[GRASS-SVN] r42191 - in
grass/branches/releasebranch_6_4/gui/wxpython: . gui_modules xml
svn_grass at osgeo.org
Sun May 9 12:59:07 EDT 2010
Author: martinl
Date: 2010-05-09 12:59:07 -0400 (Sun, 09 May 2010)
New Revision: 42191
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mcalc_builder.py
grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
wxGUI: map calc clean up
(merge r42183, r42184, r42186, r42187 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py 2010-05-09 16:48:28 UTC (rev 42190)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py 2010-05-09 16:59:07 UTC (rev 42191)
@@ -490,16 +490,16 @@
return msgString
class CommandThread(Thread):
- """Create separate thread for command
- @param cmd GRASS command (given as list)
- @param stdin standard input stream
- @param stdout redirect standard output or None
- @param stderr redirect standard error output or None
+ """!Create separate thread for command
def __init__ (self, cmd, stdin=None,
stdout=sys.stdout, stderr=sys.stderr):
+ @param cmd command (given as list)
+ @param stdin standard input stream
+ @param stdout redirect standard output or None
+ @param stderr redirect standard error output or None
Thread.__init__(self)
self.cmd = cmd
@@ -530,7 +530,6 @@
return
self.startTime = time.time()
try:
self.module = Popen(self.cmd,
stdin=subprocess.PIPE,
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mcalc_builder.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mcalc_builder.py 2010-05-09 16:48:28 UTC (rev 42190)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mcalc_builder.py 2010-05-09 16:59:07 UTC (rev 42191)
@@ -1,359 +1,349 @@
-MODULE: mcalc_builder.py
+ at package mcalc_builder.py
-CLASSES:
- * MapCalcFrame
+ at brief Map calculator, wrapper for r.mapcalc
-PURPOSE: GRASS builds r.mapcalc statements
+Classes:
+ - MapCalcFrame
- Usage:
- mcalc_builder
+(C) 2008, 2010 by the GRASS Development Team
-AUTHOR(S): GRASS Development Team
- Original author: Michael Barton, Arizona State University
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
-COPYRIGHT: (C) 2008 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+ at author Michael Barton, Arizona State University
+ at author Martin Landa <landa.martin gmail.com>
-import wx
-import os,sys
+import os
+import sys
import time
-import grassenv
+import globalvar
+if not os.getenv("GRASS_WXBUNDLED"):
+ globalvar.CheckForWx()
+import wx
import gcmd
import gselect
-import subprocess
+try:
+ import subprocess
+except:
+ sys.path.append(os.path.join(globalvar.ETCWXDIR, "compat"))
+ import subprocess
+from preferences import globalSettings as UserSettings
-imagePath = os.path.join( os.getenv("GISBASE"), "etc", "wxpython")
-sys.path.append(imagePath)
-import images
-imagepath = images.__path__[0]
-sys.path.append(imagepath)
class MapCalcFrame(wx.Frame):
+ """!Mapcalc Frame class. Calculator-style window to create and run
+ r(3).mapcalc statements
- Mapcalc Frame class. Calculator-style window to create
- and run r.mapcalc statements
- def __init__(self, parent, id, title, pos=wx.DefaultPosition,
- size=wx.DefaultSize, style=wx.TAB_TRAVERSAL|wx.DEFAULT_FRAME_STYLE,
- dimension=2):
- wx.Frame.__init__(self, parent, id, title, pos, size,
- style)
+ def __init__(self, parent, id = wx.ID_ANY, title = _('Map calculator'),
+ rast3d = False, **kwargs):
+ self.parent = parent
+ if self.parent:
+ self.log = self.parent.GetLogWindow()
+ else:
+ self.log = None
- self.Centre(wx.BOTH)
+ self.rast3d = rast3d
+ wx.Frame.__init__(self, parent, id = id, title = title, **kwargs)
- if dimension == 3:
- self.SetTitle(_("GRASS %s Map Calculator") % "3D" )
- else:
- self.SetTitle(_("GRASS %s Map Calculator") % "2D" )
# variables
- self.parent = parent
- self.heading = 'mapcalc statement'
- self.newmap = ''
- self.dimension = dimension
+ self.heading = _('mapcalc statement')
self.funct_list = [
- 'abs(x)',
- 'acos(x)',
- 'asin(x)',
- 'atan(x)',
- 'atan(x,y)',
- 'cos(x)',
- 'double(x)',
- 'eval([x,y,...,]z)',
- 'exp(x)',
- 'exp(x,y)',
- 'float(x)',
- 'graph(x,x1,y1[x2,y2..])',
- 'if(x)',
- 'if(x,a)',
- 'if(x,a,b)',
- 'if(x,a,b,c)',
- 'int(x)',
- 'isnull(x)',
- 'log(x)',
- 'log(x,b)',
- 'max(x,y[,z...])',
- 'median(x,y[,z...])',
- 'min(x,y[,z...])',
- 'mode(x,y[,z...])',
- 'not(x)',
- 'pow(x,y)',
- 'rand(a,b)',
- 'round(x)',
- 'sin(x)',
- 'sqrt(x)',
- 'tan(x)',
- 'xor(x,y)',
- 'row()',
- 'col()',
- 'x()',
- 'y()',
- 'ewres()',
- 'nsres()',
- 'null()'
+ 'abs(x)',
+ 'acos(x)',
+ 'asin(x)',
+ 'atan(x)',
+ 'atan(x,y)',
+ 'cos(x)',
+ 'double(x)',
+ 'eval([x,y,...,]z)',
+ 'exp(x)',
+ 'exp(x,y)',
+ 'float(x)',
+ 'graph(x,x1,y1[x2,y2..])',
+ 'if(x)',
+ 'if(x,a)',
+ 'if(x,a,b)',
+ 'if(x,a,b,c)',
+ 'int(x)',
+ 'isnull(x)',
+ 'log(x)',
+ 'log(x,b)',
+ 'max(x,y[,z...])',
+ 'median(x,y[,z...])',
+ 'min(x,y[,z...])',
+ 'mode(x,y[,z...])',
+ 'not(x)',
+ 'pow(x,y)',
+ 'rand(a,b)',
+ 'round(x)',
+ 'sin(x)',
+ 'sqrt(x)',
+ 'tan(x)',
+ 'xor(x,y)',
+ 'row()',
+ 'col()',
+ 'x()',
+ 'y()',
+ 'ewres()',
+ 'nsres()',
+ 'null()'
- if self.dimension == 3:
+ if self.rast3d:
indx = self.funct_list.index('y()') +1
self.funct_list.insert(indx, 'z()')
indx = self.funct_list.index('nsres()') +1
self.funct_list.insert(indx, 'tbres()')
- maplabel = 'volume'
+ maplabel = _('3D raster map')
element = 'rast3d'
else:
- maplabel = 'map'
+ maplabel = _('raster map')
element = 'cell'
+ self.operatorBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label=" %s " % _('Operators'))
+ self.operandBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label=" %s " % _('Operands'))
+ self.expressBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label=" %s " % _('Expression'))
# Buttons
- self.btn_clear = wx.Button(self, -1, "Clear")
- self.btn_help = wx.Button(self, -1, "Help")
- self.btn_run = wx.Button(self, -1, "Run")
+ self.btn_clear = wx.Button(parent = self, id = wx.ID_CLEAR)
+ self.btn_help = wx.Button(parent = self, id = wx.ID_HELP)
+ self.btn_run = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Run"))
self.btn_run.SetDefault()
- self.btn_close = wx.Button(self, -1, "Close")
+ self.btn_close = wx.Button(parent = self, id = wx.ID_CLOSE)
- self.btn_pow = wx.Button(self, -1, "^")
- self.btn_pow.SetToolTipString('exponent')
- self.btn_div = wx.Button(self, -1, "/")
- self.btn_div.SetToolTipString('divide')
- self.btn_add = wx.Button(self, -1, "+")
- self.btn_add.SetToolTipString('add')
- self.btn_minus = wx.Button(self, -1, "-")
- self.btn_minus.SetToolTipString('subtract')
- self.btn_mod = wx.Button(self, -1, "%")
- self.btn_mod.SetToolTipString('modulus')
- self.btn_mult = wx.Button(self, -1, "*")
- self.btn_mult.SetToolTipString('multiply')
+ self.btn = dict()
+ self.btn['pow'] = wx.Button(parent = self, id = wx.ID_ANY, label = "^")
+ self.btn['pow'].SetToolTipString(_('exponent'))
+ self.btn['div'] = wx.Button(parent = self, id = wx.ID_ANY, label = "/")
+ self.btn['div'].SetToolTipString(_('divide'))
+ self.btn['add'] = wx.Button(parent = self, id = wx.ID_ANY, label = "+")
+ self.btn['add'].SetToolTipString(_('add'))
+ self.btn['minus'] = wx.Button(parent = self, id = wx.ID_ANY, label = "-")
+ self.btn['minus'].SetToolTipString(_('subtract'))
+ self.btn['mod'] = wx.Button(parent = self, id = wx.ID_ANY, label = "%")
+ self.btn['mod'].SetToolTipString(_('modulus'))
+ self.btn['mult'] = wx.Button(parent = self, id = wx.ID_ANY, label = "*")
+ self.btn['mult'].SetToolTipString(_('multiply'))
- self.btn_paren = wx.Button(self, -1, "( )")
+ self.btn['paren'] = wx.Button(parent = self, id = wx.ID_ANY, label = "( )")
- self.btn_lshift = wx.Button(self, -1, "<<")
- self.btn_lshift.SetToolTipString('left shift')
- self.btn_rshift = wx.Button(self, -1, ">>")
- self.btn_rshift.SetToolTipString('right shift')
- self.btn_rshiftu = wx.Button(self, -1, ">>>")
- self.btn_rshiftu.SetToolTipString('right shift (unsigned)')
- self.btn_gt = wx.Button(self, -1, ">")
- self.btn_gt.SetToolTipString('greater than')
- self.btn_gteq = wx.Button(self, -1, ">=")
- self.btn_gteq.SetToolTipString('greater than or equal to')
- self.btn_lt = wx.Button(self, -1, "<")
- self.btn_lt.SetToolTipString('less than or equal to')
- self.btn_lteq = wx.Button(self, -1, "<=")
- self.btn_lteq.SetToolTipString('less than')
- self.btn_eq = wx.Button(self, -1, "==")
- self.btn_eq.SetToolTipString('equal to')
- self.btn_noteq = wx.Button(self, -1, "!=")
- self.btn_noteq.SetToolTipString('not equal to')
+ self.btn['lshift'] = wx.Button(parent = self, id = wx.ID_ANY, label = "<<")
+ self.btn['lshift'].SetToolTipString(_('left shift'))
+ self.btn['rshift'] = wx.Button(parent = self, id = wx.ID_ANY, label = ">>")
+ self.btn['rshift'].SetToolTipString(_('right shift'))
+ self.btn['rshiftu'] = wx.Button(parent = self, id = wx.ID_ANY, label = ">>>")
+ self.btn['rshiftu'].SetToolTipString(_('right shift (unsigned)'))
+ self.btn['gt'] = wx.Button(parent = self, id = wx.ID_ANY, label = ">")
+ self.btn['gt'].SetToolTipString(_('greater than'))
+ self.btn['gteq'] = wx.Button(parent = self, id = wx.ID_ANY, label = ">=")
+ self.btn['gteq'].SetToolTipString(_('greater than or equal to'))
+ self.btn['lt'] = wx.Button(parent = self, id = wx.ID_ANY, label = "<")
+ self.btn['lt'].SetToolTipString(_('less than or equal to'))
+ self.btn['lteq'] = wx.Button(parent = self, id = wx.ID_ANY, label = "<=")
+ self.btn['lteq'].SetToolTipString(_('less than'))
+ self.btn['eq'] = wx.Button(parent = self, id = wx.ID_ANY, label = "==")
+ self.btn['eq'].SetToolTipString(_('equal to'))
+ self.btn['noteq'] = wx.Button(parent = self, id = wx.ID_ANY, label = "!=")
+ self.btn['noteq'].SetToolTipString(_('not equal to'))
- self.btn_compl = wx.Button(self, -1, "~")
- self.btn_compl.SetToolTipString("one's complement")
- self.btn_not = wx.Button(self, -1, "!")
- self.btn_not.SetToolTipString("NOT")
- self.btn_andbit = wx.Button(self, -1, '&')
- self.btn_andbit.SetToolTipString("bitwise AND")
- self.btn_orbit = wx.Button(self, -1, "|")
- self.btn_orbit.SetToolTipString("bitwise OR")
- self.btn_and = wx.Button(self, -1, "&&&")
- self.btn_and.SetToolTipString('logical AND')
- self.btn_andnull = wx.Button(self, -1, "&&&&&")
- self.btn_andnull.SetToolTipString('logical AND (ignores NULLs')
- self.btn_or = wx.Button(self, -1, "||")
- self.btn_or.SetToolTipString('logical OR')
- self.btn_ornull = wx.Button(self, -1, "|||")
- self.btn_ornull.SetToolTipString('logical OR (ignores NULLs')
- self.btn_cond = wx.Button(self, -1, "?:")
- self.btn_cond.SetToolTipString('conditional')
+ self.btn['compl'] = wx.Button(parent = self, id = wx.ID_ANY, label = "~")
+ self.btn['compl'].SetToolTipString(_('one\'s complement'))
+ self.btn['not'] = wx.Button(parent = self, id = wx.ID_ANY, label = "!")
+ self.btn['not'].SetToolTipString(_('NOT'))
+ self.btn['andbit'] = wx.Button(parent = self, id = wx.ID_ANY, label = '&')
+ self.btn['andbit'].SetToolTipString(_('bitwise AND'))
+ self.btn['orbit'] = wx.Button(parent = self, id = wx.ID_ANY, label = "|")
+ self.btn['orbit'].SetToolTipString(_('bitwise OR'))
+ self.btn['and'] = wx.Button(parent = self, id = wx.ID_ANY, label = "&&&")
+ self.btn['and'].SetToolTipString(_('logical AND'))
+ self.btn['andnull'] = wx.Button(parent = self, id = wx.ID_ANY, label = "&&&&&")
+ self.btn['andnull'].SetToolTipString(_('logical AND (ignores NULLs'))
+ self.btn['or'] = wx.Button(parent = self, id = wx.ID_ANY, label = "||")
+ self.btn['or'].SetToolTipString(_('logical OR'))
+ self.btn['ornull'] = wx.Button(parent = self, id = wx.ID_ANY, label = "|||")
+ self.btn['ornull'].SetToolTipString(_('logical OR (ignores NULLs'))
+ self.btn['cond'] = wx.Button(parent = self, id = wx.ID_ANY, label = "?:")
+ self.btn['cond'].SetToolTipString(_('conditional'))
# Text area
- self.text_mcalc = wx.TextCtrl(self, -1, '', size=(-1,75),style=wx.TE_MULTILINE)
+ self.text_mcalc = wx.TextCtrl(parent = self, id = wx.ID_ANY, size = (-1, 75),
+ style = wx.TE_MULTILINE)
# Map and function insertion text and ComboBoxes
- self.newmaplabel = wx.StaticText(self, -1, 'Name of new %s to create' % maplabel)
- self.newmaptxt = wx.TextCtrl(self, wx.ID_ANY, size=(250,-1))
- self.mapsellabel = wx.StaticText(self, -1, 'Insert existing %s' % maplabel)
- self.mapselect = gselect.Select(self, wx.ID_ANY, size=(250,-1),
- type=element, multiple=False)
- self.functlabel = wx.StaticText(self, -1, 'Insert mapcalc function')
- self.function = wx.ComboBox(self, wx.ID_ANY, "", (-1,-1),
- (250, -1), self.funct_list, wx.CB_DROPDOWN
- | wx.CB_READONLY
- | wx.TE_PROCESS_ENTER
- #| wx.CB_SORT
+ self.newmaplabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label= _('Name for new %s to create') % maplabel)
+ self.newmaptxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+ self.mapsellabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _('Insert existing %s') % maplabel)
+ self.mapselect = gselect.Select(self, wx.ID_ANY, size = (250, -1),
+ type = element, multiple = False)
+ self.functlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _('Insert mapcalc function'))
+ self.function = wx.ComboBox(parent = self, id = wx.ID_ANY,
+ size = (250, -1), choices = self.funct_list,
+ style = wx.CB_DROPDOWN |
+ wx.CB_READONLY | wx.TE_PROCESS_ENTER)
# Bindings
- self.btn_compl.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_not.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_pow.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_div.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_add.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_minus.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_mod.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_mult.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_lshift.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_rshift.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_rshiftu.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_gt.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_gteq.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_lt.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_lteq.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_eq.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_noteq.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_andbit.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_orbit.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_and.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_andnull.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_or.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_ornull.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_cond.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_paren.Bind(wx.EVT_BUTTON, self.AddMark)
+ for btn in self.btn.keys():
+ self.btn[btn].Bind(wx.EVT_BUTTON, self.AddMark)
self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
self.btn_clear.Bind(wx.EVT_BUTTON, self.OnClear)
self.btn_run.Bind(wx.EVT_BUTTON, self.OnMCalcRun)
self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
- self.newmaptxt.Bind(wx.EVT_TEXT, self.OnNewmap)
- #self.mapselect.Bind(wx.EVT_COMBOBOX, self.OnSelect)
self.mapselect.Bind(wx.EVT_TEXT, self.OnSelect)
- #self.mapselect.Bind(wx.EVT_TEXT_ENTER, self.OnSelect)
self.function.Bind(wx.EVT_COMBOBOX, self.OnSelect)
- #self.function.Bind(wx.EVT_TEXT, self.OnSelect)
self.function.Bind(wx.EVT_TEXT_ENTER, self.OnSelect)
+ self._layout()
- self.__doLayout()
- def __doLayout(self):
- pagesizer = wx.BoxSizer(wx.VERTICAL)
+ def _layout(self):
+ sizer = wx.BoxSizer(wx.VERTICAL)
- controlsizer = wx.BoxSizer(wx.HORIZONTAL)
- btnpanelsizer = wx.GridBagSizer(1,1)
+ controlSizer = wx.BoxSizer(wx.HORIZONTAL)
+ operatorSizer = wx.StaticBoxSizer(self.operatorBox, wx.HORIZONTAL)
- buttonsizer1 = wx.GridBagSizer(5,1)
- buttonsizer1.Add(self.btn_add, (0,0))
- buttonsizer1.Add(self.btn_minus, (0,1))
- buttonsizer1.Add(self.btn_mod, (5,0))
- buttonsizer1.Add(self.btn_mult, (1,0))
- buttonsizer1.Add(self.btn_div, (1,1))
- buttonsizer1.Add(self.btn_pow, (5,1))
- buttonsizer1.Add(self.btn_gt, (2,0))
- buttonsizer1.Add(self.btn_gteq, (2,1))
- buttonsizer1.Add(self.btn_eq, (4,0))
- buttonsizer1.Add(self.btn_lt, (3,0))
- buttonsizer1.Add(self.btn_lteq, (3,1))
- buttonsizer1.Add(self.btn_noteq, (4,1))
+ buttonSizer1 = wx.GridBagSizer(5, 1)
+ buttonSizer1.Add(item = self.btn['add'], pos = (0,0))
+ buttonSizer1.Add(item = self.btn['minus'], pos = (0,1))
+ buttonSizer1.Add(item = self.btn['mod'], pos = (5,0))
+ buttonSizer1.Add(item = self.btn['mult'], pos = (1,0))
+ buttonSizer1.Add(item = self.btn['div'], pos = (1,1))
+ buttonSizer1.Add(item = self.btn['pow'], pos = (5,1))
+ buttonSizer1.Add(item = self.btn['gt'], pos = (2,0))
+ buttonSizer1.Add(item = self.btn['gteq'], pos = (2,1))
+ buttonSizer1.Add(item = self.btn['eq'], pos = (4,0))
+ buttonSizer1.Add(item = self.btn['lt'], pos = (3,0))
+ buttonSizer1.Add(item = self.btn['lteq'], pos = (3,1))
+ buttonSizer1.Add(item = self.btn['noteq'], pos = (4,1))
- buttonsizer2 = wx.GridBagSizer(5,1)
- buttonsizer2.Add(self.btn_and, (0,0))
- buttonsizer2.Add(self.btn_andbit, (1,0))
- buttonsizer2.Add(self.btn_andnull, (2,0))
- buttonsizer2.Add(self.btn_or, (0,1))
- buttonsizer2.Add(self.btn_orbit, (1,1))
- buttonsizer2.Add(self.btn_ornull, (2,1))
- buttonsizer2.Add(self.btn_lshift, (3,0))
- buttonsizer2.Add(self.btn_rshift, (3,1))
- buttonsizer2.Add(self.btn_rshiftu, (4,0))
- buttonsizer2.Add(self.btn_cond, (5,0))
- buttonsizer2.Add(self.btn_compl, (5,1))
- buttonsizer2.Add(self.btn_not, (4,1))
+ buttonSizer2 = wx.GridBagSizer(5, 1)
+ buttonSizer2.Add(item = self.btn['and'], pos = (0,0))
+ buttonSizer2.Add(item = self.btn['andbit'], pos = (1,0))
+ buttonSizer2.Add(item = self.btn['andnull'], pos = (2,0))
+ buttonSizer2.Add(item = self.btn['or'], pos = (0,1))
+ buttonSizer2.Add(item = self.btn['orbit'], pos = (1,1))
+ buttonSizer2.Add(item = self.btn['ornull'], pos = (2,1))
+ buttonSizer2.Add(item = self.btn['lshift'], pos = (3,0))
+ buttonSizer2.Add(item = self.btn['rshift'], pos = (3,1))
+ buttonSizer2.Add(item = self.btn['rshiftu'], pos = (4,0))
+ buttonSizer2.Add(item = self.btn['cond'], pos = (5,0))
+ buttonSizer2.Add(item = self.btn['compl'], pos = (5,1))
+ buttonSizer2.Add(item = self.btn['not'], pos = (4,1))
- buttonsizer3 = wx.GridBagSizer(7, 1)
- buttonsizer3.Add(self.newmaplabel, (0,0), (1,2), wx.ALIGN_CENTER)
- buttonsizer3.Add(self.newmaptxt, (1,0), (1,2), wx.TOP, 4)
- buttonsizer3.Add(self.mapsellabel, (2,0), (1,2), wx.ALIGN_CENTER)
- buttonsizer3.Add(self.mapselect, (3,0), (1,2))
- buttonsizer3.Add(self.functlabel, (4,0), (1,2), wx.ALIGN_CENTER)
- buttonsizer3.Add(self.function, (5,0), (1,2))
- buttonsizer3.Add(self.btn_paren, (6,0), (1,1), wx.ALIGN_CENTER)
- buttonsizer3.Add(self.btn_clear, (6,1), (1,1), wx.ALIGN_CENTER)
+ operandSizer = wx.StaticBoxSizer(self.operandBox, wx.HORIZONTAL)
+ buttonSizer3 = wx.GridBagSizer(7, 1)
+ buttonSizer3.Add(item = self.newmaplabel, pos = (0, 0),
+ span = (1, 2), flag = wx.ALIGN_CENTER)
+ buttonSizer3.Add(item = self.newmaptxt, pos = (1,0),
+ span = (1, 2))
+ buttonSizer3.Add(item = self.mapsellabel, pos = (2,0),
+ span = (1,2), flag = wx.ALIGN_CENTER)
+ buttonSizer3.Add(item = self.mapselect, pos = (3,0),
+ span = (1,2))
+ buttonSizer3.Add(item = self.functlabel, pos = (4,0),
+ buttonSizer3.Add(item = self.function, pos = (5,0),
+ span = (1,2))
+ buttonSizer3.Add(item = self.btn['paren'], pos = (6, 0),
+ span = (1,1), flag = wx.ALIGN_LEFT)
+ buttonSizer3.Add(item = self.btn_clear, pos = (6,1),
+ span = (1,1), flag = wx.ALIGN_RIGHT)
- buttonsizer4 = wx.GridSizer(4, 3, 3, 3)
- buttonsizer4.Add(self.btn_run,0,wx.RIGHT,5)
- buttonsizer4.Add(self.btn_close,0,wx.RIGHT,5)
- buttonsizer4.Add(self.btn_help,0,wx.RIGHT,5)
+ buttonSizer4 = wx.BoxSizer(wx.HORIZONTAL)
+ buttonSizer4.Add(item = self.btn_close,
+ flag = wx.ALL, border = 5)
+ buttonSizer4.Add(item = self.btn_run,
+ buttonSizer4.Add(item = self.btn_help,
- label = wx.StaticText(self, -1, 'Mapcalc operators')
+ operatorSizer.Add(item = buttonSizer1, proportion = 0,
+ operatorSizer.Add(item = buttonSizer2, proportion = 0,
+ flag = wx.TOP | wx.BOTTOM | wx.RIGHT, border = 5)
+ operandSizer.Add(item = buttonSizer3, proportion = 0,
+ controlSizer.Add(item = operatorSizer, proportion = 0,
+ flag = wx.RIGHT, border = 5)
+ controlSizer.Add(item = operandSizer, proportion = 0)
- btnpanelsizer.Add(label, (0,0), (1,2), wx.ALIGN_CENTER)
- btnpanelsizer.Add(buttonsizer1, (1,0), (1,1), wx.RIGHT|wx.TOP, 5)
- btnpanelsizer.Add(buttonsizer2, (1,1), (1,1), wx.LEFT|wx.TOP, 5)
+ expressSizer = wx.StaticBoxSizer(self.expressBox, wx.HORIZONTAL)
+ expressSizer.Add(item = self.text_mcalc, proportion = 1)
- controlsizer.Add(btnpanelsizer, 0, wx.ALIGN_CENTER_HORIZONTAL|wx.RIGHT, border=20)
- controlsizer.Add(buttonsizer3, proportion=0)
+ sizer.Add(item = controlSizer, flag = wx.EXPAND | wx.ALL,
+ border = 5)
+ sizer.Add(item = expressSizer, flag = wx.EXPAND | wx.LEFT | wx.RIGHT,
+ border = 5)
+ sizer.Add(item = buttonSizer4, proportion = 0,
+ flag = wx.ALIGN_RIGHT | wx.ALL, border = 1)
- pagesizer.Add(controlsizer, flag=wx.EXPAND|wx.ALL,border=10)
- pagesizer.Add(self.text_mcalc, flag=wx.EXPAND|wx.ALL,border=5)
- pagesizer.Add(buttonsizer4, 0, wx.ALIGN_CENTER_HORIZONTAL|wx.ALL, border=5)
self.SetAutoLayout(True)
- self.SetSizer(pagesizer)
- pagesizer.Fit(self)
- #pagesizer.SetSizeHints(self)
+ self.SetSizer(sizer)
+ sizer.Fit(self)
self.Layout()
- self.Show(True)
def AddMark(self,event):
+ """!Sends operators to insertion method
- Sends operators to insertion method
+ if event.GetId() == self.btn['compl'].GetId(): mark = "~"
+ elif event.GetId() == self.btn['not'].GetId(): mark = "!"
+ elif event.GetId() == self.btn['pow'].GetId(): mark = "^"
+ elif event.GetId() == self.btn['div'].GetId(): mark = "/"
+ elif event.GetId() == self.btn['add'].GetId(): mark = "+"
+ elif event.GetId() == self.btn['minus'].GetId(): mark = "-"
+ elif event.GetId() == self.btn['mod'].GetId(): mark = "%"
+ elif event.GetId() == self.btn['mult'].GetId(): mark = "*"
+ elif event.GetId() == self.btn['lshift'].GetId(): mark = "<<"
+ elif event.GetId() == self.btn['rshift'].GetId(): mark = ">>"
+ elif event.GetId() == self.btn['rshiftu'].GetId(): mark = ">>>"
+ elif event.GetId() == self.btn['gt'].GetId(): mark = ">"
+ elif event.GetId() == self.btn['gteq'].GetId(): mark = ">="
+ elif event.GetId() == self.btn['lt'].GetId(): mark = "<"
+ elif event.GetId() == self.btn['lteq'].GetId(): mark = "<="
+ elif event.GetId() == self.btn['eq'].GetId(): mark = "=="
+ elif event.GetId() == self.btn['noteq'].GetId(): mark = "!="
+ elif event.GetId() == self.btn['andbit'].GetId(): mark = "&"
+ elif event.GetId() == self.btn['orbit'].GetId(): mark = "|"
+ elif event.GetId() == self.btn['or'].GetId(): mark = "||"
+ elif event.GetId() == self.btn['ornull'].GetId(): mark = "|||"
+ elif event.GetId() == self.btn['and'].GetId(): mark = "&&"
+ elif event.GetId() == self.btn['andnull'].GetId(): mark = "&&&"
+ elif event.GetId() == self.btn['cond'].GetId(): mark = "?:"
+ elif event.GetId() == self.btn['paren'].GetId(): mark = "()"
+ self._addSomething(mark)
- if event.GetId() == self.btn_compl.GetId(): mark = "~"
- elif event.GetId() == self.btn_not.GetId(): mark = "!"
- elif event.GetId() == self.btn_pow.GetId(): mark = "^"
- elif event.GetId() == self.btn_div.GetId(): mark = "/"
- elif event.GetId() == self.btn_add.GetId(): mark = "+"
- elif event.GetId() == self.btn_minus.GetId(): mark = "-"
- elif event.GetId() == self.btn_mod.GetId(): mark = "%"
- elif event.GetId() == self.btn_mult.GetId(): mark = "*"
- elif event.GetId() == self.btn_lshift.GetId(): mark = "<<"
- elif event.GetId() == self.btn_rshift.GetId(): mark = ">>"
- elif event.GetId() == self.btn_rshiftu.GetId(): mark = ">>>"
- elif event.GetId() == self.btn_gt.GetId(): mark = ">"
- elif event.GetId() == self.btn_gteq.GetId(): mark = ">="
- elif event.GetId() == self.btn_lt.GetId(): mark = "<"
- elif event.GetId() == self.btn_lteq.GetId(): mark = "<="
- elif event.GetId() == self.btn_eq.GetId(): mark = "=="
- elif event.GetId() == self.btn_noteq.GetId(): mark = "!="
- elif event.GetId() == self.btn_andbit.GetId(): mark = "&"
- elif event.GetId() == self.btn_orbit.GetId(): mark = "|"
- elif event.GetId() == self.btn_or.GetId(): mark = "||"
- elif event.GetId() == self.btn_ornull.GetId(): mark = "|||"
- elif event.GetId() == self.btn_and.GetId(): mark = "&&"
- elif event.GetId() == self.btn_andnull.GetId(): mark = "&&&"
- elif event.GetId() == self.btn_cond.GetId(): mark = "?:"
- elif event.GetId() == self.btn_paren.GetId(): mark = "()"
- self.__addSomething(mark)
- def OnNewmap(self, event):
- self.newmap = event.GetString()
def OnSelect(self, event):
+ """!Gets raster map or function selection and send it to
+ insertion method
- Gets raster map or function selection and send it to insertion method
item = event.GetString()
- self.__addSomething(item)
+ self._addSomething(item)
self.text_mcalc.SetFocus()
- def __addSomething(self,what):
+ def _addSomething(self,what):
+ """!Inserts operators, map names, and functions into text area
- Inserts operators, map names, and functions into text area
mcalcstr = self.text_mcalc.GetValue()
newmcalcstr = ''
@@ -364,68 +354,66 @@
newmcalcstr = mcalcstr[:position]
try:
- if newmcalcstr[-1] != " ":
+ if newmcalcstr[-1] != ' ':
newmcalcstr += " "
except:
pass
newmcalcstr += what
position_offset = len(what)
- newmcalcstr += " "+mcalcstr[position:]
+ newmcalcstr += " " + mcalcstr[position:]
self.text_mcalc.SetValue(newmcalcstr)
self.text_mcalc.SetInsertionPoint(position+position_offset)
self.text_mcalc.Update()
def OnMCalcRun(self,event):
+ """!Builds and runs r.mapcalc statement
- Builds and runs r.mapcalc statement
- if self.newmap == '':
- wx.MessageBox("You must enter the name of a new map to create")
+ name = self.newmaptxt.GetValue().strip()
+ if not name:
+ gcmd.GMessage(parent = self,
+ message = _("You must enter the name of a new map to create"),
+ msgType = 'info')
return
- if self.text_mcalc.GetValue() == '':
- wx.MessageBox("You must enter a mapcalc statement to create a new map")
+ if not self.text_mcalc.GetValue().strip():
+ message = _("You must enter a mapcalc statement to create a new map"),
+ msgType = 'info')
return
+ mctxt = self.text_mcalc.GetValue().strip().replace("\n"," ")
+ mctxt = mctxt.replace(" " , "")
+ if self.rast3d:
+ prg = 'r3.mapcalc'
+ else:
+ prg = 'r.mapcalc'
- try:
- mctxt = self.text_mcalc.GetValue().strip().replace("\n"," ")
- mctxt = mctxt.replace(" ","")
- cmdlist = ["r3.mapcalc"," %s=%s" % (self.newmap,mctxt)]
- else:
- cmdlist = ["r.mapcalc"," %s=%s" % (self.newmap,mctxt)]
- p = gcmd.Command(cmdlist)
- if p.returncode == 0:
- wx.MessageBox("Map %s created successfully" % self.newmap)
- except:
- pass
+ if self.log:
+ cmd = [prg, str('%s = %s' % (name, mctxt))]
+ self.log.RunCmd(cmd)
+ self.parent.Raise()
+ else:
+ gcmd.RunCommand(prg,
+ "%s=%s" % (name, mctxt))
def OnClear(self, event):
+ """!Clears text area
- Clears text area
- self.text_mcalc.SetValue("")
+ self.text_mcalc.SetValue('')
def OnHelp(self, event):
+ """!Launches r.mapcalc help
- Launches r.mapcalc help
- cmdlist = ['g.manual','r.mapcalc']
- gcmd.Command(cmdlist)
+ gcmd.RunCommand('g.manual', entry = 'r.mapcalc')
def OnClose(self,event):
+ """!Close window"""
self.Destroy()
if __name__ == "__main__":
- if len(sys.argv) != 2:
- print >>sys.stderr, __doc__
- sys.exit()
app = wx.App(0)
- sqlb = SQLFrame(None, -1, 'SQL Builder',sys.argv[1])
+ frame = MapCalcFrame(None)
+ frame.Show()
app.MainLoop()
Modified: grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
--- grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py 2010-05-09 16:48:28 UTC (rev 42190)
+++ grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py 2010-05-09 16:59:07 UTC (rev 42191)
@@ -1060,22 +1060,21 @@
self.profile.Refresh()
self.profile.Update()
- def DispMapCalculator(self, event):
+ def OnMapCalculator(self, event):
+ """!Init map calculator for interactive creation of mapcalc statements
- Init map calculator for interactive creation of mapcalc statements
+ win = mapcalculator.MapCalcFrame(parent = self, title = _('GRASS GIS Map Calculator'))
+ win.CentreOnScreen()
+ win.Show()
- self.mapcalculator = mapcalculator.MapCalcFrame(self, wx.ID_ANY, title='',
- dimension=2)
- def Disp3DMapCalculator(self, event):
+ def OnMapCalculator3D(self, event):
+ win = mapcalculator.MapCalcFrame(parent = self, title = _('GRASS GIS Map Calculator (3D raster)'),
+ rast3d = True)
+ win.Show()
- dimension=3)
def AddToolbarButton(self, toolbar, label, icon, help, handler):
"""Adds button to the given toolbar"""
Modified: grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
--- grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml 2010-05-09 16:48:28 UTC (rev 42190)
+++ grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml 2010-05-09 16:59:07 UTC (rev 42191)
@@ -855,9 +855,9 @@
<command>r.mask</command>
</menuitem>
<menuitem>
- <label>Map calculator</label>
- <help>Map calculator for raster map algebra</help>
- <handler>self.DispMapCalculator</handler>
+ <label>Raster calculator</label>
+ <help>Map calculator for raster map algebra.</help>
+ <handler>self.OnMapCalculator</handler>
</menuitem>
<menu>
<label>Neighborhood analysis</label>
@@ -2273,9 +2273,9 @@
<command>r3.mask</command>
</menuitem>
<menuitem>
- <label>3D raster map calculator</label>
- <help>Map calculator for volumetric map algebra</help>
- <handler>self.Disp3DMapCalculator</handler>
+ <label>Volume calculator</label>
+ <help>Map calculator for 3D raster map algebra.</help>
+ <handler>self.OnMapCalculator3D</handler>
</menuitem>
<menuitem>
<label>Cross section</label>
