[GRASS-SVN] r42379 - in grass/branches/develbranch_6/gui/wxpython: . gui_modules xml
Sat May 29 08:52:03 EDT 2010
Author: martinl
Date: 2010-05-29 08:52:03 -0400 (Sat, 29 May 2010)
New Revision: 42379
Added:
   grass/branches/develbranch_6/gui/wxpython/gui_modules/vclean.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: vclean module backported from trunk
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py	2010-05-29 12:47:36 UTC (rev 42378)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py	2010-05-29 12:52:03 UTC (rev 42379)
@@ -34,6 +34,7 @@
     "toolbars.py",
     "units.py",
     "utils.py",
+    "vclean.py",
     "vdigit.py",
     "workspace.py",
Copied: grass/branches/develbranch_6/gui/wxpython/gui_modules/vclean.py (from rev 42357, grass/trunk/gui/wxpython/gui_modules/vclean.py)
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vclean.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vclean.py	2010-05-29 12:52:03 UTC (rev 42379)
@@ -0,0 +1,539 @@
+ at package vclean.py
+ at brief Dialog for interactive construction of vector cleaning operations
+Classes:
+ - VectorCleaningFrame
+(C) 2010 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Markus Metz
+import os
+import sys
+import shutil
+import wx
+import wx.lib.scrolledpanel as scrolled
+from grass.script import core as grass
+import dbm
+import gcmd
+import globalvar
+import gselect
+import render
+import utils
+from debug import Debug as Debug
+from preferences import globalSettings as UserSettings
+class VectorCleaningFrame(wx.Frame):
+    def __init__(self, parent, id=wx.ID_ANY, title=_('set up vector cleaning tools'),
+                 pos=wx.DefaultPosition, size=(-1, -1),
+                 style=wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
+                 **kwargs):
+        Dialog for interactively defining vector cleaning tools
+        wx.Frame.__init__(self, parent, id, title, pos, size, style)
+        self.parent = parent # GMFrame
+        if self.parent:
+            self.log = self.parent.GetLogWindow()
+        else:
+            self.log = None
+        # grass command
+        self.cmd = 'v.clean'
+        # statusbar
+        self.CreateStatusBar()
+	# icon
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+	# self.panel not set as in colorrules
+        # self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+        # input map to clean
+        self.inmap = ''
+        # cleaned output map
+        self.outmap = ''
+	self.ftype = ''
+        # cleaning tools
+        self.toolslines = {}
+        self.tool_desc_list = [
+            _('break lines/boundaries'),
+            _('remove duplicates'),
+            _('remove dangles'),
+            _('change boundary dangles to lines'),
+            _('remove bridges'),
+	    _('change bridges to lines'),
+	    _('snap lines/boundaries'),
+	    _('remove duplicate area centroids'),
+	    _('break polygons'),
+	    _('prune lines/boundaries'),
+	    _('remove small areas'),
+	    _('remove lines/boundaries of zero length'),
+	    _('remove small angles at nodes')
+        self.tool_list = [
+            'break',
+            'rmdupl',
+            'rmdangle',
+            'chdangle',
+            'rmbridge',
+	    'chbridge',
+	    'snap',
+	    'rmdac',
+	    'bpol',
+	    'prune',
+	    'rmarea',
+	    'rmline',
+	    'rmsa'
+	self.ftype = [
+	    'point',
+	    'line',
+	    'boundary',
+	    'centroid',
+	    'area',
+	    'face']
+	self.n_ftypes = 6
+	self.tools_string = ''
+	self.thresh_string = ''
+	self.ftype_string = ''
+	self.SetTitle(_('Set up vector cleaning tools'))
+	self.SetStatusText( _("Set up vector cleaning tools"))
+	self.elem = 'vector'
+	self.ctlabel = _('Choose cleaning tools and set thresholds')
+        # top controls
+        self.inmaplabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                         label= _('Select input vector map:'))
+        self.selectionInput = gselect.Select(parent=self, id=wx.ID_ANY,
+                                             size=globalvar.DIALOG_GSELECT_SIZE,
+                                             type='vector')
+	self.ftype_check = {}
+        ftypeBox = wx.StaticBox(parent=self, id=wx.ID_ANY,
+                                label=_(' Feature type: '))
+        self.ftypeSizer = wx.StaticBoxSizer(ftypeBox, wx.HORIZONTAL)
+        self.outmaplabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                         label= _('Select output vector map:'))
+        self.selectionOutput = gselect.Select(parent=self, id=wx.ID_ANY,
+                                             type='vector')
+        self.overwrite = wx.CheckBox(parent=self, id=wx.ID_ANY,
+                                       label=_('Allow output files to overwrite existing files'))
+        self.overwrite.SetValue(UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'))
+        # cleaning tools
+        self.ct_label = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                      label=self.ctlabel)
+        self.ct_panel = self.__toolsPanel()
+	# buttons to manage cleaning tools
+        self.btn_add = wx.Button(parent=self, id=wx.ID_ADD)
+        self.btn_remove = wx.Button(parent=self, id=wx.ID_REMOVE)
+        self.btn_moveup = wx.Button(parent=self, id=wx.ID_UP)
+        self.btn_movedown = wx.Button(parent=self, id=wx.ID_DOWN)
+        # add one tool as default
+        self.AddTool()
+	self.selected = -1
+        # Buttons
+        self.btn_close = wx.Button(parent = self, id = wx.ID_CLOSE)
+        self.btn_run = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Run"))
+        self.btn_run.SetDefault()
+	self.btn_clipboard = wx.Button(parent=self, id=wx.ID_COPY)
+	self.btn_clipboard.SetToolTipString(_("Copy the current command string to the clipboard (Ctrl+C)"))
+        self.btn_help = wx.Button(parent = self, id = wx.ID_HELP)
+        # bindings
+        self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
+        self.btn_run.Bind(wx.EVT_BUTTON, self.OnCleaningRun)
+	self.btn_clipboard.Bind(wx.EVT_BUTTON, self.OnCopy)
+        self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
+        self.btn_add.Bind(wx.EVT_BUTTON, self.OnAddTool)
+        self.btn_remove.Bind(wx.EVT_BUTTON, self.OnClearTool)
+        self.btn_moveup.Bind(wx.EVT_BUTTON, self.OnMoveToolUp)
+        self.btn_movedown.Bind(wx.EVT_BUTTON, self.OnMoveToolDown)
+        self.SetMinSize(self.GetBestSize())
+        # layout
+        self._layout()
+        self.CentreOnScreen()
+        self.Show()
+    def _layout(self):
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        # input output
+	inSizer = wx.GridBagSizer(hgap=5, vgap=5)
+        inSizer.Add(item=self.inmaplabel, pos=(0, 0),
+                       flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border=1)
+        inSizer.Add(item=self.selectionInput, pos=(1, 0),
+	self.ftype_check = [
+	    wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('point')),
+	    wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('line')),
+	    wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('boundary')),
+	    wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('centroid')),
+	    wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('area')),
+	    wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('face'))
+	typeoptSizer = wx.BoxSizer(wx.HORIZONTAL)
+	for num in range(0, self.n_ftypes):
+	    type_box = self.ftype_check[num]
+	    typeoptSizer.Add(item=type_box, flag=wx.ALIGN_LEFT, border=1)
+	self.ftypeSizer.Add(item = typeoptSizer,
+	           flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=2)
+	outSizer = wx.GridBagSizer(hgap=5, vgap=5)
+        outSizer.Add(item=self.outmaplabel, pos=(0, 0),
+        outSizer.Add(item=self.selectionOutput, pos=(1, 0),
+        replaceSizer = wx.BoxSizer(wx.HORIZONTAL)
+        replaceSizer.Add(item=self.overwrite, proportion=1,
+                         flag=wx.ALL | wx.EXPAND, border=1)
+        outSizer.Add(item=replaceSizer, pos=(2, 0),
+        # tools selection
+        bodySizer = wx.GridBagSizer(hgap=5, vgap=5)
+        bodySizer.Add(item=self.ct_label, pos=(0, 0), span=(1, 2),
+                      flag=wx.ALL, border=5)
+        bodySizer.Add(item=self.ct_panel, pos=(1, 0), span=(1, 2))
+	manageBoxSizer = wx.GridBagSizer(hgap=10, vgap=1)
+	# start with row 1 for nicer layout
+        manageBoxSizer.Add(item=self.btn_add, pos=(1, 0), border=2, flag=wx.ALL | wx.EXPAND)
+        manageBoxSizer.Add(item=self.btn_remove, pos=(2, 0), border=2, flag=wx.ALL | wx.EXPAND)
+        manageBoxSizer.Add(item=self.btn_moveup, pos=(3, 0), border=2, flag=wx.ALL | wx.EXPAND)
+        manageBoxSizer.Add(item=self.btn_movedown, pos=(4, 0), border=2, flag=wx.ALL | wx.EXPAND)
+        bodySizer.Add(item=manageBoxSizer, pos=(1, 2),
+                      flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=5)
+        bodySizer.AddGrowableCol(2)
+        # standard buttons
+        btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+        btnSizer.Add(self.btn_close,
+                     flag=wx.LEFT | wx.RIGHT, border=5)
+        btnSizer.Add(self.btn_run,
+        btnSizer.Add(self.btn_clipboard,
+        btnSizer.Add(self.btn_help,
+        # put it all together
+        sizer.Add(item=inSizer, proportion=0,
+                  flag=wx.ALL | wx.EXPAND, border=5)
+        sizer.Add(item=self.ftypeSizer, proportion=0,
+        sizer.Add(item=outSizer, proportion=0,
+        sizer.Add(item=wx.StaticLine(parent=self, id=wx.ID_ANY,
+                  style=wx.LI_HORIZONTAL), proportion=0,
+                  flag=wx.EXPAND | wx.ALL, border=5)
+        sizer.Add(item=bodySizer, proportion=1,
+        sizer.Add(item=btnSizer, proportion=0,
+                  flag=wx.ALL | wx.ALIGN_RIGHT, border=5)
+        self.SetSizer(sizer)
+        sizer.Fit(self)
+        self.Layout()
+    def __toolsPanel(self):
+        ct_panel = scrolled.ScrolledPanel(parent=self, id=wx.ID_ANY,
+	                                  size=(500, 240),
+                                          style=wx.SUNKEN_BORDER)
+        self.ct_sizer = wx.GridBagSizer(vgap=2, hgap=4)
+        ct_panel.SetSizer(self.ct_sizer)
+        ct_panel.SetAutoLayout(True)
+        return ct_panel
+    def OnAddTool(self, event):
+        """!Add tool button pressed"""
+	self.AddTool()
+    def AddTool(self):
+        snum = len(self.toolslines.keys())
+	num = snum + 1
+	# tool number
+	tool_no = wx.StaticText(parent = self.ct_panel, id = 3000+num,
+                                         label= str(num)+'.')
+	# tool
+	tool_cbox = wx.ComboBox(parent = self.ct_panel, id=1000+num,
+				size = (300, -1), choices = self.tool_desc_list,
+				style = wx.CB_DROPDOWN |
+				wx.CB_READONLY | wx.TE_PROCESS_ENTER)
+	self.Bind(wx.EVT_COMBOBOX, self.OnSetTool, tool_cbox)
+	# threshold
+	txt_ctrl = wx.TextCtrl(parent=self.ct_panel, id=2000+num, value='0.00',
+			       size=(100,-1),
+			       style=wx.TE_NOHIDESEL)
+	self.Bind(wx.EVT_TEXT, self.OnThreshValue, txt_ctrl)
+	# select
+	select = wx.CheckBox(parent=self.ct_panel, id=num)
+	select.SetValue(False)
+	self.Bind(wx.EVT_CHECKBOX, self.OnSelect, select)
+	# start with row 1 and col 1 for nicer layout
+	self.ct_sizer.Add(item=tool_no, pos=(num, 1),
+			  flag=wx.ALIGN_CENTER_VERTICAL, border=5)
+	self.ct_sizer.Add(item=tool_cbox, pos=(num, 2),
+			  flag=wx.ALIGN_CENTER | wx.RIGHT, border=5)
+	self.ct_sizer.Add(item=txt_ctrl, pos=(num, 3),
+	self.ct_sizer.Add(item=select, pos=(num, 4),
+			  flag=wx.ALIGN_CENTER | wx.RIGHT)
+	self.toolslines[num] = {
+	    'tool_desc' : '' ,
+	    'tool' : '' ,
+	    'thresh' : '0.00' }
+        self.ct_panel.Layout()
+        self.ct_panel.SetupScrolling()
+    def OnClearTool(self, event):
+        """!Remove tool button pressed"""
+        id = self.selected
+	if id > 0:
+	    self.FindWindowById(id+1000).SetValue('')
+	    self.toolslines[id]['tool_desc'] = ''
+	    self.toolslines[id]['tool'] = ''
+	    self.SetStatusText( _("%s. cleaning tool removed, will be ignored") % id)
+	else:
+	    self.SetStatusText( _("Please select a cleaning tool to remove"))
+    def OnMoveToolUp(self, event):
+        """!Move up tool button pressed"""
+	if id > 1:
+	    id_up = id - 1
+	    this_toolline = self.toolslines[id]
+	    up_toolline = self.toolslines[id_up]
+	    self.FindWindowById(id_up).SetValue(True)
+	    self.FindWindowById(id_up+1000).SetValue(this_toolline['tool_desc'])
+	    self.FindWindowById(id_up+2000).SetValue(this_toolline['thresh'])
+	    self.toolslines[id_up] = this_toolline
+	    self.FindWindowById(id).SetValue(False)
+	    self.FindWindowById(id+1000).SetValue(up_toolline['tool_desc'])
+	    self.FindWindowById(id+2000).SetValue(up_toolline['thresh'])
+	    self.toolslines[id] = up_toolline
+	    self.selected = id_up
+	    self.SetStatusText( _("%s. cleaning tool moved up") % id)
+	elif id == 1:
+	    self.SetStatusText( _("1. cleaning tool can not be moved up "))
+	elif id == -1:
+	    self.SetStatusText( _("Please select a cleaning tool to move up"))
+    def OnMoveToolDown(self, event):
+        """!Move down tool button pressed"""
+	if id > 0 and id < snum:
+	    id_down = id + 1
+	    down_toolline = self.toolslines[id_down]
+	    self.FindWindowById(id_down).SetValue(True)
+	    self.FindWindowById(id_down+1000).SetValue(this_toolline['tool_desc'])
+	    self.FindWindowById(id_down+2000).SetValue(this_toolline['thresh'])
+	    self.toolslines[id_down] = this_toolline
+	    self.FindWindowById(id+1000).SetValue(down_toolline['tool_desc'])
+	    self.FindWindowById(id+2000).SetValue(down_toolline['thresh'])
+	    self.toolslines[id] = down_toolline
+	    self.selected = id_down
+	    self.SetStatusText( _("%s. cleaning tool moved down") % id)
+	elif id == snum:
+	    self.SetStatusText( _("Last cleaning tool can not be moved down "))
+	elif id == -1:
+	    self.SetStatusText( _("Please select a cleaning tool to move down"))
+    def OnSetTool(self, event):
+        """!Tool was defined"""
+        id = event.GetId()
+	tool_no = id-1000
+	num = self.FindWindowById(id).GetCurrentSelection()
+	self.toolslines[tool_no]['tool_desc'] = self.tool_desc_list[num]
+	self.toolslines[tool_no]['tool'] = self.tool_list[num]
+	self.SetStatusText( _("%s. cleaning tool: '%s'") % (tool_no, self.tool_list[num]))
+    def OnThreshValue(self, event):
+        """!Threshold value was entered"""
+	num = id-2000
+	self.toolslines[num]['thresh'] = self.FindWindowById(id).GetValue()
+	self.SetStatusText( _("Threshold for %s. tool '%s': %s") % \
+	                   (num, self.toolslines[num]['tool'], self.toolslines[num]['thresh']))
+    def OnSelect(self, event):
+        """!Tool was selected"""
+	if self.selected > -1 and self.selected != id:
+	    win = self.FindWindowById(self.selected)
+	    win.SetValue(False)
+	if self.selected != id:
+	else:
+    def OnCleaningRun(self, event):
+        """!Builds options and runs v.clean
+	self.SetStatusText( _("Executing selected cleaning operations..."))
+	self.GetCmdStrings()
+        if self.log:
+	    cmdstring = '%s' % (self.cmd)
+	    # list -> string
+	    cmdstring += ' input=%s output=%s type=%s tool=%s thres=%s' % \
+		(self.inmap, self.outmap, self.ftype_string, self.tools_string, self.thresh_string)
+	    if self.overwrite.IsChecked():
+		cmdstring += ' --overwrite'
+            self.log.RunCmd(cmdstring)
+            self.parent.Raise()
+        else:
+		overwrite = True
+	    else:
+		overwrite = False
+	    gcmd.RunCommand(self.cmd,
+			    input = self.inmap,
+			    output = self.outmap,
+			    type = self.ftype_string,
+			    tool = self.tools_string,
+			    thresh = self.thresh_string,
+			    overwrite = overwrite)
+    def OnClose(self, event):
+        self.Destroy()
+    def OnHelp(self, event):
+        """!Show GRASS manual page"""
+        gcmd.RunCommand('g.manual',
+                        quiet = True,
+                        parent = self,
+                        entry = self.cmd)
+    def OnCopy(self, event):
+        """!Copy the command"""
+        cmddata = wx.TextDataObject()
+	# get tool and thresh strings
+        # list -> string
+        cmddata.SetText(cmdstring)
+        if wx.TheClipboard.Open():
+            wx.TheClipboard.SetData(cmddata)
+            wx.TheClipboard.Close()
+            self.SetStatusText( _("Vector cleaning command copied to clipboard"))
+    def GetCmdStrings(self):
+	# feature types
+	first = 1
+        for num in range(0, self.n_ftypes - 1):
+	    if self.ftype_check[num].IsChecked():
+		if first:
+		    self.ftype_string = '%s' % self.ftype[num]
+		    first = 0
+		else:
+		    self.ftype_string += ',%s' % self.ftype[num]
+	# cleaning tools
+	first = 1
+        for num in range(1, snum + 1):
+	    if self.toolslines[num]['tool']:
+		if first:
+		    self.tools_string = '%s' % self.toolslines[num]['tool']
+		    self.thresh_string = '%s' % self.toolslines[num]['thresh']
+		    first = 0
+		else:
+		    self.tools_string += ',%s' % self.toolslines[num]['tool']
+		    self.thresh_string += ',%s' % self.toolslines[num]['thresh']
+	self.inmap = self.selectionInput.GetValue()
+	self.outmap = self.selectionOutput.GetValue()
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2010-05-29 12:47:36 UTC (rev 42378)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2010-05-29 12:52:03 UTC (rev 42379)
@@ -80,6 +80,7 @@
 import gui_modules.prompt as prompt
 import gui_modules.menu as menu
 import gui_modules.gmodeler as gmodeler
+import gui_modules.vclean as vclean
 from   gui_modules.debug import Debug
 from   gui_modules.ghelp import MenuTreeWindow
 from   gui_modules.ghelp import AboutWindow
@@ -1013,6 +1014,17 @@
         win.CentreOnScreen()
         win.Show()
+    def OnVectorCleaning(self, event, cmd = ''):
+        """!Init interactive vector cleaning
+        if event:
+            cmd = self.GetMenuCmd(event)
+        win = vclean.VectorCleaningFrame(parent = self, cmd = cmd[0])
+        win.CentreOnScreen()
+        win.Show()
     def OnImportDxfFile(self, event):
         """!Convert multiple DXF layers to GRASS vector map layers"""
         dlg = gdialogs.DxfImportDialog(parent=self)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2010-05-29 12:47:36 UTC (rev 42378)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2010-05-29 12:52:03 UTC (rev 42379)
@@ -1837,7 +1837,7 @@
 	      <label>Clean vector map</label>
 	      <help>Toolset for cleaning topology of vector map.</help>
 	      <keywords>vector,topology</keywords>
-	      <handler>OnMenuCmd</handler>
+	      <handler>OnVectorCleaning</handler>
 	      <command>v.clean</command>
 	    </menuitem>
 	    <menuitem>
