[GRASS-SVN] r41582 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Mar 27 18:02:04 EDT 2010
Author: martinl
Date: 2010-03-27 18:02:03 -0400 (Sat, 27 Mar 2010)
New Revision: 41582
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/dbm_base.py
wxGUI/dbm: unicode bug fix
(merge r41581 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2010-03-27 21:31:41 UTC (rev 41581)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2010-03-27 22:02:03 UTC (rev 41582)
@@ -58,21 +58,6 @@
from dbm_dialogs import ModifyTableRecord
from preferences import globalSettings as UserSettings
-def unicodeValue(value):
- """!Encode value"""
- enc = UserSettings.Get(group='atm', key='encoding', subkey='value')
- if enc:
- value = unicode(value, enc)
- elif os.environ.has_key('GRASS_DB_ENCODING'):
- value = unicode(value, os.environ['GRASS_DB_ENCODING'])
- else:
- try:
- value = unicode(value, 'ascii')
- except UnicodeDecodeError:
- value = _("Unable to decode value. Set encoding in GUI preferences ('Attributes').")
- return value
class Log:
The log output is redirected to the status bar of the containing frame.
@@ -301,7 +286,7 @@
else:
# encode string values
try:
- self.itemDataMap[i].append(unicodeValue(value))
+ self.itemDataMap[i].append(dbm_base.unicodeValue(value))
self.itemDataMap[i].append(_("Unable to decode value. "
"Set encoding in GUI preferences ('Attributes')."))
Modified: grass/trunk/gui/wxpython/gui_modules/dbm_base.py
--- grass/trunk/gui/wxpython/gui_modules/dbm_base.py 2010-03-27 21:31:41 UTC (rev 41581)
+++ grass/trunk/gui/wxpython/gui_modules/dbm_base.py 2010-03-27 22:02:03 UTC (rev 41582)
@@ -21,7 +21,23 @@
import gselect
import gcmd
+from preferences import globalSettings as UserSettings
+def unicodeValue(value):
+ """!Encode value"""
+ enc = UserSettings.Get(group='atm', key='encoding', subkey='value')
+ if enc:
+ value = unicode(value, enc)
+ elif os.environ.has_key('GRASS_DB_ENCODING'):
+ value = unicode(value, os.environ['GRASS_DB_ENCODING'])
+ else:
+ try:
+ value = unicode(value, 'ascii')
+ except UnicodeDecodeError:
+ value = _("Unable to decode value. Set encoding in GUI preferences ('Attributes').")
+ return value
def createDbInfoDesc(panel, mapDBInfo, layer):
"""!Create database connection information content"""
infoFlexSizer = wx.FlexGridSizer (cols=2, hgap=1, vgap=1)
