[GRASS-SVN] r42149 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Sat May 8 07:33:29 EDT 2010
Author: martinl
Date: 2010-05-08 07:33:29 -0400 (Sat, 08 May 2010)
New Revision: 42149
grass/trunk/scripts/g.extension/g.extension.py
g.extension: list available extension in full / shell style
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2010-05-08 11:28:34 UTC (rev 42148)
+++ grass/trunk/scripts/g.extension/g.extension.py 2010-05-08 11:33:29 UTC (rev 42149)
@@ -2,24 +2,25 @@
-# MODULE: g.extension.add
+# MODULE: g.extension
# AUTHOR(S): Markus Neteler
# Pythonized by Martin Landa
-# PURPOSE: tool to download and install extensions from GRASS Addons SVN into
+# PURPOSE: Tool to download and install extensions from GRASS Addons SVN into
# local GRASS installation
-# COPYRIGHT: (C) 2009 by the Markus Neteler, GRASS Development Team
+# COPYRIGHT: (C) 2009-2010 by Markus Neteler, and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
# TODO: add sudo support where needed (i.e. check first permission to write into
# $GISBASE directory)
#%module
-#% label: Tool to maintain GRASS extensions in local GRASS installation.
+#% label: Tool to maintain the extensions in local GRASS installation.
#% description: Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions.
+#% keywords: general
#% keywords: installation
#% keywords: extensions
#%end
@@ -34,7 +35,6 @@
#%option
#% key: operation
#% type: string
-#% key_desc: name
#% description: Operation to be performed
#% required: no
#% options: add,remove
@@ -46,7 +46,7 @@
#% key_desc: url
#% description: SVN Addons repository URL
#% required: yes
-#% answer: https://svn.osgeo.org/grass/grass-addons/grass7
+#% answer: https://svn.osgeo.org/grass/grass-addons
#%end
#%option
#% key: prefix
@@ -59,7 +59,6 @@
#%option
#% key: menuitem
#% type: string
-#% key_desc: name
#% label: Menu item in wxGUI
#% description: Given as string, e.g. 'Imagery;Filter image'
#% required: no
@@ -67,9 +66,19 @@
#%flag
#% key: l
-#% description: List available modules in the GRASS Addons SVN repository
+#% description: List available modules in the add-ons repository
#% guisection: Print
#%end
+#%flag
+#% key: f
+#% description: List available modules in the add-ons repository including modules description
+#% guisection: Print
+#%end
+#%flag
+#% key: g
+#% description: List available modules in the add-ons repository in shell script style
+#%end
import os
import sys
@@ -108,22 +117,129 @@
return c
-def list_available_modules(svnurl):
+def list_available_modules(svnurl, full = False, shell = False):
grass.message(_('Fetching list of modules from GRASS-Addons SVN (be patient)...'))
pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
- for d in ['d', 'db', 'g', 'i', 'ps',
- 'p', 'r', 'r3', 'v']:
+ i = 0
+ prefix = ['d', 'db', 'g', 'i', 'ps',
+ 'p', 'r', 'r3', 'v']
+ nprefix = len(prefix)
+ for d in prefix:
+ if shell:
+ grass.percent(i, nprefix, 1)
+ i += 1
modclass = expand_module_class_name(d)
url = svnurl + '/' + modclass
f = urllib.urlopen(url)
if not f:
grass.warning(_("Unable to fetch '%s'") % url)
continue
for line in f.readlines():
+ # list modules
sline = pattern.search(line)
if sline and sline.group(2).split('.', 1)[0] == d:
- print sline.group(2).rstrip('/')
+ name = sline.group(2).rstrip('/')
+ print_module_desc(name, url, full, shell)
+ if shell:
+ grass.percent(1, 1, 1)
+def print_module_desc(name, url, full = False, shell = False):
+ if not full and not shell:
+ print name
+ return
+ if shell:
+ print 'name=' + name
+ # check main.c first
+ desc = get_module_desc(url + '/' + name + '/' + name)
+ if not desc:
+ desc = get_module_desc(url + '/' + name + '/main.c', script = False)
+ if not desc:
+ if not shell:
+ print name + '-'
+ return
+ if shell:
+ print 'description=' + desc.get('description', '')
+ print 'keywords=' + ','.join(desc.get('keywords', list()))
+ else:
+ print name + ' - ' + desc.get('description', '')
+def get_module_desc(url, script = True):
+ grass.debug('url=%s' % url)
+ f = urllib.urlopen(url)
+ if script:
+ ret = get_module_script(f)
+ else:
+ ret = get_module_main(f)
+ return ret
+def get_module_main(f):
+ if not f:
+ return dict()
+ ret = { 'keyword' : list() }
+ pattern = re.compile(r'(module.*->)(.+)(=)(.*)', re.IGNORECASE)
+ keyword = re.compile(r'(G_add_keyword\()(.+)(\);)', re.IGNORECASE)
+ key = ''
+ value = ''
+ for line in f.readlines():
+ line = line.strip()
+ find = pattern.search(line)
+ if find:
+ key = find.group(2).strip()
+ line = find.group(4).strip()
+ else:
+ find = keyword.search(line)
+ if find:
+ ret['keyword'].append(find.group(2).replace('"', '').replace('_(', '').replace(')', ''))
+ if key:
+ value += line
+ if line[-2:] == ');':
+ value = value.replace('"', '').replace('_(', '').replace(');', '')
+ if key == 'keywords':
+ ret[key] = map(lambda x: x.strip(), value.split(','))
+ else:
+ ret[key] = value
+ key = value = ''
+ return ret
+def get_module_script(f):
+ ret = dict()
+ if not f:
+ return ret
+ begin = re.compile(r'#%.*module', re.IGNORECASE)
+ end = re.compile(r'#%.*end', re.IGNORECASE)
+ mline = None
+ if not mline:
+ mline = begin.search(line)
+ if mline:
+ if end.search(line):
+ break
+ try:
+ key, value = line.split(':', 1)
+ key = key.replace('#%', '').strip()
+ value = value.strip()
+ else:
+ ret[key] = value
+ except ValueError:
+ pass
+ return ret
def cleanup():
global tmpdir
grass.try_rmdir(tmpdir)
@@ -202,8 +318,8 @@
check()
# list available modules
- if flags['l']:
- list_available_modules(options['svnurl'])
+ if flags['l'] or flags['f'] or flags['g']:
+ list_available_modules(options['svnurl'], full = flags['f'], shell = flags['g'])
return 0
else:
if not options['extension']:
