[GRASS-SVN] r42340 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon May 24 10:37:59 EDT 2010
Author: martinl
Date: 2010-05-24 10:37:59 -0400 (Mon, 24 May 2010)
New Revision: 42340
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: global overwrite option added
(merge r42339 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-05-24 14:36:07 UTC (rev 42339)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-05-24 14:37:59 UTC (rev 42340)
@@ -420,6 +420,8 @@
'author' : getpass.getuser() })
if dlg.ShowModal() == wx.ID_OK:
self.properties = dlg.GetValues()
+ for action in self.model.GetActions():
+ action.GetTask().set_flag('overwrite', self.properties['overwrite'])
dlg.Destroy()
@@ -1272,6 +1274,10 @@
return self.task.get_options()
+ def GetTask(self):
+ """!Get grassTask instance"""
+ return self.task
def SetParams(self, params):
"""!Set dictionary of parameters"""
self.task.params = params['params']
@@ -1279,12 +1285,14 @@
def MergeParams(self, params):
"""!Merge dictionary of parameters"""
- for f in params['flags']:
- self.task.set_flag(f['name'],
- f.get('value', False))
- for p in params['params']:
- self.task.set_param(p['name'],
- p.get('value', ''))
+ if params.has_key('flags'):
+ for f in params['flags']:
+ self.task.set_flag(f['name'],
+ f.get('value', False))
+ if params.has_key('params'):
+ for p in params['params']:
+ self.task.set_param(p['name'],
+ p.get('value', ''))
def SetValid(self, isvalid):
"""!Set instance to be valid/invalid"""
@@ -2337,7 +2345,12 @@
style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
wx.Dialog.__init__(self, parent, id, title, size = size,
style = style)
+ self.metaBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label=" %s " % _("Metadata"))
+ self.cmdBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label=" %s " % _("Commands"))
self.name = wx.TextCtrl(parent = self, id = wx.ID_ANY,
size = (300, 25))
self.desc = wx.TextCtrl(parent = self, id = wx.ID_ANY,
@@ -2346,6 +2359,11 @@
self.author = wx.TextCtrl(parent = self, id = wx.ID_ANY,
size = (300, 25))
+ # commands
+ self.overwrite = wx.CheckBox(parent = self, id=wx.ID_ANY,
+ label=_("Allow output files to overwrite existing files"))
+ self.overwrite.SetValue(UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'))
# buttons
self.btnOk = wx.Button(self, wx.ID_OK)
self.btnCancel = wx.Button(self, wx.ID_CANCEL)
@@ -2360,6 +2378,7 @@
self._layout()
def _layout(self):
+ metaSizer = wx.StaticBoxSizer(self.metaBox, wx.VERTICAL)
gridSizer = wx.GridBagSizer (hgap=3, vgap=3)
gridSizer.AddGrowableCol(0)
gridSizer.AddGrowableRow(1)
@@ -2390,15 +2409,22 @@
flag = wx.ALIGN_LEFT |
wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
pos = (2, 1))
+ metaSizer.Add(item = gridSizer)
+ cmdSizer = wx.StaticBoxSizer(self.cmdBox, wx.VERTICAL)
+ cmdSizer.Add(item = self.overwrite,
+ flag = wx.EXPAND | wx.ALL, border = 3)
btnStdSizer = wx.StdDialogButtonSizer()
btnStdSizer.AddButton(self.btnCancel)
btnStdSizer.AddButton(self.btnOk)
btnStdSizer.Realize()
mainSizer = wx.BoxSizer(wx.VERTICAL)
- mainSizer.Add(item=gridSizer, proportion=1,
+ mainSizer.Add(item=metaSizer, proportion=1,
flag=wx.EXPAND | wx.ALL, border=5)
+ mainSizer.Add(item=cmdSizer, proportion=0,
+ flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=3)
mainSizer.Add(item=btnStdSizer, proportion=0,
flag=wx.EXPAND | wx.ALL | wx.ALIGN_RIGHT, border=5)
@@ -2412,13 +2438,16 @@
"""!Get values"""
return { 'name' : self.name.GetValue(),
'desc' : self.desc.GetValue(),
- 'author' : self.author.GetValue() }
+ 'author' : self.author.GetValue(),
+ 'overwrite' : self.overwrite.IsChecked() }
def Init(self, prop):
"""!Initialize dialog"""
self.name.SetValue(prop['name'])
self.desc.SetValue(prop['desc'])
self.author.SetValue(prop['author'])
+ if prop.has_key('overwrite'):
+ self.overwrite.SetValue(prop['overwrite'])
class ModelParamDialog(wx.Dialog):
def __init__(self, parent, params, id = wx.ID_ANY, title = _("Model parameters"),
