[GRASS-SVN] r42179 -
grass/branches/releasebranch_6_4/display/d.text.new
svn_grass at osgeo.org
Sat May 8 16:37:25 EDT 2010
Author: neteler
Date: 2010-05-08 16:37:23 -0400 (Sat, 08 May 2010)
New Revision: 42179
grass/branches/releasebranch_6_4/display/d.text.new/description.html
grass/branches/releasebranch_6_4/display/d.text.new/main.c
backport background text color
Modified: grass/branches/releasebranch_6_4/display/d.text.new/description.html
--- grass/branches/releasebranch_6_4/display/d.text.new/description.html 2010-05-08 20:22:11 UTC (rev 42178)
+++ grass/branches/releasebranch_6_4/display/d.text.new/description.html 2010-05-08 20:37:23 UTC (rev 42179)
@@ -21,6 +21,12 @@
(where <EM>color</EM> is one of the available colors) causes text appearing on
subsequent lines to be drawn in that color.
+<DT><B>.G</B> <EM>color</EM>
+<DD>
+(where <EM>color</EM> is one of the available colors) causes the background of text
+appearing on subsequent lines to be drawn in that color.
<DT><B>.S </B> <EM>size</EM>
<DD>
(where <EM>size</EM> is a percentage within the range 0 to
@@ -67,12 +73,13 @@
<pre>
- <B>d.text</B> << EOF
- .C yellow
- .S 4
- .B 1
- This is a test of d.text
- EOF
+<B>d.text</B> << EOF
+.C yellow
+.G grey
+.S 4
+.B 1
+This is a test of d.text
+EOF
</pre>
Modified: grass/branches/releasebranch_6_4/display/d.text.new/main.c
--- grass/branches/releasebranch_6_4/display/d.text.new/main.c 2010-05-08 20:22:11 UTC (rev 42178)
+++ grass/branches/releasebranch_6_4/display/d.text.new/main.c 2010-05-08 20:37:23 UTC (rev 42179)
@@ -4,7 +4,7 @@
* MODULE: d.text
* AUTHOR(S): James Westervelt, US Army CERL
- * Updated by Huidae Cho
+ * Updated by Huidae Cho, Markus Neteler
* PURPOSE: display text in active frame
@@ -21,6 +21,7 @@
* .F {font|path}[:charset] font
* .C {color_name|RR:GG:BB|0xRRGGBB} color
+ * .G {color_name|RR:GG:BB|0xRRGGBB} background color
* .S [+|-]size[p] text size
* +/-: relative size
* p: size in pixels
@@ -73,7 +74,7 @@
static void set_color(char *);
static int get_coordinates(int *, int *, double *, double *,
struct rectinfo, char **, char, char, char);
-static void draw_text(char *, int *, int *, int, char *, double, char);
+static void draw_text(char *, int *, int *, int, char *, double, char, int, int, int);
int main(int argc, char **argv)
@@ -82,7 +83,8 @@
struct Option *text;
struct Option *size;
- struct Option *color;
+ struct Option *fgcolor;
+ struct Option *bgcolor;
struct Option *line;
struct Option *at;
struct Option *rotation;
@@ -131,6 +133,7 @@
int prev_x, prev_y;
int set_x, set_y;
double east, north;
+ int do_background, fg_color, bg_color;
/* initialize the GIS calls */
G_gisinit(argv[0]);
@@ -155,15 +158,23 @@
opt.size->description =
_("Height of letters in percentage of available frame height");
- opt.color = G_define_option();
- opt.color->key = "color";
- opt.color->type = TYPE_STRING;
- opt.color->answer = DEFAULT_COLOR;
- opt.color->required = NO;
- opt.color->description =
+ opt.fgcolor = G_define_option();
+ opt.fgcolor->key = "color";
+ opt.fgcolor->type = TYPE_STRING;
+ opt.fgcolor->answer = DEFAULT_COLOR;
+ opt.fgcolor->required = NO;
+ opt.fgcolor->description =
_("Text color, either a standard GRASS color or R:G:B triplet");
- opt.color->gisprompt = GISPROMPT_COLOR;
+ opt.fgcolor->gisprompt = GISPROMPT_COLOR;
+ opt.bgcolor = G_define_option();
+ opt.bgcolor->key = "bgcolor";
+ opt.bgcolor->type = TYPE_STRING;
+ opt.bgcolor->required = NO;
+ opt.bgcolor->description =
+ _("Text background color, either a standard GRASS color or R:G:B triplet");
+ opt.bgcolor->gisprompt = GISPROMPT_COLOR;
opt.line = G_define_option();
opt.line->key = "line";
opt.line->required = NO;
@@ -315,7 +326,15 @@
size = (int)(atof(opt.size->answer) / 100.0 * (win.b - win.t));
#endif
- set_color(opt.color->answer);
+ fg_color = D_parse_color(opt.fgcolor->answer, TRUE);
+ if (opt.bgcolor->answer) {
+ do_background = 1;
+ bg_color = D_parse_color(opt.bgcolor->answer, TRUE);
+ if (bg_color == 0) /* ie color="none" */
+ do_background = 0;
+ } else
+ set_color(opt.fgcolor->answer);
orig_x = orig_y = 0;
@@ -345,7 +364,7 @@
y2 = y;
if (text[0])
- draw_text(text, &x2, &y2, size, align, rotation, bold);
+ draw_text(text, &x2, &y2, size, align, rotation, bold, do_background, fg_color, bg_color);
if (opt.at->answer || opt.line->answer)
D_add_to_list(G_recreate_command());
else {
@@ -362,7 +381,8 @@
sprintf(buf, "%s text=\"%s\"", buf, opt.text->answer);
sprintf(buf, "%s size=%s", buf, opt.size->answer);
- sprintf(buf, "%s color=%s", buf, opt.color->answer);
+ sprintf(buf, "%s color=%s", buf, opt.fgcolor->answer);
+ sprintf(buf, "%s bgcolor=%s", buf, opt.bgcolor->answer);
sprintf(buf, "%s align=%s", buf, opt.align->answer);
sprintf(buf, "%s rotation=%s", buf, opt.rotation->answer);
sprintf(buf, "%s linespacing=%s", buf,
@@ -430,7 +450,13 @@
case 'C':
/* color */
set_color(buf_ptr);
+ fg_color = D_parse_color(buf_ptr, 1);
break;
+ case 'G':
+ /* background color */
+ bg_color = D_parse_color(buf_ptr, 1);
+ break;
case 'S':
/* size */
i = 0;
@@ -552,7 +578,7 @@
set_x = set_y = set_l = first_text = 0;
- draw_text(buf_ptr, &x, &y, size, align, rotation, bold);
+ draw_text(buf_ptr, &x, &y, size, align, rotation, bold, do_background, fg_color, bg_color);
@@ -646,11 +672,12 @@
static void draw_text(char *text, int *x, int *y, int size, char *align,
- double rotation, char bold)
+ double rotation, char bold, int do_background, int fg_color, int bg_color)
int w, h;
int t, b, l, r;
double c, s;
+ int pt, pb, pl, pr;
/* TODO: get text dimension */
/* R_get_text_box() does not work with rotation and returns a little bit
@@ -706,6 +733,15 @@
+ if (do_background) {
+ pl = *x - size/2; /* some pixels margin for both sides */
+ pt = *y + size/2;
+ pr = *x + w + size/2;
+ pb = *y - h; /* due to bug in display system here not needed */
+ D_raster_use_color(bg_color);
+ R_box_abs(pl, pt, pr, pb); /* draw the box */
+ D_raster_use_color(fg_color); /* restore */
R_move_abs(*x, *y);
R_text(text);
