[GRASS-SVN] r41616 - grass/branches/develbranch_6/raster/r.in.gdal
svn_grass at osgeo.org
Mon Mar 29 14:49:17 EDT 2010
Author: neteler
Date: 2010-03-29 14:49:17 -0400 (Mon, 29 Mar 2010)
New Revision: 41616
grass/branches/develbranch_6/raster/r.in.gdal/description.html
grass/branches/develbranch_6/raster/r.in.gdal/main.c
cache parameter added
Modified: grass/branches/develbranch_6/raster/r.in.gdal/description.html
--- grass/branches/develbranch_6/raster/r.in.gdal/description.html 2010-03-29 18:49:05 UTC (rev 41615)
+++ grass/branches/develbranch_6/raster/r.in.gdal/description.html 2010-03-29 18:49:17 UTC (rev 41616)
@@ -113,8 +113,8 @@
<h2>NOTES</h2>
-Planned improvements to <em>r.in.gdal</em> in the future include support for
-reporting everything known about a dataset if the <b>output</b> parameter is not set.
+Import of large files can be significantly faster when setting <b>memory</b> to
+the size of the input file.
<p>
The <em>r.in.gdal</em> command does support the following features, as long as
@@ -129,8 +129,7 @@
Note that if the source has no colormap, r.in.gdal in GRASS 5.0 will emit
no colormap. Use r.colors map=... color=grey to assign a greyscale colormap.
In a future version of GRASS r.in.gdal will likely be upgraded to automatically
-emit greyscale colormaps.
-<br>
+emit greyscale colormaps.<br>
<dt> Data Types
<dd> Most GDAL data types are supported. Float32 and Float64 type bands
@@ -170,6 +169,10 @@
</dl>
+<p>
+Planned improvements to <em>r.in.gdal</em> in the future include support for
+reporting everything known about a dataset if the <b>output</b> parameter is not set.
<h3>Error Messages</h3>
<i>"ERROR: Input map is rotated - cannot import."</i><br>
Modified: grass/branches/develbranch_6/raster/r.in.gdal/main.c
--- grass/branches/develbranch_6/raster/r.in.gdal/main.c 2010-03-29 18:49:05 UTC (rev 41615)
+++ grass/branches/develbranch_6/raster/r.in.gdal/main.c 2010-03-29 18:49:17 UTC (rev 41616)
@@ -66,7 +66,7 @@
struct GModule *module;
struct
- struct Option *input, *output, *target, *title, *outloc, *band;
+ struct Option *input, *output, *target, *title, *outloc, *band, *memory;
} parm;
struct Flag *flag_o, *flag_e, *flag_k, *flag_f, *flag_l;
@@ -99,6 +99,12 @@
parm.band->required = NO;
parm.band->description = _("Band to select (default is all bands)");
+ parm.memory = G_define_option();
+ parm.memory->key = "memory";
+ parm.memory->type = TYPE_INTEGER;
+ parm.memory->required = NO;
+ parm.memory->description = _("Cache size (MiB)");
parm.target = G_define_option();
parm.target->key = "target";
parm.target->type = TYPE_STRING;
@@ -173,6 +179,8 @@
/* Fire up the engines. */
GDALAllRegister();
+ if (parm.memory->answer && *parm.memory->answer)
+ GDALSetCacheMax(atol(parm.memory->answer) * 1024 * 1024);
