[GRASS-SVN] r42188 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun May 9 12:28:09 EDT 2010
Author: martinl
Date: 2010-05-09 12:28:09 -0400 (Sun, 09 May 2010)
New Revision: 42188
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: add relations
(merge r42185 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-05-09 16:27:42 UTC (rev 42187)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-05-09 16:28:09 UTC (rev 42188)
@@ -797,7 +797,9 @@
def OnDefineRelation(self, event):
"""!Define relation between data and action items"""
self.canvas.SetCursor(self.cursors["cross"])
+ self.defineRelation = { 'from' : None,
+ 'to' : None }
def OnAddAction(self, event):
"""!Add action to model"""
if self.searchDialog is None:
@@ -904,10 +906,10 @@
p.get('prompt', ''))
if data:
if p.get('age', 'old') == 'old':
- self._addLine(data, layer)
+ self.AddLine(data, layer)
data.AddAction(layer, direction = 'from')
else:
- self._addLine(layer, data)
+ self.AddLine(layer, data)
data.AddAction(layer, direction = 'to')
continue
@@ -923,10 +925,10 @@
self.model.AddData(data)
else:
# valid ?
@@ -946,13 +948,13 @@
self.SetStatusText(layer.GetLog(), 0)
- def _addLine(self, fromShape, toShape):
+ def AddLine(self, fromShape, toShape):
"""!Add connection
@param fromShape from
@param toShape to
- line = ModelRelation()
+ line = ModelRelation(fromShape, toShape)
line.SetCanvas(self)
line.SetPen(wx.BLACK_PEN)
line.SetBrush(wx.BLACK_BRUSH)
@@ -993,9 +995,9 @@
data.Show(True)
for action in data.GetActions('from'):
- self._addLine(data, action)
+ self.AddLine(data, action)
for action in data.GetActions('to'):
- self._addLine(action, data)
+ self.AddLine(action, data)
self.SetStatusText('', 0)
@@ -1350,6 +1352,7 @@
ogl.ShapeEvtHandler.__init__(self)
self.log = log
self.frame = frame
+ self.x = self.y = None
def OnLeftClick(self, x, y, keys = 0, attachment = 0):
"""!Left mouse button pressed -> select item & update statusbar"""
@@ -1358,6 +1361,15 @@
dc = wx.ClientDC(canvas)
canvas.PrepareDC(dc)
+ if hasattr(self.frame, 'defineRelation'):
+ rel = self.frame.defineRelation
+ if rel['from'] is None:
+ rel['from'] = shape
+ elif rel['to'] is None:
+ rel['to'] = shape
+ self.frame.AddLine(rel['from'], rel['to'])
+ del self.frame.defineRelation
if shape.Selected():
shape.Select(False, dc)
else:
@@ -1411,9 +1423,12 @@
self.popupID2 = wx.NewId()
self.popupID3 = wx.NewId()
+ # record coordinates
+ self.x = x
+ self.y = y
shape = self.GetShape()
popupMenu = wx.Menu()
popupMenu.Append(self.popupID1, text=_('Remove'))
self.frame.Bind(wx.EVT_MENU, self.OnRemove, id = self.popupID1)
@@ -1421,7 +1436,11 @@
popupMenu.AppendSeparator()
popupMenu.Append(self.popupID2, text=_('Add control point'))
self.frame.Bind(wx.EVT_MENU, self.OnAddPoint, id = self.popupID2)
+ popupMenu.Append(self.popupID3, text=_('Remove control point'))
+ self.frame.Bind(wx.EVT_MENU, self.OnRemovePoint, id = self.popupID3)
+ if len(shape.GetLineControlPoints()) == 2:
+ popupMenu.Enable(self.popupID3, False)
if isinstance(shape, ModelData) and '@' not in shape.GetValue():
popupMenu.Append(self.popupID3, text=_('Intermediate'),
@@ -1442,8 +1461,20 @@
def OnAddPoint(self, event):
"""!Add control point"""
- print event.GetPos()
+ shape = self.GetShape()
+ shape.InsertLineControlPoint(point = wx.RealPoint(self.x, self.y))
+ shape.ResetShapes()
+ shape.Select(True)
+ self.frame.canvas.Refresh()
+ def OnRemovePoint(self, event):
+ """!Remove control point"""
+ shape.DeleteLineControlPoint()
+ shape.Select(False)
def OnIntermediate(self, event):
"""!Mark data as intermediate"""
self.frame.ModelChanged()
@@ -1634,9 +1665,17 @@
class ModelRelation(ogl.LineShape):
"""!Data - action relation"""
- def __init__(self):
+ def __init__(self, fromShape, toShape):
+ self.fromShape = fromShape
+ self.toShape = toShape
ogl.LineShape.__init__(self)
+ def ResetShapes(self):
+ """!Reset related objects"""
+ self.fromShape.ResetControlPoints()
+ self.toShape.ResetControlPoints()
class ProcessModelFile:
"""!Process GRASS model file (gxm)"""
def __init__(self, tree):
