[GRASS-SVN] r42279 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue May 18 02:56:05 EDT 2010
Author: mmetz
Date: 2010-05-18 02:56:03 -0400 (Tue, 18 May 2010)
New Revision: 42279
grass/trunk/lib/vector/Vlib/write.c
format
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c 2010-05-18 01:10:38 UTC (rev 42278)
+++ grass/trunk/lib/vector/Vlib/write.c 2010-05-18 06:56:03 UTC (rev 42279)
@@ -141,8 +141,8 @@
\return offset into file where the feature starts (level 1)
off_t
-Vect_write_line(struct Map_info *Map,
- int type, const struct line_pnts *points, const struct line_cats *cats)
+Vect_write_line(struct Map_info *Map, int type,
+ const struct line_pnts *points, const struct line_cats *cats)
off_t offset;
@@ -189,9 +189,8 @@
\return -1 on error
off_t
-Vect_rewrite_line(struct Map_info *Map,
- int line,
+Vect_rewrite_line(struct Map_info *Map, int line, int type,
off_t ret, offset;
