[GRASS-SVN] r42201 - in grass/trunk/gui: scripts wxpython/xml
svn_grass at osgeo.org
Sun May 9 16:59:37 EDT 2010
Author: martinl
Date: 2010-05-09 16:59:37 -0400 (Sun, 09 May 2010)
New Revision: 42201
Removed:
grass/trunk/gui/scripts/g.change.gui.py
grass/trunk/gui/wxpython/xml/menudata.xml
remove g.change.gui
Deleted: grass/trunk/gui/scripts/g.change.gui.py
--- grass/trunk/gui/scripts/g.change.gui.py 2010-05-09 20:54:53 UTC (rev 42200)
+++ grass/trunk/gui/scripts/g.change.gui.py 2010-05-09 20:59:37 UTC (rev 42201)
@@ -1,47 +0,0 @@
-#!/usr/bin/env python
-# MODULE: g.change.gui
-# AUTHOR(S): Hamish Bowman
-# PURPOSE:
-# COPYRIGHT: (C) 2009 GRASS Development Team
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-#%Module
-#% description: Changes the default GRASS graphical user interface (GUI) setting.
-#% keywords: general, gui
-#%End
-#%Option
-#% key: gui
-#% type: string
-#% required: yes
-#% multiple: no
-#% options: wxpython,text
-#% label: GUI type
-#% description: Default value: GRASS_GUI if defined otherwise tcltk
-#% descriptions: wxpython;wxPython based next generation GUI;text;command line interface only
-#%End
-# simple front end to g.gui to be used from within the GUI.
-import sys
-from grass.script import core as grass
-def main():
- grass.exec_command("g.gui", flags = 'nu', gui = options['gui'])
- sys.exit(ret)
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2010-05-09 20:54:53 UTC (rev 42200)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2010-05-09 20:59:37 UTC (rev 42201)
@@ -744,13 +744,6 @@
<handler>OnMenuCmd</handler>
<command>g.gisenv</command>
</menuitem>
- <menuitem>
- <label>Change default GUI</label>
- <help>Changes the default GRASS graphical user interface (GUI) setting.</help>
- <keywords>general,gui</keywords>
- <handler>OnMenuCmd</handler>
- <command>g.change.gui.sh</command>
- </menuitem>
<separator />
<menuitem>
<label>Version</label>
