[GRASS-SVN] r42361 - grass/trunk/gui/wxpython/gui_modules
Fri May 28 11:29:37 EDT 2010
Author: martinl
Date: 2010-05-28 11:29:36 -0400 (Fri, 28 May 2010)
New Revision: 42361
   grass/trunk/gui/wxpython/gui_modules/gdialogs.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/render.py
   grass/trunk/gui/wxpython/gui_modules/wxnviz.py
wxGUI: image size dialog for exporting images
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2010-05-28 12:31:30 UTC (rev 42360)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2010-05-28 15:29:36 UTC (rev 42361)
@@ -17,6 +17,8 @@
  - DxfImportDialog
  - LayersList (used by MultiImport)
  - SetOpacityDialog
+ - StaticWrapText
+ - ImageSizeDialog
 (C) 2008-2010 by the GRASS Development Team
@@ -1487,3 +1489,72 @@
                 self.SetSize(self.wrappedSize)
             del self.resizing
+class ImageSizeDialog(wx.Dialog):
+    """!Set size for saved graphic file"""
+    def __init__(self, parent, id = wx.ID_ANY, title=_("Set image size"),
+                 style = wx.DEFAULT_DIALOG_STYLE, **kwargs):
+        self.parent = parent
+        wx.Dialog.__init__(self, parent, id = id, style=style, title=title, **kwargs)
+        self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+        self.box = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+                                label = ' % s' % _("Image size"))
+        size = self.parent.GetWindow().GetClientSize()
+        self.width = wx.SpinCtrl(parent = self, id = wx.ID_ANY,
+                                 style = wx.SP_ARROW_KEYS)
+        self.width.SetRange(20, 1e6)
+        self.width.SetValue(size.width)
+        wx.CallAfter(self.width.SetFocus)
+        self.height = wx.SpinCtrl(parent = self, id = wx.ID_ANY,
+        self.height.SetRange(20, 1e6)
+        self.height.SetValue(size.height)
+        self.btnOK = wx.Button(parent = self.panel, id = wx.ID_OK)
+        self.btnOK.SetDefault()
+        self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
+        self._layout()
+        self.SetSize(self.GetBestSize())
+    def _layout(self):
+        """!Do layout"""
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        # body
+        box = wx.StaticBoxSizer(self.box, wx.HORIZONTAL)
+        fbox = wx.FlexGridSizer(cols = 2, vgap = 5, hgap = 5)
+        fbox.Add(item = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+                                      label = _("Width:")),
+                 flag = wx.ALIGN_CENTER_VERTICAL)
+        fbox.Add(item = self.width)
+                                      label = _("Height:")),
+        fbox.Add(item = self.height)
+        box.Add(item = fbox, proportion = 1,
+                flag = wx.EXPAND | wx.ALL, border = 5)
+        sizer.Add(item = box, proportion = 1,
+                  flag=wx.EXPAND | wx.ALL, border = 3)
+        # buttons
+        btnsizer = wx.StdDialogButtonSizer()
+        btnsizer.AddButton(self.btnOK)
+        btnsizer.AddButton(self.btnCancel)
+        btnsizer.Realize()
+        sizer.Add(item = btnsizer, proportion = 0,
+                  flag = wx.EXPAND | wx.ALIGN_RIGHT | wx.ALL, border=5)
+        self.panel.SetSizer(sizer)
+        sizer.Fit(self.panel)
+        self.Layout()
+    def GetValues(self):
+        """!Get width/height values"""
+        return self.width.GetValue(), self.height.GetValue()
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-05-28 12:31:30 UTC (rev 42360)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-05-28 15:29:36 UTC (rev 42361)
@@ -1182,10 +1182,19 @@
         else:
             filetype, ltype = gdialogs.GetImageHandlers(self.MapWindow.img)
+        # get size
+        dlg = gdialogs.ImageSizeDialog(self)
+        dlg.CentreOnParent()
+        if dlg.ShowModal() != wx.ID_OK:
+            dlg.Destroy()
+            return
+        width, height = dlg.GetValues()
+        dlg.Destroy()
+        # get filename
         dlg = wx.FileDialog(parent = self,
-                            message = _("Choose a file name to save the image (no need to add extension)"),
-                            defaultDir = "",
-                            defaultFile = "",
+                            message = _("Choose a file name to save the image "
+                                        "(no need to add extension)"),
                             wildcard = filetype,
                             style=wx.SAVE | wx.FD_OVERWRITE_PROMPT)
@@ -1201,7 +1210,8 @@
             if ext != extType:
                 path = base + '.' + extType
-            self.MapWindow.SaveToFile(path, fileType)
+            self.MapWindow.SaveToFile(path, fileType,
+                                      width, height)
         dlg.Destroy()
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2010-05-28 12:31:30 UTC (rev 42360)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2010-05-28 15:29:36 UTC (rev 42361)
@@ -555,23 +555,21 @@
             self.redrawAll = False
     def OnSize(self, event):
-        Scale map image so that it is
-        the same size as the Window
+        """!Scale map image so that it is the same size as the Window
         Debug.msg(3, "BufferedWindow.OnSize():")
         # set size of the input image
         self.Map.ChangeMapSize(self.GetClientSize())
         # align extent based on center point and display resolution
         # this causes that image is not resized when display windows is resized
-        # self.Map.AlignExtentFromDisplay()
+        ### self.Map.AlignExtentFromDisplay()
         # Make new off screen bitmap: this bitmap will always have the
         # current drawing in it, so it can be used to save the image to
         # a file, or whatever.
         self.buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
         # get the image to be rendered
         self.img = self.GetImage()
@@ -591,8 +589,7 @@
         self.parent.StatusbarUpdate()
     def OnIdle(self, event):
-        Only re-render a composite map image from GRASS during
+        """!Only re-render a composite map image from GRASS during
         idle time instead of multiple times during resizing.
         if self.resize:
@@ -600,17 +597,37 @@
         event.Skip()
-    def SaveToFile(self, FileName, FileType):
-        This draws the psuedo DC to a buffer that
-        can be saved to a file.
+    def SaveToFile(self, FileName, FileType, width, height):
+        """!This draws the pseudo DC to a buffer that can be saved to
+        a file.
+        @param FileName file name
+        @param FileType type of bitmap
+        @param width image width
+        @param height image height
-        dc = wx.BufferedPaintDC(self, self.buffer)
+        busy = wx.BusyInfo(message=_("Please wait, exporting image..."),
+                           parent=self)
+        wx.Yield()
+        self.Map.ChangeMapSize((width, height))
+        ibuffer = wx.EmptyBitmap(max(1, width), max(1, height))
+        self.Map.Render(force=True, windres = True)
+        img = self.GetImage()
+        self.Draw(self.pdc, img, drawid = 99)
+        dc = wx.BufferedPaintDC(self, ibuffer)
+        dc.Clear()
+        self.PrepareDC(dc)
         self.pdc.DrawToDC(dc)
         if self.pdcVector:
             self.pdcVector.DrawToDC(dc)
-        self.buffer.SaveFile(FileName, FileType)
+        ibuffer.SaveFile(FileName, FileType)
+        busy.Destroy()
+        self.UpdateMap(render = True)
+        self.Refresh()
     def GetOverlay(self):
         Converts rendered overlay files to wx.Image
@@ -630,8 +647,7 @@
         return imgs
     def GetImage(self):
-        Converts redered map files to wx.Image
+        """!Converts redered map files to wx.Image
         Updates self.imagedict (id=99)
@@ -643,29 +659,29 @@
             img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
         else:
             img = None
         self.imagedict[img] = { 'id': imgId }
         return img
     def UpdateMap(self, render=True, renderVector=True):
         Updates the canvas anytime there is a change to the
         underlaying images or to the geometry of the canvas.
         @param render re-render map composition
         @param renderVector re-render vector map layer enabled for editing (used for digitizer)
         start = time.clock()
         self.resize = False
         # if len(self.Map.GetListOfLayers()) == 0:
         #    return False
         if self.img is None:
             render = True
         # initialize process bar (only on 'render')
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-05-28 12:31:30 UTC (rev 42360)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-05-28 15:29:36 UTC (rev 42361)
@@ -1066,12 +1066,19 @@
         return -1
         """!This draws the DC to a buffer that can be saved to a file.
         @todo fix BufferedPaintDC
-        self._display.SaveToFile(FileName)
+        self.SetCurrent()
+        self._display.SaveToFile(FileName, width, height)
         # pbuffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
         # dc = wx.BufferedPaintDC(self, pbuffer)
         # dc.Clear()
@@ -1079,7 +1086,7 @@
         # self._display.Draw(False, -1)
         # pbuffer.SaveFile(FileName, FileType)
         # self.SwapBuffers()
     def GetDisplay(self):
         """!Get display instance"""
         return self._display
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2010-05-28 12:31:30 UTC (rev 42360)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2010-05-28 15:29:36 UTC (rev 42361)
@@ -9,7 +9,7 @@
  - Overlay
  - Map
-(C) 2006-2009 by the GRASS Development Team
+(C) 2006-2010 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
 for details.
@@ -55,11 +55,10 @@
 class Layer(object):
     """!Virtual class which stores information about layers (map layers and
     overlays) of the map composition.
     For map layer use MapLayer class.
     For overlays use Overlay class.
     def __init__(self, type, cmd, name=None,
                  active=True, hidden=False, opacity=1.0):
@@ -75,7 +74,7 @@
         self.type = type
         self.name = name
         if self.type == 'command':
             self.cmd = []
             for c in cmd:
@@ -93,7 +92,7 @@
                        "active=%d, opacity=%d, hidden=%d" % \
                        (self.type, self.GetCmd(string=True), self.name, self.active,
                         self.opacity, self.hidden))
         # generated file for each layer
         self.gtemp = tempfile.mkstemp()[1]
         self.maskfile = self.gtemp + ".pgm"
@@ -101,14 +100,14 @@
             self.mapfile  = self.gtemp + ".png"
         else:
             self.mapfile  = self.gtemp + ".ppm"
     def __del__(self):
         Debug.msg (3, "Layer.__del__(): layer=%s, cmd='%s'" %
                    (self.name, self.GetCmd(string=True)))
     def Render(self):
         """!Render layer to image
         @return rendered image filename
         @return None on error
@@ -200,9 +199,9 @@
     def GetCmd(self, string=False):
         Get GRASS command as list of string.
         @param string get command as string if True otherwise as list
         @return command list/string
         if string:
@@ -224,9 +223,9 @@
     def GetOpacity(self, float=False):
         Get layer opacity level
         @param float get opacity level in <0,1> otherwise <0,100>
         @return opacity level
         if float:
@@ -253,7 +252,7 @@
     def IsActive(self):
         """!Check if layer is activated for rendering"""
         return self.active
     def SetType(self, type):
         """!Set layer type"""
         if type not in ('raster', '3d-raster', 'vector',
@@ -300,10 +299,10 @@
         self.force_render = True
 class MapLayer(Layer):
-    """!Represents map layer in the map canvas"""
-                 active=True, hidden=False, opacity=1.0):
+                 active=True, hidden=False, opacity=1.0):
+        """!Represents map layer in the map canvas
         @param type layer type ('raster', 'vector', 'command', etc.)
         @param cmd GRASS command to render layer,
         given as list, e.g. ['d.rast', 'map=elevation at PERMANENT']
@@ -314,29 +313,26 @@
         Layer.__init__(self, type, cmd, name,
                        active, hidden, opacity)
-        #self.mapfile = self.gtemp + ".ppm"
     def GetMapset(self):
-        Get mapset of map layer
+        """!Get mapset of map layer
         @return mapset name
         @return '' on error (no name given)
         if not self.name:
             return ''
         try:
             return self.name.split('@')[1]
         except IndexError:
             return self.name
 class Overlay(Layer):
-    """!Represents overlay displayed in map canvas"""
     def __init__(self, id, type, cmd,
                  active=True, hidden=True, opacity=1.0):
+        """!Represents overlay displayed in map canvas
         @param id overlay id (for PseudoDC)
         @param type overlay type ('barscale', 'legend', etc.)
         @param cmd GRASS command to render overlay,
@@ -347,10 +343,9 @@
         Layer.__init__(self, 'overlay', cmd, type,
         self.id = id
-        #self.mapfile = self.gtemp + ".png"
 class Map(object):
     """!Map composition (stack of map layers and overlays)
@@ -363,7 +358,7 @@
         # list of layers
         self.layers    = list()  # stack of available GRASS layer
         self.overlays  = list()  # stack of available overlays
         self.ovlookup  = dict()  # lookup dictionary for overlay items and overlays
@@ -385,7 +380,7 @@
         # projection info
         self.projinfo = self._projInfo()
     def _runCommand(self, cmd, **kwargs):
         """!Run command in environment defined by self.gisrc if
         defined"""
@@ -418,7 +413,7 @@
         """!Return region projection and map units information
         projinfo = dict()
         ret = self._runCommand(gcmd.RunCommand, prog = 'g.proj',
                                read = True, flags = 'p')
@@ -435,7 +430,7 @@
                 break
         return projinfo
     def GetWindow(self):
         """!Read WIND file and set up self.wind dictionary"""
         # FIXME: duplicated region WIND == g.region (at least some values)
@@ -459,81 +454,77 @@
         return self.wind
     def AdjustRegion(self):
+        """!Adjusts display resolution to match monitor size in
+        pixels. Maintains constant display resolution, not related to
+        computational region. Do NOT use the display resolution to set
+        computational resolution. Set computational resolution through
+        g.region.
-        Adjusts display resolution to match monitor size in pixels.
-        Maintains constant display resolution, not related to computational
-        region. Do NOT use the display resolution to set computational
-        resolution. Set computational resolution through g.region.
         mapwidth    = abs(self.region["e"] - self.region["w"])
         mapheight   = abs(self.region['n'] - self.region['s'])
         self.region["nsres"] =  mapheight / self.height
         self.region["ewres"] =  mapwidth  / self.width
         self.region['rows']  = round(mapheight / self.region["nsres"])
         self.region['cols']  = round(mapwidth / self.region["ewres"])
         self.region['cells'] = self.region['rows'] * self.region['cols']
         Debug.msg (3, "Map.AdjustRegion(): %s" % self.region)
         return self.region
     def AlignResolution(self):
+        """!Sets display extents to even multiple of current
+        resolution defined in WIND file from SW corner. This must be
+        done manually as using the -a flag can produce incorrect
+        extents.
-        Sets display extents to even multiple of
-        current resolution defined in WIND file from SW corner.
-        This must be done manually as using the -a flag
-        can produce incorrect extents.
         # new values to use for saving to region file
         new = {}
         n = s = e = w = 0.0
         nwres = ewres = 0.0
         # Get current values for region and display
         nsres = self.GetRegion()['nsres']
         ewres = self.GetRegion()['ewres']
         n = float(self.region['n'])
         s = float(self.region['s'])
         e = float(self.region['e'])
         w = float(self.region['w'])
         # Calculate rows, columns, and extents
         new['rows'] = math.fabs(round((n-s)/nsres))
         new['cols'] = math.fabs(round((e-w)/ewres))
         # Calculate new extents
         new['s'] = nsres * round(s/nsres)
         new['w'] = ewres * round(w/ewres)
         new['n'] = new['s'] + (new['rows'] * nsres)
         new['e'] = new['w'] + (new['cols'] * ewres)
         return new
     def AlignExtentFromDisplay(self):
         """!Align region extent based on display size from center point"""
         # calculate new bounding box based on center of display
         if self.region["ewres"] > self.region["nsres"]:
             res = self.region["ewres"]
         else:
             res = self.region["nsres"]
         Debug.msg(3, "Map.AlignExtentFromDisplay(): width=%d, height=%d, res=%f, center=%f,%f" % \
                       (self.width, self.height, res, self.region['center_easting'],
                        self.region['center_northing']))
         ew = (self.width / 2) * res
         ns = (self.height / 2) * res
         self.region['n'] = self.region['center_northing'] + ns
         self.region['s'] = self.region['center_northing'] - ns
         self.region['e'] = self.region['center_easting'] + ew
         self.region['w'] = self.region['center_easting'] - ew
         # LL locations
         if self.projinfo['proj'] == 'll':
             if self.region['n'] > 90.0:
@@ -559,12 +550,12 @@
             self.width  = 640
             self.height = 480
             return False
     def GetRegion(self, rast = [], zoom = False, vect = [], regionName = None,
                   n = None, s = None, e = None, w = None, default = False,
                   update = False):
         """!Get region settings (g.region -upgc)
         Optionally extent, raster or vector map layer can be given.
         @param rast list of raster maps
@@ -579,20 +570,20 @@
         'n':'4928010', 's':'4913700', 'w':'589980',...}
         region = {}
         tmpreg = os.getenv("GRASS_REGION")
         if tmpreg:
             del os.environ["GRASS_REGION"]
         # use external gisrc if defined
         gisrc_orig = os.getenv("GISRC")
         if self.gisrc:
             os.environ["GISRC"] = self.gisrc
         # do not update & shell style output
         cmd = {}
         cmd['flags'] = 'ugpc'
         if default:
             cmd['flags'] += 'd'
@@ -607,13 +598,13 @@
             cmd['e'] = e
         if w:
             cmd['w'] = w
         if rast:
             if zoom:
                 cmd['zoom'] = rast[0]
             else:
                 cmd['rast'] = ','.join(rast)
         if vect:
             cmd['vect'] = ','.join(vect)
@@ -634,22 +625,22 @@
                               "fix the problem.")
             e.Show()
             return self.region
         for reg in ret.splitlines():
             key, val = reg.split("=", 1)
             try:
                 region[key] = float(val)
             except ValueError:
                 region[key] = val
         # back to original gisrc
         if self.gisrc:
             os.environ["GISRC"] = gisrc_orig
         # restore region
         if tmpreg:
             os.environ["GRASS_REGION"] = tmpreg
         Debug.msg (3, "Map.GetRegion(): %s" % region)
         if update:
@@ -662,17 +653,17 @@
         return self.region
     def SetRegion(self, windres=False):
-        Render string for GRASS_REGION env. variable, so that the images will be rendered
-        from desired zoom level.
+        """!Render string for GRASS_REGION env. variable, so that the
+        images will be rendered from desired zoom level.
+        @param windres uses resolution from WIND file rather than
+        display (for modules that require set resolution like
+        d.rast.num)
-        @param windres uses resolution from WIND file rather than display (for modules that require set
-        resolution like d.rast.num)
         @return String usable for GRASS_REGION variable or None
         grass_region = ""
         if windres:
             compRegion = self.GetRegion()
             region = copy.copy(self.region)
@@ -720,41 +711,39 @@
                     continue
                 else:
                     grass_region += key + ": "  + self.wind[key] + "; "
             Debug.msg (3, "Map.SetRegion(): %s" % grass_region)
             return grass_region
         except:
             return None
     def GetListOfLayers(self, l_type=None, l_mapset=None, l_name=None,
                         l_active=None, l_hidden=None):
-        Returns list of layers of selected properties or list of all
-        layers.
+        """!Returns list of layers of selected properties or list of
+        all layers.
         @param l_type layer type, e.g. raster/vector/wms/overlay (value or tuple of values)
         @param l_mapset all layers from given mapset (only for maplayers)
         @param l_name all layers with given name
         @param l_active only layers with 'active' attribute set to True or False
         @param l_hidden only layers with 'hidden' attribute set to True or False
         @return list of selected layers
         selected = []
         if type(l_type) == type(''):
             one_type = True
         else:
             one_type = False
         if one_type and l_type == 'overlay':
             list = self.overlays
         else:
             list = self.layers
         # ["raster", "vector", "wms", ... ]
         for layer in list:
             # specified type only
@@ -763,39 +752,39 @@
                     continue
                 elif not one_type and layer.type not in l_type:
                     continue
             # mapset
             if (l_mapset != None and type != 'overlay') and \
                     layer.GetMapset() != l_mapset:
                 continue
             # name
             if l_name != None and layer.name != l_name:
                 continue
             # hidden and active layers
             if l_active != None and \
                    l_hidden != None:
                 if layer.active == l_active and \
                        layer.hidden == l_hidden:
                     selected.append(layer)
             # active layers
             elif l_active != None:
                 if layer.active == l_active:
             # hidden layers
             elif l_hidden != None:
                 if layer.hidden == l_hidden:
             # all layers
             else:
         Debug.msg (3, "Map.GetListOfLayers(): numberof=%d" % len(selected))
         return selected
     def _renderLayers(self, force, mapWindow, maps, masks, opacities):
@@ -828,11 +817,10 @@
             Debug.msg (3, "Map.Render() type=%s, layer=%s " % (layer.type, layer.name))
             ilayer += 1
     def Render(self, force=False, mapWindow=None, windres=False):
-        Creates final image composite
+        """!Creates final image composite
         This function can conditionaly use high-level tools, which
         should be avaliable in wxPython library
@@ -845,12 +833,12 @@
         maps = []
         masks =[]
         opacities = []
         if self.gisrc:
         tmp_region = os.getenv("GRASS_REGION")
         os.environ["GRASS_REGION"] = self.SetRegion(windres)
         os.environ["GRASS_WIDTH"]  = str(self.width)
@@ -865,7 +853,7 @@
             os.environ["GRASS_RENDER_IMMEDIATE"] = "png"
         else:
             os.environ["GRASS_RENDER_IMMEDIATE"] = "TRUE"
         os.environ["GRASS_PNG_READ"] = "FALSE"
         self._renderLayers(force, mapWindow, maps, masks, opacities)
@@ -885,7 +873,7 @@
                 maskstr += item.replace('\\', '/')
             maskstr = maskstr.rstrip(',')
             mapoutstr = self.mapfile.replace('\\', '/')
         # compose command
         bgcolor = ':'.join(map(str, UserSettings.Get(group='display', key='bgcolor',
                                                      subkey='color')))
@@ -918,21 +906,20 @@
         if ret != 0:
             print >> sys.stderr, _("ERROR: Rendering failed")
             return None
         if self.gisrc:
-        Debug.msg (2, "Map.Render() force=%s file=%s" % (force, self.mapfile))
+        Debug.msg (3, "Map.Render() force=%s file=%s" % (force, self.mapfile))
         return self.mapfile
     def AddLayer(self, type, command, name=None,
                  l_active=True, l_hidden=False, l_opacity=1.0, l_render=False,
                  pos=-1):
-        Adds generic map layer to list of layers
+        """!Adds generic map layer to list of layers
         @param type layer type ('raster', 'vector', etc.)
         @param command  GRASS command given as list
         @param name layer name
@@ -941,18 +928,17 @@
         @param l_opacity opacity level range from 0(transparent) - 1(not transparent)
         @param l_render render an image if True
         @param pos position in layer list (-1 for append)
         @return new layer on success
         @return None on failure
         # l_opacity must be <0;1>
         if l_opacity < 0: l_opacity = 0
         elif l_opacity > 1: l_opacity = 1
         layer = MapLayer(type=type, name=name, cmd=command,
                          active=l_active, hidden=l_hidden, opacity=l_opacity)
         # add maplayer to the list of layers
         if pos > -1:
             self.layers.insert(pos, layer)
@@ -963,26 +949,24 @@
         if l_render:
             if not layer.Render():
                 raise gcmd.GStdError(_("Unable to render map layer <%s>.") % (name))
         return layer
     def DeleteLayer(self, layer, overlay=False):
-        Removes layer from list of layers
+        """!Removes layer from list of layers
         @param layer layer instance in layer tree
         @param overlay delete overlay (use self.DeleteOverlay() instead)
         @return removed layer on success or None
         Debug.msg (3, "Map.DeleteLayer(): name=%s" % layer.name)
         if overlay:
         else:
             list = self.layers
         if layer in list:
             if layer.mapfile:
                 base = os.path.split(layer.mapfile)[0]
@@ -994,29 +978,27 @@
                 for f in glob.glob(basefile):
                     os.remove(f)
             list.remove(layer)
             return layer
         return None
     def ReorderLayers(self, layerList):
-        Reorder list to match layer tree
+        """!Reorder list to match layer tree
         @param layerList list of layers
         self.layers = layerList
         layerNameList = ""
         for layer in self.layers:
             if layer.name:
                 layerNameList += layer.name + ','
         Debug.msg (4, "Map.ReoderLayers(): layers=%s" % \
                    (layerNameList))
     def ChangeLayer(self, layer, render=False, **kargs):
-        Change map layer properties
+        """!Change map layer properties
         @param layer map layer instance
@@ -1027,7 +1009,6 @@
         @param opacity opacity level range from 0(transparent) - 1(not transparent)
         @param render render an image if True
         Debug.msg (3, "Map.ChangeLayer(): layer=%s" % layer.name)
         if kargs.has_key('type'):
@@ -1038,25 +1019,24 @@
         if kargs.has_key('name'):
             layer.SetName(kargs['name'])
         if kargs.has_key('active'):
             layer.SetActive(kargs['active'])
         if kargs.has_key('hidden'):
             layer.SetHidden(kargs['hidden'])
         if kargs.has_key('opacity'):
             layer.SetOpacity(kargs['opacity'])
         if render and not layer.Render():
             raise gcmd.GException(_("Unable to render map layer <%s>.") %
                                   (name))
         return layer
     def ChangeOpacity(self, layer, l_opacity):
-        Changes opacity value of map layer
+        """!Changes opacity value of map layer
         @param l_opacity opacity level <0;1>
@@ -1064,27 +1044,25 @@
         layer.opacity = l_opacity
         Debug.msg (3, "Map.ChangeOpacity(): layer=%s, opacity=%f" % \
                    (layer.name, layer.opacity))
     def ChangeLayerActive(self, layer, active):
-        Enable or disable map layer
+        """!Enable or disable map layer
         @param active to be rendered (True)
         layer.active = active
         Debug.msg (3, "Map.ChangeLayerActive(): name='%s' -> active=%d" % \
                    (layer.name, layer.active))
     def ChangeLayerName (self, layer, name):
-        Change name of the layer
+        """!Change name of the layer
         @param name  layer name to set up
@@ -1093,18 +1071,16 @@
         layer.name =  name
     def RemoveLayer(self, name=None, id=None):
-        Removes layer from layer list
+        """!Removes layer from layer list
         Layer is defined by name at mapset or id.
         @param name layer name (must be unique)
         @param id layer index in layer list
         # delete by name
         if name:
             retlayer = None
@@ -1118,13 +1094,12 @@
         # del by id
         elif id != None:
             return self.layers.pop(id)
         return None
     def GetLayerIndex(self, layer, overlay=False):
-        Get index of layer in layer list.
+        """!Get index of layer in layer list.
         @param layer layer instace in layer tree
         @param overlay use list of overlays instead
@@ -1138,13 +1113,13 @@
         if layer in list:
             return list.index(layer)
         return -1
     def AddOverlay(self, id, type, command,
                    l_active=True, l_hidden=True, l_opacity=1.0, l_render=False):
-        Adds overlay (grid, barscale, legend, etc.) to list of overlays
+        """!Adds overlay (grid, barscale, legend, etc.) to list of
+        overlays
         @param id overlay id (PseudoDC)
         @param type overlay type (barscale, legend)
@@ -1152,37 +1127,35 @@
         @param l_active overlay activated (True) or disabled (False)
         @param l_hidden overlay is not shown in layer tree (if True)
         @param l_render render an image (if True)
         @retutn None on failure
         Debug.msg (2, "Map.AddOverlay(): cmd=%s, render=%d" % (command, l_render))
         overlay = Overlay(id=id, type=type, cmd=command,
         self.overlays.append(overlay)
         if l_render and command != '' and not overlay.Render():
             raise gcmd.GException(_("Unable render overlay <%s>.") %
                                   (name))
         return self.overlays[-1]
     def ChangeOverlay(self, id, render=False, **kargs):
-        Change overlay properities
+        """!Change overlay properities
         Add new overlay if overlay with 'id' doesn't exist.
         @param command GRASS command to render overlay
         overlay = self.GetOverlay(id, list=False)
@@ -1197,10 +1170,10 @@
             overlay.SetActive(kargs['active'])
             overlay.SetHidden(kargs['hidden'])
             overlay.SetOpacity(kargs['opacity'])
@@ -1212,7 +1185,7 @@
     def GetOverlay(self, id, list=False):
         """!Return overlay(s) with 'id'
         @param list return list of overlays of True
         otherwise suppose 'id' to be unique
@@ -1231,23 +1204,22 @@
                 return None
             else:
                 return ovl[0]
         return ovl
     def DeleteOverlay(self, overlay):
         """!Delete overlay
         @return removed overlay on success or None
         return self.DeleteLayer(overlay, overlay=True)
     def Clean(self):
-        Clean layer stack - go trough all layers and remove them from layer list
-        Removes also l_mapfile and l_maskfile
+        """!Clean layer stack - go trough all layers and remove them
+        from layer list Removes also l_mapfile and l_maskfile
         @return 1 on faulure
         @return None on success
@@ -1265,7 +1237,7 @@
                     for f in glob.glob(removepath):
                         os.remove(f)
                 self.layers.remove(layer)
             for overlay in self.overlays:
                 if overlay.mapfile:
                     dir = os.path.dirname(overlay.mapfile)
@@ -1284,31 +1256,30 @@
         return self.layers.reverse()
 if __name__ == "__main__":
-    Test of Display class.
+    """!Test of Display class.
     Usage: display=Render()
     import gettext
     gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
     print "Initializing..."
-    os.system("g.region -d")
+    grass.run_command("g.region", flags="d")
     map = Map()
     map.width = 640
     map.height = 480
     map.AddLayer(type="raster",
                  name="elevation.dem",
                  command = ["d.rast", "elevation.dem at PERMANENT", "catlist=1000-1500", "-i"],
                  l_opacity=.7)
     map.AddLayer(type="vector",
                  name="streams",
                  command = ["d.vect", "streams at PERMANENT", "color=red", "width=3", "type=line"])
     image = map.Render(force=True)
     if image:
         os.system("display %s" % image)
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2010-05-28 12:31:30 UTC (rev 42360)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2010-05-28 15:29:36 UTC (rev 42361)
@@ -44,6 +44,7 @@
         self.data_obj = nv_data()
         self.data = pointer(self.data_obj)
+        self.width = self.height = -1
         Debug.msg(1, "Nviz::Nviz()")
@@ -64,7 +65,8 @@
         @return 1 on success
         @return 0 on failure (window resized by default to 20x20 px)
+        self.width  = width
+        self.height = height
         Debug.msg(3, "Nviz::ResizeWindow(): width=%d height=%d",
                   width, height)
         return Nviz_resize_window(width, height)
@@ -1093,14 +1095,23 @@
         return -2 if ret < 0 else 1
-    def SaveToFile(self, filename, itype = 'ppm'):
+    def SaveToFile(self, filename, width = 20, height = 20, itype = 'ppm'):
         """!Save current GL screen to ppm/tif file
         @param filename file name
         @param itype image type ('ppm' or 'tif')
+        widthOrig  = self.width
+        heightOrig = self.height
+        self.ResizeWindow(width, height)
+        GS_clear(self.data.bgcolor)
         self.Draw(False, -1)
         if itype == 'ppm':
             GS_write_ppm(filename)
         else:
             GS_write_tif(filename)
+        self.ResizeWindow(widthOrig, heightOrig)
