[GRASS-SVN] r42286 - grass/trunk/raster/r.to.vect
svn_grass at osgeo.org
Tue May 18 06:46:53 EDT 2010
Author: martinl
Date: 2010-05-18 06:46:53 -0400 (Tue, 18 May 2010)
New Revision: 42286
grass/trunk/raster/r.to.vect/main.c
r.to.vect: more guisections
Modified: grass/trunk/raster/r.to.vect/main.c
--- grass/trunk/raster/r.to.vect/main.c 2010-05-18 10:43:07 UTC (rev 42285)
+++ grass/trunk/raster/r.to.vect/main.c 2010-05-18 10:46:53 UTC (rev 42286)
@@ -68,7 +68,9 @@
module = G_define_module();
G_add_keyword(_("raster"));
- module->description = _("Converts a raster map into a vector map layer.");
+ G_add_keyword(_("conversion"));
+ G_add_keyword(_("vectorization"));
+ module->description = _("Converts a raster map into a vector map.");
in_opt = G_define_standard_option(G_OPT_R_INPUT);
@@ -91,12 +93,14 @@
value_flg->key = 'v';
value_flg->description =
_("Use raster values as categories instead of unique sequence (CELL only)");
+ value_flg->guisection = _("Attributes");
z_flg = G_define_flag();
z_flg->key = 'z';
z_flg->description =
_("Write raster values as z coordinate. Table is not created. "
"Currently supported only for points.");
+ z_flg->guisection = _("Attributes");
no_topol = G_define_flag();
no_topol->key = 'b';
