[GRASS-SVN] r42262 - in grass/trunk: include lib/python
lib/python/ctypes swig
svn_grass at osgeo.org
Sun May 16 11:39:16 EDT 2010
Author: glynn
Date: 2010-05-16 11:39:16 -0400 (Sun, 16 May 2010)
New Revision: 42262
Added:
grass/trunk/lib/python/ctypes/
grass/trunk/lib/python/ctypes/Makefile
grass/trunk/lib/python/ctypes/__init__.py
grass/trunk/include/gisdefs.h
grass/trunk/lib/python/Makefile
grass/trunk/swig/Makefile
Replace SWIG with ctypesgen for Python bindings
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2010-05-16 15:37:24 UTC (rev 42261)
+++ grass/trunk/include/gisdefs.h 2010-05-16 15:39:16 UTC (rev 42262)
@@ -64,9 +64,15 @@
void *G_incr_void_ptr(const void *, size_t);
#endif
+#ifndef CTYPESGEN
#define G_malloc(n) G__malloc(__FILE__, __LINE__, (n))
#define G_calloc(m, n) G__calloc(__FILE__, __LINE__, (m), (n))
#define G_realloc(p, n) G__realloc(__FILE__, __LINE__, (p), (n))
+#else
+#define G_malloc(n) G__malloc("<ctypesgen>", 0, (n))
+#define G_calloc(m, n) G__calloc("<ctypesgen>", 0, (m), (n))
+#define G_realloc(p, n) G__realloc("<ctypesgen>", 0, (p), (n))
+#endif
/* area.c */
int G_begin_cell_area_calculations(void);
Modified: grass/trunk/lib/python/Makefile
--- grass/trunk/lib/python/Makefile 2010-05-16 15:37:24 UTC (rev 42261)
+++ grass/trunk/lib/python/Makefile 2010-05-16 15:39:16 UTC (rev 42262)
@@ -13,7 +13,10 @@
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
+CLEAN_SUBDIRS = ctypes
default: $(PYFILES) $(PYCFILES) $(GDIR)/__init__.py $(GDIR)/__init__.pyc
+ $(MAKE) -C ctypes
$(PYDIR):
$(MKDIR) $@
Added: grass/trunk/lib/python/ctypes/Makefile
--- grass/trunk/lib/python/ctypes/Makefile (rev 0)
+++ grass/trunk/lib/python/ctypes/Makefile 2010-05-16 15:39:16 UTC (rev 42262)
@@ -0,0 +1,84 @@
+MODULE_TOPDIR = ../../..
+PACKAGE = "grasslibs"
+include $(MODULE_TOPDIR)/include/Make/Other.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
+# doxygen:
+DOXNAME=
+DOXINPUT=grasspython.dox
+MODULES = date grass raster gmath proj imagery vector display stats \
+ dbmi g3d arraystats cluster trans vedit
+date_LIBS = $(DATETIMELIB)
+grass_LIBS = $(GISLIB)
+raster_LIBS = $(RASTERLIB)
+gmath_LIBS = $(GMATHLIB)
+proj_LIBS = $(GPROJLIB)
+imagery_LIBS = $(IMAGERYLIB)
+vector_LIBS = $(VECTLIB)
+display_LIBS = $(DISPLAYLIB)
+stats_LIBS = $(STATSLIB)
+dbmi_LIBS = $(DBMILIB)
+g3d_LIBS = $(G3DLIB)
+arraystats_LIBS = $(ARRAYSTATSLIB)
+cluster_LIBS = $(CLUSTERLIB)
+trans_LIBS = $(TRANSLIB)
+vedit_LIBS = $(VEDITLIB)
+date_INC = datetime.h P_datetime.h
+grass_INC = gis.h gisdefs.h
+raster_INC = raster.h rasterdefs.h
+gmath_INC = gmath.h
+proj_INC = gprojects.h
+imagery_INC = imagery.h imagedefs.h
+vector_INC = vector.h vect/dig_structs.h vect/dig_defines.h
+display_INC = display.h
+stats_INC = stats.h
+dbmi_INC = dbmi.h
+g3d_INC = G3d.h
+arraystats_INC = arraystats.h
+cluster_INC = cluster.h
+trans_INC = transform.h
+vedit_INC = vedit.h
+CTYPESGEN = ctypesgen.py
+CTYPESFLAGS = $(INC) $(LIBPATH)
+EXTRA_CLEAN_FILES := $(foreach M,$(MODULES),$(M).pyc $(M).py)
+ifneq ($(MINGW),)
+EXTRA_LIBS = $(INTLLIB)
+endif
+include $(MODULE_TOPDIR)/include/Make/Python.make
+PYDIR = $(ETC)/python
+GDIR = $(PYDIR)/grass
+DSTDIR = $(GDIR)/lib
+PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
+PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
+LPYFILES := $(patsubst %,%.py,$(MODULES))
+default:
+ $(MAKE) $(DSTDIR)
+ $(MAKE) $(LPYFILES) $(PYFILES) $(PYCFILES)
+$(DSTDIR)/%.py: %.py | $(DSTDIR)
+ $(INSTALL_DATA) $< $@
+%.py: $(%_INC) $(%_LIBS)
+ $(CTYPESGEN) $(CTYPESFLAGS) $($*_LIBS) $(EXTRA_LIBS) $(patsubst %.h,$(ARCH_INCDIR)/%.h,$($*_INC)) -o $@
+$(PYDIR):
+ $(MKDIR) $@
+$(GDIR): | $(PYDIR)
+ $(MKDIR) $@
+$(DSTDIR): | $(GDIR)
+ $(MKDIR) $@
+.SECONDARY: $(patsubst %,%.py,$(MODULES))
Added: grass/trunk/lib/python/ctypes/__init__.py
--- grass/trunk/lib/python/ctypes/__init__.py (rev 0)
+++ grass/trunk/lib/python/ctypes/__init__.py 2010-05-16 15:39:16 UTC (rev 42262)
@@ -0,0 +1,16 @@
+import date
+import grass
+import raster
+import gmath
+import proj
+import imagery
+import vector
+import display
+import stats
+import dbmi
+import g3d
+import arraystats
+import cluster
+import trans
+import vedit
Modified: grass/trunk/swig/Makefile
--- grass/trunk/swig/Makefile 2010-05-16 15:37:24 UTC (rev 42261)
+++ grass/trunk/swig/Makefile 2010-05-16 15:39:16 UTC (rev 42262)
@@ -5,7 +5,7 @@
#compile if PYTHON present:
ifneq ($(USE_PYTHON),)
ifneq ($(strip $(CXX)),)
- SUBDIRS += python
+# SUBDIRS += python
endif
endif
