[GRASS-SVN] r42079 - in grass/trunk: include lib/vector/Vlib
Mon May 3 04:06:53 EDT 2010
Author: mmetz
Date: 2010-05-03 04:06:52 -0400 (Mon, 03 May 2010)
New Revision: 42079
   grass/trunk/include/vector.h
   grass/trunk/lib/vector/Vlib/write.c
   grass/trunk/lib/vector/Vlib/write_nat.c
   grass/trunk/lib/vector/Vlib/write_ogr.c
next step on OGR vector write access
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h	2010-05-02 17:34:38 UTC (rev 42078)
+++ grass/trunk/include/vector.h	2010-05-03 08:06:52 UTC (rev 42079)
@@ -247,7 +247,7 @@
 /* Level 2 only */
 int Vect_read_line(const struct Map_info *, struct line_pnts *, struct line_cats *,
 		   int);
-int Vect_rewrite_line(struct Map_info *, int, int, const struct line_pnts *,
+off_t Vect_rewrite_line(struct Map_info *, int, int, const struct line_pnts *,
 		      const struct line_cats *);
 int Vect_delete_line(struct Map_info *, int);
 int Vect_restore_line(struct Map_info *, int, off_t);
@@ -436,15 +436,6 @@
 int Vect_print_header(const struct Map_info *);
 void Vect__init_head(struct Map_info *);
-void Vect__delete_area_cats_from_cidx(struct Map_info *, int);
-void Vect__add_area_cats_to_cidx(struct Map_info *, int);
-int V2__delete_line(struct Map_info *, int, int (*delete_fn) (struct Map_info *, off_t));
-void Vect__add_line_to_topo(struct Map_info *, int, const struct line_pnts *,
-			    const struct line_cats *);
-off_t V2__write_line(struct Map_info *, int, const struct line_pnts *,
-		     const struct line_cats *,
-		     off_t (*write_fn) (struct Map_info *, int, const struct line_pnts *,
-					const struct line_cats *));
 /* Open/close/rewind map */
 int Vect_coor_info(const struct Map_info *, struct Coor_info *);
@@ -490,27 +481,27 @@
 int V2_read_next_line_ogr(struct Map_info *, struct line_pnts *,
 int V1_delete_line_nat(struct Map_info *, off_t);
+int V2_delete_line_nat(struct Map_info *, off_t);
 int V1_delete_line_ogr(struct Map_info *, off_t);
-int V2_delete_line_nat(struct Map_info *, int);
-int V2_delete_line_ogr(struct Map_info *, int);
+int V2_delete_line_ogr(struct Map_info *, off_t);
 int V1_restore_line_nat(struct Map_info *, off_t);
 int V2_restore_line_nat(struct Map_info *, int, off_t);
 off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
-off_t V1_write_line_ogr(struct Map_info *, int, const struct line_pnts *,
 off_t V2_write_line_nat(struct Map_info *, int, const struct line_pnts *,
+off_t V1_write_line_ogr(struct Map_info *, int, const struct line_pnts *,
+			const struct line_cats *);
 off_t V2_write_line_ogr(struct Map_info *, int, const struct line_pnts *,
-off_t V1_rewrite_line_nat(struct Map_info *, off_t, int,
+off_t V1_rewrite_line_nat(struct Map_info *, int, int, off_t,
 			  const struct line_pnts *, const struct line_cats *);
-off_t V1_rewrite_line_ogr(struct Map_info *, off_t, int,
+off_t V2_rewrite_line_nat(struct Map_info *, int, int, off_t,
-int V2_rewrite_line_nat(struct Map_info *, int, int,
-			const struct line_pnts *, const struct line_cats *);
-int V2_rewrite_line_ogr(struct Map_info *, int, int,
+off_t V1_rewrite_line_ogr(struct Map_info *, int, int, off_t,
+			  const struct line_pnts *, const struct line_cats *);
+off_t V2_rewrite_line_ogr(struct Map_info *, int, int, off_t,
     /* Build topology */
 int Vect_build_nat(struct Map_info *, int);
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c	2010-05-02 17:34:38 UTC (rev 42078)
+++ grass/trunk/lib/vector/Vlib/write.c	2010-05-03 08:06:52 UTC (rev 42079)
@@ -26,7 +26,7 @@
 	      _("for this format/level not supported"));
     return -1;
-static int rewrite_dummy()
+static off_t rewrite_dummy()
     G_warning("Vect_rewrite_line() %s",
@@ -61,7 +61,7 @@
 #endif
-static off_t (*Write_line_array[][3]) () = {
+static off_t (*Vect_write_line_array[][3]) () = {
     write_dummy, V1_write_line_nat, V2_write_line_nat}
 #ifdef HAVE_OGR
@@ -77,7 +77,7 @@
 #endif
-static int (*Vect_rewrite_line_array[][3]) () = {
+static off_t (*Vect_rewrite_line_array[][3]) () = {
     rewrite_dummy, V1_rewrite_line_nat, V2_rewrite_line_nat}
 #ifdef HAVE_OGR
@@ -98,9 +98,9 @@
     delete_dummy, V1_delete_line_nat, V2_delete_line_nat}
 #ifdef HAVE_OGR
-    delete_dummy, V1_delete_line_ogr, V2_delete_line_ogr}
+    delete_dummy, V1_delete_line_ogr, V2_delete_line_nat}
 #else
     delete_dummy, format, format}
@@ -125,533 +125,11 @@
 #endif
-  \brief Deletes area (i.e. centroid) categories from category
-  index (internal use only)
-  \param Map pointer to Map_info structure
-  \param area area id
-void Vect__delete_area_cats_from_cidx(struct Map_info *Map, int area)
-    int i;
-    struct P_area *Area;
-    static struct line_cats *Cats = NULL;
-    G_debug(3, "Vect__delete_area_cats_from_cidx() area = %d", area);
-    Area = Map->plus.Area[area];
-    if (!Area)
-	G_fatal_error(_("%s: Area %d does not exist"),
-		      "delete_area_cats_from_cidx()", area);
-    if (Area->centroid == 0) /* no centroid found */
-	return;
-    if (!Cats)
-	Cats = Vect_new_cats_struct();
-    V2_read_line_nat(Map, NULL, Cats, Area->centroid);
-    for (i = 0; i < Cats->n_cats; i++) {
-	dig_cidx_del_cat(&(Map->plus), Cats->field[i], Cats->cat[i], area,
-			 GV_AREA);
-  \brief Adds area (i.e. centroid) categories from category index
-  (internal use only)
-void Vect__add_area_cats_to_cidx(struct Map_info *Map, int area)
-    int i;
-    G_debug(3, "Vect__add_area_cats_to_cidx() area = %d", area);
-    if (!Area)
-		      "add_area_cats_to_cidx():", area);
-	return;
-    if (!Cats)
-	dig_cidx_add_cat_sorted(&(Map->plus), Cats->field[i], Cats->cat[i],
-				area, GV_AREA);
-  \brief Deletes feature (topology level) -- internal use only
-  \param pointer to Map_info structure
-  \param line feature id
-  \param fn function to delete feature (native or ogr)
-  \return 0 on success
-  \return -1 on error
-int V2__delete_line(struct Map_info *Map, int line, int (*fn_delete) (struct Map_info *, off_t))
-    int ret, i, side, type, first, next_line, area;
-    struct P_line *Line;
-    struct Plus_head *plus;
-    struct bound_box box, abox;
-    int adjacent[4], n_adjacent;
-    G_debug(3, "V2__delete_line(), line = %d", line);
-    type = first = n_adjacent = 0;
-    Line = NULL;
-    plus = &(Map->plus);
-    if (plus->built >= GV_BUILD_BASE) {
-	Line = Map->plus.Line[line];
-	if (Line == NULL)
-	    G_fatal_error(_("Attempt to delete dead feature"));
-	type = Line->type;
-    if (!Cats) {
-    /* Update category index */
-    if (plus->update_cidx) {
-	type = V2_read_line_nat(Map, NULL, Cats, line);
-	    dig_cidx_del_cat(plus, Cats->field[i], Cats->cat[i], line, type);
-    /* delete the line from coor */
-    ret = fn_delete(Map, Line->offset);
-    if (ret == -1) {
-	return ret;
-    /* Update topology */
-    if (plus->built >= GV_BUILD_AREAS && type == GV_BOUNDARY) {
-	/* Store adjacent boundaries at nodes (will be used to rebuild area/isle) */
-	/* Adjacent are stored: > 0 - we want right side; < 0 - we want left side */
-	n_adjacent = 0;
-	next_line = dig_angle_next_line(plus, line, GV_RIGHT, GV_BOUNDARY);
-	if (next_line != 0 && abs(next_line) != line) {
-	    /* N1, to the right -> we want the right side for > 0  and left for < 0 */
-	    adjacent[n_adjacent] = next_line;
-	    n_adjacent++;
-	next_line = dig_angle_next_line(plus, line, GV_LEFT, GV_BOUNDARY);
-	    /* N1, to the left -> we want the left side for > 0  and right for < 0 */
-	    adjacent[n_adjacent] = -next_line;
-	    n_adjacent++;
-	next_line = dig_angle_next_line(plus, -line, GV_RIGHT, GV_BOUNDARY);
-	    /* N2, to the right -> we want the right side for > 0  and left for < 0 */
-	    n_adjacent++;
-	next_line = dig_angle_next_line(plus, -line, GV_LEFT, GV_BOUNDARY);
-	    /* N2, to the left -> we want the left side for > 0  and right for < 0 */
-	    n_adjacent++;
-	/* Delete area(s) and islands this line forms */
-	first = 1;
-	if (Line->left > 0) {	/* delete area */
-	    Vect_get_area_box(Map, Line->left, &box);
-	    if (first) {
-		Vect_box_copy(&abox, &box);
-		first = 0;
-	    else
-		Vect_box_extend(&abox, &box);
-		Vect__delete_area_cats_from_cidx(Map, Line->left);
-	    dig_del_area(plus, Line->left);
-	else if (Line->left < 0) {	/* delete isle */
-	    dig_del_isle(plus, -Line->left);
-	if (Line->right > 0) {	/* delete area */
-	    Vect_get_area_box(Map, Line->right, &box);
-	    if (first) {
-		first = 0;
-	    else
-		Vect__delete_area_cats_from_cidx(Map, Line->right);
-	    dig_del_area(plus, Line->right);
-	else if (Line->right < 0) {	/* delete isle */
-	    dig_del_isle(plus, -Line->right);
-    /* Delete reference from area */
-    if (plus->built >= GV_BUILD_CENTROIDS && type == GV_CENTROID) {
-	    G_debug(3, "Remove centroid %d from area %d", line, Line->left);
-	    Area = Map->plus.Area[Line->left];
-	    Area->centroid = 0;
-    /* delete the line from topo */
-    dig_del_line(plus, line);
-    /* Rebuild areas/isles and attach centroids and isles */
-	int *new_areas, nnew_areas;
-	nnew_areas = 0;
-	new_areas = (int *)G_malloc(2 * n_adjacent * sizeof(int));
-	/* Rebuild areas/isles */
-	for (i = 0; i < n_adjacent; i++) {
-	    if (adjacent[i] > 0)
-		side = GV_RIGHT;
-	    else
-		side = GV_LEFT;
-	    G_debug(3, "Build area for line = %d, side = %d", adjacent[i],
-		    side);
-	    area = Vect_build_line_area(Map, abs(adjacent[i]), side);
-	    if (area > 0) {	/* area */
-		Vect_get_area_box(Map, area, &box);
-		if (first) {
-		    first = 0;
-		else
-		new_areas[nnew_areas] = area;
-		nnew_areas++;
-	    else if (area < 0) {
-		/* isle -> must be attached -> add to abox */
-		Vect_get_isle_box(Map, -area, &box);
-		if (first) {
-		    first = 0;
-		else
-	/* Reattach all centroids/isles in deleted areas + new area.
-	 *  Because isles are selected by box it covers also possible new isle created above */
-	if (!first) {		/* i.e. old area/isle was deleted or new one created */
-	    /* Reattache isles */
-	    if (plus->built >= GV_BUILD_ATTACH_ISLES)
-		Vect_attach_isles(Map, &abox);
-	    /* Reattach centroids */
-	    if (plus->built >= GV_BUILD_CENTROIDS)
-		Vect_attach_centroids(Map, &abox);
-	    for (i = 0; i < nnew_areas; i++) {
-		Vect__add_area_cats_to_cidx(Map, new_areas[i]);
-    G_debug(3, "updated lines : %d , updated nodes : %d", plus->n_uplines,
-	    plus->n_upnodes);
-    return ret;
-  \brief Add line to topo file
-  Update areas. Areas are modified if:
-  1) first or/and last point are existing nodes ->
-   - drop areas/islands whose boundaries are neighbour to this boundary at these nodes
-   - try build areas and islands for this boundary and neighbour boundaries going through these nodes
-   Question: may be by adding line created new area/isle which doesn't go through nodes of this line
-   <pre>
-             old         new line
-         | A1 | A2 |  +      /      ->  | A1 |   /|   or +   \   -> | A1 | A2 | \
-           I1   I1                        I1   I1
-   </pre>
-   - reattache all centroids/isles inside new area(s)
-   - attach new isle to area outside
-  2) line is closed ring (node at the end is new, so it is not case above)
-    - build new area/isle
-    - check if it is island or contains island(s)
-    - re-attach all centroids/isles inside new area(s)
-    Note that 1) and 2) is done by the same code.
-void Vect__add_line_to_topo(struct Map_info *Map, int line,
-			    const struct line_pnts *points, const struct line_cats *cats)
-    int first, s, n, i;
-    int type, node, next_line, area, side, sel_area, new_area[2];
-    struct P_line *Line, *NLine;
-    struct P_node *Node;
-    Line = plus->Line[line];
-    if (plus->built >= GV_BUILD_AREAS) {
-	if (type == GV_BOUNDARY) {
-	    /* Delete neighbour areas/isles */
-	    first = 1;
-	    for (s = 1; s < 3; s++) {	/* for each node */
-		if (s == 1)
-		    node = Line->N1;	/* Node 1 */
-		else
-		    node = Line->N2;
-		G_debug(3,
-			"  delete neighbour areas/iseles: side = %d node = %d",
-			s, node);
-		Node = plus->Node[node];
-		n = 0;
-		for (i = 0; i < Node->n_lines; i++) {
-		    NLine = plus->Line[abs(Node->lines[i])];
-		    if (NLine->type == GV_BOUNDARY)
-			n++;
-		G_debug(3, "  number of boundaries at node = %d", n);
-		if (n > 2) {	/* more than 2 boundaries at node ( >= 2 old + 1 new ) */
-		    /* Line above (to the right), it is enough to check to the right, because if area/isle
-		     *  exists it is the same to the left */
-		    if (s == 1)
-			next_line =
-			    dig_angle_next_line(plus, line, GV_RIGHT,
-						GV_BOUNDARY);
-		    else
-			next_line =
-			    dig_angle_next_line(plus, -line, GV_RIGHT,
-						GV_BOUNDARY);
-		    if (next_line != 0) {	/* there is a boundary to the right */
-			NLine = plus->Line[abs(next_line)];
-			if (next_line > 0)	/* the boundary is connected by 1. node */
-			    area = NLine->right;	/* we are interested just in this side (close to our line) */
-			else if (next_line < 0)	/* the boundary is connected by 2. node */
-			    area = NLine->left;
-			G_debug(3, "  next_line = %d area = %d", next_line,
-				area);
-			if (area > 0) {	/* is area */
-			    if (first) {
-				first = 0;
-			    else
-				Vect__delete_area_cats_from_cidx(Map, area);
-			    dig_del_area(plus, area);
-			else if (area < 0) {	/* is isle */
-			    dig_del_isle(plus, -area);
-	    /* Build new areas/isles. Thas true that we deleted also adjacent areas/isles, but if
-	     *  they form new one our boundary must participate, so we need to build areas/isles
-	     *  just for our boundary */
-		if (s == 1)
-		    side = GV_LEFT;
-		else
-		    side = GV_RIGHT;
-		G_debug(3, "  build area/isle on side = %d", side);
-		G_debug(3, "Build area for line = %d, side = %d", line, side);
-		area = Vect_build_line_area(Map, line, side);
-		    if (first) {
-			first = 0;
-		    else
-		    if (first) {
-			first = 0;
-		    else
-		new_area[s - 1] = area;
-	    /* Add to category index */
-		    if (new_area[s - 1] > 0) {
-			Vect__add_area_cats_to_cidx(Map, new_area[s - 1]);
-    /* Attach centroid */
-    if (plus->built >= GV_BUILD_CENTROIDS) {
-	if (type == GV_CENTROID) {
-	    sel_area = Vect_find_area(Map, points->x[0], points->y[0]);
-	    G_debug(3, "  new centroid %d is in area %d", line, sel_area);
-	    if (sel_area > 0) {
-		Area = plus->Area[sel_area];
-		if (Area->centroid == 0) {	/* first centroid */
-		    G_debug(3, "  first centroid -> attach to area");
-		    Area->centroid = line;
-		    Line->left = sel_area;
-			Vect__add_area_cats_to_cidx(Map, sel_area);
-		else {		/* duplicate centroid */
-		    G_debug(3,
-			    "  duplicate centroid -> do not attach to area");
-		    Line->left = -sel_area;
-    /* Add cetegory index */
-    for (i = 0; i < cats->n_cats; i++) {
-	dig_cidx_add_cat_sorted(plus, cats->field[i], cats->cat[i], line,
-				type);
-    return;
-  \brief Writes feature to 'coor' file (topology level) - internal use only
-  \param type feature type
-  \param points feature geometry
-  \param cats feature categories
-  \return new feature id
-off_t V2__write_line(struct Map_info *Map,
-		     int type, const struct line_pnts *points, const struct line_cats *cats,
-    int line;
-    off_t offset;
-    struct bound_box box;
-    line = 0;
-    G_debug(3, "V2__write_line()");
-    offset = write_fn(Map, type, points, cats);
-    if (offset < 0)
-	return -1;
-    /* Add line */
-	line = dig_add_line(plus, type, points, offset);
-	G_debug(3, "  line added to topo with id = %d", line);
-	dig_line_box(points, &box);
-	dig_line_set_box(plus, line, &box);
-	if (line == 1)
-	    Vect_box_copy(&(plus->box), &box);
-	else
-	    Vect_box_extend(&(plus->box), &box);
-    Vect__add_line_to_topo(Map,
-			   line, points, cats);
-	    plus->n_upnodes);
-    /* returns int line, but is defined as off_t for compatibility with
-     * Write_line_array in write.c */
-    return line;
    \brief Writes new feature to the end of file
+   Vector map topology is not required.
    The function calls G_fatal_error() on error.
    \param Map pointer to vector map
@@ -681,7 +159,7 @@
     offset =
-	(*Write_line_array[Map->format][Map->level]) (Map, type, points,
+	(*Vect_write_line_array[Map->format][Map->level]) (Map, type, points,
 						      cats);
     if (offset == -1)
@@ -691,10 +169,11 @@
     return offset;
    \brief Rewrites feature info at the given offset.
+   Vector map must be opened with full topology (level 2).
    The number of points or cats or type may change. If necessary, the
    old feature is deleted and new is written.
@@ -706,15 +185,15 @@
+   \return feature offset
    \return -1 on error
-int
+off_t
 Vect_rewrite_line(struct Map_info *Map,
 		  int line,
 		  int type, const struct line_pnts *points, const struct line_cats *cats)
-    long ret;
+    off_t ret, offset;
     G_debug(3, "Vect_rewrite_line(): name = %s, line = %d", Map->name, line);
@@ -727,8 +206,9 @@
 	Map->plus.cidx_up_to_date = 0;
+    offset = Map->plus.Line[line]->offset;
     ret =
-	(*Vect_rewrite_line_array[Map->format][Map->level]) (Map, line, type,
+	(*Vect_rewrite_line_array[Map->format][Map->level]) (Map, offset, line, type,
 							     points, cats);
     if (ret == -1)
@@ -740,7 +220,7 @@
    \brief Delete feature
-   Vector map must be opened on topo level 2.
    This function calls G_fatal_error() on error.
@@ -786,12 +266,12 @@
    \brief Restore previously deleted feature
-   \param line feature id to be deleted
+   \param line feature id to be restored
    \return -1 on error
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2010-05-02 17:34:38 UTC (rev 42078)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2010-05-03 08:06:52 UTC (rev 42079)
@@ -30,10 +30,281 @@
 #include <grass/vector.h>
 #include <grass/glocale.h>
-static off_t rewrite_line_nat(struct Map_info *, off_t, int,
+static off_t V1__rewrite_line_nat(struct Map_info *, off_t, int,
+  \brief Deletes area (i.e. centroid) categories from category
+  index (internal use only)
+  \param Map pointer to Map_info structure
+  \param area area id
+static void V2__delete_area_cats_from_cidx_nat(struct Map_info *Map, int area)
+    int i;
+    struct P_area *Area;
+    static struct line_cats *Cats = NULL;
+    G_debug(3, "V2__delete_area_cats_from_cidx_nat(), area = %d", area);
+    Area = Map->plus.Area[area];
+    if (!Area)
+	G_fatal_error(_("%s: Area %d does not exist"),
+		      "delete_area_cats_from_cidx()", area);
+    if (Area->centroid == 0) /* no centroid found */
+	return;
+    if (!Cats)
+	Cats = Vect_new_cats_struct();
+    V2_read_line_nat(Map, NULL, Cats, Area->centroid);
+    for (i = 0; i < Cats->n_cats; i++) {
+	dig_cidx_del_cat(&(Map->plus), Cats->field[i], Cats->cat[i], area,
+			 GV_AREA);
+  \brief Adds area (i.e. centroid) categories from category index
+  (internal use only)
+static void V2__add_area_cats_to_cidx_nat(struct Map_info *Map, int area)
+    int i;
+    G_debug(3, "V2__add_area_cats_to_cidx_nat(), area = %d", area);
+    if (!Area)
+		      "add_area_cats_to_cidx():", area);
+	return;
+    if (!Cats)
+	dig_cidx_add_cat_sorted(&(Map->plus), Cats->field[i], Cats->cat[i],
+				area, GV_AREA);
+  \brief Add line to topo file
+  Update areas. Areas are modified if:
+  1) first or/and last point are existing nodes ->
+   - drop areas/islands whose boundaries are neighbour to this boundary at these nodes
+   - try build areas and islands for this boundary and neighbour boundaries going through these nodes
+   Question: may be by adding line created new area/isle which doesn't go through nodes of this line
+   <pre>
+             old         new line
+         | A1 | A2 |  +      /      ->  | A1 |   /|   or +   \   -> | A1 | A2 | \
+           I1   I1                        I1   I1
+   </pre>
+   - reattache all centroids/isles inside new area(s)
+   - attach new isle to area outside
+  2) line is closed ring (node at the end is new, so it is not case above)
+    - build new area/isle
+    - check if it is island or contains island(s)
+    - re-attach all centroids/isles inside new area(s)
+    Note that 1) and 2) is done by the same code.
+static void V2__add_line_to_topo_nat(struct Map_info *Map, int line,
+			    const struct line_pnts *points, const struct line_cats *cats)
+    int first, s, n, i;
+    int type, node, next_line, area, side, sel_area, new_area[2];
+    struct Plus_head *plus;
+    struct P_line *Line, *NLine;
+    struct P_node *Node;
+    struct bound_box box, abox;
+    G_debug(3, "V2__add_line_to_topo_nat(), line = %d", line);
+    plus = &(Map->plus);
+    Line = plus->Line[line];
+    type = Line->type;
+    if (plus->built >= GV_BUILD_AREAS) {
+	if (type == GV_BOUNDARY) {
+	    /* Delete neighbour areas/isles */
+	    first = 1;
+	    for (s = 1; s < 3; s++) {	/* for each node */
+		if (s == 1)
+		    node = Line->N1;	/* Node 1 */
+		else
+		    node = Line->N2;
+		G_debug(3,
+			"  delete neighbour areas/iseles: side = %d node = %d",
+			s, node);
+		Node = plus->Node[node];
+		n = 0;
+		for (i = 0; i < Node->n_lines; i++) {
+		    NLine = plus->Line[abs(Node->lines[i])];
+		    if (NLine->type == GV_BOUNDARY)
+			n++;
+		G_debug(3, "  number of boundaries at node = %d", n);
+		if (n > 2) {	/* more than 2 boundaries at node ( >= 2 old + 1 new ) */
+		    /* Line above (to the right), it is enough to check to the right, because if area/isle
+		     *  exists it is the same to the left */
+		    if (s == 1)
+			next_line =
+			    dig_angle_next_line(plus, line, GV_RIGHT,
+						GV_BOUNDARY);
+		    else
+			next_line =
+			    dig_angle_next_line(plus, -line, GV_RIGHT,
+						GV_BOUNDARY);
+		    if (next_line != 0) {	/* there is a boundary to the right */
+			NLine = plus->Line[abs(next_line)];
+			if (next_line > 0)	/* the boundary is connected by 1. node */
+			    area = NLine->right;	/* we are interested just in this side (close to our line) */
+			else if (next_line < 0)	/* the boundary is connected by 2. node */
+			    area = NLine->left;
+			G_debug(3, "  next_line = %d area = %d", next_line,
+				area);
+			if (area > 0) {	/* is area */
+			    Vect_get_area_box(Map, area, &box);
+			    if (first) {
+				Vect_box_copy(&abox, &box);
+				first = 0;
+			    else
+				Vect_box_extend(&abox, &box);
+			    if (plus->update_cidx) {
+				V2__delete_area_cats_from_cidx_nat(Map, area);
+			    dig_del_area(plus, area);
+			else if (area < 0) {	/* is isle */
+			    dig_del_isle(plus, -area);
+	    /* Build new areas/isles. Thas true that we deleted also adjacent areas/isles, but if
+	     *  they form new one our boundary must participate, so we need to build areas/isles
+	     *  just for our boundary */
+		if (s == 1)
+		    side = GV_LEFT;
+		else
+		    side = GV_RIGHT;
+		G_debug(3, "  build area/isle on side = %d", side);
+		G_debug(3, "Build area for line = %d, side = %d", line, side);
+		area = Vect_build_line_area(Map, line, side);
+		if (area > 0) {	/* area */
+		    if (first) {
+			first = 0;
+		    else
+		    /* isle -> must be attached -> add to abox */
+		    Vect_get_isle_box(Map, -area, &box);
+		    if (first) {
+			first = 0;
+		    else
+		new_area[s - 1] = area;
+	    /* Reattach all centroids/isles in deleted areas + new area.
+	     *  Because isles are selected by box it covers also possible new isle created above */
+	    if (!first) {	/* i.e. old area/isle was deleted or new one created */
+		/* Reattache isles */
+		if (plus->built >= GV_BUILD_ATTACH_ISLES)
+		    Vect_attach_isles(Map, &abox);
+		/* Reattach centroids */
+		if (plus->built >= GV_BUILD_CENTROIDS)
+		    Vect_attach_centroids(Map, &abox);
+	    /* Add to category index */
+		    if (new_area[s - 1] > 0) {
+			V2__add_area_cats_to_cidx_nat(Map, new_area[s - 1]);
+    /* Attach centroid */
+    if (plus->built >= GV_BUILD_CENTROIDS) {
+	if (type == GV_CENTROID) {
+	    sel_area = Vect_find_area(Map, points->x[0], points->y[0]);
+	    G_debug(3, "  new centroid %d is in area %d", line, sel_area);
+	    if (sel_area > 0) {
+		Area = plus->Area[sel_area];
+		if (Area->centroid == 0) {	/* first centroid */
+		    G_debug(3, "  first centroid -> attach to area");
+		    Area->centroid = line;
+		    Line->left = sel_area;
+			V2__add_area_cats_to_cidx_nat(Map, sel_area);
+		else {		/* duplicate centroid */
+		    G_debug(3,
+			    "  duplicate centroid -> do not attach to area");
+		    Line->left = -sel_area;
+    /* Add category index */
+    for (i = 0; i < cats->n_cats; i++) {
+	dig_cidx_add_cat_sorted(plus, cats->field[i], cats->cat[i], line,
+				type);
+    return;
   \brief Writes feature to 'coor' file (level 1)
@@ -56,11 +327,11 @@
     if (offset == -1)
 	return -1;
-    return rewrite_line_nat(Map, offset, type, points, cats);
+    return V1__rewrite_line_nat(Map, offset, type, points, cats);
+  \brief Writes feature to 'coor' file (topology level) - internal use only
@@ -70,10 +341,44 @@
   \return -1 on error
-off_t V2_write_line_nat(struct Map_info *Map,
-			int type, const struct line_pnts *points, const struct line_cats *cats)
+off_t V2_write_line_nat(struct Map_info *Map, int type,
-    return V2__write_line(Map, type, points, cats, V1_write_line_nat);
+    int line;
+    off_t offset;
+    struct bound_box box;
+    line = 0;
+    G_debug(3, "V2_write_line_nat()");
+    offset = V1_write_line_nat(Map, type, points, cats);
+    if (offset < 0)
+	return -1;
+    /* Update topology */
+    /* Add line */
+    if (plus->built >= GV_BUILD_BASE) {
+	line = dig_add_line(plus, type, points, offset);
+	G_debug(3, "  line added to topo with id = %d", line);
+	dig_line_box(points, &box);
+	dig_line_set_box(plus, line, &box);
+	if (line == 1)
+	    Vect_box_copy(&(plus->box), &box);
+	else
+	    Vect_box_extend(&(plus->box), &box);
+    V2__add_line_to_topo_nat(Map, line, points, cats);
+    G_debug(3, "updated lines : %d , updated nodes : %d", plus->n_uplines,
+	    plus->n_upnodes);
+    /* returns int line, but is defined as off_t for compatibility with
+     * Vect_write_line_array in write.c */
+    return line;
@@ -95,9 +400,7 @@
   \return feature offset (rewriten feature)
   \return -1 on error
-off_t V1_rewrite_line_nat(struct Map_info *Map,
-			  off_t offset,
-			  int type,
+off_t V1_rewrite_line_nat(struct Map_info *Map, int line, int type, off_t offset,
     int old_type;
@@ -105,6 +408,8 @@
     struct line_cats *old_cats;
     off_t new_offset;
+    G_debug(3, "V1_rewrite_line_nat(), offset = %lu", (unsigned long) offset);
     /* TODO: enable points and cats == NULL  */
     /* First compare numbers of points and cats with tha old one */
@@ -122,7 +427,7 @@
 	    || ((type & GV_LINES) && (old_type & GV_LINES)))) {
 	/* equal -> overwrite the old */
     else {
 	/* differ -> delete the old and append new */
@@ -137,28 +442,24 @@
 	if (new_offset == -1)
 	    return -1;
-	return rewrite_line_nat(Map, new_offset, type, points, cats);
+	return V1__rewrite_line_nat(Map, new_offset, type, points, cats);
-  \brief Rewrites feature (topology level)
-  Old feature is deleted (marked as dead), new feature written.
+  \brief Rewrites feature to 'coor' file (topology level) - internal use only
+  \param type feature type
-  \param cats feature category
+  \param cats feature categories
+  \return offset where line was rewritten
   \return -1 on error
-int V2_rewrite_line_nat(struct Map_info *Map,
-			int line,
-			int type,
+off_t V2_rewrite_line_nat(struct Map_info *Map, int line, int type, off_t old_offset,
     /* TODO: this is just quick shortcut because we have already V2_delete_nat()
      *        and V2_write_nat() this function first deletes old line
@@ -166,9 +467,40 @@
      *        and cats was not changed or topology is not changed (nodes not moved,
      *        angles not changed etc.) */
+    off_t offset;
     V2_delete_line_nat(Map, line);
+    G_debug(3, "V2_write_line_nat(), line = %d", line);
+    offset = V1_rewrite_line_nat(Map, line, type, old_offset, points, cats);
+    if (offset < 0)
+	return -1;
-    return (V2_write_line_nat(Map, type, points, cats));
+    /* Add line */
+	if (line == 1)
+	else
+	    plus->n_upnodes);
+     * Vect_rewrite_line_array in write.c */
+    return line;
@@ -183,7 +515,7 @@
   \return -1 on error
-off_t rewrite_line_nat(struct Map_info *Map,
+off_t V1__rewrite_line_nat(struct Map_info *Map,
 		       off_t offset,
 		       int type,
@@ -312,7 +644,7 @@
-  \brief Deletes feature (topology level).
+  \brief Deletes feature (topology level) -- internal use only
@@ -320,9 +652,196 @@
   \return -1 on error
-int V2_delete_line_nat(struct Map_info *Map, int line)
+int V2_delete_line_nat(struct Map_info *Map, off_t line)
-    return V2__delete_line(Map, line, V1_delete_line_nat);
+    int ret, i, side, type, first, next_line, area;
+    struct P_line *Line;
+    int adjacent[4], n_adjacent;
+    G_debug(3, "V2_delete_line_nat(), line = %lu", (unsigned long) line);
+    type = first = n_adjacent = 0;
+    Line = NULL;
+	Line = Map->plus.Line[line];
+	if (Line == NULL)
+	    G_fatal_error(_("Attempt to delete dead feature"));
+    if (!Cats) {
+    /* Update category index */
+	type = V2_read_line_nat(Map, NULL, Cats, line);
+	    dig_cidx_del_cat(plus, Cats->field[i], Cats->cat[i], line, type);
+    /* delete the line from coor */
+    ret = V1_delete_line_nat(Map, Line->offset);
+    if (ret == -1) {
+	return ret;
+    if (plus->built >= GV_BUILD_AREAS && type == GV_BOUNDARY) {
+	/* Store adjacent boundaries at nodes (will be used to rebuild area/isle) */
+	/* Adjacent are stored: > 0 - we want right side; < 0 - we want left side */
+	n_adjacent = 0;
+	next_line = dig_angle_next_line(plus, line, GV_RIGHT, GV_BOUNDARY);
+	if (next_line != 0 && abs(next_line) != line) {
+	    /* N1, to the right -> we want the right side for > 0  and left for < 0 */
+	    adjacent[n_adjacent] = next_line;
+	    n_adjacent++;
+	next_line = dig_angle_next_line(plus, line, GV_LEFT, GV_BOUNDARY);
+	    /* N1, to the left -> we want the left side for > 0  and right for < 0 */
+	    adjacent[n_adjacent] = -next_line;
+	    n_adjacent++;
+	next_line = dig_angle_next_line(plus, -line, GV_RIGHT, GV_BOUNDARY);
+	    /* N2, to the right -> we want the right side for > 0  and left for < 0 */
+	    n_adjacent++;
+	next_line = dig_angle_next_line(plus, -line, GV_LEFT, GV_BOUNDARY);
+	    /* N2, to the left -> we want the left side for > 0  and right for < 0 */
+	    n_adjacent++;
+	/* Delete area(s) and islands this line forms */
+	first = 1;
+	if (Line->left > 0) {	/* delete area */
+	    Vect_get_area_box(Map, Line->left, &box);
+	    if (first) {
+		first = 0;
+	    else
+		V2__delete_area_cats_from_cidx_nat(Map, Line->left);
+	    dig_del_area(plus, Line->left);
+	else if (Line->left < 0) {	/* delete isle */
+	    dig_del_isle(plus, -Line->left);
+	if (Line->right > 0) {	/* delete area */
+	    Vect_get_area_box(Map, Line->right, &box);
+	    if (first) {
+		first = 0;
+	    else
+		V2__delete_area_cats_from_cidx_nat(Map, Line->right);
+	    dig_del_area(plus, Line->right);
+	else if (Line->right < 0) {	/* delete isle */
+	    dig_del_isle(plus, -Line->right);
+    /* Delete reference from area */
+    if (plus->built >= GV_BUILD_CENTROIDS && type == GV_CENTROID) {
+	    G_debug(3, "Remove centroid %d from area %d", (int) line, Line->left);
+	    Area = Map->plus.Area[Line->left];
+	    Area->centroid = 0;
+    /* delete the line from topo */
+    dig_del_line(plus, line);
+    /* Rebuild areas/isles and attach centroids and isles */
+	int *new_areas, nnew_areas;
+	nnew_areas = 0;
+	new_areas = (int *)G_malloc(2 * n_adjacent * sizeof(int));
+	/* Rebuild areas/isles */
+	for (i = 0; i < n_adjacent; i++) {
+	    if (adjacent[i] > 0)
+		side = GV_RIGHT;
+	    else
+		side = GV_LEFT;
+	    G_debug(3, "Build area for line = %d, side = %d", adjacent[i],
+		    side);
+	    area = Vect_build_line_area(Map, abs(adjacent[i]), side);
+		if (first) {
+		    first = 0;
+		else
+		new_areas[nnew_areas] = area;
+		nnew_areas++;
+		if (first) {
+		    first = 0;
+		else
+	    for (i = 0; i < nnew_areas; i++) {
+		V2__add_area_cats_to_cidx_nat(Map, new_areas[i]);
+	    plus->n_upnodes);
+    return ret;
@@ -438,12 +957,11 @@
 	    plus->n_upnodes);
     return ret;
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c	2010-05-02 17:34:38 UTC (rev 42078)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c	2010-05-03 08:06:52 UTC (rev 42079)
@@ -26,6 +26,22 @@
 static int write_attributes(int, const struct field_info *,
 			    OGRLayerH, OGRFeatureH);
+/* TODO:
+ * OGR version of V2__delete_area_cats_from_cidx_nat()
+ * function to delete corresponding entry in fidx
+ * OGR version of V2__add_area_cats_to_cidx_nat
+ * OGR version of V2__add_line_to_topo_nat
+void V2__add_line_to_topo_ogr(struct Map_info *Map, int line,
+   /* recycle code from build_ogr */
+    G_warning("feature not yet implemented, coming soon...");
+    return;
   \brief Writes feature on level 1
@@ -53,11 +69,16 @@
 	return -1;
-    /* determine feature's geometry */
-    if (type & (GV_POINTS | GV_KERNEL)) {
+    /* determine matching OGR feature geometry type */
+    /* NOTE: centroids are not supported in OGR,
+     *       pseudotopo holds virtual centroids */
+    /* NOTE: boundaries are not supported in OGR,
+     *       pseudotopo treats polygons as boundaries */
+    if (type & (GV_POINT | GV_KERNEL)) {
 	Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
-    else if (type & GV_LINES) {
+    else if (type & GV_LINE) {
 	Ogr_geometry = OGR_G_CreateGeometry(wkbLineString);
     else if (type & GV_FACE) {
@@ -116,24 +137,97 @@
     return Map->fInfo.ogr.offset_num++;
+off_t V2_write_line_ogr(struct Map_info *Map, int type,
+    int line;
+    off_t offset;
+    line = 0;
+    offset = V1_write_line_ogr(Map, type, points, cats);
+    if (offset < 0)
+	return -1;
+    /* Add line */
+	if (line == 1)
+	else
+	V2__add_line_to_topo_ogr(Map, line, points, cats);
+	    plus->n_upnodes);
+     * Write_line_array in write.c */
+    return line;
-  \brief Writes feature (topology level)
+  \brief Rewrites feature at the given offset (level 1)
+  \param offset feature offset
+  \return feature offset (rewriten feature)
   \return -1 on error
-off_t V2_write_line_ogr(struct Map_info *Map,
+off_t V1_rewrite_line_ogr(struct Map_info *Map,
+			  int line,
+			  int type,
+			  off_t offset,
-    return V2__write_line(Map, type, points, cats, V1_write_line_ogr);
+    if (type != V1_read_line_ogr(Map, NULL, NULL, offset)) {
+	G_warning(_("Unable to rewrite feature (incompatible feature types)"));
+	return -1;
+    /* delete old */
+    V1_delete_line_ogr(Map, offset);
+    return V1_write_line_ogr(Map, type, points, cats);
+  \param points feature geometry
+  \return -1 on error
+off_t V2_rewrite_line_ogr(struct Map_info *Map, int line, int type, off_t offset,
+    V2_delete_line_ogr(Map, line);
+    return (V2_write_line_ogr(Map, type, points, cats));
   \brief Deletes feature at the given offset (level 1)
   \param Map pointer Map_info structure
@@ -161,68 +255,77 @@
+  \param pointer to Map_info structure
   \return -1 on error
-int V2_delete_line_ogr(struct Map_info *Map, int line)
+int V2_delete_line_ogr(struct Map_info *Map, off_t line)
-    return V2__delete_line(Map, line, V1_delete_line_ogr);
-  \brief Rewrites feature at the given offset (level 1)
-  \param offset feature offset
-  \return feature offset (rewriten feature)
-off_t V1_rewrite_line_ogr(struct Map_info *Map,
-			  off_t offset,
-			  int type,
-    if (type != V1_read_line_ogr(Map, NULL, NULL, offset)) {
-	G_warning(_("Unable to rewrite feature (incompatible feature types)"));
-	return -1;
+    G_debug(3, "V2_delete_line_nat(), line = %d", (int) line);
+    Line = NULL;
+	if (Line == NULL)
-    /* delete old */
-    V1_delete_line_ogr(Map, offset);
+    if (!Cats) {
-    return V1_write_line_ogr(Map, type, points, cats);
+	type = V2_read_line_ogr(Map, NULL, Cats, line);
-int V2_rewrite_line_ogr(struct Map_info *Map,
-			int line,
-			int type,
-    /* delete old */
-    V2_delete_line_ogr(Map, line);
+    /* Update fidx */
-    return V2_write_line_ogr(Map, type, points, cats);
+    ret = V1_delete_line_ogr(Map, Line->offset);
+    if (ret == -1) {
+	return ret;
+	/* TODO */
+	/* remove centroid together with boundary (is really an OGR polygon) */
+	/* for OGR mapsets, virtual centroid will be removed when polygon is removed */
+	/* maybe not needed VERIFY */
+    return ret;
 int write_attributes(int cat, const struct field_info *Fi,
