[GRASS-SVN] r42357 - grass/trunk/lib/init
svn_grass at osgeo.org
Wed May 26 18:33:08 EDT 2010
Author: martinl
Date: 2010-05-26 18:33:07 -0400 (Wed, 26 May 2010)
New Revision: 42357
grass/trunk/lib/init/grass.py
minor windows oriented fixes in startup script
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2010-05-26 20:18:09 UTC (rev 42356)
+++ grass/trunk/lib/init/grass.py 2010-05-26 22:33:07 UTC (rev 42357)
@@ -85,7 +85,8 @@
def message(msg):
sys.stderr.write(msg + "\n")
+ sys.stderr.flush()
def readfile(path):
f = open(path, 'r')
s = f.read()
@@ -102,6 +103,11 @@
kwargs['shell'] = True
return subprocess.call(cmd, **kwargs)
+def Popen(cmd, **kwargs):
+ if windows:
+ kwargs['shell'] = True
+ return subprocess.Popen(cmd, **kwargs)
def gfile(*args):
return os.path.join(gisbase, *args)
@@ -384,9 +390,9 @@
# Check if python is working properly
if grass_gui == 'wxpython':
nul = open(os.devnull, 'w')
- p = subprocess.Popen([os.environ['GRASS_PYTHON']],
- stdin = subprocess.PIPE,
- stdout = nul, stderr = nul)
+ p = Popen([os.environ['GRASS_PYTHON']],
+ stdin = subprocess.PIPE,
+ stdout = nul, stderr = nul)
nul.close()
p.stdin.write("variable=True")
p.stdin.close()
@@ -494,8 +500,9 @@
def gui_startup():
- thetest = call([os.getenv('GRASS_PYTHON'), os.path.join(wxpython_base, "gis_set.py")])
+ thetest = call([os.getenv('GRASS_PYTHON'),
+ gfile(wxpython_base, "gis_set.py")])
if thetest == 0:
pass
elif thetest == 1:
@@ -617,8 +624,8 @@
# Check for gui interface
if grass_gui == "wxpython":
- subprocess.Popen([os.getenv('GRASS_PYTHON'),
- gfile(wxpython_base, "wxgui.py")])
+ Popen([os.getenv('GRASS_PYTHON'),
+ gfile(wxpython_base, "wxgui.py")])
def clear_screen():
if windows:
@@ -725,17 +732,17 @@
os.environ['HISTFILE'] = os.path.join(location, ".bash_history")
if not os.getenv('HISTSIZE') and not os.getenv('HISTFILESIZE'):
os.environ['HISTSIZE'] = "3000"
# instead of changing $HOME, start bash with: --rcfile "$LOCATION/.bashrc" ?
# if so, must care be taken to explicity call .grass.bashrc et al for
# non-interactive bash batch jobs?
userhome = os.getenv('HOME') # save original home
home = location # save .bashrc in $LOCATION
os.environ['HOME'] = home
bashrc = os.path.join(home, ".bashrc")
try_remove(bashrc)
f = open(bashrc, 'w')
f.write("test -r ~/.alias && . ~/.alias\n")
f.write("PS1='GRASS %s (%s):\w > '\n" % (grass_version, location_name))
@@ -743,7 +750,7 @@
path = os.path.join(userhome, ".grass.bashrc")
if os.access(path, os.R_OK):
f.write(readfile(path) + '\n')
f.write("export PATH=\"%s\"\n" % os.getenv('PATH'))
f.write("export HOME=\"%s\"\n" % userhome) # restore user home path
@@ -753,23 +760,26 @@
f.write("export %s=\"%s\"\n" % (env, value))
f.close()
exit_val = call([gfile("etc", "run"), os.getenv('SHELL')])
os.environ['HOME'] = userhome
def default_startup():
global exit_val
if windows:
os.environ['PS1'] = "GRASS %s> " % (grass_version)
# "$ETC/run" doesn't work at all???
- exit_val = call([os.getenv('SHELL')])
+ exit_val = subprocess.call([os.getenv('SHELL')])
cleanup_dir(os.path.join(location, ".tmp")) # remove GUI session files from .tmp
else:
os.environ['PS1'] = "GRASS %s (%s):\w > " % (grass_version, location_name)
+ if exit_val != 0:
+ fatal(_("Failed to start shell '%s'") % os.getenv('SHELL'))
def done_message():
if batch_job and os.access(batch_job, os.X_OK):
message(_("Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed.") % batch_job)
@@ -799,7 +809,7 @@
user = os.getenv('LOGNAME')
if not user:
try:
- p = subprocess.Popen(['whoami'], stdout = subprocess.PIPE)
+ p = Popen(['whoami'], stdout = subprocess.PIPE)
s = p.stdout.read()
p.wait()
user = s.strip()
@@ -850,8 +860,11 @@
os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'), os.getenv('HOMEPATH'))
# set SHELL
-if windows and not os.getenv('SHELL'):
- os.environ['SHELL'] = os.getenv('COMSPEC', 'cmd.exe')
+if windows:
+ if os.getenv('GRASS_SH'):
+ os.environ['SHELL'] = os.getenv('GRASS_SH')
+ if not os.getenv('SHELL'):
+ os.environ['SHELL'] = os.getenv('COMSPEC', 'cmd.exe')
grass_config_dir = os.path.join(os.getenv('HOME'), grass_config_dirname)
@@ -864,10 +877,6 @@
# use 'g.gisenv set="DEBUG=[0-5]"' to turn GRASS debug mode on properly.
grass_debug = os.getenv('GRASS_DEBUG')
-# GRASS_SH is normally just for Windows when not started from a bourne
-# shell. But when starting from Init.sh is still needed for GRASS_GUI (still true for GRASS 7?)
-os.environ['GRASS_SH'] = "/bin/sh"
# Set GRASS version number for R interface etc (must be an env_var for MS-Windows)
os.environ['GRASS_VERSION'] = grass_version
