[GRASS-SVN] r41619 - grass/branches/releasebranch_6_4/raster/r.grow2
svn_grass at osgeo.org
Mon Mar 29 19:24:01 EDT 2010
Author: hamish
Date: 2010-03-29 19:24:01 -0400 (Mon, 29 Mar 2010)
New Revision: 41619
grass/branches/releasebranch_6_4/raster/r.grow2/description.html
add shrinking example (#1024, merge from trunk)
Modified: grass/branches/releasebranch_6_4/raster/r.grow2/description.html
--- grass/branches/releasebranch_6_4/raster/r.grow2/description.html 2010-03-29 23:21:33 UTC (rev 41618)
+++ grass/branches/releasebranch_6_4/raster/r.grow2/description.html 2010-03-29 23:24:01 UTC (rev 41619)
@@ -9,6 +9,7 @@
option of preserving the original cells (similar to combining
<em>r.buffer</em> and <em>r.patch</em>).
<h2>NOTES</h2>
The user has the option of specifying three different metrics which
control the geometry in which grown cells are created, (controlled by
@@ -28,7 +29,6 @@
circular from a given point, with the distance given by the <b>radius</b>.
<p>
The <i>Manhattan metric</i>, or <i>Taxicab geometry</i>, is a form of geometry in
which the usual metric of Euclidean geometry is replaced by a new
metric in which the distance between two points is the sum of the (absolute)
@@ -44,7 +44,6 @@
rhombus-shaped from a given point.
<p>
The <i>Maximum metric</i> is given by the formula
<div class="code"><pre>d(dx,dy) = max(abs(dx),abs(dy))</pre></div>
@@ -52,13 +51,29 @@
where the isolines of distance from a point are squares.
<p>
If there are two cells which are equal candidates to grow into an empty space,
<em>r.grow</em> will choose the northernmost candidate; if there are multiple
candidates with the same northing, the westernmost is chosen.
+<h2>EXAMPLE</h2>
+You can shrink inwards by preparing an inverse map first, and then
+inverting the resulting grown map. For example:
+<div class="code"><pre>
+# Spearfish sample dataset
+MAP=fields
+g.region rast=$MAP
+r.mapcalc "inverse = if(isnull($MAP), 1, null())"
+r.grow in=inverse out=inverse.grown
+r.mapcalc "$MAP.shrunken = if(isnull(inverse.grown), $MAP, null())"
+r.colors $MAP.shrunken rast=$MAP
+g.remove inverse,inverse.grown
+</pre></div>
<h2>SEE ALSO</h2>
<em>
<a href="r.buffer.html">r.buffer</a>,<br>
<a href="r.grow.distance.html">r.grow.distance</a>,<br>
@@ -66,10 +81,10 @@
</em>
<p>
<em><a href="http://en.wikipedia.org/wiki/Euclidean_metric">Wikipedia Entry: Euclidean Metric</a><br>
<em><a href="http://en.wikipedia.org/wiki/Manhattan_metric">Wikipedia Entry: Manhattan Metric</a>
<h2>AUTHORS</h2>
Marjorie Larson,
@@ -77,4 +92,5 @@
<p>
Glynn Clements
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
