[GRASS-SVN] r42257 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat May 15 07:57:12 EDT 2010
Author: martinl
Date: 2010-05-15 07:57:10 -0400 (Sat, 15 May 2010)
New Revision: 42257
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/gui_modules/ghelp.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI: track history of open manual pages
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2010-05-15 10:51:50 UTC (rev 42256)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2010-05-15 11:57:10 UTC (rev 42257)
@@ -1455,3 +1455,35 @@
'ext' : 'xpm' })
return filetype, ltype
+class StaticWrapText(wx.StaticText):
+ """! A Static Text field that wraps its text to fit its width,
+ enlarging its height if necessary.
+ def __init__(self, parent, id = wx.ID_ANY, label = '', *args, **kwds):
+ self.parent = parent
+ self.originalLabel = label
+ wx.StaticText.__init__(self, parent, id, label = '', *args, **kwds)
+ self.SetLabel(label)
+ self.Bind(wx.EVT_SIZE, self.OnResize)
+ def SetLabel(self, label):
+ self.wrappedSize = None
+ self.OnResize(None)
+ def OnResize(self, event):
+ if not getattr(self, "resizing", False):
+ self.resizing = True
+ newSize = wx.Size(self.parent.GetSize().width,
+ self.GetSize().height)
+ if self.wrappedSize != newSize:
+ wx.StaticText.SetLabel(self, self.originalLabel)
+ self.Wrap(newSize.width)
+ self.wrappedSize = newSize
+ self.SetSize(self.wrappedSize)
+ del self.resizing
Modified: grass/trunk/gui/wxpython/gui_modules/ghelp.py
--- grass/trunk/gui/wxpython/gui_modules/ghelp.py 2010-05-15 10:51:50 UTC (rev 42256)
+++ grass/trunk/gui/wxpython/gui_modules/ghelp.py 2010-05-15 11:57:10 UTC (rev 42257)
@@ -12,6 +12,8 @@
- AboutWindow
- InstallExtensionWindow
- ExtensionTree
+ - ManualWindow
+ - ManualPanel
(C) 2008-2010 by the GRASS Development Team
This program is free software under the GNU General Public License
@@ -35,31 +37,23 @@
import menudata
import gcmd
import globalvar
-import menuform
+import gdialogs
class HelpWindow(wx.Frame):
"""!GRASS Quickstart help window"""
def __init__(self, parent, id, title, size, file):
wx.Frame.__init__(self, parent=parent, id=id, title=title, size=size)
sizer = wx.BoxSizer(wx.VERTICAL)
# text
- helpFrame = wx.html.HtmlWindow(parent=self, id=wx.ID_ANY)
- helpFrame.SetStandardFonts (size = 10)
- helpFrame.SetBorders(10)
- wx.InitAllImageHandlers()
- helpFrame.LoadFile(file)
- self.Ok = True
- sizer.Add(item=helpFrame, proportion=1, flag=wx.EXPAND)
+ content = ManualPanel(parent = self)
+ content.LoadPage(file)
+ sizer.Add(item = content, proportion=1, flag=wx.EXPAND)
self.SetAutoLayout(True)
self.SetSizer(sizer)
- # sizer.Fit(self)
- # sizer.SetSizeHints(self)
self.Layout()
class SearchModuleWindow(wx.Panel):
@@ -91,8 +85,8 @@
self.search.Bind(wx.EVT_TEXT, self.OnSearchModule)
if self.showTip:
- self.searchTip = menuform.StaticWrapText(parent = self, id = wx.ID_ANY,
- size = (-1, 35))
+ self.searchTip = gdialogs.StaticWrapText(parent = self, id = wx.ID_ANY,
+ size = (-1, 35))
if self.showChoice:
self.searchChoice = wx.Choice(parent = self, id = wx.ID_ANY)
@@ -1012,3 +1006,180 @@
def IsLoaded(self):
"""Check if items are loaded"""
return self._loaded
+class ManualWindow(wx.html.HtmlWindow):
+ """!This panel holds the text from GRASS docs.
+ GISBASE must be set in the environment to find the html docs dir.
+ The SYNOPSIS section is skipped, since this Panel is supposed to
+ be integrated into the cmdPanel and options are obvious there.
+ def __init__(self, parent, grass_command, text, skip_description,
+ **kwargs):
+ """!If grass_command is given, the corresponding HTML help
+ file will be presented, with all links pointing to absolute
+ paths of local files.
+ If 'skip_description' is True, the HTML corresponding to
+ SYNOPSIS will be skipped, thus only presenting the help file
+ from the DESCRIPTION section onwards.
+ If 'text' is given, it must be the HTML text to be presented
+ in the Panel.
+ wx.InitAllImageHandlers()
+ wx.html.HtmlWindow.__init__(self, parent = parent, **kwargs)
+ gisbase = os.getenv("GISBASE")
+ self.loaded = False
+ self.history = list()
+ self.historyIdx = 0
+ self.fspath = os.path.join(gisbase, "docs", "html")
+ self.SetStandardFonts (size = 10)
+ self.SetBorders(10)
+ if text is None:
+ if skip_description:
+ url = os.path.join(self.fspath, grass_command + ".html")
+ self.fillContentsFromFile(url,
+ skip_description = skip_description)
+ self.history.append(url)
+ self.loaded = True
+ else:
+ ### FIXME: calling LoadPage() is strangely time-consuming (only first call)
+ # self.LoadPage(self.fspath + grass_command + ".html")
+ else:
+ self.SetPage(text)
+ def OnLinkClicked(self, linkinfo):
+ url = linkinfo.GetHref()
+ if url[:4] != 'http':
+ url = os.path.join(self.fspath, url)
+ self.historyIdx += 1
+ self.parent.OnHistory()
+ super(ManualWindow, self).OnLinkClicked(linkinfo)
+ def fillContentsFromFile(self, htmlFile, skip_description=True):
+ """!Load content from file"""
+ aLink = re.compile(r'(<a href="?)(.+\.html?["\s]*>)', re.IGNORECASE)
+ imgLink = re.compile(r'(<img src="?)(.+\.[png|gif])', re.IGNORECASE)
+ try:
+ contents = []
+ skip = False
+ for l in file(htmlFile, "rb").readlines():
+ if "DESCRIPTION" in l:
+ skip = False
+ if not skip:
+ # do skip the options description if requested
+ if "SYNOPSIS" in l:
+ skip = skip_description
+ else:
+ # FIXME: find only first item
+ findALink = aLink.search(l)
+ if findALink is not None:
+ contents.append(aLink.sub(findALink.group(1)+
+ self.fspath+findALink.group(2),l))
+ findImgLink = imgLink.search(l)
+ if findImgLink is not None:
+ contents.append(imgLink.sub(findImgLink.group(1)+
+ self.fspath+findImgLink.group(2),l))
+ if findALink is None and findImgLink is None:
+ contents.append(l)
+ self.SetPage("".join(contents))
+ except: # The Manual file was not found
+class ManualPanel(wx.Panel):
+ def __init__(self, parent, grass_command = "index", text = None,
+ skip_description = False, **kwargs):
+ self.grass_command = grass_command
+ wx.Panel.__init__(self, parent = parent, id = wx.ID_ANY)
+ self.content = ManualWindow(self, grass_command, text,
+ skip_description)
+ self.btnNext = wx.Button(parent = self, id = wx.ID_ANY,
+ label = _("&Next"))
+ self.btnNext.Enable(False)
+ self.btnPrev = wx.Button(parent = self, id = wx.ID_ANY,
+ label = _("&Previous"))
+ self.btnPrev.Enable(False)
+ self.btnNext.Bind(wx.EVT_BUTTON, self.OnNext)
+ self.btnPrev.Bind(wx.EVT_BUTTON, self.OnPrev)
+ self._layout()
+ def _layout(self):
+ """!Do layout"""
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+ btnSizer.Add(item = self.btnPrev, proportion = 0,
+ flag = wx.ALL, border = 5)
+ btnSizer.Add(item = wx.Size(1, 1), proportion = 1)
+ btnSizer.Add(item = self.btnNext, proportion = 0,
+ flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ sizer.Add(item = self.content, proportion = 1,
+ flag = wx.EXPAND)
+ sizer.Add(item = btnSizer, proportion = 0,
+ flag = wx.EXPAND)
+ self.SetSizer(sizer)
+ sizer.Fit(self)
+ def LoadPage(self, path = None):
+ """!Load page"""
+ if not path:
+ path = os.path.join(self.content.fspath, self.grass_command + ".html")
+ self.content.history.append(path)
+ self.content.LoadPage(path)
+ def IsFile(self):
+ """!Check if file exists"""
+ return os.path.isfile(os.path.join(self.content.fspath, self.grass_command + ".html"))
+ def IsLoaded(self):
+ return self.content.loaded
+ def OnHistory(self):
+ """!Update buttons"""
+ nH = len(self.content.history)
+ iH = self.content.historyIdx
+ if iH == nH - 1:
+ elif iH > -1:
+ self.btnNext.Enable(True)
+ if iH < 1:
+ else:
+ self.btnPrev.Enable(True)
+ def OnNext(self, event):
+ """Load next page"""
+ self.content.historyIdx += 1
+ idx = self.content.historyIdx
+ path = self.content.history[idx]
+ self.OnHistory()
+ event.Skip()
+ def OnPrev(self, event):
+ """Load previous page"""
+ self.content.historyIdx -= 1
+ self.OnHistory()
+ event.Skip()
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-05-15 10:51:50 UTC (rev 42256)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-05-15 11:57:10 UTC (rev 42257)
@@ -32,7 +32,7 @@
@todo
- verify option value types
-Copyright (C) 2000-2019 by the GRASS Development Team
+Copyright (C) 2000-2010 by the GRASS Development Team
This program is free software under the GPL (>=v2) Read the file
COPYING coming with GRASS for details.
@@ -83,7 +83,8 @@
except ImportError:
import elementtree.ElementTree as etree # Python <= 2.4
-import utils
+import gdialogs
+from ghelp import ManualPanel
if gisbase is None:
@@ -601,79 +602,7 @@
"""!Get grassTask instance"""
return self.task
-class helpPanel(wx.html.HtmlWindow):
- This panel holds the text from GRASS docs.
- GISBASE must be set in the environment to find the html docs dir.
- The SYNOPSIS section is skipped, since this Panel is supposed to
- be integrated into the cmdPanel and options are obvious there.
- def __init__(self, grass_command = "index", text = None,
- skip_description=False, *args, **kwargs):
- """ If grass_command is given, the corresponding HTML help file will
- be presented, with all links pointing to absolute paths of
- local files.
- If 'skip_description' is True, the HTML corresponding to
- SYNOPSIS will be skipped, thus only presenting the help file
- from the DESCRIPTION section onwards.
- If 'text' is given, it must be the HTML text to be presented in the Panel.
- wx.html.HtmlWindow.__init__(self, *args, **kwargs)
- self.fspath = gisbase + "/docs/html/"
- self.SetStandardFonts ( size = 10 )
- self.SetBorders(10)
- if text is None:
- if skip_description:
- self.fillContentsFromFile ( self.fspath + grass_command + ".html",
- skip_description=skip_description )
- self.Ok = True
- else:
- ### FIXME: calling LoadPage() is strangely time-consuming (only first call)
- # self.LoadPage(self.fspath + grass_command + ".html")
- self.Ok = False
- else:
- self.SetPage( text )
- self.Ok = True
- def fillContentsFromFile( self, htmlFile, skip_description=True ):
- aLink = re.compile( r'(<a href="?)(.+\.html?["\s]*>)', re.IGNORECASE )
- imgLink = re.compile( r'(<img src="?)(.+\.[png|gif])', re.IGNORECASE )
- try:
- # contents = [ '<head><base href="%s"></head>' % self.fspath ]
- contents = []
- skip = False
- for l in file( htmlFile, "rb" ).readlines():
- if "DESCRIPTION" in l:
- skip = False
- if not skip:
- # do skip the options description if requested
- if "SYNOPSIS" in l:
- skip = skip_description
- else:
- # FIXME: find only first item
- findALink = aLink.search( l )
- if findALink is not None:
- contents.append( aLink.sub(findALink.group(1)+
- self.fspath+findALink.group(2),l) )
- findImgLink = imgLink.search( l )
- if findImgLink is not None:
- contents.append( imgLink.sub(findImgLink.group(1)+
- self.fspath+findImgLink.group(2),l) )
- if findALink is None and findImgLink is None:
- contents.append( l )
- self.SetPage( "".join( contents ) )
- self.Ok = True
- except: # The Manual file was not found
- self.Ok = False
class mainFrame(wx.Frame):
"""!This is the Frame containing the dialog for options input.
@@ -745,8 +674,8 @@
module_desc = self.task.label + ' ' + self.task.description
else:
module_desc = self.task.description
- self.description = StaticWrapText (parent=self.panel,
- label=module_desc)
+ self.description = gdialogs.StaticWrapText(parent=self.panel,
+ label=module_desc)
topsizer.Add (item=self.description, proportion=1, border=5,
flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
@@ -1105,9 +1034,8 @@
self.goutput = None
self.goutputId = -1
- self.manual_tab = helpPanel(parent = self.notebook, grass_command = self.task.name)
- self.manual_tabsizer = wx.BoxSizer(wx.VERTICAL)
- if not os.path.isfile(self.manual_tab.fspath + self.task.name + ".html"):
+ self.manual_tab = ManualPanel(parent = self, grass_command = self.task.name)
+ if not self.manual_tab.IsFile():
self.manual_tab.Hide()
else:
self.notebook.AddPage(self.manual_tab, text=_("Manual"))
@@ -1700,10 +1628,9 @@
tab[section].SetMinSize( (self.constrained_size[0], self.panelMinHeight) )
# tab[section].SetMinSize( constrained_size )
- if self.manual_tab.Ok:
+ if self.manual_tab.IsLoaded():
self.manual_tab.SetMinSize( (self.constrained_size[0], self.panelMinHeight) )
- # manual_tab.SetMinSize( constrained_size )
self.SetSizer( panelsizer )
panelsizer.Fit(self.notebook)
@@ -1800,10 +1727,9 @@
sel == self.manual_tab_id:
# calling LoadPage() is strangely time-consuming (only first call)
# FIXME: move to helpPage.__init__()
- if not self.manual_tab.Ok:
+ if not self.manual_tab.IsLoaded():
wx.Yield()
- self.manual_tab.LoadPage(self.manual_tab.fspath + self.task.name + ".html")
- self.manual_tab.Ok = True
+ self.manual_tab.LoadPage()
self.Layout()
@@ -2130,37 +2056,6 @@
return p.get('name', None)
return None
-class StaticWrapText(wx.StaticText):
- """! A Static Text field that wraps its text to fit its width,
- enlarging its height if necessary.
- def __init__(self, parent, id = wx.ID_ANY, label = '', *args, **kwds):
- self.parent = parent
- self.originalLabel = label
- wx.StaticText.__init__(self, parent, id, label = '', *args, **kwds)
- self.SetLabel(label)
- self.Bind(wx.EVT_SIZE, self.OnResize)
- def SetLabel(self, label):
- self.wrappedSize = None
- self.OnResize(None)
- def OnResize(self, event):
- if not getattr(self, "resizing", False):
- self.resizing = True
- newSize = wx.Size(self.parent.GetSize().width,
- self.GetSize().height)
- if self.wrappedSize != newSize:
- wx.StaticText.SetLabel(self, self.originalLabel)
- self.Wrap(newSize.width)
- self.wrappedSize = newSize
- self.SetSize(self.wrappedSize)
- del self.resizing
if __name__ == "__main__":
if len(sys.argv) == 1:
