[GRASS-SVN] r41555 -
grass/branches/releasebranch_6_4/gui/wxpython/support
svn_grass at osgeo.org
Fri Mar 26 06:59:25 EDT 2010
Author: martinl
Date: 2010-03-26 06:59:23 -0400 (Fri, 26 Mar 2010)
New Revision: 41555
grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py
updata_menudata.py - dry run (diff)
(merge r41549 & r41550 & r41551 from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py
--- grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py 2010-03-26 10:34:27 UTC (rev 41554)
+++ grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py 2010-03-26 10:59:23 UTC (rev 41555)
@@ -7,23 +7,22 @@
Prints warning for missing modules.
-(C) 2008-2009 by the GRASS Development Team
+(C) 2008-2010 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
-Usage: python update_menudata.py
+Usage: python support/update_menudata.py [-d]
+ -d - dry run (prints diff, file is not updated)
@author Martin Landa <landa.martin gmail.com>
import os
import sys
import locale
-try:
- import xml.etree.ElementTree as etree
-except ImportError:
- import elementtree.ElementTree as etree # Python <= 2.4
+import tempfile
import xml.sax
import xml.sax.handler
@@ -110,35 +109,62 @@
desc = modules[module]['desc']
node.find('help').text = desc
-def writeData(data):
+def writeData(data, file = None):
"""!Write updated menudata.xml"""
- file = os.path.join('xml', 'menudata.xml')
+ if file is None:
+ file = os.path.join('xml', 'menudata.xml')
try:
- if not os.path.exists(file):
- raise IOError
data.tree.write(file)
except IOError:
print >> sys.stderr, "'%s' not found. Please run the script from 'gui/wxpython'." % file
+ return
+ try:
+ f = open(file, 'a')
+ try:
+ f.write('\n')
+ finally:
+ f.close()
+ except IOError:
+ print >> sys.stderr, "ERROR: Unable to write to menudata file."
def main(argv = None):
if argv is None:
argv = sys.argv
- if len(argv) != 1:
+ if len(argv) > 1 and argv[1] == '-d':
+ printDiff = True
+ else:
+ printDiff = False
+ if len(argv) > 1 and argv[1] == '-h':
print >> sys.stderr, __doc__
return 1
- grass.info("Step 1: parsing modules...")
+ nuldev = file(os.devnull, 'w+')
+ grass.info("Step 1: running make...")
+ grass.call(['make'], stderr = nuldev)
+ grass.info("Step 2: parsing modules...")
modules = dict()
modules = parseModules()
- grass.info("Step 2: reading menu data...")
+ grass.info("Step 3: reading menu data...")
data = menudata.Data()
- grass.info("Step 3: updating menu data...")
+ grass.info("Step 4: updating menu data...")
updateData(data, modules)
- grass.info("Step 4: writing menu data (menudata.xml)...")
- writeData(data)
+ if printDiff:
+ tempFile = tempfile.NamedTemporaryFile()
+ grass.info("Step 5: diff menu data...")
+ writeData(data, tempFile.name)
+ grass.call(['diff', '-u',
+ os.path.join('xml', 'menudata.xml'),
+ tempFile.name], stderr = nuldev)
+ else:
+ grass.info("Step 5: writing menu data (menudata.xml)...")
+ writeData(data)
return 0
if __name__ == '__main__':
