[GRASS-SVN] r42250 - in grass/branches/develbranch_6/gui/wxpython: . gui_modules xml
Thu May 13 17:39:39 EDT 2010
Author: martinl
Date: 2010-05-13 17:39:34 -0400 (Thu, 13 May 2010)
New Revision: 42250
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
mmetz: wxGUI/mapcalc: fix 3D help, make overwrite option visible, find
also interactive (3D) map calculator in command search
(merge r42247, r42248, r42249 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py	2010-05-13 21:25:59 UTC (rev 42249)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py	2010-05-13 21:39:34 UTC (rev 42250)
@@ -37,15 +37,22 @@
     """!Mapcalc Frame class. Calculator-style window to create and run
     r(3).mapcalc statements
-    def __init__(self, parent, id = wx.ID_ANY, title = _('Map calculator'),
-                 rast3d = False, style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER, **kwargs):
+    def __init__(self, parent, cmd, id = wx.ID_ANY, title = _('Map calculator'),
+                 style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER, **kwargs):
         self.parent = parent
         if self.parent:
             self.log = self.parent.GetLogWindow()
         else:
             self.log = None
-        self.rast3d = rast3d
+        # grass command
+        self.cmd = cmd
+        if self.cmd == 'r.mapcalc':
+            self.rast3d = False
+        if self.cmd == 'r3.mapcalc':
+            self.rast3d = True
         wx.Frame.__init__(self, parent, id = id, title = title, **kwargs)
         self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
@@ -304,6 +311,7 @@
         sizer.Add(item = expressSizer, proportion = 1,
                   flag = wx.EXPAND | wx.LEFT | wx.RIGHT,
                   border = 5)
         sizer.Add(item = buttonSizer4, proportion = 0,
                   flag = wx.ALIGN_RIGHT | wx.ALL, border = 1)
@@ -394,17 +402,13 @@
         mctxt = self.text_mcalc.GetValue().strip().replace("\n"," ")
         mctxt = mctxt.replace(" " , "")
-        if self.rast3d:
-            prg = 'r3.mapcalc'
-        else:
-            prg = 'r.mapcalc'
         if self.log:
-            cmd = [prg, str('%s = %s' % (name, mctxt))]
+            cmd = [self.cmd, str('%s = %s' % (name, mctxt))]
             self.log.RunCmd(cmd)
             self.parent.Raise()
         else:
-            gcmd.RunCommand(prg,
+            gcmd.RunCommand(self.cmd,
                             "%s=%s" % (name, mctxt))
     def OnClear(self, event):
@@ -415,7 +419,7 @@
     def OnHelp(self, event):
         """!Launches r.mapcalc help
-        gcmd.RunCommand('g.manual', entry = 'r.mapcalc')
+        gcmd.RunCommand('g.manual', parent = self, entry = self.cmd)
     def OnClose(self,event):
         """!Close window"""
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2010-05-13 21:25:59 UTC (rev 42249)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2010-05-13 21:39:34 UTC (rev 42250)
@@ -164,9 +164,10 @@
                self.SetSize((w, h))
             except:
                 pass
+        else:
+            self.Centre()
         self.Layout()
-        self.Centre()
         self.Show()
         # load workspace file if requested
@@ -1009,18 +1010,26 @@
         self.profile.Refresh()
         self.profile.Update()
-    def OnMapCalculator(self, event):
+    def OnMapCalculator(self, event, cmd = ''):
         """!Init map calculator for interactive creation of mapcalc statements
-        win = mapcalculator.MapCalcFrame(parent = self, title = _('GRASS GIS Map Calculator'))
+        if event:
+            cmd = self.GetMenuCmd(event)
+        win = mapcalculator.MapCalcFrame(parent = self, title = _('GRASS GIS Map Calculator'),
+                                         cmd=cmd[0])
         win.CentreOnScreen()
         win.Show()
-    def OnMapCalculator3D(self, event):
+    def OnMapCalculator3D(self, event, cmd =''):
+        if event:
         win = mapcalculator.MapCalcFrame(parent = self, title = _('GRASS GIS Map Calculator (3D raster)'),
-                                         rast3d = True)
+                                         cmd=cmd[0])
         win.Show()
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2010-05-13 21:25:59 UTC (rev 42249)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2010-05-13 21:39:34 UTC (rev 42250)
@@ -1014,7 +1014,9 @@
 	<menuitem>
 	  <label>Raster calculator</label>
 	  <help>Map calculator for raster map algebra.</help>
+	  <keywords>raster,algebra</keywords>
 	  <handler>OnMapCalculator</handler>
+	  <command>r.mapcalc</command>
 	</menuitem>
 	<menu>
 	  <label>Neighborhood analysis</label>
@@ -2692,7 +2694,9 @@
 	<menuitem>
 	  <label>Volume calculator</label>
 	  <help>Map calculator for 3D raster map algebra.</help>
 	  <handler>OnMapCalculator3D</handler>
+	  <command>r3.mapcalc</command>
 	</menuitem>
 	<menuitem>
 	  <label>Cross section</label>
