[GRASS-SVN] r42088 - grass/trunk/raster/r.slope.aspect
svn_grass at osgeo.org
Mon May 3 11:07:39 EDT 2010
Author: martinl
Date: 2010-05-03 11:07:38 -0400 (Mon, 03 May 2010)
New Revision: 42088
grass/trunk/raster/r.slope.aspect/main.c
r.slope.aspect: more gui sections
(merge r42086 from devbr6)
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c 2010-05-03 15:00:35 UTC (rev 42087)
+++ grass/trunk/raster/r.slope.aspect/main.c 2010-05-03 15:07:38 UTC (rev 42088)
@@ -15,7 +15,7 @@
* PURPOSE: generates raster maps of slope, aspect, curvatures and
* first and second order partial derivatives from a raster map
* of true elevation values
- * COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2006, 2010 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -150,29 +150,24 @@
module = G_define_module();
G_add_keyword(_("raster"));
- G_add_keyword(_("terrain analysis"));
- module->description =
- _("Generates raster map layers of slope, aspect, curvatures and "
- "partial derivatives from a raster map layer of true elevation "
- "values. Aspect is calculated counterclockwise from east.");
+ G_add_keyword(_("terrain"));
+ module->label = _("Generates raster maps of slope, aspect, curvatures and "
+ "partial derivatives from a elevation raster map.");
+ module->description = _("Aspect is calculated counterclockwise from east.");
parm.elevation = G_define_standard_option(G_OPT_R_ELEV);
- parm.slope = G_define_option();
+ parm.slope = G_define_standard_option(G_OPT_R_OUTPUT);
parm.slope->key = "slope";
- parm.slope->type = TYPE_STRING;
parm.slope->required = NO;
- parm.slope->answer = NULL;
- parm.slope->gisprompt = "new,cell,raster";
parm.slope->description = _("Name for output slope raster map");
+ parm.slope->guisection = _("Outputs");
- parm.aspect = G_define_option();
+ parm.aspect = G_define_standard_option(G_OPT_R_OUTPUT);
parm.aspect->key = "aspect";
- parm.aspect->type = TYPE_STRING;
parm.aspect->required = NO;
- parm.aspect->answer = NULL;
- parm.aspect->gisprompt = "new,cell,raster";
parm.aspect->description = _("Name for output aspect raster map");
+ parm.aspect->guisection = _("Outputs");
parm.slope_fmt = G_define_option();
parm.slope_fmt->key = "format";
@@ -193,75 +188,54 @@
_("Type of output aspect and slope maps");
parm.out_precision->guisection = _("Settings");
- parm.pcurv = G_define_option();
+ parm.pcurv = G_define_standard_option(G_OPT_R_OUTPUT);
parm.pcurv->key = "pcurv";
- parm.pcurv->type = TYPE_STRING;
parm.pcurv->required = NO;
- parm.pcurv->answer = NULL;
- parm.pcurv->gisprompt = "new,cell,raster";
parm.pcurv->description =
_("Name for output profile curvature raster map");
- parm.pcurv->guisection = _("Advanced");
+ parm.pcurv->guisection = _("Outputs");
- parm.tcurv = G_define_option();
+ parm.tcurv = G_define_standard_option(G_OPT_R_OUTPUT);
parm.tcurv->key = "tcurv";
- parm.tcurv->type = TYPE_STRING;
parm.tcurv->required = NO;
- parm.tcurv->answer = NULL;
- parm.tcurv->gisprompt = "new,cell,raster";
parm.tcurv->description =
_("Name for output tangential curvature raster map");
- parm.tcurv->guisection = _("Advanced");
+ parm.tcurv->guisection = _("Outputs");
- parm.dx = G_define_option();
+ parm.dx = G_define_standard_option(G_OPT_R_OUTPUT);
parm.dx->key = "dx";
- parm.dx->type = TYPE_STRING;
parm.dx->required = NO;
- parm.dx->answer = NULL;
- parm.dx->gisprompt = "new,cell,raster";
parm.dx->description =
_("Name for output first order partial derivative dx (E-W slope) raster map");
- parm.dx->guisection = _("Advanced");
+ parm.dx->guisection = _("Outputs");
- parm.dy = G_define_option();
+ parm.dy = G_define_standard_option(G_OPT_R_OUTPUT);
parm.dy->key = "dy";
- parm.dy->type = TYPE_STRING;
parm.dy->required = NO;
- parm.dy->answer = NULL;
- parm.dy->gisprompt = "new,cell,raster";
parm.dy->description =
_("Name for output first order partial derivative dy (N-S slope) raster map");
- parm.dy->guisection = _("Advanced");
+ parm.dy->guisection = _("Outputs");
- parm.dxx = G_define_option();
+ parm.dxx = G_define_standard_option(G_OPT_R_OUTPUT);
parm.dxx->key = "dxx";
- parm.dxx->type = TYPE_STRING;
parm.dxx->required = NO;
- parm.dxx->answer = NULL;
- parm.dxx->gisprompt = "new,cell,raster";
parm.dxx->description =
_("Name for output second order partial derivative dxx raster map");
- parm.dxx->guisection = _("Advanced");
+ parm.dxx->guisection = _("Outputs");
- parm.dyy = G_define_option();
+ parm.dyy = G_define_standard_option(G_OPT_R_OUTPUT);
parm.dyy->key = "dyy";
- parm.dyy->type = TYPE_STRING;
parm.dyy->required = NO;
- parm.dyy->answer = NULL;
- parm.dyy->gisprompt = "new,cell,raster";
parm.dyy->description =
_("Name for output second order partial derivative dyy raster map");
- parm.dyy->guisection = _("Advanced");
+ parm.dyy->guisection = _("Outputs");
- parm.dxy = G_define_option();
+ parm.dxy = G_define_standard_option(G_OPT_R_OUTPUT);
parm.dxy->key = "dxy";
- parm.dxy->type = TYPE_STRING;
parm.dxy->required = NO;
- parm.dxy->answer = NULL;
- parm.dxy->gisprompt = "new,cell,raster";
parm.dxy->description =
_("Name for output second order partial derivative dxy raster map");
- parm.dxy->guisection = _("Advanced");
+ parm.dxy->guisection = _("Outputs");
parm.zfactor = G_define_option();
parm.zfactor->key = "zfactor";
