[GRASS-SVN] r41551 - grass/trunk/gui/wxpython/support
svn_grass at osgeo.org
Fri Mar 26 05:46:18 EDT 2010
Author: martinl
Date: 2010-03-26 05:45:59 -0400 (Fri, 26 Mar 2010)
New Revision: 41551
grass/trunk/gui/wxpython/support/update_menudata.py
'make' required
Modified: grass/trunk/gui/wxpython/support/update_menudata.py
--- grass/trunk/gui/wxpython/support/update_menudata.py 2010-03-26 09:37:45 UTC (rev 41550)
+++ grass/trunk/gui/wxpython/support/update_menudata.py 2010-03-26 09:45:59 UTC (rev 41551)
@@ -55,16 +55,16 @@
modules[interface.name] = { 'label' : interface.label,
'desc' : interface.description,
'keywords': interface.keywords }
return modules
def updateData(data, modules):
"""!Update menu data tree"""
# list of modules to be ignored
- ignore = [ 'v.type_wrapper.py',
- 'vcolors' ]
+ ignore = ['v.type_wrapper.py',
+ 'vcolors']
- menu_modules = []
+ menu_modules = list()
for node in data.tree.getiterator():
if node.tag != 'menuitem':
continue
@@ -75,7 +75,7 @@
if not item.has_key('command'):
continue
if item['command'] in ignore:
continue
@@ -89,7 +89,7 @@
else:
desc = modules[module]['desc']
node.find('help').text = desc
if not modules[module].has_key('keywords'):
grass.warning('%s: keywords missing' % module)
else:
@@ -137,33 +137,34 @@
print >> sys.stderr, __doc__
return 1
- grass.info("Step 1: parsing modules...")
+ nuldev = file(os.devnull, 'w+')
+ grass.info("Step 1: running make...")
+ grass.call(['make'], stderr = nuldev)
+ grass.info("Step 2: parsing modules...")
modules = dict()
modules = parseModules()
- grass.info("Step 2: reading menu data...")
+ grass.info("Step 3: reading menu data...")
data = menudata.Data()
- grass.info("Step 3: updating menu data...")
+ grass.info("Step 4: updating menu data...")
if printDiff:
tempFile = tempfile.NamedTemporaryFile()
- grass.info("Step 4: writing menu data...")
+ grass.info("Step 5: diff menu data...")
writeData(data, tempFile.name)
- nuldev = file(os.devnull, 'w+')
grass.call(['diff', '-u',
os.path.join('xml', 'menudata.xml'),
tempFile.name], stderr = nuldev)
else:
- grass.info("Step 4: writing menu data (menudata.xml)...")
+ grass.info("Step 5: writing menu data (menudata.xml)...")
writeData(data)
return 0
if __name__ == '__main__':
if os.getenv("GISBASE") is None:
- print >> sys.stderr, "You must be in GRASS GIS to run this program."
- sys.exit(1)
+ sys.exit("You must be in GRASS GIS to run this program.")
sys.path.append(os.path.join(os.getenv("GISBASE"), 'etc', 'wxpython', 'gui_modules'))
import menudata
