[GRASS-SVN] r42076 - grass-addons/gui/wxpython/data_catalog
svn_grass at osgeo.org
Sat May 1 06:47:41 EDT 2010
Author: rashadkm
Date: 2010-05-01 06:47:40 -0400 (Sat, 01 May 2010)
New Revision: 42076
grass-addons/gui/wxpython/data_catalog/catalog.py
grass-addons/gui/wxpython/data_catalog/mapdisplay.py
fixed coordinate view on map display
Modified: grass-addons/gui/wxpython/data_catalog/catalog.py
--- grass-addons/gui/wxpython/data_catalog/catalog.py 2010-05-01 10:26:57 UTC (rev 42075)
+++ grass-addons/gui/wxpython/data_catalog/catalog.py 2010-05-01 10:47:40 UTC (rev 42076)
@@ -36,7 +36,11 @@
gbase = os.getenv("GISBASE")
-pypath = os.path.join(gbase,'etc','gui','wxpython')
+grassversion = os.getenv("GRASS_VERSION")
+if grassversion == "7.0.svn":
+ pypath = os.path.join(gbase,'etc','gui','wxpython')
+else:
+ pypath = os.path.join(gbase,'etc','wxpython')
sys.path.append(pypath)
@@ -56,7 +60,11 @@
#To run DataCatalog from any directory set this pathname for access to gui_modules
-pypath = os.path.join(gbase,'etc','gui','wxpython','gui_modules')
+ pypath = os.path.join(gbase,'etc','gui','wxpython','gui_modules')
+else:
+ pypath = os.path.join(gbase,'etc','wxpython','gui_modules')
@@ -87,8 +95,7 @@
import gui_modules.workspace as workspace
import gui_modules.colorrules as colorrules
-version = os.getenv("GRASS_VERSION")
-if version != "6.4.svn":
+if grassversion != "6.4.0svn":
import gui_modules.menu as menu
import gui_modules.gmodeler as gmodeler
@@ -175,8 +182,7 @@
self.loclist.sort()
#self.pg_panel4 = None
- version = os.getenv("GRASS_VERSION")
- if version != "6.4.svn":
+ if grassversion != "6.4.0svn":
self.menubar = menu.Menu(parent = self, data = menudata.ManagerData())
else:
self.menubar, self.menudata = self.__createMenuBar()
@@ -251,8 +257,7 @@
"""!Creates menubar"""
self.menubar = wx.MenuBar()
- if version == "6.5.svn":
+ if grassversion == "6.5.svn":
self.menudata = menudata.ManagerData()
else:
self.menudata = menudata.Data()
@@ -318,8 +323,7 @@
subMenu = self.__createMenu(eachItem[1])
menu.AppendMenu(wx.ID_ANY, label, subMenu)
else:
- if version == "6.4.0svn":
+ if grassversion == "6.4.0svn":
self.__createMenuItem(menu, *eachItem)
else:
self.__createMenuItem7(menu, *eachItem)
@@ -1967,7 +1971,8 @@
self.page = self.notebook.GetPage(self.notebook.GetSelection())
self.page.Map.__init__()
self.page.Map.region = self.page.Map.GetRegion()
self.page.Map.projinfo = self.page.Map._projInfo()
else:
self.page.Map.projinfo = self.page.Map.ProjInfo()
@@ -2092,8 +2097,8 @@
Update $HOME/.grassrc(6/7) and gisrc files
rc = os.getenv("GISRC")
- if version == "7.0.svn":
+ grassversion = os.getenv("GRASS_VERSION")
+ if grassversion == "7.0.svn":
grassrc = os.path.join(os.getenv('HOME'), ".grassrc7.%s" % os.uname()[1])
if not os.access(grassrc, os.R_OK):
grassrc = os.path.join(os.getenv('HOME'), ".grassrc7")
Modified: grass-addons/gui/wxpython/data_catalog/mapdisplay.py
--- grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-05-01 10:26:57 UTC (rev 42075)
+++ grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-05-01 10:47:40 UTC (rev 42076)
@@ -2337,6 +2337,8 @@
else:
self.statusbar = self.frame.GetStatusBar()
self.statusbarWin = dict()
@@ -2679,6 +2681,8 @@
if self.tree:
self.tree.EnableItemType(type='3d-raster', enable=True)
+ self.toggleStatus.Enable(False)
# update status bar
@@ -2775,7 +2779,7 @@
self.toolbars['map'].combo.SetValue (_("2D view"))
self.toolbars['map'].Enable2D(True)
self.statusbarWin['toggle'].Enable(True)
+ self.toggleStatus.Enable(True)
self._mgr.Update()
def __InitDisplay(self):
@@ -2816,6 +2820,12 @@
event.Skip()
+ def OnToggleStatus(self, event):
+ Toggle status text
+ self.StatusbarUpdate()
def OnMotion(self, event):
Mouse moved
@@ -2823,10 +2833,6 @@
# update statusbar if required
if self.statusbarWin['toggle'].GetSelection() == 0: # Coordinates
- precision = int(UserSettings.Get(group = 'projection', key = 'format',
- subkey = 'precision'))
- format = UserSettings.Get(group = 'projection', key = 'format',
- subkey = 'll')
e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
if self.toolbars['vdigit'] and \
self.toolbars['vdigit'].GetAction() == 'addLine' and \
@@ -2840,43 +2846,17 @@
distance_tot += self.MapWindow.Distance(self.MapWindow.polycoords[idx-1],
self.MapWindow.polycoords[idx],
screen=False )[0]
- self.statusbar.SetStatusText("%.*f, %.*f (seg: %.*f; tot: %.*f)" % \
- (precision, e, precision, n,
- precision, distance_seg,
- precision, distance_tot), 0)
+ self.statusbar.SetStatusText("%.2f, %.2f (seg: %.2f; tot: %.2f)" % \
+ (e, n, distance_seg, distance_tot), 0)
else:
- if self.statusbarWin['projection'].IsChecked():
- if not UserSettings.Get(group='projection', key='statusbar', subkey='proj4'):
- self.statusbar.SetStatusText(_("Projection not defined (check the settings)"), 0)
- else:
- proj, coord = utils.ReprojectCoordinates(coord = (e, n),
- projOut = UserSettings.Get(group='projection',
- key='statusbar',
- subkey='proj4'),
- flags = 'd')
- if coord:
- e, n = coord
- if proj in ('ll', 'latlong', 'longlat') and format == 'DMS':
- self.statusbar.SetStatusText("%s" % \
- utils.Deg2DMS(e, n, precision = precision),
- 0)
- else:
- self.statusbar.SetStatusText("%.*f; %.*f" % \
- (precision, e, precision, n), 0)
- else:
- self.statusbar.SetStatusText(_("Error in projection (check the settings)"), 0)
+ if self.Map.projinfo['proj'] == 'll':
+ self.statusbar.SetStatusText("%s" % utils.Deg2DMS(e, n), 0)
else:
- if self.Map.projinfo['proj'] == 'll' and format == 'DMS':
- 0)
- else:
+ self.statusbar.SetStatusText("%.2f, %.2f" % (e, n), 0)
event.Skip()
def OnDraw(self, event):
Re-display current map composition
