[GRASS-SVN] r42321 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu May 20 07:09:38 EDT 2010
Author: mmetz
Date: 2010-05-20 07:09:16 -0400 (Thu, 20 May 2010)
New Revision: 42321
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/open_nat.c
fix r42320
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2010-05-19 17:57:55 UTC (rev 42320)
+++ grass/trunk/lib/vector/Vlib/open.c 2010-05-20 11:09:16 UTC (rev 42321)
@@ -773,13 +773,31 @@
char buf[2000], path[2000];
struct stat stat_buf;
switch (Map->format) {
case GV_FORMAT_NATIVE:
- dig_fseek(&(Map->dig_fp), 0L, SEEK_END);
- G_debug(2, "dig_ftell = %d", dig_ftell(&(Map->dig_fp)));
- Info->size = dig_ftell(&(Map->dig_fp));
- Info->mtime = 0L;
+ sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
+ G__file_name(path, buf, GV_COOR_ELEMENT, Map->mapset);
+ G_debug(1, "get coor info: %s", path);
+ if (0 != stat(path, &stat_buf)) {
+ G_warning(_("Unable to stat file <%s>"), path);
+ Info->size = -1L;
+ Info->mtime = -1L;
+ else {
+ Info->size = (off_t)stat_buf.st_size; /* file size */
+ Info->mtime = (long)stat_buf.st_mtime; /* last modified time */
+ /* stat does not give correct size on MINGW
+ * if the file is opened */
+#ifdef __MINGW32__
+ if (Map->open == VECT_OPEN_CODE) {
+ dig_fseek(&(Map->dig_fp), 0L, SEEK_END);
+ G_debug(2, "dig_ftell = %d", dig_ftell(&(Map->dig_fp)));
+ Info->size = dig_ftell(&(Map->dig_fp));
+#endif
break;
case GV_FORMAT_OGR:
case GV_FORMAT_OGR_DIRECT:
@@ -884,6 +902,7 @@
/* get coor info */
+ /* NOTE: coor file not yet opened */
Vect_coor_info(Map, &CInfo);
/* load head */
@@ -973,6 +992,7 @@
/* get coor info */
/* initialize spatial index */
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c 2010-05-19 17:57:55 UTC (rev 42320)
+++ grass/trunk/lib/vector/Vlib/open_nat.c 2010-05-20 11:09:16 UTC (rev 42321)
@@ -59,9 +59,15 @@
return -1;
+ /* needed to determine file size, Map->head.size will be updated by dig__read_head(Map) */
+ Vect_coor_info(Map, &CInfo);
+ Map->head.size = CInfo.size;
if (!(dig__read_head(Map)))
return (-1);
+ /* compare coor size stored in head with real size */
+ /* check should catch if LFS is required but not available */
check_coor(Map);
/* set conversion matrices */
@@ -111,6 +117,8 @@
if (Map->dig_fp.file == NULL)
return (-1);
+ /* if overwrite OK, any existing files have already been deleted by
+ * Vect_open_new(): remove this check ? */
/* check to see if dig_plus file exists and if so, remove it */
G__file_name(name_buf, buf, GV_TOPO_ELEMENT, G_mapset());
if (stat(name_buf, &info) == 0) /* file exists? */
@@ -137,17 +145,18 @@
struct Coor_info CInfo;
off_t dif;
+ /* NOTE: coor file is open */
dif = CInfo.size - Map->head.size;
G_debug(1, "coor size in head = %lu, real coor file size= %lu",
(unsigned long) Map->head.size, (unsigned long) CInfo.size);
if (dif > 0) {
- G_warning(_("Coor files of vector map <%s@%s> is larger than it should be "
+ G_warning(_("Coor file of vector map <%s@%s> is larger than it should be "
"(%ld bytes excess)"), Map->name, Map->mapset, dif);
else if (dif < 0) {
- G_warning(_("Coor files of vector <%s@%s> is shorter than it should be "
+ G_warning(_("Coor file of vector <%s@%s> is shorter than it should be "
"(%ld bytes missing)."), Map->name, Map->mapset, -dif);
return 1;
