[GRASS-SVN] r42371 - grass/trunk/raster/r.colors
svn_grass at osgeo.org
Sat May 29 07:18:23 EDT 2010
Author: martinl
Date: 2010-05-29 07:18:21 -0400 (Sat, 29 May 2010)
New Revision: 42371
grass/trunk/raster/r.colors/main.c
grass/trunk/raster/r.colors/thumbnails.py
r.colors: guisection cosmetics, be quiet when generating thumbnails
Modified: grass/trunk/raster/r.colors/main.c
--- grass/trunk/raster/r.colors/main.c 2010-05-29 10:02:57 UTC (rev 42370)
+++ grass/trunk/raster/r.colors/main.c 2010-05-29 11:18:21 UTC (rev 42371)
@@ -8,7 +8,7 @@
* PURPOSE: Allows creation and/or modification of the color table
* for a raster map layer.
- * COPYRIGHT: (C) 2006-2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006-2008, 2010 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -16,12 +16,6 @@
-/* main.c
- * specify and print options added by DBA Systems, Inc.
- * update 10/99 for GRASS 5
#include <stdlib.h>
#include <string.h>
#include <sys/types.h>
@@ -164,26 +158,12 @@
G_add_keyword(_("raster"));
G_add_keyword(_("color table"));
module->description =
- _("Creates/modifies the color table associated with a raster map layer.");
+ _("Creates/modifies the color table associated with a raster map.");
opt.map = G_define_standard_option(G_OPT_R_MAP);
opt.map->required = NO;
opt.map->guisection = _("Required");
- opt.rast = G_define_option();
- opt.rast->key = "raster";
- opt.rast->type = TYPE_STRING;
- opt.rast->required = NO;
- opt.rast->gisprompt = "old,cell,raster";
- opt.rast->description =
- _("Raster map name from which to copy color table");
- opt.rules = G_define_standard_option(G_OPT_F_INPUT);
- opt.rules->key = "rules";
- opt.rules->required = NO;
- opt.rules->description = _("Path to rules file (\"-\" to read rules from stdin)");
- opt.rules->guisection = _("Colors");
scan_rules();
opt.colr = G_define_option();
@@ -194,12 +174,29 @@
opt.colr->options = rules_list();
opt.colr->description = _("Type of color table");
opt.colr->descriptions = rules_descriptions();
- opt.colr->guisection = _("Colors");
+ opt.colr->guisection = _("Define");
+ opt.rast = G_define_option();
+ opt.rast->key = "raster";
+ opt.rast->type = TYPE_STRING;
+ opt.rast->required = NO;
+ opt.rast->gisprompt = "old,cell,raster";
+ opt.rast->description =
+ _("Raster map from which to copy color table");
+ opt.rast->guisection = _("Define");
+ opt.rules = G_define_standard_option(G_OPT_F_INPUT);
+ opt.rules->key = "rules";
+ opt.rules->required = NO;
+ opt.rules->label = _("Path to rules file");
+ opt.rules->description = _("\"-\" to read rules from stdin");
+ opt.rules->guisection = _("Define");
flag.r = G_define_flag();
flag.r->key = 'r';
flag.r->description = _("Remove existing color table");
+ flag.r->guisection = _("Remove");
flag.w = G_define_flag();
flag.w->key = 'w';
flag.w->description =
@@ -212,22 +209,22 @@
flag.n = G_define_flag();
flag.n->key = 'n';
flag.n->description = _("Invert colors");
- flag.n->guisection = _("Colors");
+ flag.n->guisection = _("Define");
flag.g = G_define_flag();
flag.g->key = 'g';
flag.g->description = _("Logarithmic scaling");
- flag.g->guisection = _("Colors");
+ flag.g->guisection = _("Define");
flag.a = G_define_flag();
flag.a->key = 'a';
flag.a->description = _("Logarithmic-absolute scaling");
- flag.a->guisection = _("Colors");
+ flag.a->guisection = _("Define");
flag.e = G_define_flag();
flag.e->key = 'e';
flag.e->description = _("Histogram equalization");
- flag.e->guisection = _("Colors");
+ flag.e->guisection = _("Define");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/trunk/raster/r.colors/thumbnails.py
--- grass/trunk/raster/r.colors/thumbnails.py 2010-05-29 10:02:57 UTC (rev 42370)
+++ grass/trunk/raster/r.colors/thumbnails.py 2010-05-29 11:18:21 UTC (rev 42371)
@@ -72,7 +72,7 @@
def ppmtopng(dst, src):
if grass.find_program("g.ppmtopng", ["help"]):
- grass.run_command('g.ppmtopng', input = src, output = dst)
+ grass.run_command('g.ppmtopng', input = src, output = dst, quiet = True)
elif grass.find_program("pnmtopng"):
fh = open(dst, 'wb')
grass.call(["pnmtopng", src], stdout = fh)
@@ -171,13 +171,13 @@
grass.use_temp_region()
grass.run_command('g.region', rows = 100, cols = 100)
- grass.mapcalc("$grad = row()/1.0", grad = tmp_grad_rel)
+ grass.mapcalc("$grad = row()/1.0", grad = tmp_grad_rel, quiet = True)
for table in os.listdir(color_dir):
path = os.path.join(color_dir, table)
grad = make_gradient(path)
make_image(output_dir, table, grad)
grass.mapcalc("$grad = row()", grad = tmp_grad_abs, quiet = True)
for table in ['grey.eq', 'grey.log', 'random']:
make_image(output_dir, table, tmp_grad_abs, True)
