[GRASS-SVN] r42316 - in grass/trunk/vector/lidar: lidarlib
r.resamp.bspline v.lidar.correction v.lidar.edgedetection
v.lidar.growing v.outlier v.surf.bspline
svn_grass at osgeo.org
Wed May 19 04:50:10 EDT 2010
Author: mmetz
Date: 2010-05-19 04:50:08 -0400 (Wed, 19 May 2010)
New Revision: 42316
Added:
grass/trunk/vector/lidar/lidarlib/lidar.h
Removed:
grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
grass/trunk/vector/lidar/lidarlib/InterpSpline.c
grass/trunk/vector/lidar/lidarlib/Makefile
grass/trunk/vector/lidar/lidarlib/raster.c
grass/trunk/vector/lidar/lidarlib/zones.c
grass/trunk/vector/lidar/r.resamp.bspline/bspline.h
grass/trunk/vector/lidar/r.resamp.bspline/crosscorr.c
grass/trunk/vector/lidar/r.resamp.bspline/main.c
grass/trunk/vector/lidar/r.resamp.bspline/resamp.c
grass/trunk/vector/lidar/v.lidar.correction/correction.c
grass/trunk/vector/lidar/v.lidar.correction/correction.h
grass/trunk/vector/lidar/v.lidar.correction/main.c
grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h
grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c
grass/trunk/vector/lidar/v.lidar.growing/growing.c
grass/trunk/vector/lidar/v.lidar.growing/growing.h
grass/trunk/vector/lidar/v.lidar.growing/main.c
grass/trunk/vector/lidar/v.outlier/main.c
grass/trunk/vector/lidar/v.outlier/outlier.c
grass/trunk/vector/lidar/v.outlier/outlier.h
grass/trunk/vector/lidar/v.surf.bspline/bspline.h
grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
grass/trunk/vector/lidar/v.surf.bspline/main.c
reorganizing lidar tools: update headers
Modified: grass/trunk/vector/lidar/lidarlib/InterpSpline.c
--- grass/trunk/vector/lidar/lidarlib/InterpSpline.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/lidarlib/InterpSpline.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -22,9 +22,8 @@
#include <float.h>
#include <math.h>
#include <string.h>
+#include <grass/lidar.h>
-#include "PolimiFunct.h"
/* Abscissa node index computation */
Modified: grass/trunk/vector/lidar/lidarlib/Makefile
--- grass/trunk/vector/lidar/lidarlib/Makefile 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/lidarlib/Makefile 2010-05-19 08:50:08 UTC (rev 42316)
@@ -8,7 +8,8 @@
include $(MODULE_TOPDIR)/include/Make/Lib.make
-default: $(ARCH_INCDIR)/PolimiFunct.h lib
+default: $(ARCH_INCDIR)/lidar.h
+ $(MAKE) lib
-$(ARCH_INCDIR)/PolimiFunct.h: PolimiFunct.h
- cp PolimiFunct.h $(ARCH_INCDIR)/PolimiFunct.h
+$(ARCH_INCDIR)/lidar.h: lidar.h
+ $(INSTALL_DATA) lidar.h $(ARCH_INCDIR)/lidar.h
Deleted: grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
--- grass/trunk/vector/lidar/lidarlib/PolimiFunct.h 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/lidarlib/PolimiFunct.h 2010-05-19 08:50:08 UTC (rev 42316)
@@ -1,218 +0,0 @@
- * MODULE: lidarlib
- * AUTHOR(S): Roberto Antolin
- * PURPOSE: LIDAR library
- * COPYRIGHT: (C) 2006 by Politecnico di Milano -
- * Polo Regionale di Como
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
-#ifndef _POLIMIFUNCT_H_
-#define _POLIMIFUNCT_H_
-#include <grass/config.h>
-#include <grass/gis.h>
-#include <grass/vector.h>
-#include <grass/dbmi.h>
-#include <grass/glocale.h>
-#include <grass/gmath.h>
-/*CONSTANTS DECLARATION */
-#define NSPLX_MAX 150 /* Maximum number of splines along East direction used in the subregions interpolation */
-#define NSPLY_MAX 150 /* Maximum number of splines along North direction used in the subregions interpolation */
-#define OVERLAP_SIZE 10 /* Subregions overlapping size. */
-#define LATO 1000 /* Side's size for v.lidar.growing. */
-#define CONTOUR 15 /**/
-#define GENERAL_ROW 0
-#define GENERAL_COLUMN 1
-#define FIRST_ROW 2
-#define LAST_ROW 3
-#define FIRST_COLUMN 4
-#define LAST_COLUMN 5
- /* FIELDS ID */
-#define F_EDGE_DETECTION_CLASS 1
-#define F_CLASSIFICATION 2
-#define F_INTERPOLATION 3
-#define F_COUNTER_OBJ 4
- /* PRE-CLASSIFICATION */
-#define PRE_TERRAIN 1
-#define PRE_EDGE 2
-#define PRE_UNKNOWN 3
- /* FINAL CLASSIFICATION */
-#define TERRAIN_SINGLE 1
-#define TERRAIN_DOUBLE 2
-#define OBJECT_DOUBLE 3
-#define OBJECT_SINGLE 4
- /* SINGLE OR DOUBLE PULSE */
-#define SINGLE_PULSE 1
-#define DOUBLE_PULSE 2
- /* INTERPOLATOR */
-#define P_BILINEAR 1
-#define P_BICUBIC 0
- /* Boolean definitions */
-#define TRUE 1
-#define FALSE 0
- /*STRUCTS DECLARATION */
- struct Reg_dimens
- double edge_h; /*Horizontal tile edge */
- double edge_v; /*Vertical tile edge */
- double overlap; /*Tile's overlapping size */
- double sn_size; /*South-North side size */
- double ew_size; /*East-West side size */
-struct Point
- double coordX;
- double coordY;
- double coordZ;
- int lineID;
- int cat;
-struct element
- double value;
- double residual;
- int freq;
-/*FUNCTIONS DECLARATION */
-/*zones */
-void P_zero_dim(struct Reg_dimens * /**/);
-int P_set_dim(struct Reg_dimens *, double, double, int *, int *);
-int P_set_regions(struct Cell_head *, /**/
- struct bound_box *, /**/
- struct bound_box *, /**/ struct Reg_dimens, /**/ int /**/);
-int P_get_edge(int, /**/ struct Reg_dimens *, /**/ double, /**/ double /**/);
-int P_get_BandWidth(int, /**/ int /**/);
-double P_estimate_splinestep(struct Map_info *, double *, double *);
-struct Point *P_Read_Vector_Region_Map(struct Map_info *, /**/
- struct Cell_head *, /**/
- int *, /**/ int, /**/ int /**/);
-struct Point *P_Read_Raster_Region_Map(double **, /**/
- int *, /**/ int *, /**/ int /**/);
-double P_Mean_Calc(struct Cell_head *, /**/ struct Point *, /**/ int /**/);
-void
-P_Sparse_Points(struct Map_info *, /**/
- struct bound_box, /**/
- double **, /**/
- double *, /**/
- int *, /**/
- double, /**/
- double, /**/
- double, /**/
- int, /**/
- int, /**/
- int, /**/
- int, /**/
- struct line_cats *, /**/
- dbDriver *, /**/ double, /**/ char * /**/);
-double **P_Regular_Points(struct Cell_head *, /**/
- double **, /**/
- double *, /**/
- double, /**/
- double, /**/
- double, /**/
- double, /**/
- int, /**/ int, /**/ int, /**/ int, /**/ int /**/);
-int P_Create_Aux2_Table(dbDriver *, /**/ char * /**/);
-int P_Create_Aux4_Table(dbDriver *, /**/ char * /**/);
-int P_Drop_Aux_Table(dbDriver *, /**/ char * /**/);
-void P_Aux_to_Raster(double **, /**/ int /**/);
-void P_Aux_to_Vector(struct Map_info *, /**/
- struct Map_info *, /**/ dbDriver *, /**/ char * /**/);
-double **P_Null_Matrix(double ** /**/);
-/*interpSpline */
-void normalDefBicubic(double **N, double *TN, double *Q, double **obsVect,
- double deltaX, double deltaY, int xNum, int yNum,
- double xMin, double yMin, int obsNum, int parNum,
- int BW);
-void normalDefBilin(double **N, double *TN, double *Q, double **obsVect,
- double xMin, double yMin, int obsNum, int parNum, int BW);
-void nCorrectLapl(double **N, /* Normal Matrix () */
- double lambda, /* */
- int xNum, /* */
- int yNum, /* */
- double deltaX, /* */
- double deltaY); /* */
-void nCorrectGrad(double **N, double lambda, int xNum, int yNum,
- double deltaX, double deltaY);
-void obsEstimateBicubic(double **obsV, /* */
- double *obsE, /* */
- double *parV, /* */
- double deltX, /* */
- double deltY, /* */
- int xNm, /* */
- int yNm, /* */
- double xMi, /* */
- double yMi, /* */
- int obsN); /* */
-double dataInterpolateBicubic(double x, /* */
- double y, /* */
- double deltaY, /* */
- int xNum, /* */
- int yNum, /* */
- double xMin, /* */
- double yMin, /* */
- double *parVect); /* */
-void obsEstimateBilin(double **obsV, double *obsE, double *parV, double deltX,
- double deltY, int xNm, int yNm, double xMi, double yMi,
- int obsN);
-double dataInterpolateBilin(double x, double y, double deltaX, double deltaY,
- int xNum, int yNum, double xMin, double yMin,
- double *parVect);
-#endif
Copied: grass/trunk/vector/lidar/lidarlib/lidar.h (from rev 42312, grass/trunk/vector/lidar/lidarlib/PolimiFunct.h)
--- grass/trunk/vector/lidar/lidarlib/lidar.h (rev 0)
+++ grass/trunk/vector/lidar/lidarlib/lidar.h 2010-05-19 08:50:08 UTC (rev 42316)
@@ -0,0 +1,218 @@
+ * MODULE: lidarlib
+ * AUTHOR(S): Roberto Antolin
+ * PURPOSE: LIDAR library
+ * COPYRIGHT: (C) 2006 by Politecnico di Milano -
+ * Polo Regionale di Como
+ * This program is free software under the
+ * GNU General Public License (>=v2).
+ * Read the file COPYING that comes with GRASS
+ * for details.
+#ifndef _POLIMIFUNCT_H_
+#define _POLIMIFUNCT_H_
+#include <grass/gis.h>
+#include <grass/gmath.h>
+#include <grass/vector.h>
+#include <grass/dbmi.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+/*CONSTANTS DECLARATION */
+#define NSPLX_MAX 150 /* Maximum number of splines along East direction used in the subregions interpolation */
+#define NSPLY_MAX 150 /* Maximum number of splines along North direction used in the subregions interpolation */
+#define OVERLAP_SIZE 10 /* Subregions overlapping size. */
+#define LATO 1000 /* Side's size for v.lidar.growing. */
+#define CONTOUR 15 /**/
+#define GENERAL_ROW 0
+#define GENERAL_COLUMN 1
+#define FIRST_ROW 2
+#define LAST_ROW 3
+#define FIRST_COLUMN 4
+#define LAST_COLUMN 5
+ /* FIELDS ID */
+#define F_EDGE_DETECTION_CLASS 1
+#define F_CLASSIFICATION 2
+#define F_INTERPOLATION 3
+#define F_COUNTER_OBJ 4
+ /* PRE-CLASSIFICATION */
+#define PRE_TERRAIN 1
+#define PRE_EDGE 2
+#define PRE_UNKNOWN 3
+ /* FINAL CLASSIFICATION */
+#define TERRAIN_SINGLE 1
+#define TERRAIN_DOUBLE 2
+#define OBJECT_DOUBLE 3
+#define OBJECT_SINGLE 4
+ /* SINGLE OR DOUBLE PULSE */
+#define SINGLE_PULSE 1
+#define DOUBLE_PULSE 2
+ /* INTERPOLATOR */
+#define P_BILINEAR 1
+#define P_BICUBIC 0
+ /* Boolean definitions */
+#define TRUE 1
+#define FALSE 0
+ /*STRUCTS DECLARATION */
+ struct Reg_dimens
+ double edge_h; /*Horizontal tile edge */
+ double edge_v; /*Vertical tile edge */
+ double overlap; /*Tile's overlapping size */
+ double sn_size; /*South-North side size */
+ double ew_size; /*East-West side size */
+struct Point
+ double coordX;
+ double coordY;
+ double coordZ;
+ int lineID;
+ int cat;
+struct element
+ double value;
+ double residual;
+ int freq;
+/*FUNCTIONS DECLARATION */
+/*zones */
+void P_zero_dim(struct Reg_dimens * /**/);
+int P_set_dim(struct Reg_dimens *, double, double, int *, int *);
+int P_set_regions(struct Cell_head *, /**/
+ struct bound_box *, /**/
+ struct bound_box *, /**/ struct Reg_dimens, /**/ int /**/);
+int P_get_edge(int, /**/ struct Reg_dimens *, /**/ double, /**/ double /**/);
+int P_get_BandWidth(int, /**/ int /**/);
+double P_estimate_splinestep(struct Map_info *, double *, double *);
+struct Point *P_Read_Vector_Region_Map(struct Map_info *, /**/
+ struct Cell_head *, /**/
+ int *, /**/ int, /**/ int /**/);
+struct Point *P_Read_Raster_Region_Map(double **, /**/
+ int *, /**/ int *, /**/ int /**/);
+double P_Mean_Calc(struct Cell_head *, /**/ struct Point *, /**/ int /**/);
+void
+P_Sparse_Points(struct Map_info *, /**/
+ struct bound_box, /**/
+ double **, /**/
+ double *, /**/
+ int *, /**/
+ double, /**/
+ double, /**/
+ double, /**/
+ int, /**/
+ int, /**/
+ int, /**/
+ int, /**/
+ struct line_cats *, /**/
+ dbDriver *, /**/ double, /**/ char * /**/);
+double **P_Regular_Points(struct Cell_head *, /**/
+ double **, /**/
+ double *, /**/
+ double, /**/
+ double, /**/
+ double, /**/
+ double, /**/
+ int, /**/ int, /**/ int, /**/ int, /**/ int /**/);
+int P_Create_Aux2_Table(dbDriver *, /**/ char * /**/);
+int P_Create_Aux4_Table(dbDriver *, /**/ char * /**/);
+int P_Drop_Aux_Table(dbDriver *, /**/ char * /**/);
+void P_Aux_to_Raster(double **, /**/ int /**/);
+void P_Aux_to_Vector(struct Map_info *, /**/
+ struct Map_info *, /**/ dbDriver *, /**/ char * /**/);
+double **P_Null_Matrix(double ** /**/);
+/*interpSpline */
+void normalDefBicubic(double **N, double *TN, double *Q, double **obsVect,
+ double deltaX, double deltaY, int xNum, int yNum,
+ double xMin, double yMin, int obsNum, int parNum,
+ int BW);
+void normalDefBilin(double **N, double *TN, double *Q, double **obsVect,
+ double xMin, double yMin, int obsNum, int parNum, int BW);
+void nCorrectLapl(double **N, /* Normal Matrix () */
+ double lambda, /* */
+ int xNum, /* */
+ int yNum, /* */
+ double deltaX, /* */
+ double deltaY); /* */
+void nCorrectGrad(double **N, double lambda, int xNum, int yNum,
+ double deltaX, double deltaY);
+void obsEstimateBicubic(double **obsV, /* */
+ double *obsE, /* */
+ double *parV, /* */
+ double deltX, /* */
+ double deltY, /* */
+ int xNm, /* */
+ int yNm, /* */
+ double xMi, /* */
+ double yMi, /* */
+ int obsN); /* */
+double dataInterpolateBicubic(double x, /* */
+ double y, /* */
+ double deltaY, /* */
+ int xNum, /* */
+ int yNum, /* */
+ double xMin, /* */
+ double yMin, /* */
+ double *parVect); /* */
+void obsEstimateBilin(double **obsV, double *obsE, double *parV, double deltX,
+ double deltY, int xNm, int yNm, double xMi, double yMi,
+ int obsN);
+double dataInterpolateBilin(double x, double y, double deltaX, double deltaY,
+ int xNum, int yNum, double xMin, double yMin,
+ double *parVect);
+#endif
Modified: grass/trunk/vector/lidar/lidarlib/raster.c
--- grass/trunk/vector/lidar/lidarlib/raster.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/lidarlib/raster.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -1,16 +1,9 @@
+#include <grass/config.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
-#include <grass/raster.h>
void
P_Sparse_Points(struct Map_info *Out, struct Cell_head *Elaboration,
Modified: grass/trunk/vector/lidar/lidarlib/zones.c
--- grass/trunk/vector/lidar/lidarlib/zones.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/lidarlib/zones.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -1,16 +1,9 @@
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
void P_zero_dim(struct Reg_dimens *dim)
Modified: grass/trunk/vector/lidar/r.resamp.bspline/bspline.h
--- grass/trunk/vector/lidar/r.resamp.bspline/bspline.h 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/r.resamp.bspline/bspline.h 2010-05-19 08:50:08 UTC (rev 42316)
@@ -18,15 +18,7 @@
/*INCLUDES*/
-#include <stdlib.h>
-#include <string.h>
-#include <grass/PolimiFunct.h>
/*STRUCTURES*/ struct Stats
double *estima;
Modified: grass/trunk/vector/lidar/r.resamp.bspline/crosscorr.c
--- grass/trunk/vector/lidar/r.resamp.bspline/crosscorr.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/r.resamp.bspline/crosscorr.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -1,9 +1,10 @@
- * MODULE: v.surf.bspline
+ * MODULE: r.resamp.bspline
+ * AUTHOR(S): Roberto Antolin (v.surf.bspline)
+ * Markus Metz (adapted for r.resamp.bspline)
* PURPOSE: Spline Interpolation and cross correlation
@@ -18,16 +19,12 @@
/*INCLUDES*/
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include "bspline.h"
#define NDATA_MAX 100
#define PARAM_LAMBDA 6
#define PARAM_SPLINE 0
Modified: grass/trunk/vector/lidar/r.resamp.bspline/main.c
--- grass/trunk/vector/lidar/r.resamp.bspline/main.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/r.resamp.bspline/main.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -17,16 +17,10 @@
/* INCLUDES */
#include <stdlib.h>
#include <string.h>
#include <math.h>
Modified: grass/trunk/vector/lidar/r.resamp.bspline/resamp.c
--- grass/trunk/vector/lidar/r.resamp.bspline/resamp.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/r.resamp.bspline/resamp.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -16,6 +16,10 @@
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
struct Point *P_Read_Raster_Region_Nulls(double **matrix,
Modified: grass/trunk/vector/lidar/v.lidar.correction/correction.c
--- grass/trunk/vector/lidar/v.lidar.correction/correction.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.lidar.correction/correction.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -1,30 +1,27 @@
- * MODULE: v.lidar.correction *
- * AUTHOR(S): Roberto Antolin & Gonzalo Moreno *
- * PURPOSE: Correction of the v.growing output *
- * COPYRIGHT: (C) 2006 by Politecnico di Milano - *
- * Polo Regionale di Como *
- * This program is free software under the *
- * GNU General Public License (>=v2). *
- * Read the file COPYING that comes with GRASS *
- * for details. *
+ * MODULE: v.lidar.correction *
+ * AUTHOR(S): Roberto Antolin & Gonzalo Moreno *
+ * general update Markus Metz *
+ * PURPOSE: Correction of the v.growing output *
+ * COPYRIGHT: (C) 2006 by Politecnico di Milano - *
+ * Polo Regionale di Como *
+ * This program is free software under the *
+ * GNU General Public License (>=v2). *
+ * Read the file COPYING that comes with GRASS *
+ * for details. *
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include "correction.h"
void
Modified: grass/trunk/vector/lidar/v.lidar.correction/correction.h
--- grass/trunk/vector/lidar/v.lidar.correction/correction.h 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.lidar.correction/correction.h 2010-05-19 08:50:08 UTC (rev 42316)
@@ -3,10 +3,10 @@
struct lidar_cat
int cat_edge; /* category in layer F_EDGE_DETECTION_CLASS */
Modified: grass/trunk/vector/lidar/v.lidar.correction/main.c
--- grass/trunk/vector/lidar/v.lidar.correction/main.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.lidar.correction/main.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -1,33 +1,28 @@
- * COPYRIGHT: (C) 2005 by Politecnico di Milano - *
- * for details. *
+ * COPYRIGHT: (C) 2005 by Politecnico di Milano - *
+ * for details. *
/*INCLUDES*/
#include <stdlib.h>
#include <string.h>
#include <math.h>
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -27,11 +27,6 @@
#include <stdlib.h>
#include <string.h>
#include <math.h>
- /* #include <grass/PolimiFunct.h> */
#include "edgedetection.h"
int edge_detection(struct Cell_head elaboration_reg, struct bound_box Overlap_Box,
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h
--- grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h 2010-05-19 08:50:08 UTC (rev 42316)
@@ -26,8 +26,9 @@
int edge_detection(struct Cell_head, /**/
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/main.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/main.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -23,15 +23,10 @@
/*INCLUDES*/
#include <stdlib.h>
#include <string.h>
#include <math.h>
int nsply, nsplx, line_out_counter;
Modified: grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c
--- grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -1,7 +1,7 @@
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
+#include <assert.h>
#include "growing.h"
Modified: grass/trunk/vector/lidar/v.lidar.growing/growing.c
--- grass/trunk/vector/lidar/v.lidar.growing/growing.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.lidar.growing/growing.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -1,9 +1,6 @@
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
void P_Aux_to_Coor(struct Map_info *In, struct Map_info *Out,
Modified: grass/trunk/vector/lidar/v.lidar.growing/growing.h
--- grass/trunk/vector/lidar/v.lidar.growing/growing.h 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.lidar.growing/growing.h 2010-05-19 08:50:08 UTC (rev 42316)
@@ -1,10 +1,9 @@
-#include <assert.h>
/* Definitions for Convex-Hull algorithm */
Modified: grass/trunk/vector/lidar/v.lidar.growing/main.c
--- grass/trunk/vector/lidar/v.lidar.growing/main.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.lidar.growing/main.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -20,16 +20,12 @@
/*INCLUDES*/
#include <stdlib.h>
#include <string.h>
#include <math.h>
/* GLOBAL DEFINITIONS */
int nsply, nsplx, count_obj;
double stepN, stepE;
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.outlier/main.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -18,16 +18,12 @@
/*INCLUDES*/
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include "outlier.h"
/* GLOBAL VARIABLES DEFINITIONS */
int nsply, nsplx;
double stepN, stepE, Thres_Outlier;
Modified: grass/trunk/vector/lidar/v.outlier/outlier.c
--- grass/trunk/vector/lidar/v.outlier/outlier.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.outlier/outlier.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -2,10 +2,6 @@
#include <stdlib.h>
#include <string.h>
#include <math.h>
extern double Thres_Outlier;
Modified: grass/trunk/vector/lidar/v.outlier/outlier.h
--- grass/trunk/vector/lidar/v.outlier/outlier.h 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.outlier/outlier.h 2010-05-19 08:50:08 UTC (rev 42316)
@@ -2,9 +2,8 @@
void
Modified: grass/trunk/vector/lidar/v.surf.bspline/bspline.h
--- grass/trunk/vector/lidar/v.surf.bspline/bspline.h 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.surf.bspline/bspline.h 2010-05-19 08:50:08 UTC (rev 42316)
@@ -18,15 +18,15 @@
/*INCLUDES*/
- /*STRUCTURES*/ struct Stats
+/*STRUCTURES*/
+struct Stats
double *estima;
double *error;
Modified: grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -18,16 +18,12 @@
/*INCLUDES*/
#include <stdlib.h>
#include <string.h>
#include <math.h>
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c 2010-05-19 07:44:52 UTC (rev 42315)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c 2010-05-19 08:50:08 UTC (rev 42316)
@@ -19,16 +19,10 @@
/* INCLUDES */
#include <stdlib.h>
#include <string.h>
#include <math.h>
/* GLOBAL VARIABLES */
