[GRASS-SVN] r42226 - in grass-addons/tools: . wingrass-packager
Tue May 11 14:50:09 EDT 2010
Author: martinl
Date: 2010-05-11 14:50:08 -0400 (Tue, 11 May 2010)
New Revision: 42226
Added:
   grass-addons/tools/wingrass-packager/
   grass-addons/tools/wingrass-packager/grass_compile.sh
   grass-addons/tools/wingrass-packager/grass_md5sum.sh
   grass-addons/tools/wingrass-packager/grass_packager.bat
   grass-addons/tools/wingrass-packager/grass_svn_info.sh
   grass-addons/tools/wingrass-packager/msys.bat
wingrass-packager added (see http://josef.fsv.cvut.cz/wingrass)
Added: grass-addons/tools/wingrass-packager/grass_compile.sh
--- grass-addons/tools/wingrass-packager/grass_compile.sh	                        (rev 0)
+++ grass-addons/tools/wingrass-packager/grass_compile.sh	2010-05-11 18:50:08 UTC (rev 42226)
@@ -0,0 +1,16 @@
+#!/bin/sh
+# Compile GRASS versions
+SRC=/osgeo4w/usr/src
+function compile {
+    cd $SRC/$1
+    svn up
+    ./mswindows/osgeo4w/package.sh
+compile grass64_release
+compile grass6_devel
+compile grass_trunk
+exit 0
Added: grass-addons/tools/wingrass-packager/grass_md5sum.sh
--- grass-addons/tools/wingrass-packager/grass_md5sum.sh	                        (rev 0)
+++ grass-addons/tools/wingrass-packager/grass_md5sum.sh	2010-05-11 18:50:08 UTC (rev 42226)
@@ -0,0 +1,19 @@
+#!/bin/sh
+# Create mdb5sum files
+HOME=/c/Users/landa/grass_packager
+function create_md5sum {
+    cd $HOME/$1
+    for file in `ls WinGRASS*.exe`; do
+	md5sum $file > ${file}.md5sum
+    done
+export PATH=$PATH:/c/OSGeo4W/apps/msys/bin
+create_md5sum grass64
+create_md5sum grass65
+create_md5sum grass70
+exit 0
Added: grass-addons/tools/wingrass-packager/grass_packager.bat
--- grass-addons/tools/wingrass-packager/grass_packager.bat	                        (rev 0)
+++ grass-addons/tools/wingrass-packager/grass_packager.bat	2010-05-11 18:50:08 UTC (rev 42226)
@@ -0,0 +1,44 @@
+ at echo off
+cd C:\Users\landa\grass_packager
+rem Compile GRASS versions
+rmdir /s /q C:\OSGeo4W\apps\grass\grass-6.4.0svn
+rmdir /s /q C:\OSGeo4W\apps\grass\grass-6.5.svn
+rmdir /s /q C:\OSGeo4W\apps\grass\grass-7.0.svn
+C:\OSGeo4W\apps\msys\bin\bash.exe C:\Users\landa\grass_packager\grass_compile.sh
+C:\OSGeo4W\apps\msys\bin\bash.exe C:\Users\landa\grass_packager\grass_install_70.sh
+rem Preparation
+if exist .\grass64 rmdir /S/Q .\grass64
+xcopy C:\OSGeo4W\usr\src\grass64_release\mswindows\* .\grass64 /S/V/F/I
+if exist .\grass65 rmdir /S/Q .\grass65
+xcopy C:\OSGeo4W\usr\src\grass6_devel\mswindows\* .\grass65 /S/V/F/I
+if exist .\grass70 rmdir /S/Q .\grass70
+xcopy C:\OSGeo4W\usr\src\grass_trunk\mswindows\* .\grass70 /S/V/F/I
+cd .\grass64
+call .\GRASS-Packager.bat
+cd ..
+cd .\grass65
+cd ..
+cd .\grass70
+cd ..
+copy .\msys.bat .\grass64\GRASS-64-Dev-Package\msys\
+copy .\msys.bat .\grass65\GRASS-65-Dev-Package\msys\
+copy .\msys.bat .\grass70\GRASS-70-Dev-Package\msys\
+C:\OSGeo4W\apps\msys\bin\sh.exe .\grass_svn_info.sh
+C:\DevTools\makensis.exe .\grass64\GRASS-Installer.nsi
+C:\DevTools\makensis.exe .\grass65\GRASS-Installer.nsi
+C:\DevTools\makensis.exe .\grass70\GRASS-Installer.nsi
+C:\OSGeo4W\apps\msys\bin\sh.exe .\grass_md5sum.sh
+pscp.exe -i .\ssh\id_dsa.ppk .\grass64\WinGRASS*.exe* landa at josef:/var/www/wingrass/grass64
+pscp.exe -i .\ssh\id_dsa.ppk .\grass65\WinGRASS*.exe* landa at josef:/var/www/wingrass/grass65
+pscp.exe -i .\ssh\id_dsa.ppk .\grass70\WinGRASS*.exe* landa at josef:/var/www/wingrass/grass70
Added: grass-addons/tools/wingrass-packager/grass_svn_info.sh
--- grass-addons/tools/wingrass-packager/grass_svn_info.sh	                        (rev 0)
+++ grass-addons/tools/wingrass-packager/grass_svn_info.sh	2010-05-11 18:50:08 UTC (rev 42226)
@@ -0,0 +1,20 @@
+#!/bin/sh
+# Update SVN version
+function update {
+    cd $SRC/$1
+    REV=`svn info | grep 'Last Changed Rev:' | cut -d':' -f2 | tr -d ' '`
+    sed "s/_SVN_REVISION \"36599\"/_SVN_REVISION \"$REV\"/g" $HOME/$2/GRASS-Installer.nsi > tmp
+    mv tmp $HOME/$2/GRASS-Installer.nsi
+update grass64_release grass64
+update grass6_devel grass65
+update grass_trunk grass70
+exit 0
Added: grass-addons/tools/wingrass-packager/msys.bat
--- grass-addons/tools/wingrass-packager/msys.bat	                        (rev 0)
+++ grass-addons/tools/wingrass-packager/msys.bat	2010-05-11 18:50:08 UTC (rev 42226)
@@ -0,0 +1,187 @@
+ at echo off
+rem Copyright (C):  2001, 2002, 2003, 2004, 2005  Earnie Boyd
+rem   mailto:earnie at users.sf.net
+rem This file is part of Minimal SYStem
+rem   http://www.mingw.org/msys.shtml
+rem
+rem File:	    msys.bat
+rem Revision:	    2.4
+rem Revision Date:  December 8th, 2005
+rem ember to set the "Start in:" field of the shortcut.
+rem A value similar to C:\msys\1.0\bin is what the "Start in:" field needs
+rem to represent.
+rem ember value of GOTO: is used to know recursion has happened.
+if "%1" == "GOTO:" goto %2
+if NOT "x%WD%" == "x" set WD=
+rem ember command.com only uses the first eight characters of the label.
+goto _WindowsNT
+rem ember that we only execute here if we are in command.com.
+:_Windows
+if "x%COMSPEC%" == "x" set COMSPEC=command.com
+start /min %COMSPEC% /e:4096 /c %0 GOTO: _Resume %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
+goto EOF
+rem ember that we execute here if we recursed.
+:_Resume
+for %%F in (1 2 3) do shift
+if NOT EXIST %WD%msys-1.0.dll set WD=.\bin\
+rem ember that we get here even in command.com.
+:_WindowsNT
+rem Hopefully a temporary workaround for getting MSYS shell to run on x64
+rem (WoW64 cmd prompt sets PROCESSOR_ARCHITECTURE to x86)
+if not "x%PROCESSOR_ARCHITECTURE%" == "xAMD64" goto _NotX64
+set COMSPEC=%WINDIR%\SysWOW64\cmd.exe
+%COMSPEC% /c %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
+goto EOF
+:_NotX64
+if NOT EXIST %WD%msys-1.0.dll set WD=%~dp0\bin\
+rem ember Set up option to use rxvt based on value of %1
+if "x%MSYSCON%" == "x" set MSYSCON=rxvt.exe
+if "x%1" == "x-norxvt" set MSYSCON=sh.exe
+if "x%1" == "x--norxvt" set MSYSCON=sh.exe
+if "x%MSYSCON%" == "xsh.exe" shift
+if "x%MSYSTEM%" == "x" set MSYSTEM=MINGW32
+if "%1" == "MINGW32" set MSYSTEM=MINGW32
+if "%1" == "MSYS" set MSYSTEM=MSYS
+if NOT "x%DISPLAY%" == "x" set DISPLAY=
+if "x%MSYSCON%" == "xrxvt.exe" goto startrxvt
+if "x%MSYSCON%" == "xsh.exe" goto startsh
+:unknowncon
+echo %MSYSCON% is an unknown option for msys.bat.
+pause
+exit 1
+:notfound
+echo Cannot find the rxvt.exe or sh.exe binary -- aborting.
+pause
+exit 1
+rem If you don't want to use rxvt then rename the file rxvt.exe to something
+rem else.  Then sh.exe will be used instead.
+:startrxvt
+if NOT EXIST %WD%rxvt.exe goto startsh
+rem Setup the default colors for rxvt.
+if "x%MSYSBGCOLOR%" == "x" set MSYSBGCOLOR=White
+if "x%MSYSFGCOLOR%" == "x" set MSYSFGCOLOR=Black
+if "x%MINGW32BGCOLOR%" == "x" set MINGW32BGCOLOR=LightYellow
+if "x%MINGW32FGCOLOR%" == "x" set MINGW32FGCOLOR=Navy
+if "%MSYSTEM%" == "MSYS" set BGCOLOR=%MSYSBGCOLOR%
+if "%MSYSTEM%" == "MSYS" set FGCOLOR=%MSYSFGCOLOR%
+if "%MSYSTEM%" == "MINGW32" set BGCOLOR=%MINGW32BGCOLOR%
+if "%MSYSTEM%" == "MINGW32" set FGCOLOR=%MINGW32FGCOLOR%
+if "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -i
+if NOT "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"
+exit
+:startsh
+if NOT EXIST %WD%sh.exe goto notfound
+start %WD%sh --login -i
+exit
+:EOF
+rem ChangeLog:
+rem 2002.03.07  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Move the @echo off to the top.
+rem	* Change the binmode setting to nobinmode.
+rem     * Remove the angle brackets around email address to workaround MS
+rem	buggy command processor.
+rem
+rem 2002.03.12  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add filter logic to find rxvt.exe
+rem
+rem 2002.03.13  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Revert the nobinmode change.
+rem
+rem 2002.03.20  Earnie Boyd  mailto:earnie at users.sf.net
+rem     * Add logic for stating bash.
+rem
+rem 2002.04.11  Earnie Boyd  mailto;earnie at users.sf.net
+rem	* Add logic for setting MSYSTEM value based on parameter.
+rem
+rem 2002.04.15  Olivier Gautherot  mailto:olivier_gautherot at mentorg.com
+rem	* Reduce number test conditions for finding an executable.
+rem
+rem 2002.04.15  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Unset DISPLAY if set before starting shell.
+rem
+rem 2002.04.16  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Remove use of DEFINED in conditional statments for variables for
+rem	command.com support.
+rem	* Add check for nonexistance of USERNAME variable for Win9x support.
+rem
+rem 2002.04.17  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add foreground and background color defaults based on MSYSTEM value.
+rem
+rem 2002.04.22  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* More Win 9x changes.
+rem
+rem 2002.05.04  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Remove the SET of USERNAME and HOME.
+rem
+rem 2002.11.18  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add command.com detection and restart with a larger environment to
+rem	avoid errors on w9x.
+rem     Many thanks to Randy W. Sims mailto:RandyS at ThePierianSpring.org.
+rem	See Randy's response to "RE: [Mingw-msys] Installation on WindowsME"
+rem	from 11/06/2002 in the archives of mingw-msys at lists.sf.net.
+rem
+rem 2002.11.19  Paul Garceau  mailto:pgarceau at attbi.com
+rem	* Fix a typo: Change COMPSPEC to COMSPEC.
+rem
+rem 2002.11.25  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Remove the SET CYGWIN since it doesn't matter any longer.
+rem
+rem 2003.02.03  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Win9x doesn't like ``EXISTS dir'' so change it to ``EXISTS dir\nul''.
+rem	Thanks to Nicolas Weber mailto:nicolasweber at gmx.de.
+rem
+rem 2003.03.06  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add -backspacekey switch to rxvt startup.
+rem	* Move RXVT color setup to startrxvt label
+rem
+rem 2004.01.30  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add -geometry parameter to work around an off by one issue with
+rem       the default values.
+rem	Thanks to Dave Schuyler mailto:parameter at users.sf.net
+rem
+rem 2004.03.28  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add -norxvt or --norxvt switch argument.
+rem	Thanks to Keith Marshall mailto:Keith.Marshall at total.com.
+rem	* Add method to determine absolute path of msys.bat so that we no
+rem	longer need to change to the bin directory.  This allows msys.bat to be
+rem	called from any working directory.
+rem	Thanks to Kevin Mack  mailto:kevin.mack at us.cd-adapco.com
+rem
+rem 2005.07.06  Max TE Woodbury  mailto:mtew at users.sf.net
+rem     * Fixed WD check for command.com systems.
+rem     * Minimized intermediate CMD window to reduce startup flashyness.
+rem     * If rxvt.exe cannot be found, try sh.exe.
+rem
+rem 2005.12.06  Tuomo Latto  mailto:nonperson at users.sf.net
+rem     * Added a temporary workaround for getting MSYS shell to run on x64.
+rem
+rem 2005.12.07  Keith Marshall  mailto:keithmarshall at users.sf.net
+rem     * ``EXISTS %WD%\sh.exe'' should be ``EXISTS %WD%sh.exe''; corrected.
+rem     * Modified Tuomo's patch, to avoid trashing Window settings in Win32.
+rem
+rem 2005.12.08  Tuomo Latto  mailto:nonperson at users.sf.net
+rem     * Keith's modified patch fails on x64; start did funny things.
+rem     Reworked, for correct behaviour on both platforms.
+rem
