[GRASS-SVN] r41529 - grass-addons/gui/wxpython/data_catalog
Tue Mar 23 08:56:35 EDT 2010
Author: rashadkm
Date: 2010-03-23 08:56:28 -0400 (Tue, 23 Mar 2010)
New Revision: 41529
Added:
   grass-addons/gui/wxpython/data_catalog/right.py
   grass-addons/gui/wxpython/data_catalog/toolbars.py
   grass-addons/gui/wxpython/data_catalog/wxgui.py
   grass-addons/gui/wxpython/data_catalog/catalog.py
minor updates only;
Modified: grass-addons/gui/wxpython/data_catalog/catalog.py
--- grass-addons/gui/wxpython/data_catalog/catalog.py	2010-03-22 18:49:44 UTC (rev 41528)
+++ grass-addons/gui/wxpython/data_catalog/catalog.py	2010-03-23 12:56:28 UTC (rev 41529)
@@ -365,15 +365,69 @@
         self.Bind(wx.EVT_MENU, rhandler, menuItem)
-    def OnXTerm(self):
-        print "asdf1"
-    def OnRunScript(self):
-        print "asdf2"
-    def OnQuit(self):
-        print "asdf3"
+    def OnXTermNoXMon(self, event):
+        Run commands that need xterm
+        self.OnXTerm(event, need_xmon = False)
+    def OnXTerm(self, event, need_xmon = True):
+        Run commands that need interactive xmon
+        @param need_xmon True to start X monitor
+        # unset display mode
+        del os.environ['GRASS_RENDER_IMMEDIATE']
+        if need_xmon:
+            # open next available xmon
+            xmonlist = []
+            # make list of xmons that are not running
+            ret = gcmd.RunCommand('d.mon',
+                                  flags = 'L',
+                                  read = True)
+            for line in ret.split('\n'):
+                line = line.strip()
+                if line.startswith('x') and 'not running' in line:
+                    xmonlist.append(line[0:2])
+            # find available xmon
+            xmon = xmonlist[0]
+            # bring up the xmon
+            cmdlist = ['d.mon', xmon]
+            p = gcmd.Command(cmdlist, wait=False)
+        # run the command
+        command = self.GetMenuCmd(event)
+        command = ' '.join(command)
+        gisbase = os.environ['GISBASE']
+        if sys.platform == "win32":
+            runbat = os.path.join(gisbase,'etc','grass-run.bat')
+            cmdlist = ["start", runbat, runbat, command]
+        else:
+            if sys.platform == "darwin":
+                xtermwrapper = os.path.join(gisbase,'etc','grass-xterm-mac')
+            else:
+                xtermwrapper = os.path.join(gisbase,'etc','grass-xterm-wrapper')
+            grassrun = os.path.join(gisbase,'etc','grass-run.sh')
+            cmdlist = [xtermwrapper, '-e', grassrun, command]
+        # reset display mode
+        os.environ['GRASS_RENDER_IMMEDIATE'] = 'TRUE'
     def OnRunCmd(self, event):
         """Run command"""
         cmdString = event.GetString()
Added: grass-addons/gui/wxpython/data_catalog/right.py
--- grass-addons/gui/wxpython/data_catalog/right.py	                        (rev 0)
+++ grass-addons/gui/wxpython/data_catalog/right.py	2010-03-23 12:56:28 UTC (rev 41529)
@@ -0,0 +1,39 @@
+import wx
+import wx_utils as wx_utils
+class RightTree(wx.TreeCtrl):
+    def __init__(self, parent, id,
+                 pos = wx.DefaultPosition,
+                 size = wx.DefaultSize,
+                 style= wx.TR_HIDE_ROOT|wx.TR_HAS_BUTTONS):
+        wx.TreeCtrl.__init__(self, parent, id, pos, size, style)
+        self.itemFont2 = wx.Font(pointSize=9,weight=0, family=wx.FONTFAMILY_DEFAULT ,style=wx.FONTSTYLE_ITALIC)
+    def PopulateDisplay(self):
+        root1 = self.AddRoot('root')
+        node_raster2 = self.AppendItem(root1, "Display 0")
+        node_vector2 = self.AppendItem(root1, "Display 1")
+        node_dbf2 = self.AppendItem(root1, "Display 2")
+        treeNodes2 = [node_raster2,node_vector2,node_dbf2]
+        #Nodes with no children are given an italic type font
+        for node in treeNodes2:
+            if not self.ItemHasChildren(node):
+	            if self.GetItemText(node) == 'Display 0':
+		            tmp_item2 = self.AppendItem(node, "No raster maps found.")
+	            elif self.GetItemText(node) == 'Display 1':
+		            tmp_item2 = self.AppendItem(node, "No vector maps found.")
+	            elif self.GetItemText(node) == 'Display 2':
+		            tmp_item2 = self.AppendItem(node, "No DBF files found.")
+	            self.SetItemFont(tmp_item2,self.itemFont2)
+        #self.pg_panel = wx.Panel(self.gm_cb, id=wx.ID_ANY, style= wx.EXPAND)
+        #self.gm_cb.AddPage(self.pg_panel, text="Display "+ str(self.disp_idx + 1), select = True)
+        #self.curr_page = self.gm_cb.GetCurrentPage()
+        # create layer tree (tree control for managing GIS layers)  and put on new notebook page
Added: grass-addons/gui/wxpython/data_catalog/toolbars.py
--- grass-addons/gui/wxpython/data_catalog/toolbars.py	                        (rev 0)
+++ grass-addons/gui/wxpython/data_catalog/toolbars.py	2010-03-23 12:56:28 UTC (rev 41529)
@@ -0,0 +1,1380 @@
+ at package toolbar
+ at brief Toolbars for Map Display window
+Classes:
+ - AbstractToolbar
+ - MapToolbar
+ - GRToolbar
+ - GCPToolbar
+ - VDigitToolbar
+ - ProfileToolbar
+ - NvizToolbar
+(C) 2007-2008 by the GRASS Development Team This program is free
+software under the GNU General Public License (>=v2). Read the file
+COPYING that comes with GRASS for details.
+ at author Michael Barton
+ at author Jachym Cepicky
+ at author Martin Landa <landa.martin gmail.com>
+import wx
+import os, sys
+import platform
+import globalvar
+import gcmd
+version = os.getenv("GRASS_VERSION")
+if version == "6.4.0svn":
+    import grassenv
+import gdialogs
+import vdigit
+from vdigit import VDigitSettingsDialog as VDigitSettingsDialog
+from debug import Debug as Debug
+from icon import Icons as Icons
+from preferences import globalSettings as UserSettings
+gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
+sys.path.append(gmpath)
+class AbstractToolbar(object):
+    """Abstract toolbar class"""
+    def __init__(self):
+        pass
+    def InitToolbar(self, parent, toolbar, toolData):
+        """Initialize toolbar, i.e. add tools to the toolbar
+        @return list of ids (of added tools)
+        for tool in toolData:
+            self.CreateTool(parent, toolbar, *tool)
+        self._toolbar = toolbar
+        self._data = toolData
+        self.parent = parent
+    def ToolbarData(self):
+        """Toolbar data"""
+        return None
+    def CreateTool(self, parent, toolbar, tool, label, bitmap, kind,
+                   shortHelp, longHelp, handler):
+        """Add tool to the toolbar
+        @return id of tool
+        bmpDisabled=wx.NullBitmap
+        if label:
+            Debug.msg(3, "CreateTool(): tool=%d, label=%s bitmap=%s" % \
+                  (tool, label, bitmap))
+            toolWin = toolbar.AddLabelTool(tool, label, bitmap,
+                                           bmpDisabled, kind,
+                                           shortHelp, longHelp)
+            parent.Bind(wx.EVT_TOOL, handler, toolWin)
+        else: # add separator
+            toolbar.AddSeparator()
+        return tool
+    def GetToolbar(self):
+        """Get toolbar widget reference"""
+        return self._toolbar
+    def EnableLongHelp(self, enable=True):
+        """Enable/disable long help
+        @param enable True for enable otherwise disable
+        for tool in self._data:
+            if tool[0] == '': # separator
+                continue
+            if enable:
+                self._toolbar.SetToolLongHelp(tool[0], tool[5])
+            else:
+                self._toolbar.SetToolLongHelp(tool[0], "")
+    def OnTool(self, event):
+        """Tool selected"""
+        if self.parent.toolbars['vdigit']:
+            # update vdigit toolbar (unselect currently selected tool)
+            id = self.parent.toolbars['vdigit'].GetAction(type='id')
+            self.parent.toolbars['vdigit'].GetToolbar().ToggleTool(id, False)
+        if event:
+            # deselect previously selected tool
+            id = self.action.get('id', -1)
+            if id != event.GetId():
+                self._toolbar.ToggleTool(self.action['id'], False)
+            else:
+                self._toolbar.ToggleTool(self.action['id'], True)
+            self.action['id'] = event.GetId()
+            event.Skip()
+        else:
+            # initialize toolbar
+    def GetAction(self, type='desc'):
+        """Get current action info"""
+        return self.action.get(type, '')
+    def SelectDefault(self, event):
+        """Select default tool"""
+        self._toolbar.ToggleTool(self.defaultAction['id'], True)
+        self.defaultAction['bind'](event)
+        self.action = { 'id' : self.defaultAction['id'],
+                        'desc' : self.defaultAction.get('desc', '') }
+    def FixSize(self, width):
+	"""Fix toolbar width on Windows
+	@todo Determine why combobox causes problems here
+        if platform.system() == 'Windows':
+            size = self._toolbar.GetBestSize()
+            self._toolbar.SetSize((size[0] + width, size[1]))
+class MapToolbar(AbstractToolbar):
+    Main Map Display toolbar
+    def __init__(self, mapdisplay, map):
+        AbstractToolbar.__init__(self)
+        self.mapcontent = map
+        self.mapdisplay = mapdisplay
+        self.toolbar = wx.ToolBar(parent=self.mapdisplay, id=wx.ID_ANY)
+        self.toolbar.SetToolBitmapSize(globalvar.toolbarSize)
+        self.InitToolbar(self.mapdisplay, self.toolbar, self.ToolbarData())
+        # optional tools
+        self.combo = wx.ComboBox(parent=self.toolbar, id=wx.ID_ANY, value=_('2D view'),
+                                 choices=[_('2D view'), _('3D view'), _('Digitize')],
+                                 style=wx.CB_READONLY, size=(90, -1))
+        self.comboid = self.toolbar.AddControl(self.combo)
+        self.mapdisplay.Bind(wx.EVT_COMBOBOX, self.OnSelectTool, self.comboid)
+        # realize the toolbar
+        self.toolbar.Realize()
+        # workaround for Mac bug. May be fixed by 2.8.8, but not before then.
+        self.combo.Hide()
+        self.combo.Show()
+        # default action
+        self.action = { 'id' : self.pointer }
+        self.defaultAction = { 'id' : self.pointer,
+                               'bind' : self.mapdisplay.OnPointer }
+        self.OnTool(None)
+        self.FixSize(width = 90)
+        self.displaymap = wx.NewId()
+        self.rendermap = wx.NewId()
+        self.erase = wx.NewId()
+        self.pointer = wx.NewId()
+        self.query = wx.NewId()
+        self.pan = wx.NewId()
+        self.zoomin = wx.NewId()
+        self.zoomout = wx.NewId()
+        self.zoomback = wx.NewId()
+        self.zoommenu = wx.NewId()
+        self.analyze = wx.NewId()
+        self.dec = wx.NewId()
+        self.savefile = wx.NewId()
+        self.printmap = wx.NewId()
+        # tool, label, bitmap, kind, shortHelp, longHelp, handler
+        return (
+            (self.displaymap, "displaymap", Icons["displaymap"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["displaymap"].GetLabel(), Icons["displaymap"].GetDesc(),
+             self.mapdisplay.OnDraw),
+            (self.rendermap, "rendermap", Icons["rendermap"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["rendermap"].GetLabel(), Icons["rendermap"].GetDesc(),
+             self.mapdisplay.OnRender),
+            (self.erase, "erase", Icons["erase"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["erase"].GetLabel(), Icons["erase"].GetDesc(),
+             self.mapdisplay.OnErase),
+            (self.pointer, "pointer", Icons["pointer"].GetBitmap(),
+             wx.ITEM_CHECK, Icons["pointer"].GetLabel(), Icons["pointer"].GetDesc(),
+             self.mapdisplay.OnPointer),
+            (self.query, "query", Icons["query"].GetBitmap(),
+             wx.ITEM_CHECK, Icons["query"].GetLabel(), Icons["query"].GetDesc(),
+             self.mapdisplay.OnQuery),
+            (self.pan, "pan", Icons["pan"].GetBitmap(),
+             wx.ITEM_CHECK, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
+             self.mapdisplay.OnPan),
+            (self.zoomin, "zoom_in", Icons["zoom_in"].GetBitmap(),
+             wx.ITEM_CHECK, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
+             self.mapdisplay.OnZoomIn),
+            (self.zoomout, "zoom_out", Icons["zoom_out"].GetBitmap(),
+             wx.ITEM_CHECK, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
+             self.mapdisplay.OnZoomOut),
+            (self.zoomback, "zoom_back", Icons["zoom_back"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["zoom_back"].GetLabel(), Icons["zoom_back"].GetDesc(),
+             self.mapdisplay.OnZoomBack),
+            (self.zoommenu, "zoommenu", Icons["zoommenu"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["zoommenu"].GetLabel(), Icons["zoommenu"].GetDesc(),
+             self.mapdisplay.OnZoomMenu),
+            (self.analyze, "analyze", Icons["analyze"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["analyze"].GetLabel(), Icons["analyze"].GetDesc(),
+             self.mapdisplay.OnAnalyze),
+            (self.dec, "overlay", Icons["overlay"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["overlay"].GetLabel(), Icons["overlay"].GetDesc(),
+             self.mapdisplay.OnDecoration),
+            (self.savefile, "savefile", Icons["savefile"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["savefile"].GetLabel(), Icons["savefile"].GetDesc(),
+             self.mapdisplay.SaveToFile),
+            (self.printmap, "printmap", Icons["printmap"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["printmap"].GetLabel(), Icons["printmap"].GetDesc(),
+             self.mapdisplay.PrintMenu),
+    def OnSelectTool(self, event):
+        Select / enable tool available in tools list
+        tool =  event.GetSelection()
+        if tool == 0:
+            self.ExitToolbars()
+            self.Enable2D(True)
+        elif tool == 1 and not self.mapdisplay.toolbars['nviz']:
+            self.mapdisplay.AddToolbar("nviz")
+        elif tool == 2 and not self.mapdisplay.toolbars['vdigit']:
+            self.mapdisplay.AddToolbar("vdigit")
+    def ExitToolbars(self):
+        if self.mapdisplay.toolbars['vdigit']:
+            self.mapdisplay.toolbars['vdigit'].OnExit()
+        if self.mapdisplay.toolbars['nviz']:
+            self.mapdisplay.toolbars['nviz'].OnExit()
+    def Enable2D(self, enabled):
+        """Enable/Disable 2D display mode specific tools"""
+        for tool in (self.pointer,
+                     self.query,
+                     self.pan,
+                     self.zoomin,
+                     self.zoomout,
+                     self.zoomback,
+                     self.zoommenu,
+                     self.analyze,
+                     self.dec,
+                     self.savefile,
+                     self.printmap):
+            self.toolbar.EnableTool(tool, enabled)
+class GRToolbar(AbstractToolbar):
+    Georectification Display toolbar
+        # self.SetToolBar(self.toolbar)
+        self.gcpset = wx.NewId()
+        self.zoomtomap = wx.NewId()
+        return (
+            (self.gcpset, "grGcpSet", Icons["grGcpSet"].GetBitmap(),
+             wx.ITEM_RADIO, Icons["grGcpSet"].GetLabel(), Icons["grGcpSet"].GetDesc(),
+             wx.ITEM_RADIO, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
+             wx.ITEM_RADIO, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
+             wx.ITEM_RADIO, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
+            (self.zoomtomap, "zoomtomap", Icons["zoommenu"].GetBitmap(),
+             wx.ITEM_NORMAL, _("Zoom to map"), _("Zoom to displayed map"),
+             self.OnZoomMap),
+    def OnZoomMap(self, event):
+        """Zoom to selected map"""
+        layer = self.mapcontent.GetListOfLayers()[0]
+        self.mapdisplay.MapWindow.ZoomToMap(layer=layer)
+        event.Skip()
+class GCPToolbar(AbstractToolbar):
+    Toolbar for managing ground control points during georectification
+    def __init__(self, parent, tbframe):
+        self.parent  = parent # GCP
+        self.tbframe = tbframe
+        self.toolbar = wx.ToolBar(parent=self.tbframe, id=wx.ID_ANY)
+        self.InitToolbar(self.tbframe, self.toolbar, self.ToolbarData())
+        self.gcpSave = wx.NewId()
+        self.gcpAdd = wx.NewId()
+        self.gcpDelete = wx.NewId()
+        self.gcpClear = wx.NewId()
+        self.gcpReload = wx.NewId()
+        self.rms = wx.NewId()
+        self.georect = wx.NewId()
+        self.settings = wx.NewId()
+        self.quit = wx.NewId()
+        return (
+            (self.gcpSave, 'grGcpSave', Icons["grGcpSave"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpSave"].GetLabel(), Icons["grGcpSave"].GetDesc(),
+             self.parent.SaveGCPs),
+            (self.gcpAdd, 'grGrGcpAdd', Icons["grGcpAdd"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpAdd"].GetLabel(), Icons["grGcpAdd"].GetDesc(),
+             self.parent.AddGCP),
+            (self.gcpDelete, 'grGrGcpDelete', Icons["grGcpDelete"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpDelete"].GetLabel(), Icons["grGcpDelete"].GetDesc(),
+             self.parent.DeleteGCP),
+            (self.gcpClear, 'grGcpClear', Icons["grGcpClear"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpClear"].GetLabel(), Icons["grGcpClear"].GetDesc(),
+             self.parent.ClearGCP),
+            (self.gcpReload, 'grGcpReload', Icons["grGcpReload"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpReload"].GetLabel(), Icons["grGcpReload"].GetDesc(),
+             self.parent.ReloadGCPs),
+            (self.rms, 'grGcpRms', Icons["grGcpRms"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpRms"].GetLabel(), Icons["grGcpRms"].GetDesc(),
+             self.parent.OnRMS),
+            (self.georect, 'grGeorect', Icons["grGeorect"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGeorect"].GetLabel(), Icons["grGeorect"].GetDesc(),
+             self.parent.OnGeorect),
+            (self.settings, 'grSettings', Icons["grSettings"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grSettings"].GetLabel(), Icons["grSettings"].GetDesc(),
+             self.parent.OnSettings),
+            (self.quit, 'grGcpQuit', Icons["grGcpQuit"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpQuit"].GetLabel(), Icons["grGcpQuit"].GetDesc(),
+             self.parent.OnQuit)
+class VDigitToolbar(AbstractToolbar):
+    Toolbar for digitization
+    def __init__(self, parent, map, layerTree=None, log=None):
+        self.mapcontent    = map       # Map class instance
+        self.parent        = parent    # MapFrame
+        self.layerTree     = layerTree # reference to layer tree associated to map display
+        self.log           = log       # log area
+        # currently selected map layer for editing (reference to MapLayer instance)
+        self.mapLayer = None
+        # list of vector layers from Layer Manager (only in the current mapset)
+        self.layers   = []
+        self.comboid    = None
+        # only one dialog can be open
+        self.settingsDialog   = None
+        # create toolbars (two rows optionally)
+        self.toolbar = []
+        self.numOfRows = 1 # number of rows for toolbar
+        for row in range(0, self.numOfRows):
+            self.toolbar.append(wx.ToolBar(parent=self.parent, id=wx.ID_ANY))
+            self.toolbar[row].SetToolBitmapSize(globalvar.toolbarSize)
+            self.toolbar[row].Bind(wx.EVT_TOOL, self.OnTool)
+            # create toolbar
+            if self.numOfRows ==  1:
+                rowdata=None
+            else:
+                rowdata = row
+            self.InitToolbar(self.parent, self.toolbar[row], self.ToolbarData(rowdata))
+        # default action (digitize new point, line, etc.)
+        self.action = { 'desc' : 'addLine',
+                        'type' : 'point',
+                        'id'   : self.addPoint }
+        # list of available vector maps
+        self.UpdateListOfLayers(updateTool=True)
+        # realize toolbar
+            self.toolbar[row].Realize()
+            self.combo.Hide()
+            self.combo.Show()
+        # disable undo/redo
+        self.toolbar[0].EnableTool(self.undo, False)
+        # toogle to pointer by default
+        self.OnTool(None)
+        self.FixSize(width = 105)
+    def ToolbarData(self, row=None):
+        Toolbar data
+        data = []
+        if row is None or row == 0:
+            self.addPoint = wx.NewId()
+            self.addLine = wx.NewId()
+            self.addBoundary = wx.NewId()
+            self.addCentroid = wx.NewId()
+            self.moveVertex = wx.NewId()
+            self.addVertex = wx.NewId()
+            self.removeVertex = wx.NewId()
+            self.splitLine = wx.NewId()
+            self.editLine = wx.NewId()
+            self.moveLine = wx.NewId()
+            self.deleteLine = wx.NewId()
+            self.additionalTools = wx.NewId()
+            self.displayCats = wx.NewId()
+            self.displayAttr = wx.NewId()
+            self.copyCats = wx.NewId()
+            data = [("", "", "", "", "", "", ""),
+                    (self.addPoint, "digAddPoint", Icons["digAddPoint"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digAddPoint"].GetLabel(), Icons["digAddPoint"].GetDesc(),
+                     self.OnAddPoint),
+                    (self.addLine, "digAddLine", Icons["digAddLine"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digAddLine"].GetLabel(), Icons["digAddLine"].GetDesc(),
+                     self.OnAddLine),
+                    (self.addBoundary, "digAddBoundary", Icons["digAddBoundary"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digAddBoundary"].GetLabel(), Icons["digAddBoundary"].GetDesc(),
+                     self.OnAddBoundary),
+                    (self.addCentroid, "digAddCentroid", Icons["digAddCentroid"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digAddCentroid"].GetLabel(), Icons["digAddCentroid"].GetDesc(),
+                     self.OnAddCentroid),
+                    (self.moveVertex, "digMoveVertex", Icons["digMoveVertex"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digMoveVertex"].GetLabel(), Icons["digMoveVertex"].GetDesc(),
+                     self.OnMoveVertex),
+                    (self.addVertex, "digAddVertex", Icons["digAddVertex"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digAddVertex"].GetLabel(), Icons["digAddVertex"].GetDesc(),
+                     self.OnAddVertex),
+                    (self.removeVertex, "digRemoveVertex", Icons["digRemoveVertex"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digRemoveVertex"].GetLabel(), Icons["digRemoveVertex"].GetDesc(),
+                     self.OnRemoveVertex),
+                    (self.splitLine, "digSplitLine", Icons["digSplitLine"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digSplitLine"].GetLabel(), Icons["digSplitLine"].GetDesc(),
+                     self.OnSplitLine),
+                    (self.editLine, "digEditLine", Icons["digEditLine"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digEditLine"].GetLabel(), Icons["digEditLine"].GetDesc(),
+                     self.OnEditLine),
+                    (self.moveLine, "digMoveLine", Icons["digMoveLine"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digMoveLine"].GetLabel(), Icons["digMoveLine"].GetDesc(),
+                     self.OnMoveLine),
+                    (self.deleteLine, "digDeleteLine", Icons["digDeleteLine"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digDeleteLine"].GetLabel(), Icons["digDeleteLine"].GetDesc(),
+                     self.OnDeleteLine),
+                    (self.displayCats, "digDispCats", Icons["digDispCats"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digDispCats"].GetLabel(), Icons["digDispCats"].GetDesc(),
+                     self.OnDisplayCats),
+                    (self.copyCats, "digCopyCats", Icons["digCopyCats"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digCopyCats"].GetLabel(), Icons["digCopyCats"].GetDesc(),
+                     self.OnCopyCA),
+                    (self.displayAttr, "digDispAttr", Icons["digDispAttr"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digDispAttr"].GetLabel(), Icons["digDispAttr"].GetDesc(),
+                     self.OnDisplayAttr),
+                    (self.additionalTools, "digAdditionalTools", Icons["digAdditionalTools"].GetBitmap(),
+                     wx.ITEM_CHECK, Icons["digAdditionalTools"].GetLabel(),
+                     Icons["digAdditionalTools"].GetDesc(),
+                     self.OnAdditionalToolMenu)]
+        if row is None or row == 1:
+            self.undo = wx.NewId()
+            self.exit = wx.NewId()
+            data.append(("", "", "", "", "", "", ""))
+            data.append((self.undo, "digUndo", Icons["digUndo"].GetBitmap(),
+                         wx.ITEM_NORMAL, Icons["digUndo"].GetLabel(), Icons["digUndo"].GetDesc(),
+                         self.OnUndo))
+            # data.append((self.undo, "digRedo", Icons["digRedo"].GetBitmap(),
+            #             wx.ITEM_NORMAL, Icons["digRedo"].GetLabel(), Icons["digRedo"].GetDesc(),
+            #             self.OnRedo))
+            data.append((self.settings, "digSettings", Icons["digSettings"].GetBitmap(),
+                         wx.ITEM_NORMAL, Icons["digSettings"].GetLabel(), Icons["digSettings"].GetDesc(),
+                         self.OnSettings))
+            data.append((self.exit, "digExit", Icons["quit"].GetBitmap(),
+                         wx.ITEM_NORMAL, Icons["digExit"].GetLabel(), Icons["digExit"].GetDesc(),
+                         self.OnExit))
+        return data
+        """Tool selected -> disable selected tool in map toolbar"""
+        # update map toolbar (unselect currently selected tool)
+        id = self.parent.toolbars['map'].GetAction(type='id')
+        self.parent.toolbars['map'].toolbar.ToggleTool(id, False)
+        # set cursor
+        cursor = self.parent.cursors["cross"]
+        self.parent.MapWindow.SetCursor(cursor)
+        # pointer
+        self.parent.OnPointer(None)
+        if event:
+                self.toolbar[0].ToggleTool(self.action['id'], False)
+            else:
+                self.toolbar[0].ToggleTool(self.action['id'], True)
+            event.Skip()
+        else:
+        # clear tmp canvas
+        if self.action['id'] != id:
+            self.parent.MapWindow.ClearLines(pdc=self.parent.MapWindow.pdcTmp)
+            if self.parent.digit and \
+                    len(self.parent.digit.driver.GetSelected()) > 0:
+                # cancel action
+                self.parent.MapWindow.OnMiddleDown(None)
+    def OnAddPoint(self, event):
+        """Add point to the vector map Laier"""
+        Debug.msg (2, "VDigitToolbar.OnAddPoint()")
+        self.action = { 'desc' : "addLine",
+                        'type' : "point",
+        self.parent.MapWindow.mouse['box'] = 'point'
+    def OnAddLine(self, event):
+        """Add line to the vector map layer"""
+        Debug.msg (2, "VDigitToolbar.OnAddLine()")
+                        'type' : "line",
+                        'id'   : self.addLine }
+        self.parent.MapWindow.mouse['box'] = 'line'
+        ### self.parent.MapWindow.polycoords = [] # reset temp line
+    def OnAddBoundary(self, event):
+        """Add boundary to the vector map layer"""
+        Debug.msg (2, "VDigitToolbar.OnAddBoundary()")
+        if self.action['desc'] != 'addLine' or \
+                self.action['type'] != 'boundary':
+            self.parent.MapWindow.polycoords = [] # reset temp line
+                        'type' : "boundary",
+                        'id'   : self.addBoundary }
+    def OnAddCentroid(self, event):
+        """Add centroid to the vector map layer"""
+        Debug.msg (2, "VDigitToolbar.OnAddCentroid()")
+                        'type' : "centroid",
+                        'id'   : self.addCentroid }
+    def OnExit (self, event=None):
+        """Quit digitization tool"""
+        # stop editing of the currently selected map layer
+        if self.mapLayer:
+            self.StopEditing()
+        # close dialogs if still open
+        if self.settingsDialog:
+            self.settingsDialog.OnCancel(None)
+        # disable the toolbar
+        self.parent.RemoveToolbar ("vdigit")
+        # set default mouse settings
+        self.parent.MapWindow.mouse['use'] = "pointer"
+        self.parent.MapWindow.mouse['box'] = "point"
+    def OnMoveVertex(self, event):
+        """Move line vertex"""
+        Debug.msg(2, "Digittoolbar.OnMoveVertex():")
+        self.action = { 'desc' : "moveVertex",
+                        'id'   : self.moveVertex }
+    def OnAddVertex(self, event):
+        """Add line vertex"""
+        Debug.msg(2, "Digittoolbar.OnAddVertex():")
+        self.action = { 'desc' : "addVertex",
+                        'id'   : self.addVertex }
+    def OnRemoveVertex(self, event):
+        """Remove line vertex"""
+        Debug.msg(2, "Digittoolbar.OnRemoveVertex():")
+        self.action = { 'desc' : "removeVertex",
+                        'id'   : self.removeVertex }
+    def OnSplitLine(self, event):
+        """Split line"""
+        Debug.msg(2, "Digittoolbar.OnSplitLine():")
+        self.action = { 'desc' : "splitLine",
+                        'id'   : self.splitLine }
+    def OnEditLine(self, event):
+        """Edit line"""
+        Debug.msg(2, "Digittoolbar.OnEditLine():")
+        self.action = { 'desc' : "editLine",
+                        'id'   : self.editLine }
+    def OnMoveLine(self, event):
+        """Move line"""
+        Debug.msg(2, "Digittoolbar.OnMoveLine():")
+        self.action = { 'desc' : "moveLine",
+                        'id'   : self.moveLine }
+        self.parent.MapWindow.mouse['box'] = 'box'
+    def OnDeleteLine(self, event):
+        """Delete line"""
+        Debug.msg(2, "Digittoolbar.OnDeleteLine():")
+        self.action = { 'desc' : "deleteLine",
+                        'id'   : self.deleteLine }
+    def OnDisplayCats(self, event):
+        """Display/update categories"""
+        Debug.msg(2, "Digittoolbar.OnDisplayCats():")
+        self.action = { 'desc' : "displayCats",
+                        'id'   : self.displayCats }
+    def OnDisplayAttr(self, event):
+        """Display/update attributes"""
+        Debug.msg(2, "Digittoolbar.OnDisplayAttr():")
+        self.action = { 'desc' : "displayAttrs",
+                        'id'   : self.displayAttr }
+    def OnCopyCA(self, event):
+        """Copy categories/attributes menu"""
+        point = wx.GetMousePosition()
+        toolMenu = wx.Menu()
+        # Add items to the menu
+        cats = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                           text=_('Copy categories'),
+                           kind=wx.ITEM_CHECK)
+        toolMenu.AppendItem(cats)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyCats, cats)
+        if self.action['desc'] == "copyCats":
+            cats.Check(True)
+        attrb = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                            text=_('Duplicate attributes'),
+        toolMenu.AppendItem(attrb)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyAttrb, attrb)
+        if self.action['desc'] == "copyAttrs":
+            attrb.Check(True)
+        # Popup the menu.  If an item is selected then its handler
+        # will be called before PopupMenu returns.
+        self.parent.MapWindow.PopupMenu(toolMenu)
+        toolMenu.Destroy()
+        if self.action['desc'] == "addPoint":
+            self.toolbar[0].ToggleTool(self.copyCats, False)
+    def OnCopyCats(self, event):
+        """Copy categories"""
+        if self.action['desc'] == 'copyCats': # select previous action
+            self.toolbar[0].ToggleTool(self.addPoint, True)
+            self.OnAddPoint(event)
+            return
+        Debug.msg(2, "Digittoolbar.OnCopyCats():")
+        self.action = { 'desc' : "copyCats",
+                        'id'   : self.copyCats }
+    def OnCopyAttrb(self, event):
+        if self.action['desc'] == 'copyAttrs': # select previous action
+            return
+        Debug.msg(2, "Digittoolbar.OnCopyAttrb():")
+        self.action = { 'desc' : "copyAttrs",
+    def OnUndo(self, event):
+        """Undo previous changes"""
+        self.parent.digit.Undo()
+        event.Skip()
+    def EnableUndo(self, enable=True):
+        """Enable 'Undo' in toolbar
+        @param enable False for disable
+        if enable:
+            if self.toolbar[0].GetToolEnabled(self.undo) is False:
+                self.toolbar[0].EnableTool(self.undo, True)
+        else:
+            if self.toolbar[0].GetToolEnabled(self.undo) is True:
+    def OnSettings(self, event):
+        """Show settings dialog"""
+        if self.parent.digit is None:
+            reload(vdigit)
+            from vdigit import Digit as Digit
+            self.parent.digit = Digit(mapwindow=self.parent.MapWindow)
+        if not self.settingsDialog:
+            self.settingsDialog = VDigitSettingsDialog(parent=self.parent, title=_("Digitization settings"),
+                                                       style=wx.DEFAULT_DIALOG_STYLE)
+            self.settingsDialog.Show()
+    def OnAdditionalToolMenu(self, event):
+        """Menu for additional tools"""
+        copy = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                           text=_('Copy features from (background) vector map'),
+        toolMenu.AppendItem(copy)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopy, copy)
+        if self.action['desc'] == "copyLine":
+            copy.Check(True)
+        flip = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                           text=_('Flip selected lines/boundaries'),
+        toolMenu.AppendItem(flip)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnFlip, flip)
+        if self.action['desc'] == "flipLine":
+            flip.Check(True)
+        merge = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                            text=_('Merge selected lines/boundaries'),
+        toolMenu.AppendItem(merge)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnMerge, merge)
+        if self.action['desc'] == "mergeLine":
+            merge.Check(True)
+        breakL = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                             text=_('Break selected lines/boundaries at intersection'),
+        toolMenu.AppendItem(breakL)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnBreak, breakL)
+        if self.action['desc'] == "breakLine":
+            breakL.Check(True)
+        snap = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                           text=_('Snap selected lines/boundaries (only to nodes)'),
+        toolMenu.AppendItem(snap)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnSnap, snap)
+        if self.action['desc'] == "snapLine":
+            snap.Check(True)
+        connect = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                              text=_('Connect selected lines/boundaries'),
+        toolMenu.AppendItem(connect)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnConnect, connect)
+        if self.action['desc'] == "connectLine":
+            connect.Check(True)
+        query = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                            text=_('Query features'),
+        toolMenu.AppendItem(query)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnQuery, query)
+        if self.action['desc'] == "queryLine":
+            query.Check(True)
+        zbulk = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                            text=_('Z bulk-labeling of 3D lines'),
+        toolMenu.AppendItem(zbulk)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnZBulk, zbulk)
+        if self.action['desc'] == "zbulkLine":
+            zbulk.Check(True)
+        typeconv = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                               text=_('Feature type conversion'),
+        toolMenu.AppendItem(typeconv)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnTypeConversion, typeconv)
+        if self.action['desc'] == "typeConv":
+            typeconv.Check(True)
+        if self.action['desc'] == 'addPoint':
+            self.toolbar[0].ToggleTool(self.additionalTools, False)
+    def OnCopy(self, event):
+        """Copy selected features from (background) vector map"""
+        if self.action['desc'] == 'copyLine': # select previous action
+            return
+        Debug.msg(2, "Digittoolbar.OnCopy():")
+        self.action = { 'desc' : "copyLine",
+                        'id'   : self.additionalTools }
+    def OnFlip(self, event):
+        """Flip selected lines/boundaries"""
+        if self.action['desc'] == 'flipLine': # select previous action
+            return
+        Debug.msg(2, "Digittoolbar.OnFlip():")
+        self.action = { 'desc' : "flipLine",
+    def OnMerge(self, event):
+        """Merge selected lines/boundaries"""
+        if self.action['desc'] == 'mergeLine': # select previous action
+            return
+        Debug.msg(2, "Digittoolbar.OnMerge():")
+        self.action = { 'desc' : "mergeLine",
+    def OnBreak(self, event):
+        """Break selected lines/boundaries"""
+        if self.action['desc'] == 'breakLine': # select previous action
+            return
+        Debug.msg(2, "Digittoolbar.OnBreak():")
+        self.action = { 'desc' : "breakLine",
+    def OnSnap(self, event):
+        """Snap selected features"""
+        if self.action['desc'] == 'snapLine': # select previous action
+            return
+        Debug.msg(2, "Digittoolbar.OnSnap():")
+        self.action = { 'desc' : "snapLine",
+    def OnConnect(self, event):
+        """Connect selected lines/boundaries"""
+        if self.action['desc'] == 'connectLine': # select previous action
+            return
+        Debug.msg(2, "Digittoolbar.OnConnect():")
+        self.action = { 'desc' : "connectLine",
+    def OnQuery(self, event):
+        """Query selected lines/boundaries"""
+        if self.action['desc'] == 'queryLine': # select previous action
+            return
+        Debug.msg(2, "Digittoolbar.OnQuery(): %s" % \
+                      UserSettings.Get(group='vdigit', key='query', subkey='selection'))
+        self.action = { 'desc' : "queryLine",
+    def OnZBulk(self, event):
+        """Z bulk-labeling selected lines/boundaries"""
+        if not self.parent.digit.driver.Is3D():
+            wx.MessageBox(parent=self.parent,
+                          message=_("Vector map is not 3D. Operation canceled."),
+                          caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+            return
+        if self.action['desc'] == 'zbulkLine': # select previous action
+            return
+        Debug.msg(2, "Digittoolbar.OnZBulk():")
+        self.action = { 'desc' : "zbulkLine",
+    def OnTypeConversion(self, event):
+        """Feature type conversion
+        Supported conversions:
+         - point <-> centroid
+         - line <-> boundary
+        if self.action['desc'] == 'typeConv': # select previous action
+            return
+        Debug.msg(2, "Digittoolbar.OnTypeConversion():")
+        self.action = { 'desc' : "typeConv",
+    def OnSelectMap (self, event):
+        Select vector map layer for editing
+        If there is a vector map layer already edited, this action is
+        firstly terminated. The map layer is closed. After this the
+        selected map layer activated for editing.
+        if event.GetSelection() == 0: # create new vector map layer
+            if self.mapLayer:
+                openVectorMap = self.mapLayer.GetName(fullyQualified=False)['name']
+            else:
+                openVectorMap = None
+            mapName = gdialogs.CreateNewVector(self.parent,
+                                               exceptMap=openVectorMap, log=self.log,
+                                               cmdDef=(['v.edit', 'tool=create'], "map"),
+                                               disableAdd=True)[0]
+            if mapName:
+                # add layer to map layer tree
+                if self.layerTree:
+                    self.layerTree.AddLayer(ltype='vector',
+                                            lname=mapName,
+                                            lchecked=True,
+                                            lopacity=1.0,
+                                            lcmd=['d.vect', 'map=%s' % mapName])
+                    vectLayers = self.UpdateListOfLayers(updateTool=True)
+                    selection = vectLayers.index(mapName)
+                else:
+                    pass # TODO (no Layer Manager)
+            else:
+                self.combo.SetValue(_('Select vector map'))
+                return
+        else:
+            selection = event.GetSelection() - 1 # first option is 'New vector map'
+        # skip currently selected map
+        if self.layers[selection] == self.mapLayer:
+            return False
+        if self.mapLayer:
+            # deactive map layer for editing
+        # select the given map layer for editing
+        self.StartEditing(self.layers[selection])
+        event.Skip()
+        return True
+    def StartEditing (self, mapLayer):
+        Start editing selected vector map layer.
+        @param mapLayer reference to MapLayer instance
+        # deactive layer
+        self.mapcontent.ChangeLayerActive(mapLayer, False)
+        # clean map canvas
+        ### self.parent.MapWindow.EraseMap()
+        # unset background map if needed
+        if UserSettings.Get(group='vdigit', key='bgmap',
+                            subkey='value', internal=True) == mapLayer.GetName():
+            UserSettings.Set(group='vdigit', key='bgmap',
+                             subkey='value', value='', internal=True)
+        self.parent.statusbar.SetStatusText(_("Please wait, "
+                                              "opening vector map <%s> for editing...") % \
+                                                mapLayer.GetName(),
+                                            0)
+        # reload vdigit module
+        reload(vdigit)
+        self.mapLayer = mapLayer
+        # open vector map
+        try:
+            self.parent.digit.SetMapName(mapLayer.GetName())
+        except gcmd.DigitError, e:
+            print >> sys.stderr, e # wxMessageBox
+            return False
+        # update toolbar
+        self.combo.SetValue(mapLayer.GetName())
+        self.parent.toolbars['map'].combo.SetValue (_('Digitize'))
+        Debug.msg (4, "VDigitToolbar.StartEditing(): layer=%s" % mapLayer.GetName())
+        # change cursor
+        if self.parent.MapWindow.mouse['use'] == 'pointer':
+            self.parent.MapWindow.SetCursor(self.parent.cursors["cross"])
+        # create pseudoDC for drawing the map
+        self.parent.MapWindow.pdcVector = vdigit.PseudoDC()
+        self.parent.digit.driver.SetDevice(self.parent.MapWindow.pdcVector)
+        if not self.parent.MapWindow.resize:
+            self.parent.MapWindow.UpdateMap(render=True)
+        opacity = mapLayer.GetOpacity(float=True)
+        if opacity < 1.0:
+            alpha = int(opacity * 255)
+            self.parent.digit.driver.UpdateSettings(alpha)
+        return True
+    def StopEditing (self):
+        """Stop editing of selected vector map layer.
+        @return True on success
+        @return False on failure
+        if not self.mapLayer:
+            return False
+        Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
+        self.combo.SetValue (_('Select vector map'))
+        # save changes
+        if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
+            if self.parent.digit.GetUndoLevel() > 0:
+                dlg = wx.MessageDialog(parent=self.parent,
+                                       message=_("Do you want to save changes "
+                                                 "in vector map <%s>?") % self.mapLayer.GetName(),
+                                       caption=_("Save changes?"),
+                                       style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+                if dlg.ShowModal() == wx.ID_NO:
+                    # revert changes
+                    self.parent.digit.Undo(0)
+                dlg.Destroy()
+                                              "closing and rebuilding topology of "
+                                              "vector map <%s>...") % self.mapLayer.GetName(),
+                                            0)
+        self.parent.digit.SetMapName(None) # -> close map
+        # re-active layer
+        item = self.parent.tree.FindItemByData('maplayer', self.mapLayer)
+        if item and self.parent.tree.IsItemChecked(item):
+            self.mapcontent.ChangeLayerActive(self.mapLayer, True)
+        # change cursor
+        self.parent.MapWindow.SetCursor(self.parent.cursors["default"])
+        # disable pseudodc for vector map layer
+        self.parent.MapWindow.pdcVector = None
+        self.parent.digit.driver.SetDevice(None)
+        # close dialogs
+        for dialog in ('attributes', 'category'):
+            if self.parent.dialogs[dialog]:
+                self.parent.dialogs[dialog].Close()
+                self.parent.dialogs[dialog] = None
+        self.parent.digit.__del__() # FIXME: destructor is not called here (del)
+        self.parent.digit = None
+        self.parent.MapWindow.redrawAll = True
+        return True
+    def UpdateListOfLayers (self, updateTool=False):
+        Update list of available vector map layers.
+        This list consists only editable layers (in the current mapset)
+        Optionally also update toolbar
+        Debug.msg (4, "VDigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
+                   updateTool)
+        layerNameSelected = None
+         # name of currently selected layer
+        if self.mapLayer:
+            layerNameSelected = self.mapLayer.GetName()
+        # select vector map layer in the current mapset
+        layerNameList = []
+        self.layers = self.mapcontent.GetListOfLayers(l_type="vector",
+                                                      l_mapset=grassenv.GetGRASSVariable('MAPSET'))
+        for layer in self.layers:
+            if not layer.name in layerNameList: # do not duplicate layer
+                layerNameList.append (layer.GetName())
+        if updateTool: # update toolbar
+                value = _('Select vector map')
+            else:
+                value = layerNameSelected
+            if not self.comboid:
+                self.combo = wx.ComboBox(self.toolbar[self.numOfRows-1], id=wx.ID_ANY, value=value,
+                                         choices=[_('New vector map'), ] + layerNameList, size=(85, -1),
+                                         style=wx.CB_READONLY)
+                self.comboid = self.toolbar[self.numOfRows-1].InsertControl(0, self.combo)
+                self.parent.Bind(wx.EVT_COMBOBOX, self.OnSelectMap, self.comboid)
+            else:
+                self.combo.SetItems([_('New vector map'), ] + layerNameList)
+            self.toolbar[self.numOfRows-1].Realize()
+        return layerNameList
+    def GetLayer(self):
+        """Get selected layer for editing -- MapLayer instance"""
+        return self.mapLayer
+class ProfileToolbar(AbstractToolbar):
+    Toolbar for profiling raster map
+        self.transect = wx.NewId()
+        self.addraster = wx.NewId()
+        self.draw = wx.NewId()
+        self.options = wx.NewId()
+        self.drag = wx.NewId()
+        self.zoom = wx.NewId()
+        self.unzoom = wx.NewId()
+        self.save = wx.NewId()
+        self.printer = wx.NewId()
+        return   (
+            (self.addraster, 'raster', Icons["addrast"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["addrast"].GetLabel(), Icons["addrast"].GetDesc(),
+             self.parent.OnSelectRaster),
+            (self.transect, 'transect', Icons["transect"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["transect"].GetLabel(), Icons["transect"].GetDesc(),
+             self.parent.OnDrawTransect),
+            (self.draw, 'profiledraw', Icons["profiledraw"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["profiledraw"].GetLabel(), Icons["profiledraw"].GetDesc(),
+             self.parent.OnCreateProfile),
+            (self.options, 'options', Icons["profileopt"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["profileopt"].GetLabel(), Icons["profileopt"].GetDesc(),
+             self.parent.ProfileOptionsMenu),
+            (self.drag, 'drag', Icons['pan'].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
+             self.parent.OnDrag),
+            (self.zoom, 'zoom', Icons['zoom_in'].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
+             self.parent.OnZoom),
+            (self.unzoom, 'unzoom', Icons['zoom_back'].GetBitmap(),
+             self.parent.OnRedraw),
+            (self.erase, 'erase', Icons["erase"].GetBitmap(),
+             self.parent.OnErase),
+            (self.save, 'save', Icons["savefile"].GetBitmap(),
+             self.parent.SaveToFile),
+            (self.printer, 'print', Icons["printmap"].GetBitmap(),
+             self.parent.PrintMenu),
+            (self.quit, 'quit', Icons["quit"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["quit"].GetLabel(), Icons["quit"].GetDesc(),
+             self.parent.OnQuit),
+class NvizToolbar(AbstractToolbar):
+    Nviz toolbar
+    def __init__(self, parent, map):
+        self.toolbar = wx.ToolBar(parent=self.parent, id=wx.ID_ANY)
+        self.InitToolbar(self.parent, self.toolbar, self.ToolbarData())
+        return   (
+            (self.settings, "settings", Icons["nvizSettings"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["nvizSettings"].GetLabel(), Icons["nvizSettings"].GetDesc(),
+             self.OnSettings),
+             self.OnExit),
+        win = self.parent.nvizToolWin
+        if not win.IsShown():
+            self.parent.nvizToolWin.Show()
+        else:
+            self.parent.nvizToolWin.Hide()
+        """Quit nviz tool (swith to 2D mode)"""
+        # hide dialogs if still open
+        if self.parent.nvizToolWin:
+        self.parent.RemoveToolbar ("nviz")
Added: grass-addons/gui/wxpython/data_catalog/wxgui.py
--- grass-addons/gui/wxpython/data_catalog/wxgui.py	                        (rev 0)
+++ grass-addons/gui/wxpython/data_catalog/wxgui.py	2010-03-23 12:56:28 UTC (rev 41529)
@@ -0,0 +1,1464 @@
+ at package wxgui.py
+ at brief Main Python app for GRASS wxPython GUI. Main menu, layer management
+toolbar, notebook control for display management and access to
+command console.
+Classes:
+ - GMFrame
+ - GMApp
+(C) 2006-2009 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Michael Barton (Arizona State University)
+ at author Jachym Cepicky (Mendel University of Agriculture)
+import sys
+import os
+import time
+import traceback
+import re
+import string
+import getopt
+import platform
+### XML
+try:
+    import xml.etree.ElementTree as etree
+except ImportError:
+    import elementtree.ElementTree as etree # Python <= 2.4
+### i18N
+import gettext
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+pypath = "/usr/local/grass-7.0.svn/etc/wxpython"
+sys.path.append(pypath)
+import gui_modules
+gmpath = gui_modules.__path__[0]
+import images
+imagepath = images.__path__[0]
+sys.path.append(imagepath)
+import icons
+gmpath = icons.__path__[0]
+import gui_modules.globalvar as globalvar
+if not os.getenv("GRASS_WXBUNDLED"):
+    globalvar.CheckForWx()
+import wx
+import wx.aui
+import wx.combo
+import wx.html
+import wx.stc
+import wx.lib.customtreectrl as CT
+import wx.lib.flatnotebook as FN
+grassPath = os.path.join(globalvar.ETCDIR, "python")
+sys.path.append(grassPath)
+from grass.script import core as grass
+import gui_modules.utils as utils
+import gui_modules.preferences as preferences
+import gui_modules.wxgui_utils as wxgui_utils
+import mapdisplay as mapdisp
+import gui_modules.menudata as menudata
+import gui_modules.menuform as menuform
+import gui_modules.histogram as histogram
+import gui_modules.profile as profile
+import gui_modules.rules as rules
+import gui_modules.mcalc_builder as mapcalculator
+import gui_modules.gcmd as gcmd
+import gui_modules.georect as georect
+import gui_modules.dbm as dbm
+import gui_modules.workspace as workspace
+import gui_modules.goutput as goutput
+import gui_modules.gdialogs as gdialogs
+import gui_modules.colorrules as colorrules
+import gui_modules.ogc_services as ogc_services
+import gui_modules.prompt as prompt
+from   gui_modules.debug import Debug
+from   gui_modules.help import MenuTreeWindow
+from   gui_modules.help import AboutWindow
+from   icons.icon import Icons
+import glob
+import render
+#from mapwindow import BufferedWindow
+from right import RightTree
+import LayerTree
+UserSettings = preferences.globalSettings
+class GMFrame(wx.Panel):
+    GIS Manager frame with notebook widget for controlling
+    GRASS GIS. Includes command console page for typing GRASS
+    (and other) commands, tree widget page for managing GIS map layers.
+    def __init__(self, parent, id=wx.ID_ANY, title=_("GRASS GIS Layer Manager"),
+                 workspace=None,frame=None):
+        self.baseTitle = title
+        self.iconsize  = (16, 16)
+        wx.Panel.__init__(self, parent=parent, id=id, size=(550, 450),
+                          style=wx.DEFAULT_FRAME_STYLE)
+        #self.SetTitle(self.baseTitle)
+        #self.SetName("LayerManager")
+        #self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+        #self._auimgr = wx.aui.AuiManager(self)
+        self.frame = frame
+        # initialize variables
+        self.disp_idx      = 0            # index value for map displays and layer trees
+        self.curr_page     = ''           # currently selected page for layer tree notebook
+        self.curr_pagenum  = ''           # currently selected page number for layer tree notebook
+        self.encoding      = 'ISO-8859-1' # default encoding for display fonts
+        self.workspaceFile = workspace    # workspace file
+        self.menucmd       = dict()       # menuId / cmd
+        self.georectifying = None         # reference to GCP class or None
+        # list of open dialogs
+        self.dialogs        = dict()
+        self.dialogs['preferences'] = None
+        self.dialogs['atm'] = list()
+        # creating widgets
+        # -> self.notebook, self.goutput, self.outpage
+        #self.notebook  = self.__createNoteBook()
+        self.menubar, self.menudata = self.__createMenuBar()
+        #self.statusbar = self.CreateStatusBar(number=1)
+        #self.cmdprompt, self.cmdinput = self.__createCommandPrompt()
+        self.toolbar   = self.__createToolBar()
+        # bindings
+        self.Bind(wx.EVT_CLOSE,    self.OnCloseWindow)
+        self.Bind(wx.EVT_KEY_UP,   self.OnKey)
+        # minimal frame size
+        #self.SetMinSize((500, 400))
+        # AUI stuff
+        #       self._auimgr.AddPane(self.toolbar, wx.aui.AuiPaneInfo().ToolbarPane().
+        #                              Top().Dockable(False).CloseButton(False).
+        #                              DestroyOnClose(True).Row(0).Layer(0))
+        #self._auimgr.AddPane(self.notebook, wx.aui.AuiPaneInfo().
+        #                     Left().CentrePane().BestSize((-1,-1)).Dockable(False).
+        #                     CloseButton(False).DestroyOnClose(True).Row(1).Layer(0))
+        #self._auimgr.AddPane(self.cmdprompt, wx.aui.AuiPaneInfo().
+        #                     Bottom().BestSize((-1, 65)).Dockable(False).
+        #                     PaneBorder(False).Row(1).Layer(0).Position(0).
+        #                     CaptionVisible(False))
+        #self._auimgr.Update()
+        #wx.CallAfter(self.notebook.SetSelection, 0)
+        #wx.CallAfter(self.cmdinput.SetFocus)
+        # use default window layout ?
+        if UserSettings.Get(group='general', key='defWindowPos', subkey='enabled') is True:
+            dim = UserSettings.Get(group='general', key='defWindowPos', subkey='dim')
+            try:
+               x, y = map(int, dim.split(',')[0:2])
+               w, h = map(int, dim.split(',')[2:4])
+               self.SetPosition((x, y))
+               self.SetSize((w, h))
+            except:
+                pass
+    def OnMapsetChange(self,event):
+	    Create the tree nodes based on selected location and mapset.
+	    Also update gisrc and grassrc files.
+	    self.tree.DeleteAllItems()
+	    self.AddTreeNodes(self.cmbLocation.GetValue(),self.cmbMapset.GetValue())
+	    self.gisrc['LOCATION_NAME'] = str(self.cmbLocation.GetValue())
+	    self.gisrc['MAPSET'] = str(self.cmbMapset.GetValue())
+	    self.update_grassrc(self.gisrc)
+	    #gcmd.RunCommand("g.gisenv", set = "MAPSET=%s" % str(self.cmbMapset.GetValue()))
+    def OnLocationChange(self,event):
+	    Populate mapset combobox with selected location.
+	    self.cmbMapset.Clear()
+	    self.cmbMapset.SetValue("Select Mapset")
+	    maplists = self.GetMapsets(self.cmbLocation.GetValue())
+	    for mapsets in maplists:
+		    self.cmbMapset.Append(str(mapsets))
+    def GetMapsets(self,location):
+	    Read and returns all mapset int GRASS data directory.
+	    maplist = []
+	    for mapset in glob.glob(os.path.join(self.gisdbase, location, "*")):
+		    if os.path.isdir(mapset) and os.path.isfile(os.path.join(self.gisdbase, location, mapset, "WIND")):
+			    maplist.append(os.path.basename(mapset))
+	    return maplist
+    def __createMenuBar(self):
+        """!Creates menubar"""
+        self.menubar = wx.MenuBar()
+        self.menudata = menudata.Data()
+        for eachMenuData in self.menudata.GetMenu():
+            for eachHeading in eachMenuData:
+                menuLabel = eachHeading[0]
+                menuItems = eachHeading[1]
+                self.menubar.Append(self.__createMenu(menuItems), menuLabel)
+        self.frame.SetMenuBar(self.menubar)
+        return (self.menubar, self.menudata)
+    def __createMenu(self, menuData):
+        """!Creates menu"""
+        menu = wx.Menu()
+        for eachItem in menuData:
+            if len(eachItem) == 2:
+                label = eachItem[0]
+                subMenu = self.__createMenu(eachItem[1])
+                menu.AppendMenu(wx.ID_ANY, label, subMenu)
+            else:
+                self.__createMenuItem(menu, *eachItem)
+        self.Bind(wx.EVT_MENU_HIGHLIGHT_ALL, self.OnMenuHighlight)
+        return menu
+    def __createMenuItem(self, menu, label, help, handler, gcmd, keywords, shortcut = '', kind = wx.ITEM_NORMAL):
+        """!Creates menu items"""
+        if not label:
+            menu.AppendSeparator()
+            return
+        if len(gcmd) > 0:
+            helpString = gcmd + ' -- ' + help
+        else:
+            helpString = help
+        if shortcut:
+            label += '\t' + shortcut
+        menuItem = menu.Append(wx.ID_ANY, label, helpString, kind)
+        self.menucmd[menuItem.GetId()] = gcmd
+        if len(gcmd) > 0 and \
+                gcmd.split()[0] not in globalvar.grassCmd['all']:
+            menuItem.Enable (False)
+        rhandler = eval(handler)
+        self.Bind(wx.EVT_MENU, rhandler, menuItem)
+    def __createToolBar(self):
+        """!Creates toolbar"""
+        self.toolbar = self.frame.CreateToolBar()
+        for each in self.ToolbarData():
+            self.AddToolbarButton(self.toolbar, *each)
+        return self.toolbar
+    def OnMenuHighlight(self, event):
+        Default menu help handler
+         # Show how to get menu item info from this event handler
+        id = event.GetMenuId()
+        item = self.GetMenuBar().FindItemById(id)
+        if item:
+            text = item.GetText()
+            help = item.GetHelp()
+        # but in this case just call Skip so the default is done
+        event.Skip()
+    def OnGeorectify(self, event):
+        Launch georectifier module
+        georect.GeorectWizard(self)
+    def OnMapsets(self, event):
+        Launch mapset access dialog
+        dlg = preferences.MapsetAccess(parent=self, id=wx.ID_ANY)
+        dlg.CenterOnScreen()
+        # if OK is pressed...
+        if dlg.ShowModal() == wx.ID_OK:
+            ms = dlg.GetMapsets()
+            # run g.mapsets with string of accessible mapsets
+            gcmd.RunCommand('g.mapsets',
+                            parent = self,
+                            mapset = '%s' % ','.join(ms))
+    def OnRDigit(self, event):
+        Launch raster digitizing module
+        pass
+    def OnCBPageChanged(self, event):
+        """!Page in notebook (display) changed"""
+        old_pgnum = event.GetOldSelection()
+        new_pgnum = event.GetSelection()
+        self.curr_page   = self.gm_cb.GetCurrentPage()
+        self.curr_pagenum = self.gm_cb.GetSelection()
+        try:
+            self.curr_page.maptree.mapdisplay.SetFocus()
+            self.curr_page.maptree.mapdisplay.Raise()
+        except:
+            pass
+        event.Skip()
+    def OnPageChanged(self, event):
+        """!Page in notebook changed"""
+        page = event.GetSelection()
+        if page == self.goutput.pageid:
+            # remove '(...)'
+            self.notebook.SetPageText(page, _("Command output"))
+        event.Skip()
+    def OnCBPageClosed(self, event):
+        Page of notebook closed
+        Also close associated map display
+        if UserSettings.Get(group='manager', key='askOnQuit', subkey='enabled'):
+            maptree = self.curr_page.maptree
+            if self.workspaceFile:
+                message = _("Do you want to save changes in the workspace?")
+            else:
+                message = _("Do you want to store current settings "
+                            "to workspace file?")
+            # ask user to save current settings
+            if maptree.GetCount() > 0:
+                dlg = wx.MessageDialog(self,
+                                       message=message,
+                                       caption=_("Close Map Display %d") % (self.curr_pagenum + 1),
+                                       wx.CANCEL | wx.ICON_QUESTION | wx.CENTRE)
+                ret = dlg.ShowModal()
+                if ret == wx.ID_YES:
+                    if not self.workspaceFile:
+                        self.OnWorkspaceSaveAs()
+                    else:
+                        self.SaveToWorkspaceFile(self.workspaceFile)
+                elif ret == wx.ID_CANCEL:
+                    event.Veto()
+                    dlg.Destroy()
+                    return
+                dlg.Destroy()
+        self.gm_cb.GetPage(event.GetSelection()).maptree.Map.Clean()
+        self.gm_cb.GetPage(event.GetSelection()).maptree.Close(True)
+        self.curr_page = None
+        event.Skip()
+    def GetLogWindow(self):
+        """!Get widget for command output"""
+        return self.goutput
+    def GetMenuCmd(self, event):
+        """!Get GRASS command from menu item
+        Return command as a list"""
+        layer = None
+        if event:
+            cmd = self.menucmd[event.GetId()]
+        try:
+            cmdlist = cmd.split(' ')
+        except: # already list?
+            cmdlist = cmd
+        # check list of dummy commands for GUI modules that do not have GRASS
+        # bin modules or scripts.
+        if cmd in ['vcolors']:
+            return cmdlist
+        try:
+            layer = self.curr_page.maptree.layer_selected
+            name = self.curr_page.maptree.GetPyData(layer)[0]['maplayer'].name
+            type = self.curr_page.maptree.GetPyData(layer)[0]['type']
+        except:
+            layer = None
+        if layer and len(cmdlist) == 1: # only if no paramaters given
+            if (type == 'raster' and cmdlist[0][0] == 'r' and cmdlist[0][1] != '3') or \
+                    (type == 'vector' and cmdlist[0][0] == 'v'):
+                input = menuform.GUI().GetCommandInputMapParamKey(cmdlist[0])
+                if input:
+                    cmdlist.append("%s=%s" % (input, name))
+        return cmdlist
+    def RunMenuCmd(self, event):
+        """!Run command selected from menu"""
+        cmd = self.GetMenuCmd(event)
+        self.goutput.RunCmd(cmd, switchPage=True)
+    def OnMenuCmd(self, event, cmd = ''):
+        """!Parse command selected from menu"""
+        if event:
+        menuform.GUI().ParseCommand(cmd, parentframe=self)
+    def OnChangeLocation(self, event):
+        """Change current location"""
+        dlg = gdialogs.LocationDialog(parent = self)
+            location, mapset = dlg.GetValues()
+            if location and mapset:
+                ret = gcmd.RunCommand("g.gisenv",
+                                      set = "LOCATION_NAME=%s" % location)
+                ret += gcmd.RunCommand("g.gisenv",
+                                       set = "MAPSET=%s" % mapset)
+                if ret > 0:
+                    wx.MessageBox(parent = self,
+                                  message = _("Unable to switch to location <%(loc)s> mapset <%(mapset)s>.") % \
+                                      { 'loc' : location, 'mapset' : mapset },
+                                  caption = _("Error"), style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
+                else:
+                    # close workspace
+                    self.OnWorkspaceClose()
+                    self.OnWorkspaceNew()
+                                  message = _("Current location is <%(loc)s>.\n"
+                                              "Current mapset is <%(mapset)s>.") % \
+                                  caption = _("Info"), style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+    def OnChangeMapset(self, event):
+        """Change current mapset"""
+        dlg = gdialogs.MapsetDialog(parent = self)
+            mapset = dlg.GetMapset()
+            if mapset:
+                if gcmd.RunCommand("g.gisenv",
+                                   set = "MAPSET=%s" % mapset) != 0:
+                                  message = _("Unable to switch to mapset <%s>.") % mapset,
+                else:
+                                  message = _("Current mapset is <%s>.") % mapset,
+    def OnNewVector(self, event):
+        """!Create new vector map layer"""
+        name, add = gdialogs.CreateNewVector(self, log = self.goutput,
+                                             cmd = (('v.edit',
+                                                     { 'tool' : 'create' },
+                                                     'map')))
+        if name and add:
+            self.curr_page.maptree.AddLayer(ltype='vector',
+                                            lname=name,
+                                            lchecked=True,
+                                            lopacity=1.0,
+                                            lcmd=['d.vect', 'map=%s' % name])
+    def OnMenuTree(self, event):
+        """!Show dialog with menu tree"""
+        dlg = MenuTreeWindow(self)
+        dlg.CentreOnScreen()
+        dlg.Show()
+    def OnAboutGRASS(self, event):
+        """!Display 'About GRASS' dialog"""
+        win = AboutWindow(self)
+        win.Centre()
+        win.Show(True)
+    def OnWorkspace(self, event):
+        """!Workspace menu (new, load)"""
+        menu = wx.Menu()
+        new = wx.MenuItem(menu, wx.ID_ANY, Icons["workspaceNew"].GetLabel())
+        new.SetBitmap(Icons["workspaceNew"].GetBitmap(self.iconsize))
+        menu.AppendItem(new)
+        self.Bind(wx.EVT_MENU, self.OnWorkspaceNew, new)
+        load = wx.MenuItem(menu, wx.ID_ANY, Icons["workspaceLoad"].GetLabel())
+        load.SetBitmap(Icons["workspaceLoad"].GetBitmap(self.iconsize))
+        menu.AppendItem(load)
+        self.Bind(wx.EVT_MENU, self.OnWorkspaceLoad, load)
+        # create menu
+        self.PopupMenu(menu)
+        menu.Destroy()
+    def OnWorkspaceNew(self, event=None):
+        """!Create new workspace file
+        Erase current workspace settings first"""
+        Debug.msg(4, "GMFrame.OnWorkspaceNew():")
+        # start new map display if no display is available
+        if not self.curr_page:
+            self.NewDisplay()
+             dlg = wx.MessageDialog(self, message=_("Current workspace is not empty. "
+                                                    "Do you want to store current settings "
+                                                    "to workspace file?"),
+                                    caption=_("Create new workspace?"),
+                                    style=wx.YES_NO | wx.YES_DEFAULT | \
+                                        wx.CANCEL | wx.ICON_QUESTION)
+                 dlg.Destroy()
+                 return
+             dlg.Destroy()
+        # delete all items
+        maptree.DeleteAllItems()
+        # add new root element
+        maptree.root = maptree.AddRoot("Map Layers")
+        self.curr_page.maptree.SetPyData(maptree.root, (None,None))
+        # no workspace file loaded
+        self.workspaceFile = None
+        self.SetTitle(self.baseTitle)
+    def OnWorkspaceOpen(self, event=None):
+        """!Open file with workspace definition"""
+        dlg = wx.FileDialog(parent=self, message=_("Choose workspace file"),
+                            defaultDir=os.getcwd(), wildcard="*.gxw")
+        filename = ''
+            filename = dlg.GetPath()
+        if filename == '':
+            return
+        Debug.msg(4, "GMFrame.OnWorkspaceOpen(): filename=%s" % filename)
+        # delete current layer tree content
+        self.LoadWorkspaceFile(filename)
+        self.workspaceFile = filename
+        self.SetTitle(self.baseTitle + " - " +  os.path.basename(self.workspaceFile))
+    def LoadWorkspaceFile(self, filename):
+        """!Load layer tree definition stored in GRASS Workspace XML file (gxw)
+        @todo Validate against DTD
+        @return False on error
+        # dtd
+        dtdFilename = os.path.join(globalvar.ETCWXDIR, "xml", "grass-gxw.dtd")
+        # parse workspace file
+        try:
+            gxwXml = workspace.ProcessWorkspaceFile(etree.parse(filename))
+        except Exception, err:
+            raise gcmd.GStdError(_("Reading workspace file <%(file)s> failed.\n"
+                                   "Invalid file, unable to parse XML document."
+                                   "\n\n%(err)s") % { 'file' : filename, 'err': err},
+                                 parent = self)
+        busy = wx.BusyInfo(message=_("Please wait, loading workspace..."),
+                           parent=self)
+        wx.Yield()
+        # load layer manager window properties
+        if UserSettings.Get(group='workspace', key='posManager', subkey='enabled') is False:
+            if gxwXml.layerManager['pos']:
+                self.SetPosition(gxwXml.layerManager['pos'])
+            if gxwXml.layerManager['size']:
+                self.SetSize(gxwXml.layerManager['size'])
+        # start map displays first (list of layers can be empty)
+        displayId = 0
+        mapdisplay = []
+        for display in gxwXml.displays:
+            mapdisplay.append(self.NewDisplay(show=False))
+            maptree = self.gm_cb.GetPage(displayId).maptree
+            # set windows properties
+            mapdisplay[-1].SetProperties(render=display['render'],
+                                         mode=display['mode'],
+                                         showCompExtent=display['showCompExtent'],
+                                         constrainRes=display['constrainRes'],
+                                         projection=display['projection']['enabled'])
+            if display['projection']['enabled']:
+                if display['projection']['epsg']:
+                    UserSettings.Set(group = 'display', key = 'projection', subkey = 'epsg',
+                                     value = display['projection']['epsg'])
+                    if display['projection']['proj']:
+                        UserSettings.Set(group = 'display', key = 'projection', subkey = 'proj4',
+                                         value = display['projection']['proj'])
+            # set position and size of map display
+            if UserSettings.Get(group='workspace', key='posDisplay', subkey='enabled') is False:
+                if display['pos']:
+                    mapdisplay[-1].SetPosition(display['pos'])
+                if display['size']:
+                    mapdisplay[-1].SetSize(display['size'])
+            # set extent if defined
+            if display['extent']:
+                w, s, e, n = display['extent']
+                maptree.Map.region = maptree.Map.GetRegion(w=w, s=s, e=e, n=n)
+            mapdisplay[-1].Show()
+            displayId += 1
+        maptree = None
+        selected = [] # list of selected layers
+        # load list of map layers
+        for layer in gxwXml.layers:
+            display = layer['display']
+            maptree = self.gm_cb.GetPage(display).maptree
+            newItem = maptree.AddLayer(ltype=layer['type'],
+                                       lname=layer['name'],
+                                       lchecked=layer['checked'],
+                                       lopacity=layer['opacity'],
+                                       lcmd=layer['cmd'],
+                                       lgroup=layer['group'],
+                                       lnviz=layer['nviz'],
+                                       lvdigit=layer['vdigit'])
+            if layer.has_key('selected'):
+                if layer['selected']:
+                    selected.append((maptree, newItem))
+                else:
+                    maptree.SelectItem(newItem, select=False)
+        for maptree, layer in selected:
+            if not maptree.IsSelected(layer):
+                maptree.SelectItem(layer, select=True)
+                maptree.layer_selected = layer
+        busy.Destroy()
+        if maptree:
+            # reverse list of map layers
+            maptree.Map.ReverseListOfLayers()
+        for mdisp in mapdisplay:
+            mdisp.MapWindow2D.UpdateMap()
+        return True
+    def OnWorkspaceLoad(self, event=None):
+        """!Load given map layers into layer tree"""
+        dialog = gdialogs.LoadMapLayersDialog(parent=self, title=_("Load map layers into layer tree"))
+        if dialog.ShowModal() == wx.ID_OK:
+                self.NewDisplay()
+                               parent=self)
+            wx.Yield()
+            for layerName in dialog.GetMapLayers():
+                if dialog.GetLayerType() == 'raster':
+                    cmd = ['d.rast', 'map=%s' % layerName]
+                elif dialog.GetLayerType() == 'vector':
+                    cmd = ['d.vect', 'map=%s' % layerName]
+                newItem = maptree.AddLayer(ltype=dialog.GetLayerType(),
+                                           lname=layerName,
+                                           lchecked=True,
+                                           lopacity=1.0,
+                                           lcmd=cmd,
+                                           lgroup=None)
+            busy.Destroy()
+    def OnWorkspaceLoadGrcFile(self, event):
+        """!Load map layers from GRC file (Tcl/Tk GUI) into map layer tree"""
+        dlg = wx.FileDialog(parent=self, message=_("Choose GRC file to load"),
+                            defaultDir=os.getcwd(), wildcard="*.grc")
+        filename = ''
+            return
+        Debug.msg(4, "GMFrame.OnWorkspaceLoadGrcFile(): filename=%s" % filename)
+            self.NewDisplay()
+                           parent=self)
+        wx.Yield()
+        maptree = None
+        for layer in workspace.ProcessGrcFile(filename).read(self):
+            maptree = self.gm_cb.GetPage(layer['display']).maptree
+                                       lgroup=layer['group'])
+            busy.Destroy()
+        if maptree:
+    def OnWorkspaceSaveAs(self, event=None):
+        """!Save workspace definition to selected file"""
+        dlg = wx.FileDialog(parent=self, message=_("Choose file to save current workspace"),
+                            defaultDir=os.getcwd(), wildcard="*.gxw", style=wx.FD_SAVE)
+        filename = ''
+            return False
+        # check for extension
+        if filename[-4:] != ".gxw":
+            filename += ".gxw"
+        if os.path.exists(filename):
+            dlg = wx.MessageDialog(self, message=_("Workspace file <%s> already exists. "
+                                                   "Do you want to overwrite this file?") % filename,
+                                   caption=_("Save workspace"), style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+            if dlg.ShowModal() != wx.ID_YES:
+                dlg.Destroy()
+                return False
+        Debug.msg(4, "GMFrame.OnWorkspaceSaveAs(): filename=%s" % filename)
+        self.SaveToWorkspaceFile(filename)
+    def OnWorkspaceSave(self, event=None):
+        """!Save file with workspace definition"""
+                                                   "Do you want to overwrite this file?") % \
+                                       self.workspaceFile,
+                dlg.Destroy()
+            else:
+                Debug.msg(4, "GMFrame.OnWorkspaceSave(): filename=%s" % self.workspaceFile)
+        else:
+    def SaveToWorkspaceFile(self, filename):
+        """!Save layer tree layout to workspace file
+        Return True on success, False on error
+        try:
+            file = open(filename, "w")
+        except IOError:
+            wx.MessageBox(parent=self,
+                          message=_("Unable to open workspace file <%s> for writing.") % filename,
+            return False
+        try:
+            workspace.WriteWorkspaceFile(lmgr=self, file=file)
+        except StandardError, e:
+            file.close()
+                          message=_("Writing current settings to workspace file failed (%s)." % e),
+                          style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+            return False
+        file.close()
+        return True
+    def OnWorkspaceClose(self, event=None):
+        """!Close file with workspace definition
+        If workspace has been modified ask user to save the changes.
+        Debug.msg(4, "GMFrame.OnWorkspaceClose(): file=%s" % self.workspaceFile)
+        displays = []
+        for page in range(0, self.gm_cb.GetPageCount()):
+            displays.append(self.gm_cb.GetPage(page).maptree.mapdisplay)
+        for display in displays:
+            display.OnCloseWindow(event)
+        self.disp_idx = 0
+    def RulesCmd(self, event, cmd = ''):
+        Launches dialog for commands that need rules
+        input and processes rules
+        if event:
+        if cmd[0] == 'r.colors' or cmd[0] == 'vcolors':
+            ctable = colorrules.ColorTable(self, cmd=cmd[0])
+            ctable.Show()
+        else:
+            dlg = rules.RulesText(self, cmd=cmd)
+                gtemp = utils.GetTempfile()
+                output = open(gtemp, "w")
+                try:
+                    output.write(dlg.rules)
+                finally:
+                    output.close()
+                cmdlist = [cmd[0],
+                           'input=%s' % dlg.inmap,
+                           'output=%s' % dlg.outmap,
+                           'rules=%s' % gtemp]
+                if dlg.overwrite == True:
+                    cmdlist.append('--o')
+                dlg.Destroy()
+                self.goutput.RunCmd(cmdlist)
+    def OnPreferences(self, event):
+        """!General GUI preferences/settings"""
+        if not self.dialogs['preferences']:
+            dlg = preferences.PreferencesDialog(parent=self)
+            self.dialogs['preferences'] = dlg
+            self.dialogs['preferences'].CenterOnScreen()
+        self.dialogs['preferences'].ShowModal()
+    def DispHistogram(self, event):
+        Init histogram display canvas and tools
+        self.histogram = histogram.HistFrame(self,
+                                             id=wx.ID_ANY, pos=wx.DefaultPosition, size=(400,300),
+        #show new display
+        self.histogram.Show()
+        self.histogram.Refresh()
+        self.histogram.Update()
+    def DispProfile(self, event):
+        Init profile canvas and tools
+        self.profile = profile.ProfileFrame(self,
+        self.profile.Show()
+        self.profile.Refresh()
+        self.profile.Update()
+    def DispMapCalculator(self, event):
+        Init map calculator for interactive creation of mapcalc statements
+        self.mapcalculator = mapcalculator.MapCalcFrame(self, wx.ID_ANY, title='',
+                                                        dimension=2)
+    def Disp3DMapCalculator(self, event):
+                                                        dimension=3)
+    def AddToolbarButton(self, toolbar, label, icon, help, handler):
+        """!Adds button to the given toolbar"""
+        if not label:
+            return
+        tool = toolbar.AddLabelTool(id=wx.ID_ANY, label=label, bitmap=icon, shortHelp=help)
+        self.Bind(wx.EVT_TOOL, handler, tool)
+        return   (
+                 ('newdisplay', Icons["newdisplay"].GetBitmap(),
+                  Icons["newdisplay"].GetLabel(), self.OnNewDisplay),
+                 ('workspaceLoad', Icons["workspaceLoad"].GetBitmap(),
+                  Icons["workspaceLoad"].GetLabel(), self.OnWorkspace),
+                 ('workspaceOpen', Icons["workspaceOpen"].GetBitmap(),
+                  Icons["workspaceOpen"].GetLabel(), self.OnWorkspaceOpen),
+                 ('workspaceSave', Icons["workspaceSave"].GetBitmap(),
+                  Icons["workspaceSave"].GetLabel(), self.OnWorkspaceSave),
+                 ('addrast', Icons["addrast"].GetBitmap(),
+                  Icons["addrast"].GetLabel(), self.OnAddRaster),
+                 ('addshaded', Icons["addshaded"].GetBitmap(),
+                  _("Add various raster-based map layers"), self.OnAddRasterMisc),
+                 ('addvect', Icons["addvect"].GetBitmap(),
+                  Icons["addvect"].GetLabel(), self.OnAddVector),
+                 ('addthematic', Icons["addthematic"].GetBitmap(),
+                  _("Add various vector-based map layer"), self.OnAddVectorMisc),
+                 ('addcmd',  Icons["addcmd"].GetBitmap(),
+                  Icons["addcmd"].GetLabel(),  self.OnAddCommand),
+                 ('addgrp',  Icons["addgrp"].GetBitmap(),
+                  Icons["addgrp"].GetLabel(), self.OnAddGroup),
+                 ('addovl',  Icons["addovl"].GetBitmap(),
+                  Icons["addovl"].GetLabel(), self.OnAddOverlay),
+                 ('delcmd',  Icons["delcmd"].GetBitmap(),
+                  Icons["delcmd"].GetLabel(), self.OnDeleteLayer),
+                 ('attrtable', Icons["attrtable"].GetBitmap(),
+                  Icons["attrtable"].GetLabel(), self.OnShowAttributeTable)
+    def OnImportDxfFile(self, event):
+        """!Convert multiple DXF layers to GRASS vector map layers"""
+        dlg = gdialogs.MultiImportDialog(parent=self, type='dxf',
+                                         title=_("Import DXF layers"))
+        dlg.ShowModal()
+    def OnImportGdalLayers(self, event):
+        """!Convert multiple GDAL layers to GRASS raster map layers"""
+        dlg = gdialogs.MultiImportDialog(parent=self, type='gdal',
+                                         title=_("Import GDAL layers"))
+        dlg.ShowModal()
+    def OnLinkGdalLayers(self, event):
+        """!Link multiple GDAL layers to GRASS raster map layers"""
+                                         title=_("Link GDAL layers"),
+                                         link = True)
+        dlg.ShowModal()
+    def OnImportOgrLayers(self, event):
+        """!Convert multiple OGR layers to GRASS vector map layers"""
+        dlg = gdialogs.MultiImportDialog(parent=self, type='ogr',
+                                         title=_("Import OGR layers"))
+        dlg.ShowModal()
+    def OnLinkOgrLayers(self, event):
+        """!Links multiple OGR layers to GRASS vector map layers"""
+                                         title=_("Link OGR layers"),
+                                         link = True)
+        dlg.ShowModal()
+    def OnImportWMS(self, event):
+        """!Import data from OGC WMS server"""
+        dlg = ogc_services.WMSDialog(parent = self, service = 'wms')
+        if dlg.ShowModal() == wx.ID_OK: # -> import layers
+            layers = dlg.GetLayers()
+            if len(layers.keys()) > 0:
+                for layer in layers.keys():
+                    cmd = ['r.in.wms',
+                           'mapserver=%s' % dlg.GetSettings()['server'],
+                           'layers=%s' % layer,
+                           'output=%s' % layer]
+                    styles = ','.join(layers[layer])
+                    if styles:
+                        cmd.append('styles=%s' % styles)
+                    self.goutput.RunCmd(cmd, switchPage = True)
+            else:
+                self.goutput.WriteWarning(_("Nothing to import. No WMS layer selected."))
+        dlg.Destroy()
+    def OnShowAttributeTable(self, event):
+        Show attribute table of the given vector map layer
+            self.MsgNoLayerSelected()
+            return
+        # no map layer selected
+        if not layer:
+            return
+        # available only for vector map layers
+        try:
+            maptype = self.curr_page.maptree.GetPyData(layer)[0]['maplayer'].type
+        except:
+            maptype = None
+        if not maptype or maptype != 'vector':
+                          message=_("Attribute management is available only "
+                                    "for vector maps."),
+                          caption=_("Message"),
+                          style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+            return
+        if not self.curr_page.maptree.GetPyData(layer)[0]:
+            return
+        dcmd = self.curr_page.maptree.GetPyData(layer)[0]['cmd']
+        if not dcmd:
+            return
+        busy = wx.BusyInfo(message=_("Please wait, loading attribute data..."),
+                           parent=self)
+        wx.Yield()
+        dbmanager = dbm.AttributeManager(parent=self, id=wx.ID_ANY,
+                                         size=wx.Size(500, 300),
+                                         item=layer, log=self.goutput)
+        busy.Destroy()
+        # register ATM dialog
+        self.dialogs['atm'].append(dbmanager)
+        # show ATM window
+        dbmanager.Show()
+    def OnNewDisplay(self, event=None):
+        """!Create new layer tree and map display instance"""
+        self.NewDisplay()
+    def NewDisplay(self, show=True):
+        """!Create new layer tree, which will
+        create an associated map display frame
+        @param show show map display window if True
+        @return reference to mapdisplay intance
+        Debug.msg(1, "GMFrame.NewDisplay(): idx=%d" % self.disp_idx)
+        # make a new page in the bookcontrol for the layer tree (on page 0 of the notebook)
+        self.pg_panel = wx.Panel(self.gm_cb, id=wx.ID_ANY, style= wx.EXPAND)
+        self.gm_cb.AddPage(self.pg_panel, text="Display "+ str(self.disp_idx + 1), select = True)
+        # create layer tree (tree control for managing GIS layers)  and put on new notebook page
+        self.curr_page.maptree = wxgui_utils.LayerTree(self.curr_page, id=wx.ID_ANY, pos=wx.DefaultPosition,
+                                                       size=wx.DefaultSize, style=wx.TR_HAS_BUTTONS
+                                                       |wx.TR_LINES_AT_ROOT|wx.TR_HIDE_ROOT
+                                                       |wx.TR_DEFAULT_STYLE|wx.NO_BORDER|wx.FULL_REPAINT_ON_RESIZE,
+                                                       idx=self.disp_idx, lmgr=self, notebook=self.gm_cb,
+                                                       auimgr=self._auimgr, showMapDisplay=show)
+        # layout for controls
+        cb_boxsizer = wx.BoxSizer(wx.VERTICAL)
+        cb_boxsizer.Add(self.curr_page.maptree, proportion=1, flag=wx.EXPAND, border=1)
+        self.curr_page.SetSizer(cb_boxsizer)
+        cb_boxsizer.Fit(self.curr_page.maptree)
+        self.curr_page.Layout()
+        self.curr_page.maptree.Layout()
+            idx = 4 + self.disp_idx * 4
+            try:
+                x, y = map(int, dim.split(',')[idx:idx + 2])
+                w, h = map(int, dim.split(',')[idx + 2:idx + 4])
+                self.curr_page.maptree.mapdisplay.SetPosition((x, y))
+                self.curr_page.maptree.mapdisplay.SetSize((w, h))
+            except:
+                pass
+        self.disp_idx += 1
+        return self.curr_page.maptree.mapdisplay
+    # toolBar button handlers
+    def OnAddRaster(self, event):
+        """!Add raster map layer"""
+            self.NewDisplay(show=False)
+        self.AddRaster(event)
+    def OnAddRasterMisc(self, event):
+        """!Add raster menu"""
+        rastmenu = wx.Menu()
+        # add items to the menu
+        if self.curr_page.maptree.mapdisplay.toolbars['nviz']:
+            addrast3d = wx.MenuItem(rastmenu, -1, Icons ["addrast3d"].GetLabel())
+            addrast3d.SetBitmap(Icons["addrast3d"].GetBitmap (self.iconsize))
+            rastmenu.AppendItem(addrast3d)
+            self.Bind(wx.EVT_MENU, self.AddRaster3d, addrast3d)
+        addshaded = wx.MenuItem(rastmenu, -1, Icons ["addshaded"].GetLabel())
+        addshaded.SetBitmap(Icons["addshaded"].GetBitmap (self.iconsize))
+        rastmenu.AppendItem(addshaded)
+        self.Bind(wx.EVT_MENU, self.AddShaded, addshaded)
+        addrgb = wx.MenuItem(rastmenu, -1, Icons["addrgb"].GetLabel())
+        addrgb.SetBitmap(Icons["addrgb"].GetBitmap(self.iconsize))
+        rastmenu.AppendItem(addrgb)
+        self.Bind(wx.EVT_MENU, self.AddRGB, addrgb)
+        addhis = wx.MenuItem(rastmenu, -1, Icons ["addhis"].GetLabel())
+        addhis.SetBitmap(Icons["addhis"].GetBitmap (self.iconsize))
+        rastmenu.AppendItem(addhis)
+        self.Bind(wx.EVT_MENU, self.AddHIS, addhis)
+        addrastarrow = wx.MenuItem(rastmenu, -1, Icons ["addrarrow"].GetLabel())
+        addrastarrow.SetBitmap(Icons["addrarrow"].GetBitmap (self.iconsize))
+        rastmenu.AppendItem(addrastarrow)
+        self.Bind(wx.EVT_MENU, self.AddRastarrow, addrastarrow)
+        addrastnums = wx.MenuItem(rastmenu, -1, Icons ["addrnum"].GetLabel())
+        addrastnums.SetBitmap(Icons["addrnum"].GetBitmap (self.iconsize))
+        rastmenu.AppendItem(addrastnums)
+        self.Bind(wx.EVT_MENU, self.AddRastnum, addrastnums)
+        self.PopupMenu(rastmenu)
+        rastmenu.Destroy()
+        # show map display
+        self.curr_page.maptree.mapdisplay.Show()
+    def OnAddVector(self, event):
+        """!Add vector map layer"""
+        self.AddVector(event)
+    def OnAddVectorMisc(self, event):
+        """!Add vector menu"""
+        vectmenu = wx.Menu()
+        addtheme = wx.MenuItem(vectmenu, -1, Icons["addthematic"].GetLabel())
+        addtheme.SetBitmap(Icons["addthematic"].GetBitmap(self.iconsize))
+        vectmenu.AppendItem(addtheme)
+        self.Bind(wx.EVT_MENU, self.AddThemeMap, addtheme)
+        addchart = wx.MenuItem(vectmenu, -1, Icons["addchart"].GetLabel())
+        addchart.SetBitmap(Icons["addchart"].GetBitmap(self.iconsize))
+        vectmenu.AppendItem(addchart)
+        self.Bind(wx.EVT_MENU, self.AddThemeChart, addchart)
+        self.PopupMenu(vectmenu)
+        vectmenu.Destroy()
+    def OnAddOverlay(self, event):
+        """!Add overlay menu"""
+        ovlmenu = wx.Menu()
+        addgrid = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addgrid"].GetLabel())
+        addgrid.SetBitmap(Icons["addgrid"].GetBitmap(self.iconsize))
+        ovlmenu.AppendItem(addgrid)
+        self.Bind(wx.EVT_MENU, self.AddGrid, addgrid)
+        addlabels = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addlabels"].GetLabel())
+        addlabels.SetBitmap(Icons["addlabels"].GetBitmap(self.iconsize))
+        ovlmenu.AppendItem(addlabels)
+        self.Bind(wx.EVT_MENU, self.OnAddLabels, addlabels)
+        addgeodesic = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addgeodesic"].GetLabel())
+        addgeodesic.SetBitmap(Icons["addgeodesic"].GetBitmap(self.iconsize))
+        ovlmenu.AppendItem(addgeodesic)
+        self.Bind(wx.EVT_MENU, self.AddGeodesic, addgeodesic)
+        addrhumb = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addrhumb"].GetLabel())
+        addrhumb.SetBitmap(Icons["addrhumb"].GetBitmap(self.iconsize))
+        ovlmenu.AppendItem(addrhumb)
+        self.Bind(wx.EVT_MENU, self.AddRhumb, addrhumb)
+        self.PopupMenu(ovlmenu)
+        ovlmenu.Destroy()
+    def AddRaster(self, event):
+        self.notebook.SetSelection(0)
+        self.curr_page.maptree.AddLayer('raster')
+    def AddRaster3d(self, event):
+        self.curr_page.maptree.AddLayer('3d-raster')
+    def AddRGB(self, event):
+        """!Add RGB layer"""
+        self.curr_page.maptree.AddLayer('rgb')
+    def AddHIS(self, event):
+        """!Add HIS layer"""
+        self.curr_page.maptree.AddLayer('his')
+    def AddShaded(self, event):
+        """!Add shaded relief map layer"""
+        self.curr_page.maptree.AddLayer('shaded')
+    def AddRastarrow(self, event):
+        """!Add raster flow arrows map"""
+        self.curr_page.maptree.AddLayer('rastarrow')
+    def AddRastnum(self, event):
+        """!Add raster map with cell numbers"""
+        self.curr_page.maptree.AddLayer('rastnum')
+    def AddVector(self, event):
+        """!Add vector layer"""
+        self.curr_page.maptree.AddLayer('vector')
+    def AddThemeMap(self, event):
+        """!Add thematic map layer"""
+        self.curr_page.maptree.AddLayer('thememap')
+    def AddThemeChart(self, event):
+        """!Add thematic chart layer"""
+        self.curr_page.maptree.AddLayer('themechart')
+    def OnAddCommand(self, event):
+        """!Add command line layer"""
+        self.curr_page.maptree.AddLayer('command')
+    def OnAddGroup(self, event):
+        """!Add layer group"""
+        self.curr_page.maptree.AddLayer('group')
+    def AddGrid(self, event):
+        """!Add layer grid"""
+        self.curr_page.maptree.AddLayer('grid')
+    def AddGeodesic(self, event):
+        """!Add layer geodesic"""
+        self.curr_page.maptree.AddLayer('geodesic')
+    def AddRhumb(self, event):
+        """!Add layer rhumb"""
+        self.curr_page.maptree.AddLayer('rhumb')
+    def OnAddLabels(self, event):
+        """!Add layer vector labels"""
+        self.curr_page.maptree.AddLayer('labels')
+    def OnDeleteLayer(self, event):
+        Delete selected map display layer in GIS Manager tree widget
+        if not self.curr_page or not self.curr_page.maptree.layer_selected:
+            return
+        if UserSettings.Get(group='manager', key='askOnRemoveLayer', subkey='enabled'):
+            layerName = ''
+            for item in self.curr_page.maptree.GetSelections():
+                name = str(self.curr_page.maptree.GetItemText(item))
+                idx = name.find('(opacity')
+                if idx > -1:
+                    layerName += '<' + name[:idx].strip(' ') + '>,\n'
+                else:
+                    layerName += '<' + name + '>,\n'
+            layerName = layerName.rstrip(',\n')
+            if len(layerName) > 2: # <>
+                message = _("Do you want to remove map layer(s)\n%s\n"
+                            "from layer tree?") % layerName
+            else:
+                message = _("Do you want to remove selected map layer(s) "
+            dlg = wx.MessageDialog (parent=self, message=message,
+                                    caption=_("Remove map layer"),
+                                    style=wx.YES_NO | wx.YES_DEFAULT | wx.CANCEL | wx.ICON_QUESTION)
+            if dlg.ShowModal() in [wx.ID_NO, wx.ID_CANCEL]:
+                dlg.Destroy()
+                return
+            dlg.Destroy()
+        for layer in self.curr_page.maptree.GetSelections():
+            if self.curr_page.maptree.GetPyData(layer)[0]['type'] == 'group':
+                self.curr_page.maptree.DeleteChildren(layer)
+            self.curr_page.maptree.Delete(layer)
+    def OnKey(self, event):
+        """!Check hotkey"""
+        try:
+            kc = chr(event.GetKeyCode())
+        except ValueError:
+            event.Skip()
+            return
+        if event.AltDown():
+            if kc == 'R':
+                self.OnAddRaster(None)
+            elif kc == 'V':
+                self.OnAddVector(None)
+        event.Skip()
+    def OnCloseWindow(self, event):
+        """!Cleanup when wxGUI is quit"""
+        self.Destroy()
+    def MsgNoLayerSelected(self):
+        """!Show dialog message 'No layer selected'"""
+                      message=_("No map layer selected. Operation cancelled."),
