[GRASS-SVN] r42391 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sun May 30 07:19:16 EDT 2010
Author: martinl
Date: 2010-05-30 07:19:16 -0400 (Sun, 30 May 2010)
New Revision: 42391
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
wxGUI: minor fixes, don't render empty image
(merge r42390 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2010-05-30 11:15:23 UTC (rev 42390)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2010-05-30 11:19:16 UTC (rev 42391)
@@ -37,13 +37,13 @@
 import globalvar
-grassPath = os.path.join(globalvar.ETCDIR, "python")
-sys.path.append(grassPath)
+sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
 import grass.script as grass
 import gcmd
 import utils
 from preferences import globalSettings as UserSettings
+from debug import Debug
 wxGdalSelect, EVT_GDALSELECT = NewEvent()
@@ -96,9 +96,9 @@
         self.ftype = ftype
         # remove vector maps which do not contain given feature type
-        self.tcp.SetFilter(self.__isElement)
+        self.tcp.SetFilter(self._isElement)
-    def __isElement(self, vectorName):
+    def _isElement(self, vectorName):
         """!Check if element should be filtered out"""
         try:
             if int(grass.vector_info_topo(vectorName)[self.ftype]) < 1:
@@ -410,12 +410,12 @@
          # dictionary of table and associated columns (type, length, values, ids)
         self.tables = {}
-        if not self.__CheckDBConnection(): # -> self.layers
+        if not self._CheckDBConnection(): # -> self.layers
             return
-        self.__DescribeTables() # -> self.tables
+        self._DescribeTables() # -> self.tables
-    def __CheckDBConnection(self):
+    def _CheckDBConnection(self):
         """!Check DB connection"""
         nuldev = file(os.devnull, 'w+')
         self.layers = grass.vector_db(map=self.map, stderr=nuldev)
@@ -426,13 +426,16 @@
         return True
-    def __DescribeTables(self):
+    def _DescribeTables(self):
         """!Describe linked tables"""
         for layer in self.layers.keys():
             # determine column names and types
             table = self.layers[layer]["table"]
             columns = {} # {name: {type, length, [values], [ids]}}
             i = 0
+            Debug.msg(1, "gselect.VectorDBInfo._DescribeTables(): table=%s driver=%s database=%s" % \
+                          (self.layers[layer]["table"], self.layers[layer]["driver"],
+                           self.layers[layer]["database"]))
             for item in grass.db_describe(table = self.layers[layer]["table"],
                                           driver = self.layers[layer]["driver"],
                                           database = self.layers[layer]["database"])['cols']:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2010-05-30 11:15:23 UTC (rev 42390)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2010-05-30 11:19:16 UTC (rev 42391)
@@ -909,25 +909,29 @@
         else:
             del os.environ["GRASS_REGION"]
-        # run g.pngcomp to get composite image
-        ret = gcmd.RunCommand('g.pnmcomp',
-                              input = '%s' % ",".join(maps),
-                              mask = '%s' % ",".join(masks),
-                              opacity = '%s' % ",".join(opacities),
-                              background = bgcolor,
-                              width = self.width,
-                              height = self.height,
-                              output = self.mapfile)
+        if maps:
+            # run g.pngcomp to get composite image
+            ret = gcmd.RunCommand('g.pnmcomp',
+                                  input = '%s' % ",".join(maps),
+                                  mask = '%s' % ",".join(masks),
+                                  opacity = '%s' % ",".join(opacities),
+                                  background = bgcolor,
+                                  width = self.width,
+                                  height = self.height,
+                                  output = self.mapfile)
+            if ret != 0:
+                print >> sys.stderr, _("ERROR: Rendering failed")
+                return None
+            Debug.msg (3, "Map.Render() force=%s file=%s" % (force, self.mapfile))
-        if ret != 0:
-            print >> sys.stderr, _("ERROR: Rendering failed")
-            return None
         # back to original gisrc
         if self.gisrc:
             os.environ["GISRC"] = gisrc_orig
-        Debug.msg (3, "Map.Render() force=%s file=%s" % (force, self.mapfile))
+        if not maps:
+            return None
         return self.mapfile
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py	2010-05-30 11:15:23 UTC (rev 42390)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py	2010-05-30 11:19:16 UTC (rev 42391)
@@ -20,22 +20,16 @@
 import locale
 import globalvar
 from grass.script import core as grass
 import gcmd
-try:
-    import subprocess
-except:
-    compatPath = os.path.join(globalvar.ETCWXDIR, "compat")
-    sys.path.append(compatPath)
-    import subprocess
 def normalize_whitespace(text):
     """!Remove redundant whitespace from a string"""
-    return string.join( string.split(text), ' ')
+    return string.join(string.split(text), ' ')
 def GetTempfile(pref=None):
@@ -291,10 +285,13 @@
     cmdlist = ['v.category',
                'input=%s' % vector,
                'option=report']
+    if not vector:
+        return layers
     layers = []
     ret = gcmd.RunCommand('v.category',
+                          flags = 'g',
                           read = True,
                           input = vector,
                           option = 'report')
@@ -303,14 +300,14 @@
         return layers
     for line in ret.splitlines():
-        if not 'Layer' in line:
-            continue
-        value = line.split(':')[1].strip()
-        if '/' in value: # value/name
-            layers.append(value.split('/')[0])
-        else:
-            layers.append(value)
+        try:
+            layer = line.split(' ')[0]
+            if layer not in layers:
+                layers.append(layer)
+        except ValueError:
+            pass
+    Debug.msg(3, "utils.GetVectorNumberOfLayers(): vector=%s -> %s" % \
+                  (vector, ','.join(layers)))
     return layers
