[GRASS-SVN] r42211 - grass/trunk/gui/wxpython/gui_modules
Mon May 10 08:23:11 EDT 2010
Author: martinl
Date: 2010-05-10 08:23:07 -0400 (Mon, 10 May 2010)
New Revision: 42211
   grass/trunk/gui/wxpython/gui_modules/ghelp.py
   grass/trunk/gui/wxpython/gui_modules/gmodeler.py
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/gui_modules/prompt.py
wxGUI: search module engine collapsible
Modified: grass/trunk/gui/wxpython/gui_modules/ghelp.py
--- grass/trunk/gui/wxpython/gui_modules/ghelp.py	2010-05-10 10:50:30 UTC (rev 42210)
+++ grass/trunk/gui/wxpython/gui_modules/ghelp.py	2010-05-10 12:23:07 UTC (rev 42211)
@@ -64,7 +64,9 @@
 class SearchModuleWindow(wx.Panel):
     """!Search module window (used in MenuTreeWindow)"""
-    def __init__(self, parent, id = wx.ID_ANY, cmdPrompt = None, showChoice = True, **kwargs):
+    def __init__(self, parent, id = wx.ID_ANY, cmdPrompt = None,
+                 showChoice = True, showTip = False, **kwargs):
+        self.showTip    = showTip
         self.showChoice = showChoice
         self.cmdPrompt  = cmdPrompt
@@ -88,11 +90,14 @@
                                   style = wx.TE_PROCESS_ENTER)
         self.search.Bind(wx.EVT_TEXT, self.OnSearchModule)
-        if self.showChoice:
+        if self.showTip:
             self.searchTip  = menuform.StaticWrapText(parent = self, id = wx.ID_ANY,
                                                       size = (-1, 35))
+        if self.showChoice:
             self.searchChoice = wx.Choice(parent = self, id = wx.ID_ANY)
+            if self.cmdPrompt:
+                self.searchChoice.SetItems(self.cmdPrompt.GetCommandItems())
             self.searchChoice.Bind(wx.EVT_CHOICE, self.OnSelectModule)
         self._layout()
@@ -107,11 +112,15 @@
                       flag=wx.ALIGN_CENTER_VERTICAL, pos = (0, 0))
         gridSizer.Add(item = self.search,
                       flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (0, 1))
+        row = 1
+        if self.showTip:
+            gridSizer.Add(item = self.searchTip,
+                          flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (row, 0), span = (1, 2))
+            row += 1
         if self.showChoice:
-            gridSizer.Add(item = self.searchTip,
-                          flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (1, 0), span = (1, 2))
             gridSizer.Add(item = self.searchChoice,
-                          flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (2, 0), span = (1, 2))
         sizer.Add(item = gridSizer, proportion = 1)
@@ -137,6 +146,11 @@
         text = event.GetString()
         if not text:
             self.cmdPrompt.SetFilter(None)
+            mList = self.cmdPrompt.GetCommandItems()
+            self.searchChoice.SetItems(mList)
+            if self.showTip:
+                self.searchTip.SetLabel(_("%d modules found") % len(mList))
+            event.Skip()
             return
         modules = dict()
@@ -162,9 +176,12 @@
                 modules[group].append(name)
         self.cmdPrompt.SetFilter(modules)
-        self.searchTip.SetLabel(_("%d modules found") % iFound)
+        if self.showTip:
+            self.searchTip.SetLabel(_("%d modules found") % iFound)
+        event.Skip()
     def OnSelectModule(self, event):
         """!Module selected from choice, update command prompt"""
         cmd  = event.GetString().split(' ', 1)[0]
@@ -178,7 +195,8 @@
             self.cmdPrompt.SetFocus()
         desc = self.cmdPrompt.GetCommandDesc(cmd)
-        self.searchTip.SetLabel(desc)
+        if self.showTip:
+            self.searchTip.SetLabel(desc)
 class MenuTreeWindow(wx.Panel):
     """!Show menu tree"""
@@ -315,7 +333,7 @@
         nItems = len(self.tree.itemsMarked)
         if event.GetString():
-            self.parent.SetStatusText(_("%d items match") % nItems, 0)
+            self.parent.SetStatusText(_("%d modules match") % nItems, 0)
         else:
             self.parent.SetStatusText("", 0)
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2010-05-10 10:50:30 UTC (rev 42210)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2010-05-10 12:23:07 UTC (rev 42211)
@@ -1538,7 +1538,7 @@
                                    label=" %s " % _("Command"))
         self.cmd_prompt = prompt.GPromptSTC(parent = self)
-        self.search = SearchModuleWindow(parent = self.panel, cmdPrompt = self.cmd_prompt)
+        self.search = SearchModuleWindow(parent = self.panel, cmdPrompt = self.cmd_prompt, showTip = True)
         # get commands
         items = self.cmd_prompt.GetCommandItems()
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2010-05-10 10:50:30 UTC (rev 42210)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2010-05-10 12:23:07 UTC (rev 42211)
@@ -188,11 +188,20 @@
         # search & command prompt
-        self.search = SearchModuleWindow(parent = self.panelPrompt, cmdPrompt = self.cmd_prompt)
         if self.parent.GetName() != 'LayerManager':
-            self.search.Hide()
+            self.search = None
             self.cmd_prompt.Hide()
+        else:
+            self.infoCollapseLabelExp = _("Click here to show search module engine")
+            self.infoCollapseLabelCol = _("Click here to hide search module engine")
+            self.searchPane = wx.CollapsiblePane(parent = self.panelOutput,
+                                                 label = self.infoCollapseLabelExp,
+                                                 style = wx.CP_DEFAULT_STYLE |
+                                                 wx.CP_NO_TLW_RESIZE | wx.EXPAND)
+            self.MakeSearchPaneContent(self.searchPane.GetPane())
+            self.searchPane.Collapse(True)
+            self.Bind(wx.EVT_COLLAPSIBLEPANE_CHANGED, self.OnSearchPaneChanged, self.searchPane)
+            self.search.Bind(wx.EVT_TEXT,             self.OnUpdateStatusBar)
         # stream redirection
@@ -235,15 +244,15 @@
         OutputSizer = wx.BoxSizer(wx.VERTICAL)
         PromptSizer = wx.BoxSizer(wx.VERTICAL)
         ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
+        if self.search and self.search.IsShown():
+            OutputSizer.Add(item=self.searchPane, proportion=0,
+                            flag=wx.EXPAND | wx.ALL, border=3)
         OutputSizer.Add(item=self.cmd_output, proportion=1,
         OutputSizer.Add(item=self.console_progressbar, proportion=0,
                         flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=3)
-        if self.search.IsShown():
-            PromptSizer.Add(item=self.search, proportion=0,
-                            flag=wx.EXPAND | wx.ALL, border=3)
         PromptSizer.Add(item=self.cmd_prompt, proportion=1,
                         flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.TOP, border=3)
@@ -269,20 +278,40 @@
         # split window
         if self.parent.GetName() == 'LayerManager':
-            self.SplitHorizontally(self.panelOutput, self.panelPrompt, -75)
-            self.SetMinimumPaneSize(self.btn_cmd_clear.GetSize()[1] + 75)
+            self.SplitHorizontally(self.panelOutput, self.panelPrompt, -50)
+            self.SetMinimumPaneSize(self.btn_cmd_clear.GetSize()[1] + 50)
         else:
             self.SplitHorizontally(self.panelOutput, self.panelPrompt, -45)
             self.SetMinimumPaneSize(self.btn_cmd_clear.GetSize()[1] + 10)
         self.SetSashGravity(1.0)
-        self.Fit()
         # layout
         self.SetAutoLayout(True)
         self.Layout()
+    def MakeSearchPaneContent(self, pane):
+        """!Create search pane"""
+        border = wx.BoxSizer(wx.VERTICAL)
+        self.search = SearchModuleWindow(parent = pane, cmdPrompt = self.cmd_prompt)
+        border.Add(item = self.search, proportion = 1,
+                   flag = wx.EXPAND | wx.ALL, border = 1)
+        pane.SetSizer(border)
+        border.Fit(pane)
+    def OnSearchPaneChanged(self, event):
+        """!Collapse search module box"""
+        if self.searchPane.IsExpanded():
+            self.searchPane.SetLabel(self.infoCollapseLabelCol)
+        else:
+            self.searchPane.SetLabel(self.infoCollapseLabelExp)
+        self.Layout()
+        self.SendSizeEvent()
     def GetPanel(self, prompt = True):
         """!Get panel
@@ -542,6 +571,16 @@
         """!Get running command or None"""
         return self.requestQ.get()
+    def OnUpdateStatusBar(self, event):
+        """!Update statusbar text"""
+        if event.GetString():
+            nItems = len(self.cmd_prompt.GetCommandItems())
+            self.parent.SetStatusText(_('%d modules match') % nItems, 0)
+        else:
+            self.parent.SetStatusText('', 0)
+        event.Skip()
     def OnCmdOutput(self, event):
         """!Print command output"""
         message = event.text
Modified: grass/trunk/gui/wxpython/gui_modules/prompt.py
--- grass/trunk/gui/wxpython/gui_modules/prompt.py	2010-05-10 10:50:30 UTC (rev 42210)
+++ grass/trunk/gui/wxpython/gui_modules/prompt.py	2010-05-10 12:23:07 UTC (rev 42211)
@@ -561,6 +561,9 @@
         else:
             mList = self.moduleList
+        if not mList:
+            return items
         prefixes = mList.keys()
         prefixes.sort()
@@ -569,6 +572,8 @@
                 name = prefix + '.' + command
                 items.append(name)
+        items.sort()
         return items
     def _getListOfModules(self):
