[GRASS-SVN] r42207 - grass/trunk/vector/lidar/r.resamp.bspline
Mon May 10 05:53:53 EDT 2010
Author: mmetz
Date: 2010-05-10 05:53:53 -0400 (Mon, 10 May 2010)
New Revision: 42207
   grass/trunk/vector/lidar/r.resamp.bspline/main.c
remove ogrid option, was for deugging only; finetune lambda
Modified: grass/trunk/vector/lidar/r.resamp.bspline/main.c
--- grass/trunk/vector/lidar/r.resamp.bspline/main.c	2010-05-10 09:52:02 UTC (rev 42206)
+++ grass/trunk/vector/lidar/r.resamp.bspline/main.c	2010-05-10 09:53:53 UTC (rev 42207)
@@ -60,7 +60,7 @@
     int cat = 1;
     struct GModule *module;
-    struct Option *in_opt, *out_opt, *grid_opt, *ogrid_opt, *stepE_opt, *stepN_opt,
+    struct Option *in_opt, *out_opt, *grid_opt, *stepE_opt, *stepN_opt,
 		  *lambda_f_opt, *method_opt;
     struct Flag *null_flag, *cross_corr_flag;
@@ -89,10 +89,6 @@
     grid_opt->key = "grid";
     grid_opt->required = NO;
-    ogrid_opt = G_define_standard_option(G_OPT_V_OUTPUT);
-    ogrid_opt->key = "ogrid";
-    ogrid_opt->required = NO;
     stepE_opt = G_define_option();
     stepE_opt->key = "se";
     stepE_opt->type = TYPE_DOUBLE;
@@ -123,7 +119,7 @@
     lambda_f_opt->type = TYPE_DOUBLE;
     lambda_f_opt->required = NO;
     lambda_f_opt->description = _("Tykhonov regularization parameter (affects smoothing)");
-    lambda_f_opt->answer = "0.001";
+    lambda_f_opt->answer = "0.005";
     lambda_f_opt->guisection = _("Settings");
     null_flag = G_define_flag();
