[GRASS-SVN] r41608 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Mar 29 06:43:55 EDT 2010
Author: martinl
Date: 2010-03-29 06:43:39 -0400 (Mon, 29 Mar 2010)
New Revision: 41608
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: load model file (gxm)
(merge r41607 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-03-29 10:40:06 UTC (rev 41607)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-03-29 10:43:39 UTC (rev 41608)
@@ -9,6 +9,8 @@
- ModelAction
- ModelSearchDialog
- ModelData
+ - ProcessModelFile
+ - WriteModelFile
(C) 2010 by the GRASS Development Team
This program is free software under the GNU General Public License
@@ -21,6 +23,11 @@
import shlex
import time
+try:
+ import xml.etree.ElementTree as etree
+except ImportError:
+ import elementtree.ElementTree as etree # Python <= 2.4
import globalvar
if not os.getenv("GRASS_WXBUNDLED"):
globalvar.CheckForWx()
@@ -32,6 +39,9 @@
import toolbars
import menuform
import prompt
+import gcmd
+import utils
+from debug import Debug
from grass.script import core as grass
@@ -49,6 +59,8 @@
self.searchDialog = None # module search dialog
self.actions = list() # list of recorded actions
self.data = list() # list of recorded data items
+ self.baseTitle = title
+ self.modelFile = None # loaded model
wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
self.SetName("Modeler")
@@ -102,8 +114,31 @@
def OnModelOpen(self, event):
"""!Load model from file"""
- pass
+ debug = True
+ if debug is False:
+ dlg = wx.FileDialog(parent = self, message=_("Choose model file"),
+ defaultDir = os.getcwd(),
+ wildcard=_("GRASS Model File (*.gxm)|*.gxm"))
+ if dlg.ShowModal() == wx.ID_OK:
+ filename = dlg.GetPath()
+ else:
+ filename = '/home/martin/model.gxm'
+ if not filename:
+ return
+ Debug.msg(4, "ModelFrame.OnModelOpen(): filename=%s" % filename)
+ # close current model
+ ### self.OnModelClose()
+ self.LoadModelFile(filename)
+ self.modelFile = filename
+ self.SetTitle(self.baseTitle + " - " + os.path.basename(self.modelFile))
+ self.SetStatusText(_('%d actions loaded into model') % len(self.actions), 0)
def OnModelSave(self, event):
"""!Save model to file"""
pass
@@ -223,7 +258,44 @@
self.canvas.Refresh()
self.SetStatusText(layer.GetLog(), 0)
+ def LoadModelFile(self, filename):
+ """!Load model definition stored in GRASS Model XML file (gxm)
+ @todo Validate against DTD
+ Raise exception on error.
+ ### dtdFilename = os.path.join(globalvar.ETCWXDIR, "xml", "grass-gxm.dtd")
+ # parse workspace file
+ try:
+ gxmXml = ProcessModelFile(etree.parse(filename))
+ except Exception, err:
+ raise gcmd.GStdError(_("Reading model file <%(file)s> failed.\n"
+ "Invalid file, unable to parse XML document."
+ "\n\n%(err)s") % { 'file' : filename, 'err': err},
+ parent = self)
+ busy = wx.BusyInfo(message=_("Please wait, loading model..."),
+ parent=self)
+ wx.Yield()
+ # load model
+ for action in gxmXml.actions:
+ actionShape = ModelAction(parent = self,
+ x = action['pos'][0],
+ y = action['pos'][1],
+ width = action['size'][0],
+ height = action['size'][1],
+ cmd = action['cmd'])
+ self.canvas.diagram.AddShape(actionShape)
+ actionShape.Show(True)
+ self._addEvent(actionShape)
+ self.actions.append(actionShape)
+ self.canvas.Refresh(True)
class ModelCanvas(ogl.ShapeCanvas):
"""!Canvas where model is drawn"""
def __init__(self, parent):
@@ -448,7 +520,94 @@
self.searchBy.SetSelection(0)
self.search.SetValue('')
self.cmd_prompt.OnCmdErase(None)
+class ProcessModelFile:
+ """!Process GRASS model file (gxm)"""
+ def __init__(self, tree):
+ """!A ElementTree handler for the GXM XML file, as defined in
+ grass-gxm.dtd.
+ self.tree = tree
+ self.root = self.tree.getroot()
+ # list of actions, data
+ self.actions = list()
+ self._processFile()
+ def _filterValue(self, value):
+ """!Filter value
+ @param value
+ value = value.replace('<', '<')
+ value = value.replace('>', '>')
+ return value
+ def _getNodeText(self, node, tag, default = ''):
+ """!Get node text"""
+ p = node.find(tag)
+ if p is not None:
+ return utils.normalize_whitespace(p.text)
+ return default
+ def _processFile(self):
+ """!Process model file"""
+ for action in self.root.findall('action'):
+ pos = size = None
+ posAttr = action.get('position', None)
+ if posAttr:
+ posVal = map(int, posAttr.split(','))
+ try:
+ pos = (posVal[0], posVal[1])
+ except:
+ pos = None
+ sizeAttr = action.get('size', None)
+ if sizeAttr:
+ sizeVal = map(int, sizeAttr.split(','))
+ try:
+ size = (sizeVal[0], sizeVal[1])
+ except:
+ size = None
+ task = action.find('task')
+ if task:
+ cmd = self._processTask(task)
+ else:
+ cmd = None
+ self.actions.append({ 'pos' : pos,
+ 'size': size,
+ 'cmd' : cmd })
+ def _processTask(self, node):
+ """!Process task"""
+ cmd = list()
+ name = node.get('name', None)
+ if not name:
+ return cmd
+ cmd.append(name)
+ # flags
+ for p in node.findall('flag'):
+ flag = p.get('name', '')
+ if len(flag) > 1:
+ cmd.append('--' + flag)
+ else:
+ cmd.append('-' + flag)
+ # parameters
+ for p in node.findall('parameter'):
+ cmd.append('%s=%s' % (p.get('name', ''),
+ self._filterValue(self._getNodeText(p, 'value'))))
+ return cmd
+class WriteModelFile:
+ """!Write GRASS model file (gxm)"""
+ pass
def main():
app = wx.PySimpleApp()
frame = ModelFrame(parent = None)
