[GRASS-SVN] r41553 -
grass/branches/develbranch_6/gui/wxpython/support
svn_grass at osgeo.org
Fri Mar 26 06:32:27 EDT 2010
Author: martinl
Date: 2010-03-26 06:32:13 -0400 (Fri, 26 Mar 2010)
New Revision: 41553
grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py
updata_menudata.py - dry run (diff)
(merge r41549 & r41550 & r41551 from devbr6)
Modified: grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py
--- grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py 2010-03-26 10:16:09 UTC (rev 41552)
+++ grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py 2010-03-26 10:32:13 UTC (rev 41553)
@@ -12,13 +12,16 @@
License (>=v2). Read the file COPYING that comes with GRASS
for details.
-Usage: python support/update_menudata.py
+Usage: python support/update_menudata.py [-d]
+ -d - dry run (prints diff, file is not updated)
@author Martin Landa <landa.martin gmail.com>
import os
import sys
+import tempfile
try:
import xml.etree.ElementTree as etree
except ImportError:
@@ -53,16 +56,16 @@
modules[interface.name] = { 'label' : interface.label,
'desc' : interface.description,
'keywords': interface.keywords }
return modules
def updateData(data, modules):
"""!Update menu data tree"""
# list of modules to be ignored
- ignore = [ 'v.type_wrapper.py',
- 'vcolors' ]
+ ignore = ['v.type_wrapper.py',
+ 'vcolors']
+ menu_modules = list()
for node in data.tree.getiterator():
if node.tag != 'menuitem':
continue
@@ -73,7 +76,7 @@
if not item.has_key('command'):
continue
if item['command'] in ignore:
continue
@@ -87,7 +90,7 @@
else:
desc = modules[module]['desc']
node.find('help').text = desc
if not modules[module].has_key('keywords'):
grass.warning('%s: keywords missing' % module)
else:
@@ -96,12 +99,18 @@
grass.warning("Adding tag 'keywords' to '%s'" % module)
node.find('keywords').text = ','.join(modules[module]['keywords'])
-def writeData(data):
+ menu_modules.append(item['command'])
+ for module in modules.keys():
+ if module not in menu_modules:
+ grass.warning("'%s' not available from the menu" % module)
+def writeData(data, file = None):
"""!Write updated menudata.xml"""
- file = os.path.join('xml', 'menudata.xml')
+ if file is None:
+ file = os.path.join('xml', 'menudata.xml')
try:
- if not os.path.exists(file):
- raise IOError
data.tree.write(file)
except IOError:
print >> sys.stderr, "'%s' not found. Please run the script from 'gui/wxpython'." % file
@@ -120,26 +129,43 @@
if argv is None:
argv = sys.argv
- if len(argv) != 1:
+ if len(argv) > 1 and argv[1] == '-d':
+ printDiff = True
+ else:
+ printDiff = False
+ if len(argv) > 1 and argv[1] == '-h':
print >> sys.stderr, __doc__
return 1
- grass.info("Step 1: parsing modules...")
+ nuldev = file(os.devnull, 'w+')
+ grass.info("Step 1: running make...")
+ grass.call(['make'], stderr = nuldev)
+ grass.info("Step 2: parsing modules...")
modules = dict()
modules = parseModules()
- grass.info("Step 2: reading menu data...")
+ grass.info("Step 3: reading menu data...")
data = menudata.Data()
- grass.info("Step 3: updating menu data...")
+ grass.info("Step 4: updating menu data...")
- grass.info("Step 4: writing menu data (menudata.xml)...")
- writeData(data)
+ if printDiff:
+ tempFile = tempfile.NamedTemporaryFile()
+ grass.info("Step 5: diff menu data...")
+ writeData(data, tempFile.name)
+ grass.call(['diff', '-u',
+ os.path.join('xml', 'menudata.xml'),
+ tempFile.name], stderr = nuldev)
+ else:
+ grass.info("Step 5: writing menu data (menudata.xml)...")
+ writeData(data)
return 0
if __name__ == '__main__':
if os.getenv("GISBASE") is None:
- print >> sys.stderr, "You must be in GRASS GIS to run this program."
- sys.exit(1)
+ sys.exit("You must be in GRASS GIS to run this program.")
sys.path.append(os.path.join(os.getenv("GISBASE"), 'etc', 'wxpython', 'gui_modules'))
import menudata
