[GRASS-SVN] r42138 - grass/trunk/lib/gis
svn_grass at osgeo.org
Thu May 6 03:38:46 EDT 2010
Author: huhabla
Date: 2010-05-06 03:38:44 -0400 (Thu, 06 May 2010)
New Revision: 42138
grass/trunk/lib/gis/parser_wps.c
XML creation enhancements.
Modified: grass/trunk/lib/gis/parser_wps.c
--- grass/trunk/lib/gis/parser_wps.c 2010-05-05 23:40:55 UTC (rev 42137)
+++ grass/trunk/lib/gis/parser_wps.c 2010-05-06 07:38:44 UTC (rev 42138)
@@ -106,7 +106,7 @@
* Multiple vector or raster map outputs marked as one option are not supported (wps 1.0.0 specification
* does not allow multiple outputs with only one identifier).
- * Multiple outputs must be wrapped via a python script.
+ * Multiple outputs must be wrapped via a python script or created as group.
* There is not support for optional outputs.
@@ -129,6 +129,7 @@
const char *abstract = NULL;
const char **keywords = NULL;
int data_type, is_input, is_output;
+ int num_raster_inputs = 0, num_raster_outputs = 0;
int min = 0, max = 0;
int num_keywords = 0;
int found_output = 0;
@@ -173,17 +174,6 @@
wps_print_process_description_begin(store, status, identifier, title, abstract, keywords, num_keywords);
wps_print_data_inputs_begin();
- /* We have two default options, which define the resolution of the created mapset */
- wps_print_literal_input_output(WPS_INPUT, 0, 1, "grass_resolution_ns", "Resolution of the mapset in north-south direction in [m] or [degrees]",
- "This parameter defines the north-south resolution of the mapset in meter or degrees, which should be used to process the input and output raster data. To enable this setting, you need to specify north-south and east-west resolution.",
- "float", 0, NULL, 0, "25", TYPE_OTHER);
- wps_print_literal_input_output(WPS_INPUT, 0, 1, "grass_resolution_ew", "Resolution of the mapset in east-west direction in [m] or [degrees]",
- "This parameter defines the east-west resolution of the mapset in meters or degrees, which should be used to process the input and output raster data. To enable this setting, you need to specify north-south and east-west resolution.",
- wps_print_literal_input_output(WPS_INPUT, 0, 1, "grass_band_number", "Band to select for processing (default is all bands)",
- "This parameter defines band number of the input raster files which should be processed. As default all bands are processed and used as single and multiple inputs for raster modules.",
- "integer", 0, NULL, 0, NULL, TYPE_OTHER);
/* Print the bounding box element with all the coordinate reference systems, which are supported by grass*/
/* Currently Disabled! A list of all proj4 supported EPSG coordinate reference systems must be implemented*/
if(1 == 0)
@@ -201,6 +191,7 @@
num_keywords = 0;
value = NULL;
is_input = 1;
+ is_output = 0;
data_type = TYPE_OTHER;
if (opt->gisprompt) {
@@ -213,11 +204,18 @@
char *token = G_store(s);
/* we print only input parameter, sort out the output parameter */
- if(strcmp(token, "new") == 0)
+ if(strcmp(token, "new") == 0) {
is_input = 0;
+ is_output = 1;
if(strcmp(token, "raster") == 0)
data_type = TYPE_RASTER;
+ /* Count the raster inputs and outputs for default option creation */
+ if(is_input == 1)
+ num_raster_inputs++;
+ if(is_output == 1)
+ num_raster_outputs++;
if(strcmp(token, "vector") == 0)
@@ -319,6 +317,21 @@
+ /* We have two default options, which define the resolution of the created mapset */
+ if(num_raster_inputs > 0 || num_raster_outputs > 0) {
+ wps_print_literal_input_output(WPS_INPUT, 0, 1, "grass_resolution_ns", "Resolution of the mapset in north-south direction in meters or degrees",
+ "This parameter defines the north-south resolution of the mapset in meter or degrees, which should be used to process the input and output raster data. To enable this setting, you need to specify north-south and east-west resolution.",
+ "float", 1, NULL, 0, "25", TYPE_OTHER);
+ wps_print_literal_input_output(WPS_INPUT, 0, 1, "grass_resolution_ew", "Resolution of the mapset in east-west direction in meters or degrees",
+ "This parameter defines the east-west resolution of the mapset in meters or degrees, which should be used to process the input and output raster data. To enable this setting, you need to specify north-south and east-west resolution.",
+ /* In case multi band raster maps should be imported, the band number must be provided */
+ if(num_raster_inputs > 0)
+ wps_print_literal_input_output(WPS_INPUT, 0, 1, "grass_band_number", "Band to select for processing (default is all bands)",
+ "This parameter defines band number of the input raster files which should be processed. As default all bands are processed and used as single and multiple inputs for raster modules.",
+ "integer", 0, NULL, 0, NULL, TYPE_OTHER);
/* End of inputs */
wps_print_data_inputs_end();
/* Start of the outputs */
@@ -445,10 +458,10 @@
if(abstract)
- fprintf(stdout,"\t\t<ows:Abstract>\n");
- fprintf(stdout, "\t\t\tThe manual page of this module is available here:\n");
- fprintf(stdout, "\t\t\thttp://grass.osgeo.org/grass70/manuals/html70_user/%s.html\n", identifier);
- fprintf(stdout, "\t\t</ows:Abstract>\n");
+ fprintf(stdout,"\t\t<ows:Abstract>");
+ fprintf(stdout, "The manual page of this module is available here: ");
+ fprintf(stdout, "http://grass.osgeo.org/grass70/manuals/html70_user/%s.html", identifier);
+ fprintf(stdout, "</ows:Abstract>\n");
for(i = 0; i < num_keywords; i++)
@@ -624,12 +637,13 @@
if(unitofmesure)
fprintf(stdout,"\t\t\t\t\t<UOMs>\n");
- fprintf(stdout,"\t\t\t\t\t<Default>\n");
- fprintf(stdout,"\t\t\t\t\t\t<ows:UOM>meters</ows:UOM>\n");
- fprintf(stdout,"\t\t\t\t\t</Default>\n");
- fprintf(stdout,"\t\t\t\t\t<Supported>\n");
- fprintf(stdout,"\t\t\t\t\t</Supported>\n");
+ fprintf(stdout,"\t\t\t\t\t\t<Default>\n");
+ fprintf(stdout,"\t\t\t\t\t\t\t<ows:UOM>meters</ows:UOM>\n");
+ fprintf(stdout,"\t\t\t\t\t\t</Default>\n");
+ fprintf(stdout,"\t\t\t\t\t\t<Supported>\n");
+ fprintf(stdout,"\t\t\t\t\t\t\t<ows:UOM>degrees</ows:UOM>\n");
+ fprintf(stdout,"\t\t\t\t\t\t</Supported>\n");
fprintf(stdout,"\t\t\t\t\t</UOMs>\n");
if(num_choices == 0 || choices == NULL)
