[GRASS-SVN] r42369 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat May 29 05:52:41 EDT 2010
Author: martinl
Date: 2010-05-29 05:52:41 -0400 (Sat, 29 May 2010)
New Revision: 42369
grass/branches/develbranch_6/gui/wxpython/gui_modules/histogram.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
wxGUI/histogram: major clean up
(merge r42368 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/histogram.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/histogram.py 2010-05-29 09:42:34 UTC (rev 42368)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/histogram.py 2010-05-29 09:52:41 UTC (rev 42369)
@@ -1,73 +1,54 @@
-MODULE: histogram
+ at package histogram.py
-CLASSES:
- * BufferedWindow
- * HistFrame
+Plotting histogram
-PURPOSE: Plotting histogram
+Classes:
+ - BufferedWindow
+ - HistFrame
-AUTHORS: The GRASS Development Team
- Michael Barton
+COPYRIGHT: (C) 2007, 2010 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
-COPYRIGHT: (C) 2007 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+ at author Michael Barton
+ at author Various updates by Martin Landa
+import os
+import sys
import wx
-import wx.aui
-import os, sys, time, glob, math
-from threading import Thread
-import globalvar
-try:
- import subprocess
-except:
- CompatPath = os.path.join(globalvar.ETCWXDIR)
- sys.path.append(CompatPath)
- from compat import subprocess
-gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
-sys.path.append(gmpath)
import render
import menuform
import disp_print
import utils
-from gui_modules.preferences import DefaultFontDialog as DefaultFontDialog
-from debug import Debug as Debug
-from icon import Icons as Icons
+import gdialogs
+import globalvar
+from toolbars import HistogramToolbar
+from preferences import DefaultFontDialog
+from debug import Debug
+from icon import Icons
-import images
-imagepath = images.__path__[0]
-sys.path.append(imagepath)
-os.environ["GRASS_BACKGROUNDCOLOR"] = "blue"
class BufferedWindow(wx.Window):
- A Buffered window class.
+ """!A Buffered window class.
When the drawing needs to change, you app needs to call the
UpdateHist() method. Since the drawing is stored in a bitmap, you
can also save the drawing to file by calling the
SaveToFile(self,file_name,file_type) method.
- def __init__(self, parent, id,
- pos = wx.DefaultPosition,
- size = wx.DefaultSize,
- style=wx.NO_FULL_REPAINT_ON_RESIZE,
- Map=None):
- wx.Window.__init__(self, parent, id, pos, size, style)
+ def __init__(self, parent, id = wx.ID_ANY,
+ style = wx.NO_FULL_REPAINT_ON_RESIZE,
+ Map = None, **kwargs):
+ wx.Window.__init__(self, parent, id = id, style = style, **kwargs)
self.parent = parent
self.Map = Map
self.mapname = self.parent.mapname
# Flags
@@ -75,36 +56,34 @@
self.resize = False # indicates whether or not a resize event has taken place
self.dragimg = None # initialize variable for map panning
self.pen = None # pen for drawing zoom boxes, etc.
# Event bindings
self.Bind(wx.EVT_PAINT, self.OnPaint)
self.Bind(wx.EVT_SIZE, self.OnSize)
self.Bind(wx.EVT_IDLE, self.OnIdle)
# Render output objects
self.mapfile = None # image file to be rendered
self.img = "" # wx.Image object (self.mapfile)
self.imagedict = {} # images and their PseudoDC ID's for painting and dragging
self.pdc = wx.PseudoDC()
- self._Buffer = '' # will store an off screen empty bitmap for saving to file
+ self._buffer = '' # will store an off screen empty bitmap for saving to file
# make sure that extents are updated at init
self.Map.region = self.Map.GetRegion()
self.Map.SetRegion()
self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
- def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0,0,0,0]):
+ def Draw(self, pdc, img = None, drawid = None, pdctype = 'image', coords = [0,0,0,0]):
+ """!Draws histogram or clears window
- Draws histogram or clears window
if drawid == None:
if pdctype == 'image' :
drawid = imagedict[img]
@@ -114,11 +93,11 @@
drawid = wx.NewId()
else:
pdc.SetId(drawid)
pdc.BeginDrawing()
Debug.msg (3, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % (drawid, pdctype, coords))
if pdctype == 'clear': # erase the display
bg = wx.WHITE_BRUSH
pdc.SetBackground(bg)
@@ -126,7 +105,7 @@
self.Refresh()
pdc.EndDrawing()
return
if pdctype == 'image':
bg = wx.TRANSPARENT_BRUSH
@@ -134,17 +113,15 @@
w,h = bitmap.GetSize()
pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
pdc.SetIdBounds(drawid, (coords[0],coords[1],w,h))
pdc.EndDrawing()
self.Refresh()
def OnPaint(self, event):
+ """!Draw psuedo DC to buffer
- Draw psuedo DC to buffer
- dc = wx.BufferedPaintDC(self, self._Buffer)
+ dc = wx.BufferedPaintDC(self, self._buffer)
# use PrepareDC to set position correctly
self.PrepareDC(dc)
# we need to clear the dc BEFORE calling PrepareDC
@@ -157,80 +134,83 @@
r = rgn.GetBox()
# draw to the dc using the calculated clipping rect
self.pdc.DrawToDCClipped(dc,r)
def OnSize(self, event):
+ """!Init image size to match window size
- Init image size to match window size
- # set size of the input image
+ # set size of the input image
self.Map.width, self.Map.height = self.GetClientSize()
# Make new off screen bitmap: this bitmap will always have the
# current drawing in it, so it can be used to save the image to
# a file, or whatever.
- self._Buffer = wx.EmptyBitmap(self.Map.width, self.Map.height)
+ self._buffer = wx.EmptyBitmap(self.Map.width, self.Map.height)
# get the image to be rendered
self.img = self.GetImage()
# update map display
if self.img and self.Map.width + self.Map.height > 0: # scale image during resize
self.img = self.img.Scale(self.Map.width, self.Map.height)
self.render = False
self.UpdateHist()
# re-render image on idle
self.resize = True
def OnIdle(self, event):
+ """!Only re-render a histogram image from GRASS during idle
+ time instead of multiple times during resizing.
- Only re-render a histogram image from GRASS during
- idle time instead of multiple times during resizing.
if self.resize:
self.render = True
self.UpdateHist()
event.Skip()
- def SaveToFile(self, FileName, FileType):
+ def SaveToFile(self, FileName, FileType, width, height):
+ """!This will save the contents of the buffer to the specified
+ file. See the wx.Windows docs for wx.Bitmap::SaveFile for the
+ details
- This will save the contents of the buffer
- to the specified file. See the wx.Windows docs for
- wx.Bitmap::SaveFile for the details
+ busy = wx.BusyInfo(message=_("Please wait, exporting image..."),
+ parent=self)
+ wx.Yield()
+ self.Map.ChangeMapSize((width, height))
+ ibuffer = wx.EmptyBitmap(max(1, width), max(1, height))
+ self.Map.Render(force=True, windres = True)
+ img = self.GetImage()
+ self.Draw(self.pdc, img, drawid = 99)
+ dc = wx.BufferedPaintDC(self, ibuffer)
+ dc.Clear()
+ self.PrepareDC(dc)
self.pdc.DrawToDC(dc)
- self._Buffer.SaveFile(FileName, FileType)
+ ibuffer.SaveFile(FileName, FileType)
+ busy.Destroy()
def GetImage(self):
+ """!Converts files to wx.Image
- Converts files to wx.Image
if self.Map.mapfile and os.path.isfile(self.Map.mapfile) and \
os.path.getsize(self.Map.mapfile):
img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
else:
img = None
self.imagedict[img] = 99 # set image PeudoDC ID
return img
- def UpdateHist(self, img=None):
+ def UpdateHist(self, img = None):
+ """!Update canvas if histogram options changes or window
+ changes geometry
- Update canvas if histogram options changes or window changes geometry
Debug.msg (2, "BufferedWindow.UpdateHist(%s): render=%s" % (img, self.render))
oldfont = ""
oldencoding = ""
if self.render:
# render new map images
# set default font and encoding environmental variables
if "GRASS_FONT" in os.environ:
oldfont = os.environ["GRASS_FONT"]
@@ -241,294 +221,230 @@
os.environ[GRASS_ENCODING] = self.parent.encoding
# using active comp region
- self.Map.GetRegion(update=True)
+ self.Map.GetRegion(update = True)
- self.mapfile = self.Map.Render(force=self.render)
+ self.mapfile = self.Map.Render(force = self.render)
self.resize = False
if not self.img: return
try:
id = self.imagedict[self.img]
except:
return
# paint images to PseudoDC
self.pdc.Clear()
self.pdc.RemoveAll()
- self.Draw(self.pdc, self.img, drawid=id) # draw map image background
+ self.Draw(self.pdc, self.img, drawid = id) # draw map image background
self.resize = False
# update statusbar
# Debug.msg (3, "BufferedWindow.UpdateHist(%s): region=%s" % self.Map.region)
self.parent.statusbar.SetStatusText("Raster/Image map layer <%s>" % self.parent.mapname)
if oldfont != "":
os.environ["GRASS_FONT"] = oldfont
if oldencoding != "":
os.environ["GRASS_ENCODING"] = oldencoding
def EraseMap(self):
+ """!Erase the map display
- Erase the map display
- self.Draw(self.pdc, pdctype='clear')
+ self.Draw(self.pdc, pdctype = 'clear')
class HistFrame(wx.Frame):
+ """!Main frame for hisgram display window. Uses d.histogram
+ rendered onto canvas
- Main frame for hisgram display window.
- Uses d.histogram rendered onto canvas
- def __init__(self, parent=None, id = wx.ID_ANY, title="Histogram of image or raster map",
- pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.DEFAULT_FRAME_STYLE):
- wx.Frame.__init__(self, parent, id, title, pos, size, style)
- toolbar = self.__createToolBar()
+ def __init__(self, parent = None, id = wx.ID_ANY,
+ title = _("GRASS GIS Histogram of image or raster map"),
+ style = wx.DEFAULT_FRAME_STYLE, **kwargs):
+ wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
self.Map = render.Map() # instance of render.Map to be associated with display
self.layer = None # reference to layer with histogram
- # Set the size & cursor
- self.SetClientSize(size)
- self.iconsize = (16, 16)
# Init variables
self.params = {} # previously set histogram parameters
self.propwin = '' # ID of properties dialog
self.font = ""
self.encoding = 'ISO-8859-1' # default encoding for display fonts
+ self.toolbar = HistogramToolbar(parent = self)
+ self.SetToolBar(self.toolbar)
# Add statusbar
self.mapname = ''
- self.statusbar = self.CreateStatusBar(number=1, style=0)
+ self.statusbar = self.CreateStatusBar(number = 1, style = 0)
# self.statusbar.SetStatusWidths([-2, -1])
hist_frame_statusbar_fields = ["Histogramming %s" % self.mapname]
for i in range(len(hist_frame_statusbar_fields)):
self.statusbar.SetStatusText(hist_frame_statusbar_fields[i], i)
# Init map display
self.InitDisplay() # initialize region values
# initialize buffered DC
- self.HistWindow = BufferedWindow(self, id = wx.ID_ANY, Map=self.Map) # initialize buffered DC
+ self.HistWindow = BufferedWindow(self, id = wx.ID_ANY, Map = self.Map) # initialize buffered DC
# Bind various events
self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
# Init print module and classes
self.printopt = disp_print.PrintOptions(self, self.HistWindow)
# Add layer to the map
- self.layer = self.Map.AddLayer(type="command", name='histogram', command=['d.histogram'],
- l_active=False, l_hidden=False, l_opacity=1, l_render=False)
- def __createToolBar(self):
- """!Creates toolbar"""
- toolbar = self.CreateToolBar()
- for each in self.toolbarData():
- self.AddToolbarButton(toolbar, *each)
- toolbar.Realize()
- def AddToolbarButton(self, toolbar, label, icon, help, handler):
- """!Adds buttons to the toolbar"""
- if not label:
- toolbar.AddSeparator()
- return
- tool = toolbar.AddLabelTool(id=wx.ID_ANY, label=label, bitmap=icon, shortHelp=help)
- self.Bind(wx.EVT_TOOL, handler, tool)
- def toolbarData(self):
- return (
- ('histogram',
- Icons["histogram"].GetBitmap(),
- Icons["histogram"].GetLabel(),
- self.OnOptions),
- ('rendermap',
- Icons["displaymap"].GetBitmap(),
- Icons["displaymap"].GetLabel(),
- self.OnRender),
- ('erase',
- Icons["erase"].GetBitmap(),
- Icons["erase"].GetLabel(),
- self.OnErase),
- ('font',
- Icons["font"].GetBitmap(),
- Icons["font"].GetLabel(),
- self.SetHistFont),
- ('save',
- Icons["savefile"].GetBitmap(),
- Icons["savefile"].GetLabel(),
- self.SaveToFile),
- ('print',
- Icons["printmap"].GetBitmap(),
- Icons["printmap"].GetLabel(),
- self.PrintMenu),
- ('quit',
- Icons["quit"].GetBitmap(),
- Icons["quit"].GetLabel(),
- self.OnQuit))
+ self.layer = self.Map.AddLayer(type = "command", name = 'histogram', command = ['d.histogram'],
+ l_active = False, l_hidden = False, l_opacity = 1, l_render = False)
def InitDisplay(self):
+ """!Initialize histogram display, set dimensions and region
- Initialize histogram display, set dimensions and region
self.width, self.height = self.GetClientSize()
self.Map.geom = self.width, self.height
def OnOptions(self, event):
"""!Change histogram settings"""
cmd = ['d.histogram']
if self.mapname != '':
cmd.append('map=%s' % self.mapname)
menuform.GUI().ParseCommand(cmd,
- completed=(self.GetOptData, None, self.params),
- parentframe=self)
+ completed = (self.GetOptData, None, self.params),
+ parentframe = self)
def GetOptData(self, dcmd, layer, params, propwin):
+ """!Callback method for histogram command generated by dialog
+ created in menuform.py
- Callback method for histogram command generated by
- dialog created in menuform.py
if dcmd:
- name = utils.GetLayerNameFromCmd(dcmd, fullyQualified=True)
+ name = utils.GetLayerNameFromCmd(dcmd, fullyQualified = True)
self.SetHistLayer(name)
self.params = params
self.propwin = propwin
self.HistWindow.UpdateHist()
def SetHistLayer(self, name):
+ """!Set histogram layer
- Set histogram layer
self.mapname = name
- self.layer = self.Map.ChangeLayer(layer=self.layer,
- command=[['d.histogram', 'map=%s' % self.mapname],],
- active=True)
+ self.layer = self.Map.ChangeLayer(layer = self.layer,
+ command = [['d.histogram', 'map=%s' % self.mapname],],
+ active = True)
return self.layer
def SetHistFont(self, event):
+ """!Set font for histogram. If not set, font will be default
+ display font.
- Set font for histogram. If not
- set, font will be default display font.
- dlg = DefaultFontDialog(parent=self, id=wx.ID_ANY,
- title=_('Select font for histogram text'))
+ dlg = DefaultFontDialog(parent = self, id = wx.ID_ANY,
+ title = _('Select font for histogram text'))
dlg.fontlb.SetStringSelection(self.font, True)
if dlg.ShowModal() == wx.ID_CANCEL:
dlg.Destroy()
return
# set default font type, font, and encoding to whatever selected in dialog
if dlg.font != None:
self.font = dlg.font
if dlg.encoding != None:
self.encoding = dlg.encoding
dlg.Destroy()
def OnErase(self, event):
+ """!Erase the histogram display
- Erase the histogram display
- self.HistWindow.Draw(self.HistWindow.pdc, pdctype='clear')
+ self.HistWindow.Draw(self.HistWindow.pdc, pdctype = 'clear')
def OnRender(self, event):
+ """!Re-render histogram
- Re-render histogram
+ def GetWindow(self):
+ """!Get buffered window"""
+ return self.HistWindow
def SaveToFile(self, event):
+ """!Save to file
- Save to file
- filetype = "PNG file (*.png)|*.png|"\
- "TIF file (*.tif)|*.tif|"\
- "GIF file (*.gif)|*.gif"
- dlg = wx.FileDialog(self, "Choose a file name to save the image as a PNG to",
- defaultDir = "",
- defaultFile = "",
- wildcard = filetype,
- style=wx.SAVE|wx.FD_OVERWRITE_PROMPT)
+ filetype, ltype = gdialogs.GetImageHandlers(self.HistWindow.img)
+ # get size
+ dlg = gdialogs.ImageSizeDialog(self)
+ dlg.CentreOnParent()
+ if dlg.ShowModal() != wx.ID_OK:
+ dlg.Destroy()
+ return
+ width, height = dlg.GetValues()
+ dlg.Destroy()
+ # get filename
+ dlg = wx.FileDialog(parent = self,
+ message = _("Choose a file name to save the image "
+ "(no need to add extension)"),
+ wildcard = filetype,
+ style=wx.SAVE | wx.FD_OVERWRITE_PROMPT)
if dlg.ShowModal() == wx.ID_OK:
- base = os.path.splitext(dlg.GetPath())[0]
- ext = os.path.splitext(dlg.GetPath())[1]
- if dlg.GetFilterIndex() == 0:
- type = wx.BITMAP_TYPE_PNG
- path = dlg.GetPath()
- if ext != '.png': path = base+'.png'
- elif dlg.GetFilterIndex() == 1:
- type = wx.BITMAP_TYPE_TIF
- if ext != '.tif': path = base+'.tif'
- elif dlg.GetFilterIndex() == 2:
- if ext != '.gif': path = base+'.gif'
- self.HistWindow.SaveToFile(path, type)
+ path = dlg.GetPath()
+ if not path:
+ dlg.Destroy()
+ return
+ base, ext = os.path.splitext(path)
+ fileType = ltype[dlg.GetFilterIndex()]['type']
+ extType = ltype[dlg.GetFilterIndex()]['ext']
+ if ext != extType:
+ path = base + '.' + extType
+ self.HistWindow.SaveToFile(path, fileType,
+ width, height)
+ self.HistWindow.UpdateHist()
dlg.Destroy()
def PrintMenu(self, event):
+ """!Print options and output menu
- Print options and output menu
point = wx.GetMousePosition()
printmenu = wx.Menu()
# Add items to the menu
- setup = wx.MenuItem(printmenu, -1,'Page setup')
+ setup = wx.MenuItem(printmenu, id = wx.ID_ANY, text = _('Page setup'))
printmenu.AppendItem(setup)
self.Bind(wx.EVT_MENU, self.printopt.OnPageSetup, setup)
- preview = wx.MenuItem(printmenu, -1,'Print preview')
+ preview = wx.MenuItem(printmenu, id = wx.ID_ANY, text = _('Print preview'))
printmenu.AppendItem(preview)
self.Bind(wx.EVT_MENU, self.printopt.OnPrintPreview, preview)
- doprint = wx.MenuItem(printmenu, -1,'Print display')
+ doprint = wx.MenuItem(printmenu, id = wx.ID_ANY, text = _('Print display'))
printmenu.AppendItem(doprint)
self.Bind(wx.EVT_MENU, self.printopt.OnDoPrint, doprint)
# Popup the menu. If an item is selected then its handler
# will be called before PopupMenu returns.
self.PopupMenu(printmenu)
printmenu.Destroy()
def OnQuit(self, event):
self.Close(True)
def OnCloseWindow(self, event):
- Window closed
+ """!Window closed
Also remove associated rendered images
try:
@@ -537,5 +453,4 @@
pass
self.Map.Clean()
self.Destroy()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-05-29 09:42:34 UTC (rev 42368)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-05-29 09:52:41 UTC (rev 42369)
@@ -12,7 +12,8 @@
- ProfileToolbar
- NvizToolbar
- ModelToolbar
+ - HistogramToolbar
(C) 2007-2010 by the GRASS Development Team
@@ -1443,5 +1444,52 @@
wx.ITEM_NORMAL, Icons['quit'].GetLabel(), Icons['quit'].GetDesc(),
self.parent.OnCloseWindow),
+class HistogramToolbar(AbstractToolbar):
+ """!Histogram modeler toolbar (see histogram.py)
+ def __init__(self, parent):
+ AbstractToolbar.__init__(self, parent)
+ self.InitToolbar(self.ToolbarData())
+ # realize the toolbar
+ self.Realize()
+ def ToolbarData(self):
+ """!Toolbar data"""
+ self.histogram = wx.NewId()
+ self.rendermap = wx.NewId()
+ self.erase = wx.NewId()
+ self.font = wx.NewId()
+ self.save = wx.NewId()
+ self.hprint = wx.NewId()
+ self.quit = wx.NewId()
+ # tool, label, bitmap, kind, shortHelp, longHelp, handler
+ return (
+ (self.histogram, 'histogram', Icons["histogram"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["histogram"].GetLabel(), Icons["histogram"].GetDesc(),
+ self.parent.OnOptions),
+ (self.rendermap, 'rendermap', Icons["displaymap"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["displaymap"].GetLabel(), Icons["displaymap"].GetDesc(),
+ self.parent.OnRender),
+ (self.erase, 'erase', Icons["erase"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["erase"].GetLabel(), Icons["erase"].GetDesc(),
+ self.parent.OnErase),
+ (self.font, 'font', Icons["font"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["font"].GetLabel(), Icons["font"].GetDesc(),
+ self.parent.SetHistFont),
+ (self.save, 'save', Icons["savefile"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["savefile"].GetLabel(), Icons["savefile"].GetDesc(),
+ self.parent.SaveToFile),
+ (self.hprint, 'print', Icons["printmap"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["printmap"].GetLabel(), Icons["printmap"].GetDesc(),
+ self.parent.PrintMenu),
+ (self.quit, 'quit', Icons["quit"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["quit"].GetLabel(), Icons["quit"].GetDesc(),
+ self.parent.OnQuit)
