[GRASS-SVN] r42393 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun May 30 07:36:45 EDT 2010
Author: martinl
Date: 2010-05-30 07:36:45 -0400 (Sun, 30 May 2010)
New Revision: 42393
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
wxGUI/d.vect: avoid repetitive running of the same commands
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-05-30 11:31:53 UTC (rev 42392)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-05-30 11:36:45 UTC (rev 42393)
@@ -652,7 +652,7 @@
if vector:
self.InsertColumns(vector, layer)
- def InsertColumns(self, vector, layer, excludeKey = False, type = None):
+ def InsertColumns(self, vector, layer, excludeKey = False, type = None, dbInfo = None):
"""!Insert columns for a vector attribute table into the columns combobox
@param vector vector name
@@ -660,7 +660,8 @@
@param excludeKey exclude key column from the list?
@param type only columns of given type (given as list)
- dbInfo = VectorDBInfo(vector)
+ if not dbInfo:
+ dbInfo = VectorDBInfo(vector)
try:
table = dbInfo.GetTable(int(layer))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-05-30 11:31:53 UTC (rev 42392)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-05-30 11:36:45 UTC (rev 42393)
@@ -207,6 +207,11 @@
map = pMap.get('value', '')
else:
map = None
+ # avoid running db.describe several times
+ cparams = dict()
+ cparams[map] = { 'dbInfo' : None,
+ 'layers' : None, }
# update reference widgets
for uid in p['wxId-bind']:
@@ -214,8 +219,10 @@
name = win.GetName()
if name == 'LayerSelect':
- self.data[win.InsertLayers] = { 'vector' : map }
+ if not cparams[map]['layers']:
+ win.InsertLayers(vector = map)
+ cparams[map]['layers'] = win.GetItems()
elif name == 'TableSelect':
pDriver = self.task.get_param('dbdriver', element='prompt', raiseError=False)
driver = db = None
@@ -239,7 +246,10 @@
layer = 1
if map:
- self.data[win.InsertColumns] = { 'vector' : map, 'layer' : layer }
+ if not cparams[map]['dbInfo']:
+ cparams[map]['dbInfo'] = gselect.VectorDBInfo(map)
+ self.data[win.InsertColumns] = { 'vector' : map, 'layer' : layer,
+ 'dbInfo' : cparams[map]['dbInfo'] }
else: # table
driver = db = None
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2010-05-30 11:31:53 UTC (rev 42392)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2010-05-30 11:36:45 UTC (rev 42393)
@@ -282,20 +282,16 @@
def GetVectorNumberOfLayers(vector):
"""!Get list of vector layers"""
- cmdlist = ['v.category',
- 'input=%s' % vector,
- 'option=report']
+ layers = []
if not vector:
return layers
- layers = []
ret = gcmd.RunCommand('v.category',
flags = 'g',
read = True,
input = vector,
option = 'report')
if not ret:
return layers
