[GRASS-SVN] r42300 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue May 18 09:33:52 EDT 2010
Author: martinl
Date: 2010-05-18 09:33:50 -0400 (Tue, 18 May 2010)
New Revision: 42300
grass/trunk/gui/wxpython/gui_modules/debug.py
grass/trunk/gui/wxpython/gui_modules/wxnviz.py
wxGUI/wxnviz: use Debug.msg instead of G_debug
Modified: grass/trunk/gui/wxpython/gui_modules/debug.py
--- grass/trunk/gui/wxpython/gui_modules/debug.py 2010-05-18 13:24:33 UTC (rev 42299)
+++ grass/trunk/gui/wxpython/gui_modules/debug.py 2010-05-18 13:33:50 UTC (rev 42300)
@@ -49,11 +49,15 @@
if self.debuglevel != level:
self.debuglevel = level
- def msg (self, level, message):
+ def msg (self, level, message, *args):
self._update_level()
if self.debuglevel > 0 and level > 0 and level <= self.debuglevel:
- print >> sys.stderr, "GUI D%d/%d: %s" % (level, self.debuglevel, message)
+ if args:
+ print >> sys.stderr, "GUI D%d/%d: " % (level, self.debuglevel) + \
+ message % args
+ else:
+ message
def get_level(self):
"""!Return current GUI debug level"""
return self.debuglevel
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2010-05-18 13:24:33 UTC (rev 42299)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2010-05-18 13:33:50 UTC (rev 42300)
@@ -23,8 +23,7 @@
from grass.lib.ogsf import *
from grass.lib.nviz import *
-def G_debug(level, str, *args):
- print str, args
+from debug import Debug
class Nviz(object):
def __init__(self, log):
@@ -46,7 +45,7 @@
self.data_obj = nv_data()
self.data = pointer(self.data_obj)
- G_debug(1, "Nviz::Nviz()")
+ Debug.msg(1, "Nviz::Nviz()")
def __del__(self):
"""!Destroy Nviz class instance"""
@@ -66,8 +65,8 @@
@return 0 on failure (window resized by default to 20x20 px)
- G_debug(1, "Nviz::ResizeWindow(): width=%d height=%d",
- width, height)
+ Debug.msg(1, "Nviz::ResizeWindow(): width=%d height=%d",
+ width, height)
return Nviz_resize_window(width, height)
def SetViewDefault(self):
@@ -85,8 +84,8 @@
hmax = c_float()
Nviz_get_exag_height(byref(hdef), byref(hmin), byref(hmax))
- G_debug(1, "Nviz::SetViewDefault(): hdef=%f, hmin=%f, hmax=%f",
- hdef, hmin, hmax)
+ Debug.msg(1, "Nviz::SetViewDefault(): hdef=%f, hmin=%f, hmax=%f",
+ hdef.value, hmin.value, hmax.value)
return (z_exag, hdef.value, hmin.value, hmax.value)
@@ -104,8 +103,8 @@
Nviz_set_viewpoint_twist(self.data, twist)
Nviz_set_viewpoint_persp(self.data, persp)
- G_debug(1, "Nviz::SetView(): x=%f, y=%f, height=%f, persp=%f, twist=%f",
- x, y, height, persp, twist)
+ Debug.msg(1, "Nviz::SetView(): x=%f, y=%f, height=%f, persp=%f, twist=%f",
+ x, y, height, persp, twist)
return 1
@@ -116,7 +115,7 @@
@return 1
- G_debug(1, "Nviz::SetZExag(): z_exag=%f", z_exag)
+ Debug.msg(1, "Nviz::SetZExag(): z_exag=%f", z_exag)
return Nviz_change_exag(self.data, z_exag)
def Draw(self, quick, quick_mode):
@@ -138,13 +137,13 @@
else:
Nviz_draw_all(self.data)
- G_debug(1, "Nviz::Draw(): quick=%d", quick)
+ Debug.msg(1, "Nviz::Draw(): quick=%d", quick)
def EraseMap(self):
"""!Erase map display (with background color)
GS_clear(self.data.bgcolor)
- G_debug(1, "Nviz::EraseMap()")
+ Debug.msg(1, "Nviz::EraseMap()")
def InitView(self):
"""!Initialize view"""
@@ -165,7 +164,7 @@
# clear window
- G_debug(1, "Nviz::InitView()")
+ Debug.msg(1, "Nviz::InitView()")
def SetBgColor(self, color_str):
"""!Set background color
@@ -189,7 +188,7 @@
Nviz_set_light_color(self.data, 1, 1.0, 1.0, 1.0)
Nviz_set_light_ambient(self.data, 1, 0.3, 0.3, 0.3)
- G_debug(1, "Nviz::SetLightsDefault()")
+ Debug.msg(1, "Nviz::SetLightsDefault()")
def LoadSurface(self, name, color_name, color_value):
"""!Load raster map (surface)
@@ -238,7 +237,7 @@
# focus on loaded self.data
Nviz_set_focus_map(MAP_OBJ_UNDEFINED, -1)
- G_debug(1, "Nviz::LoadRaster(): name=%s -> id=%d", name, id)
+ Debug.msg(1, "Nviz::LoadRaster(): name=%s -> id=%d", name, id)
return id
@@ -253,7 +252,7 @@
if not GS_surf_exists(id):
return 0
- G_debug(1, "Nviz::UnloadSurface(): id=%d", id)
+ Debug.msg(1, "Nviz::UnloadSurface(): id=%d", id)
if GS_delete_surface(id) < 0:
return 0
@@ -290,7 +289,7 @@
G_fully_qualified_name(name, mapset), 0.0,
self.data)
- G_debug(1, "Nviz::LoadVector(): name=%s -> id=%d", name, id)
+ Debug.msg(1, "Nviz::LoadVector(): name=%s -> id=%d", name, id)
return id
@@ -303,7 +302,7 @@
@return 1 on success
- G_debug(1, "Nviz::UnloadVector(): id=%d", id)
+ Debug.msg(1, "Nviz::UnloadVector(): id=%d", id)
if points:
if not GP_site_exists(id):
@@ -359,7 +358,7 @@
G_fully_qualified_name(name, mapset), -1.0,
self.data)
- G_debug(1, "Nviz::LoadVolume(): name=%s -> id=%d", name, id)
+ Debug.msg(1, "Nviz::LoadVolume(): name=%s -> id=%d", name, id)
return id
@@ -374,7 +373,7 @@
if not GVL_vol_exists(id):
return 0
- G_debug(1, "Nviz::UnloadVolume(): id=%d", id)
+ Debug.msg(1, "Nviz::UnloadVolume(): id=%d", id)
if GVL_delete_vol(id) < 0:
return 0
@@ -490,8 +489,8 @@
ret = Nviz_set_attr(id, MAP_OBJ_SURF, attr, CONST_ATT,
NULL, val, self.data)
- G_debug(1, "Nviz::SetSurfaceAttr(): id=%d, attr=%d, map=%d, value=%s",
- id, attr, map, value)
+ Debug.msg(1, "Nviz::SetSurfaceAttr(): id=%d, attr=%d, map=%d, value=%s",
+ id, attr, map, value)
return 1 if ret else -2
@@ -542,8 +541,8 @@
return -1
- G_debug(1, "Nviz::UnsetSurfaceAttr(): id=%d, attr=%d",
- id, attr)
+ Debug.msg(1, "Nviz::UnsetSurfaceAttr(): id=%d, attr=%d",
+ id, attr)
ret = Nviz_unset_attr(id, MAP_OBJ_SURF, attr)
@@ -560,7 +559,7 @@
@return -1 surface not found
@return -2 setting attributes failed
- G_debug(1, "Nviz::SetSurfaceRes(): id=%d, fine=%d, coarse=%d",
+ Debug.msg(1, "Nviz::SetSurfaceRes(): id=%d, fine=%d, coarse=%d",
id, fine, coarse)
if id > 0:
@@ -595,8 +594,8 @@
- G_debug(1, "Nviz::SetSurfaceStyle(): id=%d, style=%d",
- id, style)
+ Debug.msg(1, "Nviz::SetSurfaceStyle(): id=%d, style=%d",
+ id, style)
if id > 0:
@@ -626,8 +625,8 @@
- G_debug(1, "Nviz::SetWireColor(): id=%d, color=%s",
- id, color_str)
+ Debug.msg(1, "Nviz::SetWireColor(): id=%d, color=%s",
+ id, color_str)
color = Nviz_color_from_str(color_str)
@@ -662,8 +661,8 @@
x, y, z = c_float(), c_float(), c_float()
GS_get_trans(id, byref(x), byref(y), byref(z))
- G_debug(1, "Nviz::GetSurfacePosition(): id=%d, x=%f, y=%f, z=%f",
- id, x, y, z)
+ Debug.msg(1, "Nviz::GetSurfacePosition(): id=%d, x=%f, y=%f, z=%f",
+ id, x, y, z)
return [x.value, y.value, z.value]
@@ -680,8 +679,8 @@
return -1
- G_debug(1, "Nviz::SetSurfacePosition(): id=%d, x=%f, y=%f, z=%f",
- id, x, y, z)
+ Debug.msg(1, "Nviz::SetSurfacePosition(): id=%d, x=%f, y=%f, z=%f",
+ id, x, y, z)
GS_set_trans(id, x, y, z)
@@ -702,8 +701,8 @@
if not GV_vect_exists(id):
return -1
- G_debug(1, "Nviz::SetVectorMode(): id=%d, color=%s, width=%d, flat=%d",
- id, color_str, width, flat)
+ Debug.msg(1, "Nviz::SetVectorMode(): id=%d, color=%s, width=%d, flat=%d",
+ id, color_str, width, flat)
@@ -725,8 +724,8 @@
return -1
- G_debug(1, "Nviz::SetVectorLineHeight(): id=%d, height=%f",
- id, height)
+ Debug.msg(1, "Nviz::SetVectorLineHeight(): id=%d, height=%f",
+ id, height)
GV_set_trans(id, 0.0, 0.0, height)
@@ -767,9 +766,9 @@
return -1
- G_debug(1, "Nviz::SetVectorPointMode(): id=%d, color=%s, "
- "width=%d, size=%f, marker=%d",
- id, color_str, width, size, marker)
+ Debug.msg(1, "Nviz::SetVectorPointMode(): id=%d, color=%s, "
+ "width=%d, size=%f, marker=%d",
+ id, color_str, width, size, marker)
@@ -790,8 +789,8 @@
return -1
- G_debug(1, "Nviz::SetVectorPointHeight(): id=%d, height=%f",
- id, height)
+ Debug.msg(1, "Nviz::SetVectorPointHeight(): id=%d, height=%f",
+ id, height)
GP_set_trans(id, 0.0, 0.0, height)
@@ -992,9 +991,9 @@
ret = GVL_isosurf_set_att_const(id, isosurf_id, attr, val)
- G_debug(1, "Nviz::SetIsosurfaceAttr(): id=%d, isosurf=%d, "
- "attr=%d, map=%d, value=%s",
- id, isosurf_id, attr, map, value)
+ Debug.msg(1, "Nviz::SetIsosurfaceAttr(): id=%d, isosurf=%d, "
+ "attr=%d, map=%d, value=%s",
+ id, isosurf_id, attr, map, value)
return 1 if ret > 0 else -2
@@ -1055,8 +1054,8 @@
if isosurf_id > GVL_isosurf_num_isosurfs(id) - 1:
return -2
- G_debug(1, "Nviz::UnsetSurfaceAttr(): id=%d, isosurf_id=%d, attr=%d",
- id, isosurf_id, attr)
+ Debug.msg(1, "Nviz::UnsetSurfaceAttr(): id=%d, isosurf_id=%d, attr=%d",
+ id, isosurf_id, attr)
ret = GVL_isosurf_unset_att(id, isosurf_id, attr)
