[GRASS-SVN] r42118 - grass/branches/develbranch_6/raster/r.out.gdal
svn_grass at osgeo.org
Wed May 5 09:16:46 EDT 2010
Author: mmetz
Date: 2010-05-05 09:16:45 -0400 (Wed, 05 May 2010)
New Revision: 42118
grass/branches/develbranch_6/raster/r.out.gdal/export_band.c
grass/branches/develbranch_6/raster/r.out.gdal/main.c
human-readable numbers
Modified: grass/branches/develbranch_6/raster/r.out.gdal/export_band.c
--- grass/branches/develbranch_6/raster/r.out.gdal/export_band.c 2010-05-05 13:08:23 UTC (rev 42117)
+++ grass/branches/develbranch_6/raster/r.out.gdal/export_band.c 2010-05-05 13:16:45 UTC (rev 42118)
@@ -180,10 +180,11 @@
G_percent(row + 1, rows, 2);
+ G_debug(1, "min %g max %g", dfCellMin, dfCellMax);
/* can the GDAL datatype hold the data range to be exported ? */
/* f-flag does not override */
- if (exact_range_check(export_datatype, dfCellMin, dfCellMax, name)) {
+ if (exact_range_check(dfCellMin, dfCellMax, export_datatype, name)) {
G_warning("Raster export results in data loss.");
ret = -2;
@@ -511,7 +512,7 @@
G_warning(_("GDAL datatype: %s, range: %d - %d"),
GDALGetDataTypeName(datatype), TYPE_BYTE_MIN,
TYPE_BYTE_MAX);
- G_warning(_("Raster map <%s> range: %f - %f"), name, min, max);
+ G_warning(_("Raster map <%s> range: %g - %g"), name, min, max);
return 1;
else
@@ -523,7 +524,7 @@
GDALGetDataTypeName(datatype), TYPE_UINT16_MIN,
TYPE_UINT16_MAX);
return 1;
else
@@ -536,7 +537,7 @@
GDALGetDataTypeName(datatype), TYPE_INT16_MIN,
TYPE_INT16_MAX);
return 1;
else
@@ -549,7 +550,7 @@
GDALGetDataTypeName(datatype), TYPE_INT32_MIN,
TYPE_INT32_MAX);
return 1;
else
@@ -561,7 +562,7 @@
G_warning(_("GDAL datatype: %s, range: %u - %u"),
GDALGetDataTypeName(datatype), TYPE_UINT32_MIN,
TYPE_UINT32_MAX);
return 1;
else
@@ -571,10 +572,10 @@
case GDT_CFloat32:
if (min < TYPE_FLOAT32_MIN || max > TYPE_FLOAT32_MAX) {
G_warning(_("Selected GDAL datatype does not cover data range."));
- G_warning(_("GDAL datatype: %s, range: %f - %f"),
+ G_warning(_("GDAL datatype: %s, range: %g - %g"),
GDALGetDataTypeName(datatype), TYPE_FLOAT32_MIN,
TYPE_FLOAT32_MAX);
return 1;
else
@@ -585,10 +586,10 @@
/* not possible because DCELL is FLOAT64, not 128bit floating point, but anyway... */
if (min < TYPE_FLOAT64_MIN || max > TYPE_FLOAT64_MAX) {
GDALGetDataTypeName(datatype), TYPE_FLOAT64_MIN,
TYPE_FLOAT64_MAX);
return 1;
else
Modified: grass/branches/develbranch_6/raster/r.out.gdal/main.c
--- grass/branches/develbranch_6/raster/r.out.gdal/main.c 2010-05-05 13:08:23 UTC (rev 42117)
+++ grass/branches/develbranch_6/raster/r.out.gdal/main.c 2010-05-05 13:16:45 UTC (rev 42118)
@@ -500,7 +500,7 @@
&cellhead, maptype, nodataval, nodataopt->key,
default_nodataval);
- /* nodata problem */
+ /* nodata value is present in the data to be exported */
if (retval == -1) {
if (flag_f->answer)
G_warning(_("Forcing raster export."));
@@ -692,7 +692,7 @@
TYPE_FLOAT32_MAX);
- G_warning(_("Range to be exported: %f - %f"), min, max);
+ G_warning(_("Range to be exported: %g - %g"), min, max);
return 1;
else
@@ -717,7 +717,7 @@
* accordingly below for the other GDAL types */
if (nodataval != (double)(GByte)(CELL) nodataval) {
G_warning(_("Mismatch between metadata nodata value and actual nodata value in exported raster: "
- "specified nodata value %f gets converted to %d by selected GDAL datatype."),
+ "specified nodata value %g gets converted to %d by selected GDAL datatype."),
nodataval, (GByte)(CELL) nodataval);
G_warning(_("GDAL datatype: %s, valid range: %d - %d"),
@@ -730,7 +730,7 @@
case GDT_UInt16:
if (nodataval != (double)(GUInt16)(CELL) nodataval) {
nodataval, (GUInt16)(CELL) nodataval);
G_warning(_("GDAL datatype: %s, valid range: %u - %u"),
@@ -744,7 +744,7 @@
case GDT_CInt16:
if (nodataval != (double)(GInt16)(CELL) nodataval) {
nodataval, (GInt16)(CELL) nodataval);
@@ -757,7 +757,7 @@
case GDT_UInt32:
if (nodataval != (double)(GUInt32)(DCELL) nodataval) {
nodataval, (GUInt32)(DCELL) nodataval);
@@ -772,7 +772,7 @@
/* GInt32 is equal to CELL, but that may change in the future */
if (nodataval != (double)(GInt32)(CELL) nodataval) {
nodataval, (GInt32)(CELL) nodataval);
@@ -786,7 +786,7 @@
case GDT_CFloat32:
if (nodataval != (double)(float) nodataval) {
- "specified nodata value %f gets converted to %f by selected GDAL datatype."),
+ "specified nodata value %g gets converted to %g by selected GDAL datatype."),
nodataval, (float) nodataval);
G_warning(_("GDAL datatype: %s, valid range: %g - %g"),
