[GRASS-SVN] r41605 - grass-addons/raster/r.in.swisstopo
svn_grass at osgeo.org
Mon Mar 29 03:00:47 EDT 2010
Author: Juergen
Date: 2010-03-29 03:00:45 -0400 (Mon, 29 Mar 2010)
New Revision: 41605
grass-addons/raster/r.in.swisstopo/description.html
minor changes (changed a link and some spelling errors)
Modified: grass-addons/raster/r.in.swisstopo/description.html
--- grass-addons/raster/r.in.swisstopo/description.html 2010-03-29 02:45:11 UTC (rev 41604)
+++ grass-addons/raster/r.in.swisstopo/description.html 2010-03-29 07:00:45 UTC (rev 41605)
@@ -60,13 +60,13 @@
<DD>Default: <em>bilinear</em></DD>
<h2>Manual download and installation of the module (without svn)</h2>
-<p>You can find the current version of r.in.swisstopo <a href="http://svn.osgeo.org/grass/grass-addons/raster/r.in.swisstopo/">here</a><br>
+<p>You can find the current version of r.in.swisstopo <a href="http://trac.osgeo.org/grass/browser/grass-addons/raster/r.in.swisstopo/">here</a><br>
<br>
Installation:<br>
You might need to have root privileges for the following. If you do not have these, please ask your system administrator
<br>
<ul>
-<li>Simply copy the file 'r.in.swisstopo.sh' into your $GISBASE/scripts/ directory.<br>
+<li>Simply copy the file 'r.in.swisstopo' into your $GISBASE/scripts/ directory.<br>
(To find out your $GISBASE directory, call the following command from within a GRASS terminal:<br>
<i>env | grep $GISBASE</i>)<br>
Or directly copy the file from within the GRASS terminal with something like:
@@ -75,7 +75,7 @@
<li>Additionally, you might have to make the script executable with:<br>
<i>chmod +x $GISBASE/scripts/r.in.swisstopo.sh</i>
<br></li>
-<li>Finally, copy this file (description.html) into the $GISBASE/docs/html/ directory and name it r.in.swisstopo.sh
+<li>Finally, copy this file (description.html) into the $GISBASE/docs/html/ directory and name it r.in.swisstopo.html
<br></li>
</ul>
<br>
