[GRASS-SVN] r42366 - grass/branches/develbranch_6/visualization/nviz2/cmd
Fri May 28 12:56:29 EDT 2010
Author: martinl
Date: 2010-05-28 12:56:24 -0400 (Fri, 28 May 2010)
New Revision: 42366
   grass/branches/develbranch_6/visualization/nviz2/cmd/args.c
   grass/branches/develbranch_6/visualization/nviz2/cmd/main.c
   grass/branches/develbranch_6/visualization/nviz2/cmd/surface.c
   grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c
   grass/branches/develbranch_6/visualization/nviz2/cmd/volume.c
   grass/branches/develbranch_6/visualization/nviz2/cmd/write_img.c
nviz_cmd: guisections cosmetics
(merge r42365 from devbr6)
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/args.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/args.c	2010-05-28 16:51:55 UTC (rev 42365)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/args.c	2010-05-28 16:56:24 UTC (rev 42366)
@@ -1,19 +1,17 @@
-   \file args.c
+  \file args.c
+  \brief Parse command
+  (C) 2008, 2010 by the GRASS Development Team
+  This program is free software under the GNU General Public
+  License (>=v2). Read the file COPYING that comes with GRASS
+  for details.
+  \author Martin Landa <landa.martin gmail.com> (Google SoC 2008/2010)
-   \brief Parse command
-   (C) 2008 by the GRASS Development Team
-   This program is free software under the GNU General Public
-   License (>=v2). Read the file COPYING that comes with GRASS
-   for details.
-   \author Martin Landa <landa.martin gmail.com> (Google SoC 2008)
-   \date 2008
 #include <stdlib.h>
 #include <string.h>
@@ -33,21 +31,22 @@
 static void args_volume(struct GParams *);
-   \param argc number of arguments
-   \param argv arguments array
-   \param params GRASS parameters
-   \return 1
+  \param argc number of arguments
+  \param argv arguments array
+  \param params GRASS parameters
+  \return 1
 void parse_command(int argc, char *argv[], struct GParams *params)
     params->mode_all = G_define_flag();
     params->mode_all->key = 'a';
     params->mode_all->description =
 	_("Use draw mode for all loaded surfaces");
+    params->mode_all->guisection = _("Surfaces");
     /*** surface attributes ***/
     args_surface(params);
@@ -71,7 +70,7 @@
     /* output */
     params->output = G_define_standard_option(G_OPT_F_OUTPUT);
     params->output->description =
-	_("Name for output file (do not add extension)");
+	_("Name for output file (without extension)");
     params->output->guisection = _("Image");
     /* format */
@@ -112,7 +111,7 @@
     params->elev_map->required = NO;
     params->elev_map->multiple = YES;
     params->elev_map->description = _("Name of raster map(s) for elevation");
-    params->elev_map->guisection = _("Surface");
+    params->elev_map->guisection = _("Surfaces");
     params->elev_const = G_define_option();
     params->elev_const->key = "elevation_value";
@@ -121,20 +120,20 @@
     params->elev_const->required = NO;
     params->elev_const->multiple = YES;
     params->elev_const->description = _("Elevation value(s)");
-    params->elev_const->guisection = _("Surface");
+    params->elev_const->guisection = _("Surfaces");
     /* color */
     params->color_map = G_define_standard_option(G_OPT_R_MAP);
     params->color_map->multiple = YES;
     params->color_map->required = NO;
     params->color_map->description = _("Name of raster map(s) for color");
-    params->color_map->guisection = _("Surface");
+    params->color_map->guisection = _("Surfaces");
     params->color_map->key = "color_map";
     params->color_const = G_define_standard_option(G_OPT_C_FG);
     params->color_const->multiple = YES;
     params->color_const->label = _("Color value(s)");
-    params->color_const->guisection = _("Surface");
+    params->color_const->guisection = _("Surfaces");
     params->color_const->key = "color_value";
     params->color_const->answer = NULL;
@@ -143,7 +142,7 @@
     params->mask_map->multiple = YES;
     params->mask_map->required = NO;
     params->mask_map->description = _("Name of raster map(s) for mask");
-    params->mask_map->guisection = _("Surface");
+    params->mask_map->guisection = _("Surfaces");
     params->mask_map->key = "mask_map";
     /* transparency */
@@ -152,7 +151,7 @@
     params->transp_map->required = NO;
     params->transp_map->description =
 	_("Name of raster map(s) for transparency");
-    params->transp_map->guisection = _("Surface");
+    params->transp_map->guisection = _("Surfaces");
     params->transp_map->key = "transparency_map";
     params->transp_const = G_define_option();
@@ -162,7 +161,7 @@
     params->transp_const->required = NO;
     params->transp_const->multiple = YES;
     params->transp_const->description = _("Transparency value(s)");
-    params->transp_const->guisection = _("Surface");
+    params->transp_const->guisection = _("Surfaces");
     params->transp_const->options = "0-255";
     /* shininess */
@@ -170,7 +169,7 @@
     params->shine_map->multiple = YES;
     params->shine_map->required = NO;
     params->shine_map->description = _("Name of raster map(s) for shininess");
-    params->shine_map->guisection = _("Surface");
+    params->shine_map->guisection = _("Surfaces");
     params->shine_map->key = "shininess_map";
     params->shine_const = G_define_option();
@@ -180,7 +179,7 @@
     params->shine_const->required = NO;
     params->shine_const->multiple = YES;
     params->shine_const->description = _("Shininess value(s)");
-    params->shine_const->guisection = _("Surface");
+    params->shine_const->guisection = _("Surfaces");
     params->shine_const->options = "0-255";
     /* emission */
@@ -188,7 +187,7 @@
     params->emit_map->multiple = YES;
     params->emit_map->required = NO;
     params->emit_map->description = _("Name of raster map(s) for emission");
-    params->emit_map->guisection = _("Surface");
+    params->emit_map->guisection = _("Surfaces");
     params->emit_map->key = "emission_map";
     params->emit_const = G_define_option();
@@ -198,7 +197,7 @@
     params->emit_const->required = NO;
     params->emit_const->multiple = YES;
     params->emit_const->description = _("Emission value(s)");
-    params->emit_const->guisection = _("Surface");
+    params->emit_const->guisection = _("Surfaces");
     params->emit_const->options = "0-255";
@@ -209,7 +208,7 @@
     params->mode->key = "mode";
     params->mode->key_desc = "string";
     params->mode->type = TYPE_STRING;
-    params->mode->required = YES;
+    params->mode->required = NO;
     params->mode->multiple = YES;
     params->mode->description = _("Draw mode");
     params->mode->options = "coarse,fine,both";
@@ -221,7 +220,7 @@
     params->res_fine->key = "resolution_fine";
     params->res_fine->key_desc = "value";
     params->res_fine->type = TYPE_INTEGER;
-    params->res_fine->required = YES;
+    params->res_fine->required = NO;
     params->res_fine->multiple = YES;
     params->res_fine->description = _("Fine resolution");
     params->res_fine->answer = "6";
@@ -232,7 +231,7 @@
     params->res_coarse->key = "resolution_coarse";
     params->res_coarse->key_desc = "value";
     params->res_coarse->type = TYPE_INTEGER;
-    params->res_coarse->required = YES;
+    params->res_coarse->required = NO;
     params->res_coarse->multiple = YES;
     params->res_coarse->description = _("Coarse resolution");
     params->res_coarse->answer = "9";
@@ -243,7 +242,7 @@
     params->style->key = "style";
     params->style->key_desc = "string";
     params->style->type = TYPE_STRING;
-    params->style->required = YES;
+    params->style->required = NO;
     params->style->multiple = YES;
     params->style->description = _("Draw style");
     params->style->options = "wire,surface";
@@ -255,7 +254,7 @@
     params->shade->key = "shading";
     params->shade->key_desc = "string";
     params->shade->type = TYPE_STRING;
-    params->shade->required = YES;
+    params->shade->required = NO;
     params->shade->multiple = YES;
     params->shade->description = _("Shading");
     params->shade->options = "flat,gouraud";
@@ -265,7 +264,7 @@
     /* wire color */
     params->wire_color = G_define_standard_option(G_OPT_C_FG);
     params->wire_color->multiple = YES;
-    params->wire_color->required = YES;
+    params->wire_color->required = NO;
     params->wire_color->label = _("Wire color");
     params->wire_color->key = "wire_color";
     params->wire_color->answer = "136:136:136";
@@ -276,7 +275,7 @@
@@ -288,7 +287,7 @@
     params->surface_pos->key = "position";
     params->surface_pos->key_desc = "x,y,z";
     params->surface_pos->type = TYPE_INTEGER;
-    params->surface_pos->required = YES;
+    params->surface_pos->required = NO;
     params->surface_pos->multiple = YES;
     params->surface_pos->description = _("Position");
     params->surface_pos->guisection = _("Draw");
@@ -332,7 +331,7 @@
     params->vline_mode->key = "vline_mode";
     params->vline_mode->key_desc = "string";
     params->vline_mode->type = TYPE_STRING;
-    params->vline_mode->required = YES;
+    params->vline_mode->required = NO;
     params->vline_mode->multiple = YES;
     params->vline_mode->description = _("Vector line display mode");
     params->vline_mode->options = "surface,flat";
@@ -356,7 +355,7 @@
     params->vline_pos->key = "vline_position";
     params->vline_pos->key_desc = "x,y,z";
     params->vline_pos->type = TYPE_INTEGER;
-    params->vline_pos->required = YES;
+    params->vline_pos->required = NO;
     params->vline_pos->multiple = YES;
     params->vline_pos->description = _("Position");
     params->vline_pos->guisection = _("Vector lines");
@@ -412,7 +411,7 @@
     params->vpoint_marker->key = "vpoint_marker";
     params->vpoint_marker->key_desc = "string";
     params->vpoint_marker->type = TYPE_STRING;
-    params->vpoint_marker->required = YES;
+    params->vpoint_marker->required = NO;
     params->vpoint_marker->multiple = YES;
     params->vpoint_marker->description = _("Icon marker");
     params->vpoint_marker->options =
@@ -425,7 +424,7 @@
     params->vpoint_pos->key = "vpoint_position";
     params->vpoint_pos->key_desc = "x,y,z";
     params->vpoint_pos->type = TYPE_INTEGER;
-    params->vpoint_pos->required = YES;
+    params->vpoint_pos->required = NO;
     params->vpoint_pos->multiple = YES;
     params->vpoint_pos->description = _("Position");
     params->vpoint_pos->guisection = _("Vector points");
@@ -498,7 +497,7 @@
     params->volume = G_define_standard_option(G_OPT_R3_MAPS);
     params->volume->required = NO;
-    params->volume->guisection = _("Volume");
+    params->volume->guisection = _("Volumes");
     params->volume->key = "volume";
     /* mode */
@@ -506,7 +505,7 @@
     params->volume_mode->key = "volume_mode";
     params->volume_mode->key_desc = "string";
     params->volume_mode->type = TYPE_STRING;
-    params->volume_mode->required = YES;
+    params->volume_mode->required = NO;
     params->volume_mode->multiple = YES;
     params->volume_mode->description = _("Volume draw mode");
     params->volume_mode->options = "isosurface,slice";
@@ -518,7 +517,7 @@
     params->volume_shade->key = "volume_shading";
     params->volume_shade->key_desc = "string";
     params->volume_shade->type = TYPE_STRING;
-    params->volume_shade->required = YES;
+    params->volume_shade->required = NO;
     params->volume_shade->multiple = YES;
     params->volume_shade->description = _("Volume shading");
     params->volume_shade->options = "flat,gouraud";
@@ -530,10 +529,10 @@
     params->volume_pos->key = "volume_position";
     params->volume_pos->key_desc = "x,y,z";
     params->volume_pos->type = TYPE_INTEGER;
-    params->volume_pos->required = YES;
+    params->volume_pos->required = NO;
     params->volume_pos->multiple = YES;
     params->volume_pos->description = _("Volume position");
-    params->volume_pos->guisection = _("Volume");
+    params->volume_pos->guisection = _("Volumes");
     params->volume_pos->answer = "0,0,0";
     /* resolution  */
@@ -541,11 +540,11 @@
     params->volume_res->key = "volume_resolution";
     params->volume_res->key_desc = "value";
     params->volume_res->type = TYPE_INTEGER;
-    params->volume_res->required = YES;
+    params->volume_res->required = NO;
     params->volume_res->multiple = YES;
     params->volume_res->description = _("Volume resolution");
     params->volume_res->answer = "3";
-    params->volume_res->guisection = _("Volume");
+    params->volume_res->guisection = _("Volumes");
     /* isosurface level */
     params->isosurf_level = G_define_option();
@@ -555,7 +554,7 @@
     params->isosurf_level->required = NO;
     params->isosurf_level->multiple = YES;
     params->isosurf_level->description = _("Isosurface level");
-    params->isosurf_level->guisection = _("Volume");
+    params->isosurf_level->guisection = _("Volumes");
     return;
@@ -583,9 +582,9 @@
-   \brief Check parameters consistency
-   \param params module parameters
+  \brief Check parameters consistency
+  \param params module parameters
 void check_parameters(const struct GParams *params)
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/main.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/main.c	2010-05-28 16:51:55 UTC (rev 42365)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/main.c	2010-05-28 16:56:24 UTC (rev 42366)
@@ -3,15 +3,15 @@
  * MODULE:       nviz_cmd
- * AUTHOR(S):    Martin Landa <landa.martin gmail.com> (Google SoC 2008)
+ * AUTHOR(S):    Martin Landa <landa.martin gmail.com> (Google SoC 2008/2010)
  * PURPOSE:      Experimental NVIZ CLI prototype
- * COPYRIGHT:    (C) 2008 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2008,2010 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
+ *               This program is free software under the GNU General
+ *               Public License (>=v2). Read the file COPYING that
+ *               comes with GRASS for details.
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/surface.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/surface.c	2010-05-28 16:51:55 UTC (rev 42365)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/surface.c	2010-05-28 16:56:24 UTC (rev 42366)
@@ -1,19 +1,17 @@
-   \file surface.c
+  \file surface.c
+  \brief Surface subroutines
+  for details.
-   \brief Surface subroutines
-   for details.
-   \date 2008
 #include <stdlib.h>
 #include <string.h>
@@ -22,11 +20,11 @@
 #include "local_proto.h"
-   \brief Load raster maps/constants and set surface attributes
-   \param data nviz data
+  \brief Load raster maps/constants and set surface attributes
+  \param data nviz data
 int load_rasters(const struct GParams *params, nv_data * data)
     char *mapset;
@@ -182,10 +180,10 @@
-   \brief Set draw mode for loaded surfaces
+  \brief Set draw mode for loaded surfaces
 void surface_set_draw_mode(const struct GParams *params)
     int *surf_list, nsurfs;
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c	2010-05-28 16:51:55 UTC (rev 42365)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c	2010-05-28 16:56:24 UTC (rev 42366)
@@ -1,19 +1,17 @@
-   \file vector.c
+  \file vector.c
+  \brief Vector subroutines
-   \brief Vector subroutines
+  for details.
-   for details.
-   \date 2008
 #include <stdlib.h>
 #include <string.h>
@@ -25,13 +23,13 @@
 			const struct Option *, const struct Option *, int, nv_data *);
-   \brief Load vector maps (lines)
-   \return number of loaded vectors
+  \brief Load vector maps (lines)
+  \return number of loaded vectors
 int load_vlines(const struct GParams *params, nv_data * data)
     return load_vectors(params->elev_map, params->elev_const,
@@ -40,13 +38,13 @@
-   \brief Load vector maps (points)
+  \brief Load vector maps (points)
 int load_vpoints(const struct GParams *params, nv_data * data)
@@ -103,13 +101,13 @@
-   \brief Set vector lines mode
-   \param params parameters
-   \return 1 on success
-   \return 0 on failure
+  \brief Set vector lines mode
+  \param params parameters
+  \return 1 on success
+  \return 0 on failure
 int vlines_set_attrb(const struct GParams *params)
     int i, color, width, flat, height;
@@ -138,13 +136,13 @@
-   \brief Set vector points mode
+  \brief Set vector points mode
 int vpoints_set_attrb(const struct GParams *params)
     int i;
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/volume.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/volume.c	2010-05-28 16:51:55 UTC (rev 42365)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/volume.c	2010-05-28 16:56:24 UTC (rev 42366)
@@ -1,19 +1,17 @@
-   \file volume.c
+  \file volume.c
+  \brief Volume subroutines
-   \brief Volume subroutines
+  for details.
-   for details.
-   \date 2008
 #include <stdlib.h>
 #include <grass/G3d.h>
@@ -22,13 +20,13 @@
-   \brief Load 3d raster map layers -> volume
+  \brief Load 3d raster map layers -> volume
-   \return number of loaded volumes
+  \return number of loaded volumes
 int load_rasters3d(const struct GParams *params, nv_data *data)
   int i, nvol, id;
@@ -54,7 +52,7 @@
   \brief Add isosurfaces and set their attributes
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/write_img.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/write_img.c	2010-05-28 16:51:55 UTC (rev 42365)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/write_img.c	2010-05-28 16:56:24 UTC (rev 42366)
@@ -1,35 +1,32 @@
-   \file write_img.c
+  \file write_img.c
+  \brief Save current GL screen to image file.
+  for details.
+  Based on visualization/nviz/src/anim_support.c
+  \author Updated/modified by Martin Landa <landa.martin gmail.com>
-   \brief Save current GL screen to image file.
-   for details.
-   Based on visualization/nviz/src/anim_support.c
-   \author Updated/modified by Martin Landa <landa.martin gmail.com>
-   \date 2008
 #include <grass/gsurf.h>
 #include <grass/gstypes.h>
-   \brief Save current GL screen to an ppm file.
-   \param name filename
-   \return 0 on failure (unsupported format)
+  \brief Save current GL screen to an ppm file.
+  \param name filename
+  \return 0 on failure (unsupported format)
 int write_img(const char *name, int format)
     if (format == FORMAT_PPM)
