[GRASS-SVN] r42070 - grass-addons/gui/wxpython/data_catalog
svn_grass at osgeo.org
Sat May 1 05:30:33 EDT 2010
Author: rashadkm
Date: 2010-05-01 05:30:31 -0400 (Sat, 01 May 2010)
New Revision: 42070
grass-addons/gui/wxpython/data_catalog/LayerTree.py
grass-addons/gui/wxpython/data_catalog/mapdisplay.py
fixed multiple location issues
Modified: grass-addons/gui/wxpython/data_catalog/LayerTree.py
--- grass-addons/gui/wxpython/data_catalog/LayerTree.py 2010-05-01 08:57:41 UTC (rev 42069)
+++ grass-addons/gui/wxpython/data_catalog/LayerTree.py 2010-05-01 09:30:31 UTC (rev 42070)
@@ -55,8 +55,12 @@
self.ID_COPY = wx.NewId()
self.ID_DEL = wx.NewId()
self.ID_OSSIM = wx.NewId()
+ self.ID_OSSIM2 = wx.NewId()
self.ID_INFO = wx.NewId()
self.ID_REPORT = wx.NewId()
+ self.ID_AREA = 200
+ self.ID_LENGTH = 201
+ self.ID_COOR = 202
acel = wx.AcceleratorTable([
(wx.ACCEL_CTRL, ord('R'), self.ID_REN ) ,
@@ -68,6 +72,9 @@
self.dict = {}
+ self.colour = '0:0:0' #default colour for vector lines
+ self.colour_selected = False
self.layer = []
self.maplayer = None
@@ -82,8 +89,8 @@
self.MapWindow = self.mapdisplay.MapWindow2D
self.Bind(CT.EVT_TREE_ITEM_CHECKED, self.OnLayerChecked)
+ self.Bind(CT.EVT_TREE_ITEM_ACTIVATED, self.ChooseColour)
self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK,self.OnTreePopUp)
self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.OnEndRename)
self.Bind(wx.EVT_TREE_BEGIN_LABEL_EDIT, self.OnBeginRename)
@@ -93,10 +100,41 @@
self.Bind(wx.EVT_MENU,self.OnRename,id=self.ID_REN)
self.Bind(wx.EVT_MENU,self.OnDelete,id=self.ID_DEL)
self.Bind(wx.EVT_MENU,self.OnOssim,id=self.ID_OSSIM)
+ self.Bind(wx.EVT_MENU,self.OnOssim2,id=self.ID_OSSIM2)
self.Bind(wx.EVT_MENU,self.OnInfo,id=self.ID_INFO)
self.Bind(wx.EVT_MENU,self.OnReport,id=self.ID_REPORT)
+ self.Bind(wx.EVT_MENU,self.OnvReport,id=self.ID_AREA)
+ self.Bind(wx.EVT_MENU,self.OnvReport,id=self.ID_LENGTH)
+ self.Bind(wx.EVT_MENU,self.OnvReport,id=self.ID_COOR)
+ def ChooseColour(self,event):
+ colourdialog = wx.ColourDialog(self)
+ colourdialog.ShowModal()
+ rgb = colourdialog.GetColourData().GetColour()
+ rgb = str(rgb)
+ self.colour = rgb.replace(',',':')
+ self.colour = self.colour.strip('(')
+ self.colour = self.colour.strip(')')
+ item = event.GetItem()
+ col = colourdialog.GetColourData().GetColour()
+ self.SetHilightFocusColour(col)
+ self.SetItemTextColour(item,col)
+ parent = self.GetItemParent(item)
+ if self.IsItemChecked(parent):
+ self.colour_selected = True
+ self.CheckItem(parent)
+ else:
def OnInfo(self,event):
item = self.GetSelection()
@@ -127,7 +165,6 @@
notebook = leftpanel.GetParent()
frame = notebook.GetParent()
- notebook.SetSelection(2)
if not self.ItemHasChildren(item):
self.mapname = self.GetItemText(item) + "@" + frame.cmbMapset.GetValue()
@@ -135,15 +172,38 @@
if pText == "Raster Map" :
command = ["r.report", 'map=' + self.mapname]
frame.goutput.RunCmd(command)
- if pText == "Vector Map" :
- command = ["v.report", 'map=' + self.mapname]
- frame.goutput.RunCmd(command)
+# if pText == "Vector Map" :
+# command = ["v.report", 'map=' + self.mapname]
+# frame.goutput.RunCmd(command)
+ def OnvReport(self,event):
+ item = self.GetSelection()
+ Id = event.GetId()
+ if Id == 200:
+ option = 'area'
+ elif Id == 201:
+ option = 'length'
+ elif Id == 202:
+ option = 'coor'
+ pText = self.GetItemText(parent)
+ leftpanel=self.GetParent()
+ notebook = leftpanel.GetParent()
+ frame = notebook.GetParent()
+ #if not self.ItemHasChildren(item):
+ self.mapname = self.GetItemText(item) + "@" + frame.cmbMapset.GetValue()
+ command = ["v.report", 'map=' + self.mapname,'option=' + str(option)]
+ frame.goutput.RunCmd(command)
def OnLayerChecked(self, event):
"""!Enable/disable data layer"""
@@ -159,44 +219,54 @@
- if not self.ItemHasChildren(item):
- self.mapname = self.GetItemText(item) + "@" + frame.cmbMapset.GetValue()
- #for f in frames:
- # print f.GetName()
- #maptree = mapframe.maptree
- if pText == "Raster Map" :
+ #for f in frames:
+ # print f.GetName()
+ #maptree = mapframe.maptree
+ if pText == "Raster Map" :
+ if checked == True:
self.cmd= ['d.rast', str("map=" + self.mapname)]
- l_type='raster'
- self.maplayer = self.MapWindow.Map.AddLayer(type='raster', name=self.mapname, command=self.cmd)
+ maplayer = self.MapWindow.Map.AddLayer(type='raster', name=self.mapname, command=self.cmd)
+ self.layer_selected = maplayer
+ self.type = 'raster'
+ else:
+ layers = self.MapWindow.Map.GetListOfLayers( l_type='raster', l_name=self.mapname)
+ for layer in layers:
+ self.MapWindow.Map.DeleteLayer(layer)
+ self.MapWindow.EraseMap()
- #layer = maptree.PrependItem(parent=maptree.root, text=self.mapname, ct_type=1)
- #maptree.first = True
- #maptree.layer_selected = layer
- #maptree.CheckItem(layer)
- #self.layer.append(self.maplayer)
- #maptree.PlusLayer(self.maplayer)
+ if pText == "Vector Map" :
+ self.cmd= ['d.vect', str("map=" + self.mapname),str('color=' + self.colour)]
+ if self.colour_selected == False:
+ maplayer = self.MapWindow.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
+ else:
+ layers = self.MapWindow.Map.GetListOfLayers( l_type='vector', l_name=self.mapname)
+ maplayer=layer.__init__(type='vector', name=self.mapname, cmd=self.cmd)
+ self.type = 'vector'
+ else:
+ self.MapWindow.Map.region = self.MapWindow.Map.GetRegion()
+ self.MapWindow.flag = True
+ self.MapWindow.UpdateMap(render=True)
+ self.MapWindow.flag = False
- self.cmd= ['d.vect', str("map=" + self.mapname)]
- l_type='vector'
- self.maplayer = self.MapWindow.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
- self.MapWindow.Map.region = self.MapWindow.Map.GetRegion()
- self.MapWindow.flag = True
- self.MapWindow.UpdateMap(render=True)
- self.MapWindow.flag = False
@@ -217,15 +287,16 @@
glocs = glob.glob(os.path.join(self.gisdbase,location, mapset,"*"))
for gloc in glocs:
if not os.path.isfile(gloc) and os.path.isdir(gloc):
- if(os.path.basename(gloc)=='cellhd'):
- for rast in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
- self.PrependItem(node_raster, os.path.basename(rast),ct_type=1)
- elif(os.path.basename(gloc)=='vector'):
- for vect in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
- self.PrependItem(node_vector, os.path.basename(vect),ct_type=1)
- elif(os.path.basename(gloc)=='dbf'):
- for dfile in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
- self.PrependItem(node_dbf, os.path.basename(dfile),ct_type=1)
+ if(os.path.basename(gloc)=='cellhd'):
+ for rast in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
+ self.PrependItem(node_raster, os.path.basename(rast),ct_type=1)
+ elif(os.path.basename(gloc)=='vector'):
+ for vect in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
+ vectormap = self.PrependItem(node_vector, os.path.basename(vect),ct_type=1)
+ self.PrependItem(vectormap, "colour")
+ elif(os.path.basename(gloc)=='dbf'):
+ for dfile in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
+ self.PrependItem(node_dbf, os.path.basename(dfile),ct_type=1)
#Nodes with no children are given an italic type font
for node in treeNodes:
@@ -243,13 +314,7 @@
self.SortChildren(node_vector)
self.SortChildren(node_dbf)
- def OnToggleExpand(self,event):
- if self.treeExpand.GetValue() == True:
- self.ExpandAll()
- else:
- self.CollapseAll()
def OnBeginRename(self,event):
item = self.GetItemText(event.GetItem())
@@ -283,16 +348,34 @@
Display a popupMenu for copy,rename & delete operations
- if not self.ItemHasChildren(item) and \
- self.GetItemFont(item) != self.itemFont:
+ # if not self.ItemHasChildren(item) and \
+ # self.GetItemFont(item) != self.itemFont:
+ if self.GetItemText(item)!='Raster Map' and \
+ self.GetItemText(item)!='Vector Map' and \
+ self.GetItemText(item)!='DBF' and \
+ self.GetItemText(item)!='colour' and \
+ self.GetItemFont(item) != self.itemFont:
self.popupmenu = wx.Menu()
mnuCopy = self.popupmenu.Append(self.ID_COPY,'&Copy\tCtrl+C')
mnuRename = self.popupmenu.Append(self.ID_REN,'&Rename\tCtrl-R')
mnuDel = self.popupmenu.Append(self.ID_DEL,'&Delete\tDEL')
- mnuOssim = self.popupmenu.Append(self.ID_OSSIM,'&send to OssimPlanet')
+ #self.popupmenu.AppendSeperator()
+ mnuOssim = self.popupmenu.Append(self.ID_OSSIM,'&Send to OssimPlanet')
+ mnuOssim = self.popupmenu.Append(self.ID_OSSIM2,'&Remove from OssimPlanet')
mnuInfo = self.popupmenu.Append(self.ID_INFO,'&Info')
- mnuReport = self.popupmenu.Append(self.ID_REPORT,'&Report')
+ if pText == 'Vector Map':
+ mnuReport = wx.Menu()
+ mnuReport.Append(self.ID_AREA, 'Area')
+ mnuReport.Append(self.ID_LENGTH, 'Length')
+ mnuReport.Append(self.ID_COOR, 'Coordinate')
+ self.popupmenu.AppendMenu(wx.ID_ANY, 'Report', mnuReport)
+ else:
+ mnuReport =self.popupmenu.Append(self.ID_REPORT,'&Report')
self.PopupMenu(self.popupmenu)
@@ -399,23 +482,58 @@
def OnOssim( self,event ):
- Performs grass command for deleting a map
+ Performs grass command for adding a map
+ cmdflag = None
parent =self.GetItemParent(item)
if self.GetItemText(parent) == "Raster Map" :
cmdflag = 'r.planet.py -a map=' + str(self.GetItemText(item))
- elif self.GetItemText(parent) == "Vector Map" :
- cmdflag = 'v.planet.py -a map=' + str(self.GetItemText(item))
+ else:
+ if self.GetItemText(item) == 'colour':
+ col=self.GetItemTextColour(item)
+ mapname = self.GetItemParent(item)
+ else:
+ child,cookie = self.GetFirstChild(item)
+ mapname = item
+ col = self.GetItemTextColour(child)
+ if col.IsOk() is True:
+ col=str(col)
+ col = col.replace('(','')
+ col = col.replace(')','')
+ col = col.split(',')
- if cmdflag:
- #command = ["r.planet.py", cmdflag]
- #gcmd.CommandThread(command,stdout=None,stderr=None).run()
+ cmdflag = 'v.planet.py -a map=' + str(self.GetItemText(mapname)) + \
+ ' brush=' + str(col[0].strip()+','+col[1].strip()+','+col[2].strip()) + \
+ ' pen=' + str(col[0].strip()+','+col[1].strip()+','+col[2].strip()) + \
+ ' size=' +str('1,1')
+ #print cmdflag
+ if cmdflag is not None:
current = OssimPlanet(cmdflag)
current.start()
+ def OnOssim2( self,event ):
+ Performs grass command for deleting a map
+ cmdflag = None
+ parent =self.GetItemParent(item)
+ if self.GetItemText(parent) == "Raster Map" :
+ cmdflag = 'r.planet.py -r map=' + str(self.GetItemText(item))
+ else:
+ previtem = self.GetItemParent(item)
+ cmdflag = 'v.planet.py -r map=' + str(self.GetItemText(previtem))
+ else:
+ cmdflag = 'v.planet.py -r map=' + str(self.GetItemText(item))
+ current = OssimPlanet(cmdflag)
+ current.start()
def OnDisplay(self, event):
Modified: grass-addons/gui/wxpython/data_catalog/mapdisplay.py
--- grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-05-01 08:57:41 UTC (rev 42069)
+++ grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-05-01 09:30:31 UTC (rev 42070)
@@ -76,6 +76,8 @@
from debug import Debug
from preferences import globalSettings as UserSettings
+from tcp4ossim import zoomto
from LayerTree import LayerTree
from threading import Thread
@@ -2430,7 +2432,8 @@
self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY, Map=self.Map, tree=self.tree, gismgr=self._layerManager)
# default is 2D display mode
self.MapWindow = self.MapWindow2D
- #self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
+ self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
+ self.MapWindow.Bind(wx.EVT_LEFT_DOWN, self.OnClick)
self.MapWindow.SetCursor(self.cursors["default"])
# used by Nviz (3D display mode)
self.MapWindow3D = None
@@ -2528,6 +2531,27 @@
#r.rightSizer.Add(self.maptree)
+ def OnClick(self,event):
+ if self.frame.radiobox.GetSelection() == 0:
+ x, y = self.MapWindow.Pixel2Cell(event.GetPosition())
+ out = subprocess.Popen(['m.proj', '-o'], stdout=subprocess.PIPE, stdin=subprocess.PIPE).communicate("%s %s" % (x,y))[0]
+ f = out.replace("'"," ").replace('d',' ').replace('"',' ').replace('\n','').split('\t')
+ lon = f[0].split(' ')
+ lat = f[1].split(' ')[:-1]
+ if lat[-1] == 'N':
+ signlat = 1
+ if lat[-1] == 'S':
+ signlat = -1
+ if lon[-1] == 'E':
+ signlon = 1
+ if lon[-1] == 'W':
+ signlon = -1
+ lat = (float(lat[0]) + (float(lat[1]) / 60) + float(lat[2]) / 3600) * float(signlat)
+ lon = (float(lon[0]) + (float(lon[1]) / 60) + float(lon[2]) / 3600) * float(signlon)
+ self.frame.mInfo.SetValue(str(lat) + ' , ' + str(lon))
+ zoomto(str(lon),str(lat),15000)
+ event.Skip()
def read_gisrc(self):
Read variables gisrc file
