_ITERATION_ERROR);
- param.error->guisection = _("solver");
param.solver = N_define_standard_option(N_OPT_SOLVER_SYMM);
- param.solver->guisection = _("solver");
param.solver->options = "cg,pcg,cholesky";
param.full_les = G_define_flag();
@@ -258,6 +254,10 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ /* Make sure that the current projection is not lat/long */
+ if ((G_projection() == PROJECTION_LL))
+ G_fatal_error(_("Lat/Long location is not supported by %s. Please reproject map first."),
+ G_program_name());
/*Check the river parameters */
if (param.river_leak->answer == NULL && param.river_bed->answer == NULL &&
Modified: grass/trunk/raster/r.solute.transport/main.c
--- grass/trunk/raster/r.solute.transport/main.c 2010-03-21 00:37:47 UTC (rev 41502)
+++ grass/trunk/raster/r.solute.transport/main.c 2010-03-21 00:55:27 UTC (rev 41503)
@@ -33,7 +33,7 @@
struct Option *output, *phead, *hc_x, *hc_y,
*c, *status, *diff_x, *diff_y, *q, *cs, *r, *top, *nf, *cin,
- *bottom, *vector_x, *vector_y, *bugded, *type, *dt, *maxit, *error, *solver, *sor,
+ *bottom, *vector_x, *vector_y, *type, *dt, *maxit, *error, *solver, *sor,
*al, *at, *loops, *stab;
struct Flag *full_les;
struct Flag *cfl;
@@ -91,6 +91,7 @@
param.q = G_define_standard_option(G_OPT_R_INPUT);
param.q->key = "q";
+ param.q->guisection = _("water flow");
param.q->required = NO;
param.q->description = _("Groundwater sources and sinks in [m^3/s]");
@@ -98,7 +99,8 @@
param.cin->key = "cin";
param.cin->required = NO;
param.cin->gisprompt = "old,raster,raster";
- param.cin->description = _("concentration sources and sinks bounded to a "
+ param.cin->guisection = _("water flow");
+ param.cin->description = _("Concentration sources and sinks bounded to a "
"water source or sink in [kg/s]");
@@ -107,7 +109,7 @@
param.cs->type = TYPE_STRING;
param.cs->required = YES;
param.cs->gisprompt = "old,raster,raster";
- param.cs->description = _("concentration of inner sources and inner sinks in [kg/s] "
+ param.cs->description = _("Concentration of inner sources and inner sinks in [kg/s] "
"(i.e. a chemical reaction)");
param.r = G_define_standard_option(G_OPT_R_INPUT);
@@ -130,12 +132,12 @@
param.output->description = _("The resulting concentration of the numerical solute "
"transport calculation will be written to this map. [kg/m^3]");
param.vector_x = G_define_option();
param.vector_x->key = "vx";
param.vector_x->type = TYPE_STRING;
param.vector_x->required = NO;
param.vector_x->gisprompt = "new,raster,raster";
+ param.vector_x->guisection = _("water flow");
param.vector_x->description =
_("Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n");
@@ -144,6 +146,7 @@
param.vector_y->type = TYPE_STRING;
param.vector_y->required = NO;
param.vector_y->gisprompt = "new,raster,raster";
+ param.vector_y->guisection = _("water flow");
param.vector_y->description =
_("Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n");
@@ -183,16 +186,19 @@
param.stab->required = NO;
param.stab->answer = "full";
param.stab->options = "full,exp";
+ param.stab->guisection = _("stabelization");
param.stab->description =
_("Set the flow stabilizing scheme (full or exponential upwinding).");
param.full_les->key = 'f';
+ param.full_les->guisection = _("solver");
param.full_les->description = _("Use a full filled quadratic linear equation system,"
" default is a sparse linear equation system.");
param.cfl = G_define_flag();
param.cfl->key = 'c';
+ param.cfl->guisection = _("stabelization");
param.cfl->description =
_("Use the Courant-Friedrichs-Lewy criteria for time step calculation");
@@ -236,6 +242,11 @@
exit(EXIT_FAILURE);
/*Set the maximum iterations */
sscanf(param.maxit->answer, "%i", &(maxit));
/*Set the calculation error break criteria */
