[GRASS-SVN] r42355 - in grass/trunk/gui/wxpython: gui_modules icons
Wed May 26 16:02:23 EDT 2010
Author: martinl
Date: 2010-05-26 16:02:22 -0400 (Wed, 26 May 2010)
New Revision: 42355
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/gui_modules/wxnviz.py
   grass/trunk/gui/wxpython/icons/grass_icons.py
   grass/trunk/gui/wxpython/icons/icon.py
wxGUI/nviz: minor clean up (nviz_mapdisp)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-05-26 14:26:05 UTC (rev 42354)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-05-26 20:02:22 UTC (rev 42355)
@@ -308,9 +308,10 @@
         Add defined toolbar to the window
         Currently known toolbars are:
-        - map basic map toolbar
-        - digit vector digitizer
-        - georect georectifier
+         - 'map'     - basic map toolbar
+         - 'vdigit'  - vector digitizer
+         - 'georect' - georectifier
+         - 'nviz'    - 3D view mode
         # default toolbar
         if name == "map":
@@ -377,7 +378,7 @@
         # nviz
         elif name == "nviz":
             import nviz
             # check for GLCanvas and OpenGL
             msg = None
             if not nviz.haveGLCanvas:
@@ -389,7 +390,7 @@
                 msg = _("Unable to switch to 3D display mode.\nThe Nviz python extension "
                         "was not found or loaded properly.\n"
                         "Switching back to 2D display mode.\n\nDetails: %s" % nviz.errorMsg)
             if msg:
                 self.toolbars['map'].combo.SetValue (_("2D view"))
                 wx.MessageBox(parent=self,
@@ -397,13 +398,13 @@
                               caption=_("Error"),
                               style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
                 return
             # add Nviz toolbar and disable 2D display mode tools
             self.toolbars['nviz'] = toolbars.NvizToolbar(self, self.Map)
             self.toolbars['map'].Enable2D(False)
             # update layer tree (-> enable 3d-rasters)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2010-05-26 14:26:05 UTC (rev 42354)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2010-05-26 20:02:22 UTC (rev 42355)
@@ -483,20 +483,20 @@
         If self.redrawAll is False on self.pdcTmp content is re-drawn
         Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
         dc = wx.BufferedPaintDC(self, self.buffer)
         ### dc.SetBackground(wx.Brush("White"))
         dc.Clear()
         # use PrepareDC to set position correctly
         self.PrepareDC(dc)
         # create a clipping rect from our position and size
         # and update region
         rgn = self.GetUpdateRegion().GetBox()
         dc.SetClippingRect(rgn)
         switchDraw = False
         if self.redrawAll is None:
             self.redrawAll = True
@@ -505,7 +505,7 @@
         if self.redrawAll: # redraw pdc and pdcVector
             # draw to the dc using the calculated clipping rect
             self.pdc.DrawToDCClipped(dc, rgn)
             # draw vector map layer
             if self.pdcVector:
                 # decorate with GDDC (transparency)
@@ -515,13 +515,13 @@
                 except NotImplementedError, e:
                     print >> sys.stderr, e
                     self.pdcVector.DrawToDCClipped(dc, rgn)
             self.bufferLast = None
         else: # do not redraw pdc and pdcVector
             if self.bufferLast is None:
                 # draw to the dc
                 self.pdc.DrawToDC(dc)
                 if self.pdcVector:
                     try:
@@ -534,11 +534,11 @@
                 # store buffered image
                 # self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
                 self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
             pdcLast = self.PseudoDC(vdigit = False)
             pdcLast.DrawBitmap(self.bufferLast, 0, 0, False)
             pdcLast.DrawToDC(dc)
         # draw decorations (e.g. region box)
         try:
             gcdc = wx.GCDC(dc)
@@ -546,14 +546,14 @@
             self.pdcDec.DrawToDC(dc)
         # draw temporary object on the foreground
         ### self.pdcTmp.DrawToDCClipped(dc, rgn)
         self.pdcTmp.DrawToDC(dc)
         if switchDraw:
             self.redrawAll = False
     def OnSize(self, event):
         Scale map image so that it is
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-05-26 14:26:05 UTC (rev 42354)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-05-26 20:02:22 UTC (rev 42355)
@@ -63,11 +63,11 @@
 class GLWindow(MapWindow, glcanvas.GLCanvas):
     """!OpenGL canvas for Map Display Window"""
     def __init__(self, parent, id,
-                 pos=wx.DefaultPosition,
-                 size=wx.DefaultSize,
-                 style=wx.NO_FULL_REPAINT_ON_RESIZE,
-                 Map=None, tree=None, lmgr=None):
+                 pos = wx.DefaultPosition,
+                 size = wx.DefaultSize,
+                 style = wx.NO_FULL_REPAINT_ON_RESIZE,
+                 Map = None, tree = None, lmgr = None):
         self.parent = parent # MapFrame
         self.Map = Map
         self.tree = tree
@@ -86,7 +86,7 @@
                         # do not render vector lines in quick mode
                         'vlines' : False,
                         'vpoints' : False }
         # list of loaded map layers (layer tree items)
         self.layers = []
@@ -94,7 +94,7 @@
         # use display region instead of computational
         os.environ['GRASS_REGION'] = self.Map.SetRegion()
         # create nviz instance
@@ -109,15 +109,17 @@
         self.nvizThread.start()
         time.sleep(.1)
         self.nvizClass = self.nvizThread.nvizClass
         # GRASS_REGION needed only for initialization
         del os.environ['GRASS_REGION']
+        self.img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
         # default values
-        self.view = copy.deepcopy(UserSettings.Get(group='nviz', key='view')) # copy
-        self.iview = UserSettings.Get(group='nviz', key='view', internal=True)
+        self.view = copy.deepcopy(UserSettings.Get(group = 'nviz', key = 'view')) # copy
+        self.iview = UserSettings.Get(group = 'nviz', key = 'view', internal = True)
         self.nvizDefault = NvizDefault()
         self.size = None
@@ -128,7 +130,7 @@
         self.Bind(wx.EVT_LEFT_UP, self.OnLeftUp)
         self.Bind(wx.EVT_MOTION, self.OnMouseAction)
         self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouseAction)
         self.Bind(EVT_UPDATE_PROP, self.UpdateMapObjProperties)
         self.Bind(EVT_UPDATE_VIEW, self.UpdateView)
@@ -137,14 +139,14 @@
     def OnClose(self, event):
         # cleanup when window actually closes (on quit) and not just is hidden
         self.Reset()
     def OnEraseBackground(self, event):
         pass # do nothing, to avoid flashing on MSW
         self.size = self.parent.GetClientSize()
         if self.GetContext():
-            Debug.msg(3, "GLCanvas.OnSize(): w=%d, h=%d" % \
+            Debug.msg(3, "GLCanvas.OnSize(): w = %d, h = %d" % \
                       (self.size.width, self.size.height))
             self.SetCurrent()
             self.nvizClass.ResizeWindow(self.size.width,
@@ -154,14 +156,14 @@
     def OnPaint(self, event):
         Debug.msg(3, "GLCanvas.OnPaint()")
         dc = wx.PaintDC(self)
         self.SetCurrent()
         if not self.initView:
             self.nvizClass.InitView()
             self.initView = True
         self.LoadDataLayers()
         self.UnloadDataLayers()
@@ -172,22 +174,22 @@
                 self.parent.nvizToolWin.UpdatePage('view')
                 layer = self.GetSelectedLayer()
                 if layer:
-                    if layer.type == 'raster':
+                    if layer.type ==  'raster':
                         self.parent.nvizToolWin.UpdatePage('surface')
-                    elif layer.type == 'vector':
+                    elif layer.type ==  'vector':
                         self.parent.nvizToolWin.UpdatePage('vector')
                 self.parent.nvizToolWin.UpdateSettings()
                 # update widgets
                 win = self.parent.nvizToolWin.FindWindowById( \
                     self.parent.nvizToolWin.win['vector']['lines']['surface'])
                 win.SetItems(self.GetLayerNames('raster'))
             self.init = True
         self.UpdateMap()
     def OnMouseAction(self, event):
         # change position
         if event.Dragging() and event.LeftIsDown():
@@ -195,25 +197,25 @@
             ### self.x, self.y = event.GetPosition()
             ### self.Refresh(False)
             pass
         # change perspective with mouse wheel
         wheel = event.GetWheelRotation()
-        if wheel != 0:
+        if wheel !=  0:
             current  = event.GetPositionTuple()[:]
-            Debug.msg (5, "GLWindow.OnMouseMotion(): wheel=%d" % wheel)
+            Debug.msg (5, "GLWindow.OnMouseMotion(): wheel = %d" % wheel)
             prev_value = self.view['persp']['value']
             if wheel > 0:
                 value = -1 * self.view['persp']['step']
             else:
                 value = self.view['persp']['step']
-            self.view['persp']['value'] += value
+            self.view['persp']['value'] +=  value
             if self.view['persp']['value'] < 1:
                 self.view['persp']['value'] = 1
             elif self.view['persp']['value'] > 100:
                 self.view['persp']['value'] = 100
-            if prev_value != self.view['persp']['value']:
+            if prev_value !=  self.view['persp']['value']:
                 if hasattr(self.parent, "nvizToolWin"):
@@ -221,48 +223,46 @@
                                            self.iview['height']['value'],
                                            self.view['persp']['value'],
                                            self.view['twist']['value'])
                 # redraw map
                 self.OnPaint(None)
                 # update statusbar
                 ### self.parent.StatusbarUpdate()
     def OnLeftDown(self, event):
         self.CaptureMouse()
-        ### self.x, self.y = self.lastX, self.lastY = event.GetPosition()
     def OnLeftUp(self, event):
         self.ReleaseMouse()
     def UpdateView(self, event):
         """!Change view settings"""
         self.nvizClass.SetView(self.view['pos']['x'], self.view['pos']['y'],
         if event and event.zExag:
             self.nvizClass.SetZExag(self.view['z-exag']['value'])
         if event: event.Skip()
-    def UpdateMap(self, render=True):
-        Updates the canvas anytime there is a change to the
+    def UpdateMap(self, render = True):
+        """!Updates the canvas anytime there is a change to the
         underlaying images or to the geometry of the canvas.
         @param render re-render map composition
         start = time.clock()
         self.resize = False
         if self.render['quick'] is False:
             self.parent.statusbarWin['progress'].Show()
             self.parent.statusbarWin['progress'].SetRange(2)
             self.parent.statusbarWin['progress'].SetValue(0)
             self.parent.statusbarWin['progress'].SetValue(1)
             self.nvizClass.Draw(False, -1)
@@ -270,58 +270,55 @@
             # quick
             mode = wxnviz.DRAW_QUICK_SURFACE | wxnviz.DRAW_QUICK_VOLUME
             if self.render['vlines']:
-                mode |= wxnviz.DRAW_QUICK_VLINES
+                mode |=  wxnviz.DRAW_QUICK_VLINES
             if self.render['vpoints']:
-                mode |= wxnviz.DRAW_QUICK_VPOINTS
+                mode |=  wxnviz.DRAW_QUICK_VPOINTS
             self.nvizClass.Draw(True, mode)
         else: # None -> reuse last rendered image
             pass # TODO
         self.SwapBuffers()
         stop = time.clock()
             self.parent.statusbarWin['progress'].SetValue(2)
             # hide process bar
             self.parent.statusbarWin['progress'].Hide()
         # update statusbar
-        Debug.msg(3, "GLWindow.UpdateMap(): quick=%d, -> time=%g" % \
+        Debug.msg(3, "GLWindow.UpdateMap(): quick = %d, -> time = %g" % \
                       (self.render['quick'], (stop-start)))
-        # print stop-start
     def EraseMap(self):
+        """!Erase the canvas
-        Erase the canvas
         self.nvizClass.EraseMap()
         self.SwapBuffers()
     def IsLoaded(self, item):
         """!Check if layer (item) is already loaded
         @param item layer item
         layer = self.tree.GetPyData(item)[0]['maplayer']
         data = self.tree.GetPyData(item)[0]['nviz']
         if not data:
             return 0
             if not data['surface'].has_key('object'):
                 return 0
             if not data['vlines'].has_key('object') and \
                     not data['points'].has_key('object'):
                 return 0
         return 1
     def _GetDataLayers(self, item, litems):
@@ -329,7 +326,7 @@
         # load raster & vector maps
         while item and item.IsOk():
             type = self.tree.GetPyData(item)[0]['type']
-            if type == 'group':
+            if type ==  'group':
                 subItem = self.tree.GetFirstChild(item)[0]
                 self._GetDataLayers(subItem, litems)
                 item = self.tree.GetNextSibling(item)
@@ -338,14 +335,14 @@
                     type not in ('raster', 'vector', '3d-raster'):
                 continue
             litems.append(item)
     def LoadDataLayers(self):
         """!Load raster/vector from current layer tree
         @todo volumes
         if not self.tree:
@@ -356,21 +353,21 @@
         self._GetDataLayers(item, listOfItems)
         start = time.time()
         while(len(listOfItems) > 0):
             item = listOfItems.pop()
             if item not in self.layers:
                 try:
-                    if type == 'raster':
+                    if type ==  'raster':
                         self.LoadRaster(item)
-                    elif type == '3d-raster':
+                    elif type ==  '3d-raster':
                         self.LoadRaster3d(item)
                 except gcmd.NvizError, e:
                     print >> sys.stderr, "Nviz:" + e.message
                 try:
-                    if type == 'vector':
+                    if type ==  'vector':
                         vecType = []
                         if data and data.has_key('vector'):
@@ -381,13 +378,11 @@
                 self.init = False
         stop = time.time()
-        Debug.msg(3, "GLWindow.LoadDataLayers(): time=%f" % (stop-start))
-        # print stop - start
+        Debug.msg(3, "GLWindow.LoadDataLayers(): time = %f" % (stop-start))
     def UnloadDataLayers(self):
         """!Unload any layers that have been deleted from layer tree"""
         if not self.tree:
@@ -403,11 +398,11 @@
             if layer not in listOfItems:
                 ltype = self.tree.GetPyData(layer)[0]['type']
                 try:
-                    if ltype == 'raster':
+                    if ltype ==  'raster':
                         self.UnloadRaster(layer)
-                    elif ltype == '3d-raster':
+                    elif ltype ==  '3d-raster':
                         self.UnloadRaster3d(layer)
-                    elif ltype == 'vector':
+                    elif ltype ==  'vector':
                         data = self.tree.GetPyData(layer)[0]['nviz']
                         vecType = []
@@ -419,19 +414,19 @@
                     self.UpdateView(None)
         stop = time.time()
-        Debug.msg(3, "GLWindow.UnloadDataLayers(): time=%f" % (stop-start))
+        Debug.msg(3, "GLWindow.UnloadDataLayers(): time = %f" % (stop-start))
     def SetMapObjProperties(self, item, id, nvizType):
         """!Set map object properties
         Properties must be afterwards updated by
         UpdateMapObjProperties().
         @param id nviz layer id (or -1)
         @param nvizType nviz data type (surface, points, vector)
@@ -444,24 +439,24 @@
             # init data structure
             self.tree.GetPyData(item)[0]['nviz'] = {}
                 # reset to default properties
                 data[nvizType] = self.nvizDefault.SetSurfaceDefaultProp()
-            elif type == 'vector':
+            elif type ==  'vector':
                 # reset to default properties (lines/points)
                 data['vector'] = self.nvizDefault.SetVectorDefaultProp()
                 data[nvizType] = self.nvizDefault.SetVolumeDefaultProp()
         else:
             # complete data (use default values)
                 data['surface'] = self.nvizDefault.SetSurfaceDefaultProp()
                 if not data['vector']['lines']:
                     self.nvizDefault.SetVectorLinesDefaultProp(data['vector']['lines'])
                 if not data['vector']['points']:
@@ -471,18 +466,18 @@
             for sec in data.keys():
                 for sec1 in data[sec].keys():
                     for sec2 in data[sec][sec1].keys():
-                        if sec2 != 'all':
+                        if sec2 !=  'all':
                             data[sec][sec1][sec2]['update'] = None
-            event = wxUpdateProperties(data=data)
+            event = wxUpdateProperties(data = data)
             wx.PostEvent(self, event)
         # set id
         if id > 0:
             if type in ('raster', '3d-raster'):
                data[nvizType]['object'] = { 'id' : id,
                                             'init' : False }
                 data['vector'][nvizType]['object'] = { 'id' : id,
                                                        'init' : False }
@@ -490,33 +485,33 @@
     def LoadRaster(self, item):
         """!Load 2d raster map and set surface attributes
         @param layer item
         return self._loadRaster(item)
     def LoadRaster3d(self, item):
         """!Load 3d raster map and set surface attributes
         @param layer item
     def _loadRaster(self, item):
         """!Load 2d/3d raster map and set its attributes
         @param layer item
         if layer.type not in ('raster', '3d-raster'):
             return
             id = self.nvizClass.LoadSurface(str(layer.name), None, None)
             nvizType = 'surface'
             errorMsg = _("Loading raster map")
-        elif layer.type == '3d-raster':
+        elif layer.type ==  '3d-raster':
             id = self.nvizClass.LoadVolume(str(layer.name), None, None)
             nvizType = 'volume'
             errorMsg = _("Loading 3d raster map")
@@ -535,50 +530,50 @@
         data = self.SetMapObjProperties(item, id, nvizType)
         # update properties
         # update tools window
         if hasattr(self.parent, "nvizToolWin") and \
-                item == self.GetSelectedLayer(type='item'):
+                item ==  self.GetSelectedLayer(type = 'item'):
             toolWin = self.parent.nvizToolWin
                 win = toolWin.FindWindowById( \
                     toolWin.win['vector']['lines']['surface'])
                 win.SetItems(self.GetLayerNames(layer.type))
             #toolWin.UpdatePage(nvizType)
             #toolWin.SetPage(nvizType)
         return id
     def UnloadRaster(self, item):
         """!Unload 2d raster map
         @param layer item
         return self._unloadRaster(item)
     def UnloadRaster3d(self, item):
         """!Unload 3d raster map
         @param layer item
     def _unloadRaster(self, item):
         """!Unload 2d/3d raster map
             return
             unloadFn = self.nvizClass.UnloadSurface
             errorMsg = _("Unable to unload raster map")
@@ -588,58 +583,58 @@
             unloadFn = self.nvizClass.UnloadVolume
             errorMsg = _("Unable to unload 3d raster map")
             successMsg = _("3d raster map")
         id = data[nvizType]['object']['id']
-        if unloadFn(id) == 0:
+        if unloadFn(id) ==  0:
             print >> sys.stderr, "Nviz:" + "%s <%s>" % (errorMsg, layer.name)
         else:
             print "Nviz:" + "%s <%s> %s" % (successMsg, layer.name, _("unloaded successfully"))
         data[nvizType].pop('object')
         self.layers.remove(item)
-                layer.type == 'raster':
+                layer.type ==  'raster':
             # remove surface page
-            if toolWin.notebook.GetSelection() == toolWin.page[nvizType]['id']:
+            if toolWin.notebook.GetSelection() ==  toolWin.page[nvizType]['id']:
                 toolWin.notebook.RemovePage(toolWin.page[nvizType]['id'])
                 toolWin.page[nvizType]['id'] = -1
                 toolWin.page['settings']['id'] = 1
-    def LoadVector(self, item, vecType=None):
+    def LoadVector(self, item, vecType = None):
         """!Load 2D or 3D vector map overlay
         @param vecType vector type (lines / points)
-        if layer.type != 'vector':
+        if layer.type !=  'vector':
             return
         if vecType is None:
             # load data type by default
             vecType = []
             for v in ('lines', 'points'):
-                if UserSettings.Get(group='nviz', key='vector',
-                                    subkey=[v, 'show']):
+                if UserSettings.Get(group = 'nviz', key = 'vector',
+                                    subkey = [v, 'show']):
                     vecType.append(v)
         # set default properties
         self.SetMapObjProperties(item, -1, 'lines')
         self.SetMapObjProperties(item, -1, 'points')
         id = -1
         for type in vecType:
-            if type == 'lines':
+            if type ==  'lines':
                 id = self.nvizClass.LoadVector(str(layer.name), False)
             else:
                 id = self.nvizClass.LoadVector(str(layer.name), True)
@@ -648,7 +643,7 @@
                 print >> sys.stderr, "Nviz:" + _("Loading vector map <%(name)s> (%(type)s) failed") % \
                     { 'name' : layer.name, 'type' : type }
                 continue
             # update layer properties
             self.SetMapObjProperties(item, id, type)
@@ -656,63 +651,62 @@
         # update properties
             toolWin.UpdatePage('vector')
             toolWin.SetPage('vector')
         return id
-    def UnloadVector(self, item, vecType=None):
+    def UnloadVector(self, item, vecType = None):
         """!Unload vector map overlay
         @param vecType vector type (lines, points)
         data = self.tree.GetPyData(item)[0]['nviz']['vector']
         if vecType is None:
             vecType = []
                     vecType.append(v)
         for vtype in vecType:
             if not data[vtype].has_key('object'):
                 continue
             id = data[vtype]['object']['id']
-            if vtype == 'lines':
+            if vtype ==  'lines':
                 ret = self.nvizClass.UnloadVector(id, False)
             else:
                 ret = self.nvizClass.UnloadVector(id, True)
-            if ret == 0:
+            if ret ==  0:
                 print >> sys.stderr, "Nviz:" + _("Unable to unload vector map <%(name)s> (%(type)s)") % \
                     { 'name': layer.name, 'type' : vtype }
             else:
                 print "Nviz:" + _("Vector map <%(name)s> (%(type)s) unloaded successfully") % \
                     { 'name' : layer.name, 'type' : vtype }
             data[vtype].pop('object')
-            self.layers.remove(id)
+            self.layers.remove(id)
                 vecType is None:
-            if toolWin.notebook.GetSelection() == toolWin.page['surface']['id']:
+            if toolWin.notebook.GetSelection() ==  toolWin.page['surface']['id']:
                 toolWin.notebook.RemovePage(toolWin.page['surface']['id'])
                 toolWin.page['surface']['id'] = -1
@@ -721,30 +715,29 @@
         """!Reset (unload data)"""
         for item in self.layers:
             type = self.tree.GetPyData(item)[0]['maplayer'].type
                 self.UnloadRaster(item)
                 self.UnloadRaster3d(item)
                 self.UnloadVector(item)
         self.init = False
     def OnZoomToMap(self, event):
-        Set display extents to match selected raster
-        or vector map or volume.
+        """!Set display extents to match selected raster or vector
+        map or volume.
         @todo vector, volume
         if layer is None:
             return
-        Debug.msg (3, "GLWindow.OnZoomToMap(): layer=%s, type=%s" % \
+        Debug.msg (3, "GLWindow.OnZoomToMap(): layer = %s, type = %s" % \
                        (layer.name, layer.type))
         self.nvizClass.SetViewportDefault()
     def ResetView(self):
@@ -754,17 +747,17 @@
             self.iview['height']['min'], \
             self.iview['height']['max'] = self.nvizClass.SetViewDefault()
-        self.view['pos']['x'] = UserSettings.Get(group='nviz', key='view',
-                                                 subkey=('pos', 'x'))
-        self.view['pos']['y'] = UserSettings.Get(group='nviz', key='view',
-        self.view['persp']['value'] = UserSettings.Get(group='nviz', key='view',
-                                                       subkey=('persp', 'value'))
-        self.view['twist']['value'] = UserSettings.Get(group='nviz', key='view',
-                                                       subkey=('twist', 'value'))
-        event = wxUpdateView(zExag=False)
+        self.view['pos']['x'] = UserSettings.Get(group = 'nviz', key = 'view',
+                                                 subkey = ('pos', 'x'))
+        self.view['pos']['y'] = UserSettings.Get(group = 'nviz', key = 'view',
+        self.view['persp']['value'] = UserSettings.Get(group = 'nviz', key = 'view',
+                                                       subkey = ('persp', 'value'))
+        self.view['twist']['value'] = UserSettings.Get(group = 'nviz', key = 'view',
+                                                       subkey = ('twist', 'value'))
+        event = wxUpdateView(zExag = False)
     def UpdateMapObjProperties(self, event):
@@ -776,13 +769,13 @@
             self.UpdateSurfaceProperties(id, data['surface'])
             # -> initialized
             data['surface']['object']['init'] = True
         elif data.has_key('volume'):
             id = data['volume']['object']['id']
             self.UpdateVolumeProperties(id, data['volume'])
             # -> initialized
             data['volume']['object']['init'] = True
         elif data.has_key('vector'):
             for type in ('lines', 'points'):
                 if data['vector'][type].has_key('object'):
@@ -799,45 +792,45 @@
             if not data['attribute'].has_key(attrb) or \
                     not data['attribute'][attrb].has_key('update'):
                 continue
             map = data['attribute'][attrb]['map']
             value = data['attribute'][attrb]['value']
             if map is None: # unset
                 # only optional attributes
-                if attrb == 'mask':
+                if attrb ==  'mask':
                     # TODO: invert mask
                     # TODO: broken in NVIZ
                     self.nvizClass.UnsetSurfaceMask(id)
-                elif attrb == 'transp':
+                elif attrb ==  'transp':
                     self.nvizClass.UnsetSurfaceTransp(id)
-                elif attrb == 'emit':
+                elif attrb ==  'emit':
                     self.nvizClass.UnsetSurfaceEmit(id)
             else:
-                if type(value) == type('') and \
-                        len(value) <= 0: # ignore empty values (TODO: warning)
+                if type(value) ==  type('') and \
+                        len(value) <=  0: # ignore empty values (TODO: warning)
                     continue
-                if attrb == 'topo':
+                if attrb ==  'topo':
                     self.nvizClass.SetSurfaceTopo(id, map, str(value))
-                elif attrb == 'color':
+                elif attrb ==  'color':
                     self.nvizClass.SetSurfaceColor(id, map, str(value))
-                elif attrb == 'mask':
+                elif attrb ==  'mask':
                     # TODO: invert mask
                     self.nvizClass.SetSurfaceMask(id, False, str(value))
                     self.nvizClass.SetSurfaceTransp(id, map, str(value))
-                elif attrb == 'shine':
+                elif attrb ==  'shine':
                     self.nvizClass.SetSurfaceShine(id, map, str(value))
                     self.nvizClass.SetSurfaceEmit(id, map, str(value))
             data['attribute'][attrb].pop('update')
         # draw res
         if data['draw']['resolution'].has_key('update'):
             coarse = data['draw']['resolution']['coarse']
             fine   = data['draw']['resolution']['fine']
             if data['draw']['all']:
                 self.nvizClass.SetSurfaceRes(-1, fine, coarse)
             else:
@@ -848,17 +841,17 @@
         if data['draw']['mode'].has_key('update'):
             if data['draw']['mode']['value'] < 0: # need to calculate
                 data['draw']['mode']['value'] = \
-                    self.nvizDefault.GetDrawMode(mode=data['draw']['mode']['desc']['mode'],
-                                                 style=data['draw']['mode']['desc']['style'],
-                                                 shade=data['draw']['mode']['desc']['shading'],
-                                                 string=True)
+                    self.nvizDefault.GetDrawMode(mode = data['draw']['mode']['desc']['mode'],
+                                                 style = data['draw']['mode']['desc']['style'],
+                                                 shade = data['draw']['mode']['desc']['shading'],
+                                                 string = True)
             style = data['draw']['mode']['value']
                 self.nvizClass.SetSurfaceStyle(-1, style)
             else:
                 self.nvizClass.SetSurfaceStyle(id, style)
             data['draw']['mode'].pop('update')
         # wire color
         if data['draw']['wire-color'].has_key('update'):
             color = data['draw']['wire-color']['value']
@@ -876,11 +869,8 @@
             self.nvizClass.SetSurfacePosition(id, x, y, z)
             data['position'].pop('update')
-    def UpdateVolumeProperties(self, id, data, isosurfId=None):
+    def UpdateVolumeProperties(self, id, data, isosurfId = None):
         """!Update volume (isosurface/slice) map object properties"""
-        # draw
             self.nvizClass.SetIsosurfaceRes(id, data['draw']['resolution']['value'])
             data['draw']['resolution'].pop('update')
@@ -888,8 +878,8 @@
         if data['draw']['shading'].has_key('update'):
             if data['draw']['shading']['value'] < 0: # need to calculate
                 data['draw']['shading']['value'] = \
-                    self.nvizDefault.GetDrawMode(shade=data['draw']['shading'],
-                                                 string=False)
+                    self.nvizDefault.GetDrawMode(shade = data['draw']['shading'],
+                                                 string = False)
             data['draw']['shading'].pop('update')
@@ -904,48 +894,48 @@
                     continue
                 map = isosurf[attrb]['map']
                 value = isosurf[attrb]['value']
                         # TODO: invert mask
                         self.nvizClass.UnsetIsosurfaceMask(id, isosurfId)
                         self.nvizClass.UnsetIsosurfaceTransp(id, isosurfId)
                         self.nvizClass.UnsetIsosurfaceEmit(id, isosurfId)
                 else:
                         continue
                         self.nvizClass.SetIsosurfaceColor(id, isosurfId, map, str(value))
                         # TODO: invert mask
                         self.nvizClass.SetIsosurfaceMask(id, isosurfId, False, str(value))
                         self.nvizClass.SetIsosurfaceTransp(id, isosurfId, map, str(value))
                         self.nvizClass.SetIsosurfaceShine(id, isosurfId, map, str(value))
                         self.nvizClass.SetIsosurfaceEmit(id, isosurfId, map, str(value))
                 isosurf[attrb].pop('update')
-            isosurfId += 1
+            isosurfId +=  1
     def UpdateVectorProperties(self, id, data, type):
         """!Update vector layer properties
         @param id layer id
         @param data properties
         @param type lines/points
-        if type == 'points':
+        if type ==  'points':
             self.UpdateVectorPointsProperties(id, data[type])
         else:
             self.UpdateVectorLinesProperties(id, data[type])
     def UpdateVectorLinesProperties(self, id, data):
         """!Update vector line map object properties"""
         # mode
@@ -954,13 +944,13 @@
                 data['mode'].has_key('update'):
             width = data['width']['value']
             color = data['color']['value']
-            if data['mode']['type'] == 'flat':
+            if data['mode']['type'] ==  'flat':
                 flat = True
                 if data.has_key('surface'):
                     data.pop('surface')
             else:
                 flat = False
             self.nvizClass.SetVectorLineMode(id, color,
                                              width, flat)
@@ -979,7 +969,7 @@
         # surface
         if data['mode'].has_key('update'):
-            sid = self.GetLayerId(type='raster', name=data['mode']['surface'])
+            sid = self.GetLayerId(type = 'raster', name = data['mode']['surface'])
             if sid > -1:
                 self.nvizClass.SetVectorLineSurface(id, sid)
@@ -994,17 +984,17 @@
             ret = self.nvizClass.SetVectorPointMode(id, data['color']['value'],
                                                     data['width']['value'], float(data['size']['value']),
                                                     data['marker']['value'] + 1)
             error = None
-            if ret == -1:
-                error = _("Vector point layer not found (id=%d)") % id
-            elif ret == -2:
-                error = _("Unable to set data layer properties (id=%d)") % id
+            if ret ==  -1:
+                error = _("Vector point layer not found (id = %d)") % id
+            elif ret ==  -2:
+                error = _("Unable to set data layer properties (id = %d)") % id
             if error:
-                raise gcmd.NvizError(parent=self.parent,
-                                     message=_("Setting data layer properties failed.\n\n%s") % error)
+                raise gcmd.NvizError(parent = self.parent,
+                                     message = _("Setting data layer properties failed.\n\n%s") % error)
             for prop in ('size', 'width', 'marker', 'color'):
                 if data[prop].has_key('update'):
                     data[prop].pop('update')
@@ -1017,19 +1007,19 @@
         # surface
             if sid > -1:
                 self.nvizClass.SetVectorPointSurface(id, sid)
             data['mode'].pop('update')
     def GetLayerNames(self, type):
         """!Return list of map layer names of given type"""
         layerName = []
             mapLayer = self.tree.GetPyData(item)[0]['maplayer']
-            if type != mapLayer.GetType():
+            if type !=  mapLayer.GetType():
                 continue
             layerName.append(mapLayer.GetName())
@@ -1043,7 +1033,7 @@
             mapLayer = self.tree.GetPyData(item)[0]['maplayer'].GetName()
-            if mapLayer == name:
+            if mapLayer ==  name:
                 return self.tree.GetPyData(item)[0]['nviz']
         return {}
@@ -1055,20 +1045,21 @@
-            if type != mapLayer.GetType() or \
-                    name != mapLayer.GetName():
+            if type !=  mapLayer.GetType() or \
+                    name !=  mapLayer.GetName():
                 continue
                 return data['surface']['object']['id']
-            elif type == 'vpoint':
+            elif type ==  'vpoint':
                 return data['vector']['points']['object']['id']
-            elif type == 'vline':
+            elif type ==  'vline':
                 return data['vector']['lines']['object']['id']
                 return data['volume']['object']['id']
         return -1
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2010-05-26 14:26:05 UTC (rev 42354)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2010-05-26 20:02:22 UTC (rev 42355)
@@ -1350,8 +1350,8 @@
             (self.settings, "settings", Icons["nvizSettings"].GetBitmap(),
              wx.ITEM_NORMAL, Icons["nvizSettings"].GetLabel(), Icons["nvizSettings"].GetDesc(),
              self.OnSettings),
-            (self.quit, 'quit', Icons["quit"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["quit"].GetLabel(), Icons["quit"].GetDesc(),
+            (self.quit, 'quit', Icons["nvizQuit"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["nvizQuit"].GetLabel(), Icons["nvizQuit"].GetDesc(),
              self.OnExit),
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2010-05-26 14:26:05 UTC (rev 42354)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2010-05-26 20:02:22 UTC (rev 42355)
@@ -119,7 +119,7 @@
         return Nviz_change_exag(self.data, z_exag)
     def Draw(self, quick, quick_mode):
-        """!Draw map
+        """!Draw canvas
         Draw quick mode:
          - DRAW_QUICK_SURFACE
@@ -130,6 +130,8 @@
         @param quick if true draw in wiremode
         @param quick_mode quick mode
+        Debug.msg(3, "Nviz::Draw(): quick=%d", quick)
         Nviz_draw_cplane(self.data, -1, -1) # ?
         if quick:
@@ -137,8 +139,6 @@
         else:
             Nviz_draw_all(self.data)
-        Debug.msg(3, "Nviz::Draw(): quick=%d", quick)
     def EraseMap(self):
         """!Erase map display (with background color)
@@ -1092,3 +1092,4 @@
         ret = GVL_isosurf_set_drawres(id, res, res, res)
         return -2 if ret < 0 else 1
Modified: grass/trunk/gui/wxpython/icons/grass_icons.py
--- grass/trunk/gui/wxpython/icons/grass_icons.py	2010-05-26 14:26:05 UTC (rev 42354)
+++ grass/trunk/gui/wxpython/icons/grass_icons.py	2010-05-26 20:02:22 UTC (rev 42355)
@@ -105,7 +105,7 @@
     "grGcpReload"  : 'gui-redraw.gif',
     "grSettings"   : 'edit-color.gif',
     # nviz
-    "nvizSettings" : 'edit-color.gif',
+    "nvizSettings" : 'edit-color.gif',
     # modeler
     "modelActionAdd" : wx.ART_ERROR,
     "modelDataAdd"   : wx.ART_ERROR,
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py	2010-05-26 14:26:05 UTC (rev 42354)
+++ grass/trunk/gui/wxpython/icons/icon.py	2010-05-26 20:02:22 UTC (rev 42355)
@@ -138,10 +138,11 @@
 Icons = {
     # map display
     "displaymap" : MetaIcon (img=Icons["displaymap"],
-                             label=_("Display map")),
+                             label=_("Display map"),
+                             desc = _("Re-render modified map layers")),
     "rendermap"  : MetaIcon (img=Icons["rendermap"],
                              label=_("Re-render map"),
-                             desc=_("Force re-rendering of all layers")),
+                             desc=_("Force re-rendering all map layers")),
     "erase"      : MetaIcon (img=Icons["erase"],
                              label=_("Erase display")),
     "pointer"    : MetaIcon (img=Icons["pointer"],
@@ -334,8 +335,11 @@
                             desc=_("Settings dialog for georectification tool")),
     # nviz
     "nvizSettings": MetaIcon (img=Icons["nvizSettings"],
-                              label=_("Settings"),
-                              desc=_("Show Nviz settings dialog")),
+                              label=_("3D view mode tools"),
+                              desc=_("Show/hide 3D view mode tools dialog")),
+    "nvizQuit": MetaIcon (img=Icons["quit"],
+                          label=_("Quit 3D view mode"),
+                          desc=_("Switch back to 2D view mode")),
     # modeler
     "modelNew" : MetaIcon (img=Icons["fileNew"],
                            label=_("Create new model (Ctrl+N)")),
