[GRASS-SVN] r42235 - grass/trunk/raster/r.watershed/ram
Wed May 12 05:33:34 EDT 2010
Author: mmetz
Date: 2010-05-12 05:33:34 -0400 (Wed, 12 May 2010)
New Revision: 42235
Added:
   grass/trunk/raster/r.watershed/ram/do_flatarea.c
   grass/trunk/raster/r.watershed/ram/Gwater.h
   grass/trunk/raster/r.watershed/ram/do_astar.c
   grass/trunk/raster/r.watershed/ram/init_vars.c
   grass/trunk/raster/r.watershed/ram/main.c
new option to beautify flat areas
Modified: grass/trunk/raster/r.watershed/ram/Gwater.h
--- grass/trunk/raster/r.watershed/ram/Gwater.h	2010-05-12 08:28:11 UTC (rev 42234)
+++ grass/trunk/raster/r.watershed/ram/Gwater.h	2010-05-12 09:33:34 UTC (rev 42235)
@@ -54,7 +54,7 @@
 extern CELL n_basins;
 extern OC_STACK *ocs;
 extern int ocs_alloced;
-extern FLAG *worked, *in_list, *s_b, *swale;
+extern FLAG *worked, *in_list, *s_b, *swale, *flat_done;
 extern RAMSEG dis_seg, alt_seg, wat_seg, asp_seg, bas_seg, haf_seg;
 extern RAMSEG r_h_seg, dep_seg;
 extern RAMSEG slp_seg, s_l_seg, s_g_seg, l_s_seg;
@@ -77,7 +77,7 @@
 extern char seg_name[GNAME_MAX], bas_name[GNAME_MAX], haf_name[GNAME_MAX], thr_name[8];
 extern char ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX], sg_name[GNAME_MAX];
 extern char wat_name[GNAME_MAX], asp_name[GNAME_MAX], arm_name[GNAME_MAX], dis_name[GNAME_MAX];
-extern char ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
+extern char ele_flag, pit_flag, run_flag, dis_flag, ob_flag, flat_flag;
 extern char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
 extern char bas_flag, seg_flag, haf_flag, er_flag;
 extern char st_flag, sb_flag, sg_flag, sl_flag, ls_flag;
@@ -100,6 +100,9 @@
 double get_slope(int, int, int, int, CELL, CELL);
 int replace(int, int, int, int);
+/* do_flatarea.c */
+int do_flatarea(int, CELL);
 /* do_cum.c */
 int do_cum(void);
 int do_cum_mfd(void);
Modified: grass/trunk/raster/r.watershed/ram/do_astar.c
--- grass/trunk/raster/r.watershed/ram/do_astar.c	2010-05-12 08:28:11 UTC (rev 42234)
+++ grass/trunk/raster/r.watershed/ram/do_astar.c	2010-05-12 09:33:34 UTC (rev 42235)
@@ -10,7 +10,7 @@
     int count;
     int upr, upc, r, c, ct_dir;
     CELL alt_val, alt_nbr[8];
-    CELL is_in_list, is_worked;
+    CELL is_in_list, is_worked, flat_is_done, nbr_flat_is_done;
     int index_doer, index_up;
     /* sides
      * |7|1|4|
@@ -22,6 +22,7 @@
     double dx, dy, dist_to_nbr[8], ew_res, ns_res;
     double slope[8];
     int skip_diag;
+    CELL *alt_bak;
     G_message(_("SECTION 2: A* Search."));
@@ -44,6 +45,27 @@
     first_astar = heap_index[1];
     first_cum = do_points;
+    if (flat_flag) {
+	alt_bak =
+	    (CELL *) G_malloc(sizeof(CELL) * size_array(&alt_seg, nrows, ncols));
+	flat_done = flag_create(nrows, ncols);
+	flat_is_done = 0;
+	for (r = 0; r < nrows; r++) {
+	    for (c = 0; c < ncols; c++) {
+		index_doer = SEG_INDEX(alt_seg, r, c);
+		alt_bak[index_doer] = alt[index_doer];
+		flag_unset(flat_done, r, c);
+    else {
+	alt_bak = NULL;
+	flat_done = NULL;
+	flat_is_done = 1;
     /* A* Search: search uphill, get downhill paths */
     while (heap_size > 0) {
 	G_percent(count++, do_points, 1);
@@ -64,7 +86,9 @@
 	alt_val = alt[index_doer];
-	FLAG_SET(worked, r, c);
+	if (flat_flag) {
+	    flat_is_done = FLAG_GET(flat_done, r, c);
 	/* check all neighbours, breadth first search */
 	for (ct_dir = 0; ct_dir < sides; ct_dir++) {
@@ -78,9 +102,31 @@
 		is_in_list = FLAG_GET(in_list, upr, upc);
 		is_worked = FLAG_GET(worked, upr, upc);
 		skip_diag = 0;
+		alt_nbr[ct_dir] = alt[index_up];
+		if (flat_flag && !is_worked) {
+		    alt_val = alt[index_doer];
+		    if (!flat_is_done && alt_nbr[ct_dir] == alt_val) {
+			do_flatarea(index_doer, alt_val);
+			flat_is_done = 1;
+			nbr_flat_is_done = 1;
+		    nbr_flat_is_done = FLAG_GET(flat_done, upr, upc);
+		    if (!nbr_flat_is_done) {
+			/* use original ele values */
+			alt_val = alt_bak[index_doer];
+			alt_nbr[ct_dir] = alt_bak[index_up];
+		    else {
+			/* use modified ele values */
 		/* avoid diagonal flow direction bias */
 		if (!is_worked) {
-		    alt_nbr[ct_dir] = alt[index_up];
 		    slope[ct_dir] =
 			get_slope2(alt_val, alt_nbr[ct_dir],
 				   dist_to_nbr[ct_dir]);
@@ -121,6 +167,7 @@
 	    }    /* end if in region */
 	}    /* end sides */
+	FLAG_SET(worked, r, c);
     G_percent(count, do_points, 1);	/* finish it */
     if (mfd == 0)
@@ -129,6 +176,17 @@
     flag_destroy(in_list);
     G_free(heap_index);
+    if (flat_flag) {
+		alt[index_doer] = alt_bak[index_doer];
+	G_free(alt_bak);
+	flag_destroy(flat_done);
     return 0;
Added: grass/trunk/raster/r.watershed/ram/do_flatarea.c
--- grass/trunk/raster/r.watershed/ram/do_flatarea.c	                        (rev 0)
+++ grass/trunk/raster/r.watershed/ram/do_flatarea.c	2010-05-12 09:33:34 UTC (rev 42235)
@@ -0,0 +1,436 @@
+ * flat area beautification after Garbrecht and Martz (1997)
+ * Garbrecht, J. & Martz, L. W. (1997)
+ * The assignment of drainage direction over flat surfaces in raster
+ * digital elevation models. J. Hydrol 193, 204–213.
+ * the method is modifed for speed, only one pass is necessary to get
+ * the gradient away from higher terrain
+#include <limits.h>
+#include <assert.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "Gwater.h"
+#include "do_astar.h"
+#include "rbtree.h"
+struct pq_node
+    int idx;
+    struct pq_node *next;
+struct pq
+    struct pq_node *first, *last;
+    int size;
+struct pq *pq_create(void)
+    struct pq *q = G_malloc(sizeof(struct pq));
+    q->first = G_malloc(sizeof(struct pq_node));
+    q->first->next = NULL;
+    q->first->idx = -1;
+    q->last = q->first;
+    q->size = 0;
+    return q;
+/* dummy end must always be allocated and empty */
+int pq_add(int idx, struct pq *q)
+    assert(q->last);
+    if (q->last->idx != -1)
+	G_fatal_error("idx is %d", q->last->idx);
+    q->last->idx = idx;
+    if (q->last->next == NULL) {
+	struct pq_node *n = (struct pq_node *) G_malloc(sizeof(struct pq_node));
+	n->next = NULL;
+	n->idx = -1;
+	q->last->next = n;
+	q->last = q->last->next;
+    else {
+	assert(NULL);
+    assert(q->last != q->last->next);
+    assert(q->first != q->last);
+    assert(q->last->idx == -1);
+    assert(q->last->next == NULL);
+    q->size++;
+    return 0;
+int pq_drop(struct pq *q)
+    int idx = q->first->idx;
+    struct pq_node *n = q->first;
+    assert(q->first != q->first->next);
+    assert(q->size);
+    q->size--;
+    q->first = q->first->next;
+    assert(q->first);
+    assert(n != q->first);
+    G_free(n);
+    return idx;
+int pq_destroy(struct pq *q)
+    struct pq_node *delme;
+    while (q->first) {
+	delme = q->first;
+	G_free(delme);
+    G_free(q);
+    return 0;
+struct orders {
+    int index, uphill, downhill;
+    char flag;
+int cmp_orders(const void *a, const void *b)
+    struct orders *oa = (struct orders *)a;
+    struct orders *ob = (struct orders *)b;
+    return (oa->index < ob->index ? -1 : (oa->index > ob->index));
+int do_flatarea(int index, CELL ele)
+    int upr, upc, r, c, ct_dir;
+    CELL is_in_list, is_worked, this_in_list;
+    int index_doer, index_up;
+    int n_flat_cells = 0, counter;
+    CELL ele_nbr, min_ele_diff;
+    int uphill_order, downhill_order, max_uphill_order, max_downhill_order;
+    int last_order;
+    struct pq *up_pq = pq_create();
+    struct pq *down_pq = pq_create();
+    struct orders inc_order, *order_found, *nbr_order_found;
+    struct RB_TREE *order_tree = rbtree_create(cmp_orders, sizeof(struct orders));
+    pq_add(index, down_pq);
+    inc_order.downhill = -1;
+    inc_order.uphill = 0;
+    inc_order.index = index;
+    inc_order.flag = 1;
+    rbtree_insert(order_tree, &inc_order);
+    n_flat_cells++;
+    min_ele_diff = INT_MAX;
+    max_uphill_order = max_downhill_order = 0;
+    /* get uphill start points */
+    counter = 0;
+    while (down_pq->size) {
+	if ((index_doer = pq_drop(down_pq)) == -1)
+	    G_fatal_error("get start points: no more points in down queue");
+	seg_index_rc(alt_seg, index_doer, &r, &c);
+	FLAG_SET(flat_done, r, c);
+	/* check all neighbours, breadth first search */
+	for (ct_dir = 0; ct_dir < sides; ct_dir++) {
+	    /* get r, c (upr, upc) for this neighbour */
+	    upr = r + nextdr[ct_dir];
+	    upc = c + nextdc[ct_dir];
+	    /* check if r, c are within region */
+	    if (upr >= 0 && upr < nrows && upc >= 0 && upc < ncols) {
+		index_up = SEG_INDEX(alt_seg, upr, upc);
+		is_in_list = FLAG_GET(in_list, upr, upc);
+		is_worked = FLAG_GET(worked, upr, upc);
+		ele_nbr = alt[index_up];
+		if (ele_nbr == ele && !is_worked) {
+		    inc_order.uphill = -1;
+		    inc_order.index = index_up;
+		    inc_order.flag = 0;
+		    /* not yet added to queue */
+		    if ((order_found = rbtree_find(order_tree, &inc_order)) == NULL) {
+			n_flat_cells++;
+			/* add to down queue if not yet in there */
+			pq_add(index_up, down_pq);
+			/* add to up queue if not yet in there */
+			if (is_in_list) {
+			    pq_add(index_up, up_pq);
+			    /* set uphill order to 0 */
+			    counter++;
+    if (n_flat_cells < 5) {
+	/* clean up */
+	pq_destroy(up_pq);
+	pq_destroy(down_pq);
+	rbtree_destroy(order_tree);
+	return 1;
+    G_debug(2, "%d flat cells, %d cells in tree, %d start cells", n_flat_cells, (int)order_tree->count, counter);
+    down_pq = pq_create();
+    /* got uphill start points, do uphill correction */
+    counter = 0;
+    uphill_order = 1;
+    while (up_pq->size) {
+	int is_in_down_queue = 0;
+	if ((index_doer = pq_drop(up_pq)) == -1)
+	    G_fatal_error("uphill order: no more points in up queue");
+	this_in_list = FLAG_GET(in_list, r, c);
+	/* get uphill order for this point */
+	inc_order.index = index_doer;
+	    G_fatal_error(_("flat cell escaped for uphill correction"));
+	last_order = uphill_order - 1;
+	uphill_order = order_found->uphill;
+	if (last_order > uphill_order)
+	    G_warning("queue error: last uphill order %d > current uphill order %d", last_order, uphill_order);
+	/* debug */
+	if (uphill_order == -1)
+	    G_fatal_error(_("uphill order not set"));
+	if (max_uphill_order < uphill_order)
+	    max_uphill_order = uphill_order;
+	uphill_order++;
+	counter++;
+		/* all cells that are in_list should have been added previously as uphill start points */
+		    if ((nbr_order_found = rbtree_find(order_tree, &inc_order)) == NULL) {
+			G_fatal_error(_("flat cell escaped in uphill correction"));
+		    if (nbr_order_found->flag != 1) {
+			if (is_in_list)
+			    G_warning("cell should be in queue");
+			/* add to up queue */
+			/* set nbr uphill order = current uphill order + 1 */
+			nbr_order_found->uphill = uphill_order;
+			nbr_order_found->flag = 1;
+		/* add focus cell to down queue */
+		if (!this_in_list && !is_in_down_queue &&
+		    ele_nbr != ele && !is_in_list && !is_worked) {
+		    pq_add(index_doer, down_pq);
+		    /* set downhill order to 0 */
+		    order_found->downhill = 0;
+		    is_in_down_queue = 1;
+		if (ele_nbr > ele && min_ele_diff > ele_nbr - ele)
+		    min_ele_diff = ele_nbr - ele;
+    /* debug: all flags should be set to 1 */
+    up_pq = pq_create();
+    /* got downhill start points, do downhill correction */
+    downhill_order = 1;
+	    G_fatal_error("downhill order: no more points in down queue");
+	/* get downhill order for this point */
+	    G_fatal_error(_("flat cell escaped for downhill correction"));
+	last_order = downhill_order - 1;
+	downhill_order = order_found->downhill;
+	if (last_order > downhill_order)
+	    G_warning("queue error: last downhill order %d > current downhill order %d", last_order, downhill_order);
+	/* debug */
+	if (downhill_order == -1)
+	    G_fatal_error(_("downhill order: downhill order not set"));
+	downhill_order++;
+			G_fatal_error(_("flat cell escaped in downhill correction"));
+		    if (nbr_order_found->downhill == -1) {
+			/* add to down queue */
+			/* set nbr downhill order = current downhill order + 1 */
+			nbr_order_found->downhill = downhill_order;
+			if (max_downhill_order < downhill_order)
+			    max_downhill_order = downhill_order;
+			if (is_in_list) {
+			    /* unset flag */
+			    nbr_order_found->flag = 0;
+			    //nbr_order_found->downhill = 0;
+    /* got uphill and downhill order, adjust ele */
+    /* increment: ele += uphill_order +  max_downhill_order - downhill_order */
+    /* decrement: ele += uphill_order - max_uphill_order - downhill_order */
+    //max_downhill_order++;
+	    G_fatal_error("no more points in up queue");
+	/* get uphill and downhill order for this point */
+	    G_fatal_error(_("flat cell escaped for adjustment"));
+	/* debug */
+	    G_fatal_error(_("adjustment: uphill order not set"));
+	    G_fatal_error(_("adjustment: downhill order not set"));
+	/* increment */
+	if (this_in_list) {
+	    downhill_order = max_downhill_order;
+	    uphill_order = 0;
+	alt[index_doer] += uphill_order + max_downhill_order - downhill_order;
+			G_fatal_error(_("flat cell escaped in adjustment"));
+		    if (nbr_order_found->flag != 0) {
+			if (is_in_list)
+			    G_warning("adjustment: in_list cell should be in queue");
+    /* clean up */
+    return 0;
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c	2010-05-12 08:28:11 UTC (rev 42234)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c	2010-05-12 09:33:34 UTC (rev 42235)
@@ -33,6 +33,7 @@
     mfd = 1;
     c_fac = 5;
     abs_acc = 0;
+    flat_flag = 0;
     ele_scale = 1;
     for (r = 1; r < argc; r++) {
@@ -82,6 +83,8 @@
 	    mfd = 0;
 	else if (strcmp(argv[r], "-a") == 0)
 	    abs_acc = 1;
+	else if (strcmp(argv[r], "-b") == 0)
+	    flat_flag = 1;
 	else
 	    usage(argv[0]);
@@ -155,7 +158,7 @@
     elebuf = Rast_allocate_buf(ele_map_type);
     if (ele_map_type == FCELL_TYPE || ele_map_type == DCELL_TYPE)
-	ele_scale = 1000; 	/* should be enough to do the trick */
+	ele_scale = 10000; 	/* should be enough to do the trick */
     /* read elevation input and mark NULL/masked cells */
     /* intialize accumulation and drainage direction */
Modified: grass/trunk/raster/r.watershed/ram/main.c
--- grass/trunk/raster/r.watershed/ram/main.c	2010-05-12 08:28:11 UTC (rev 42234)
+++ grass/trunk/raster/r.watershed/ram/main.c	2010-05-12 09:33:34 UTC (rev 42235)
@@ -33,7 +33,7 @@
 CELL n_basins;
 OC_STACK *ocs;
 int ocs_alloced;
-FLAG *worked, *in_list, *s_b, *swale;
+FLAG *worked, *in_list, *s_b, *swale, *flat_done;
@@ -59,7 +59,7 @@
     sg_name[GNAME_MAX];
-char ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
+char ele_flag, pit_flag, run_flag, dis_flag, ob_flag, flat_flag;
