[GRASS-SVN] r42327 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri May 21 04:17:11 EDT 2010
Author: martinl
Date: 2010-05-21 04:17:09 -0400 (Fri, 21 May 2010)
New Revision: 42327
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py
bugfix #1072
(merge r42325 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py 2010-05-21 08:11:07 UTC (rev 42326)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py 2010-05-21 08:17:09 UTC (rev 42327)
@@ -1567,8 +1567,19 @@
def OnTableItemDelete(self, event):
"""Delete selected item(s) from the list"""
list = self.FindWindowById(self.layerPage[self.layer]['tableData'])
item = list.GetFirstSelected()
+ if UserSettings.Get(group='atm', key='askOnDeleteRec', subkey='enabled'):
+ deleteDialog = wx.MessageBox(parent=self,
+ message=_("Selected column '%s' will PERMANENTLY removed "
+ "from table. Do you want to drop the column?") % \
+ (list.GetItemText(item)),
+ caption=_("Drop column(s)"),
+ style=wx.YES_NO | wx.CENTRE)
+ if deleteDialog != wx.YES:
+ return False
while item != -1:
self.listOfCommands.append(['v.db.dropcol',
'map=%s' % self.vectmap,
@@ -1576,21 +1587,35 @@
'column=%s' % list.GetItemText(item)])
list.DeleteItem(item)
# apply changes
self.ApplyCommands()
# update widgets
table = self.mapDBInfo.layers[self.layer]['table']
self.FindWindowById(self.layerPage[self.layer]['renameCol']).SetItems(self.mapDBInfo.GetColumns(table))
self.FindWindowById(self.layerPage[self.layer]['renameCol']).SetSelection(0)
event.Skip()
def OnTableItemDeleteAll(self, event):
"""Delete all items from the list"""
- table = self.mapDBInfo.layers[self.layer]['table']
- cols = self.mapDBInfo.GetColumns(table)
+ table = self.mapDBInfo.layers[self.layer]['table']
+ cols = self.mapDBInfo.GetColumns(table)
+ keyColumn = self.mapDBInfo.layers[self.layer]['key']
+ if keyColumn in cols:
+ cols.remove(keyColumn)
+ message=_("Selected columns\n%s\nwill PERMANENTLY removed "
+ "from table. Do you want to drop the columns?") % \
+ ('\n'.join(cols)),
+ return False
for col in cols:
self.listOfCommands = [['v.db.dropcol',
