[GRASS-SVN] r42271 - in grass/trunk: . include/Make lib/python
lib/python/ctypes
svn_grass at osgeo.org
Mon May 17 13:45:06 EDT 2010
Author: glynn
Date: 2010-05-17 13:45:05 -0400 (Mon, 17 May 2010)
New Revision: 42271
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/include/Make/Platform.make.in
grass/trunk/lib/python/Makefile
grass/trunk/lib/python/ctypes/
grass/trunk/lib/python/ctypes/Makefile
Add configure check for ctypesgen
Ignore configure failures for SWIG
Ignore build failures for lib/python/ctypes
Modified: grass/trunk/configure
--- grass/trunk/configure 2010-05-17 15:17:31 UTC (rev 42270)
+++ grass/trunk/configure 2010-05-17 17:45:05 UTC (rev 42271)
@@ -14201,8 +14201,48 @@
fi
- if test "$SWIG" = "no" ; then
- { echo "configure: error: *** couldn't find swig" 1>&2; exit 1; }
+ # if test "$SWIG" = "no" ; then
+ # AC_MSG_ERROR([*** couldn't find swig])
+ # fi
+ # look for the ctypesgen.py script
+ # Extract the first word of "ctypesgen.py", so it can be a program name with args.
+set dummy ctypesgen.py; ac_word=$2
+echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
+echo "configure:14213: checking for $ac_word" >&5
+case "$CTYPESGEN" in
+ ac_cv_path_CTYPESGEN="$CTYPESGEN" # Let the user override the test with a path.
+ ac_cv_path_CTYPESGEN="$CTYPESGEN" # Let the user override the test with a dos path.
+ IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
+ ac_dummy="$PATH"
+ for ac_dir in $ac_dummy; do
+ test -z "$ac_dir" && ac_dir=.
+ if test -f $ac_dir/$ac_word; then
+ ac_cv_path_CTYPESGEN="$ac_dir/$ac_word"
+ break
+ fi
+ done
+ IFS="$ac_save_ifs"
+ test -z "$ac_cv_path_CTYPESGEN" && ac_cv_path_CTYPESGEN="no"
+esac
+CTYPESGEN="$ac_cv_path_CTYPESGEN"
+if test -n "$CTYPESGEN"; then
+ echo "$ac_t""$CTYPESGEN" 1>&6
+else
+ echo "$ac_t""no" 1>&6
+fi
+ if test "$CTYPESGEN" = "no" ; then
+ echo "configure: warning: *** couldn't find ctypesgen" 1>&2
+ CTYPESGEN=
fi
# check for available OSX archs in Python, assume framework
@@ -14229,10 +14269,11 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14236: checking whether to use wxWidgets" >&5
+echo "configure:14277: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -14253,7 +14294,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:14257: checking for $ac_word" >&5
+echo "configure:14298: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -14301,7 +14342,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14305: checking wxWidgets version" >&5
+echo "configure:14346: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -14324,15 +14365,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14328: checking for $ac_hdr" >&5
+echo "configure:14369: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 14331 "configure"
+#line 14372 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:14336: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -14663,6 +14704,7 @@
s%@USE_LARGEFILES@%$USE_LARGEFILES%g
s%@PY_CONFIG@%$PY_CONFIG%g
s%@SWIG@%$SWIG%g
+s%@CTYPESGEN@%$CTYPESGEN%g
s%@PYTHONINC@%$PYTHONINC%g
s%@PYTHONCFLAGS@%$PYTHONCFLAGS%g
s%@PYTHONLDFLAGS@%$PYTHONLDFLAGS%g
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2010-05-17 15:17:31 UTC (rev 42270)
+++ grass/trunk/configure.in 2010-05-17 17:45:05 UTC (rev 42271)
@@ -1785,8 +1785,16 @@
# look for the swig program
AC_PATH_PROG(SWIG, swig, no)
- AC_MSG_ERROR([*** couldn't find swig])
+ # fi
+ AC_PATH_PROG(CTYPESGEN, ctypesgen.py, no)
+ AC_MSG_WARN([*** couldn't find ctypesgen])
+ CTYPESGEN=
fi
@@ -1810,6 +1818,7 @@
AC_SUBST(PYTHONCFLAGS)
AC_SUBST(PYTHONLDFLAGS)
AC_SUBST(SWIG)
+AC_SUBST(CTYPESGEN)
AC_SUBST(USE_PYTHON)
AC_SUBST(MACOSX_ARCHS_PYTHON)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2010-05-17 15:17:31 UTC (rev 42270)
+++ grass/trunk/include/Make/Platform.make.in 2010-05-17 17:45:05 UTC (rev 42271)
@@ -220,6 +220,7 @@
PYTHONCFLAGS = @PYTHONCFLAGS@
PYTHONLDFLAGS = @PYTHONLDFLAGS@
SWIG = @SWIG@
+CTYPESGEN = @CTYPESGEN@
USE_PYTHON = @USE_PYTHON@
MACOSX_ARCHS_PYTHON = @MACOSX_ARCHS_PYTHON@
Modified: grass/trunk/lib/python/Makefile
--- grass/trunk/lib/python/Makefile 2010-05-17 15:17:31 UTC (rev 42270)
+++ grass/trunk/lib/python/Makefile 2010-05-17 17:45:05 UTC (rev 42271)
@@ -16,7 +16,7 @@
CLEAN_SUBDIRS = ctypes
default: $(PYFILES) $(PYCFILES) $(GDIR)/__init__.py $(GDIR)/__init__.pyc
- $(MAKE) -C ctypes
+ -$(MAKE) -C ctypes
$(PYDIR):
$(MKDIR) $@
Property changes on: grass/trunk/lib/python/ctypes
___________________________________________________________________
Added: svn:ignore
+ [a-z]*.py
Modified: grass/trunk/lib/python/ctypes/Makefile
--- grass/trunk/lib/python/ctypes/Makefile 2010-05-17 15:17:31 UTC (rev 42270)
+++ grass/trunk/lib/python/ctypes/Makefile 2010-05-17 17:45:05 UTC (rev 42271)
@@ -44,7 +44,6 @@
trans_INC = transform.h
vedit_INC = vedit.h
-CTYPESGEN = ctypesgen.py
CTYPESFLAGS = $(INC) $(LIBPATH)
EXTRA_CLEAN_FILES := $(foreach M,$(MODULES),$(M).pyc $(M).py)
@@ -62,9 +61,11 @@
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
LPYFILES := $(patsubst %,%.py,$(MODULES))
+ifneq ($(strip $(CTYPESGEN)),)
default:
$(MAKE) $(DSTDIR)
$(MAKE) $(LPYFILES) $(PYFILES) $(PYCFILES)
+endif
$(DSTDIR)/%.py: %.py | $(DSTDIR)
$(INSTALL_DATA) $< $@
