[GRASS-SVN] r42404 - in grass/branches/develbranch_6/gui/wxpython: . gui_modules
Mon May 31 06:13:24 EDT 2010
Author: martinl
Date: 2010-05-31 06:13:00 -0400 (Mon, 31 May 2010)
New Revision: 42404
   grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI/nviz: nviz tool window intergrated into layer manager
(merge r42403 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py	2010-05-31 09:41:42 UTC (rev 42403)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py	2010-05-31 10:13:00 UTC (rev 42404)
@@ -192,6 +192,10 @@
         """!Get map instace"""
         return self.Map
+    def GetMapDisplay(self):
+        """!Get associated MapFrame"""
+        return self.mapdisplay
     def OnIdle(self, event):
         Only re-order and re-render a composite map image from GRASS during
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2010-05-31 09:41:42 UTC (rev 42403)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2010-05-31 10:13:00 UTC (rev 42404)
@@ -304,9 +304,8 @@
         self.decorationDialog = None # decoration/overlays
     def AddToolbar(self, name):
-        Add defined toolbar to the window
+        """!Add defined toolbar to the window
         Currently known toolbars are:
          - 'map'     - basic map toolbar
          - 'vdigit'  - vector digitizer
@@ -399,49 +398,41 @@
                               style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
                 return
             # add Nviz toolbar and disable 2D display mode tools
             self.toolbars['nviz'] = toolbars.NvizToolbar(self, self.Map)
             self.toolbars['map'].Enable2D(False)
             # update layer tree (-> enable 3d-rasters)
             if self.tree:
                 self.tree.EnableItemType(type='3d-raster', enable=True)
             # update status bar
             self.statusbarWin['toggle'].Enable(False)
             # erase map window
             self.MapWindow.EraseMap()
             self.statusbar.SetStatusText(_("Please wait, loading data..."), 0)
             # create GL window & NVIZ toolbar
             if not self.MapWindow3D:
                 self.MapWindow3D = nviz.GLWindow(self, id=wx.ID_ANY,
                                                  Map=self.Map, tree=self.tree, lmgr=self._layerManager)
-                # -> show after paint
-                self.nvizToolWin = nviz.NvizToolWindow(self, id=wx.ID_ANY,
-                                                       mapWindow=self.MapWindow3D)
+                self.MapWindow = self.MapWindow3D
+                # add Nviz notebookpage
+                self._layerManager.AddNviz()
                 self.MapWindow3D.OnPaint(None) # -> LoadData
                 self.MapWindow3D.Show()
                 self.MapWindow3D.UpdateView(None)
+            else:
-            self.nvizToolWin.Show()
             # switch from MapWindow to MapWindowGL
             # add nviz toolbar
             self._mgr.DetachPane(self.MapWindow2D)
             self.MapWindow2D.Hide()
             self._mgr.AddPane(self.MapWindow3D, wx.aui.AuiPaneInfo().CentrePane().
@@ -456,18 +447,15 @@
                               BottomDockable(False).TopDockable(True).
                               CloseButton(False).Layer(2))
-            self.MapWindow = self.MapWindow3D
             self.SetStatusText("", 0)
         self._mgr.Update()
     def RemoveToolbar (self, name):
-        Removes toolbar from the window
+        """!Removes toolbar from the window
-        TODO: Only hide, activate by calling AddToolbar()
+        @todo Only hide, activate by calling AddToolbar()
         # cannot hide main toolbar
         if name == "map":
             return
@@ -482,8 +470,6 @@
         self.toolbars[name] = None
         if name == 'nviz':
-            # hide nviz tools
-            self.nvizToolWin.Hide()
             # unload data
             #            self.MapWindow3D.Reset()
             # switch from MapWindowGL to MapWindow
@@ -495,12 +481,14 @@
                               CloseButton(False).DestroyOnClose(True).
                               Layer(0))
             self.MapWindow = self.MapWindow2D
+            # remove nviz notebook page
+            self._layerManager.RemoveNviz()
             # update layer tree (-> disable 3d-rasters)
             if self.tree:
                 self.tree.EnableItemType(type='3d-raster', enable=False)
             self.MapWindow.UpdateMap()
         self.toolbars['map'].combo.SetValue (_("2D view"))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2010-05-31 09:41:42 UTC (rev 42403)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2010-05-31 10:13:00 UTC (rev 42404)
@@ -68,7 +68,10 @@
 import wx
 import wx.html
-import wx.lib.flatnotebook as FN
+try:
+    import wx.lib.agw.flatnotebook as FN
+except ImportError:
+    import wx.lib.flatnotebook as FN
 import wx.lib.colourselect as csel
 import wx.lib.filebrowsebutton as filebrowse
 from wx.lib.expando import ExpandoTextCtrl, EVT_ETC_LAYOUT_NEEDED
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-05-31 09:41:42 UTC (rev 42403)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-05-31 10:13:00 UTC (rev 42404)
@@ -172,20 +172,20 @@
         if not self.init:
             self.ResetView()
-            if hasattr(self.parent, "nvizToolWin"):
-                self.parent.nvizToolWin.UpdatePage('view')
+            if hasattr(self._layermanager, "nviz"):
+                self._layermanager.nviz.UpdatePage('view')
                 layer = self.GetSelectedLayer()
                 if layer:
                     if layer.type ==  'raster':
-                        self.parent.nvizToolWin.UpdatePage('surface')
+                        self._layermanager.nviz.UpdatePage('surface')
                     elif layer.type ==  'vector':
-                        self.parent.nvizToolWin.UpdatePage('vector')
+                        self._layermanager.nviz.UpdatePage('vector')
-                self.parent.nvizToolWin.UpdateSettings()
+                self._layermanager.nviz.UpdateSettings()
                 # update widgets
-                win = self.parent.nvizToolWin.FindWindowById( \
-                    self.parent.nvizToolWin.win['vector']['lines']['surface'])
+                win = self._layermanager.nviz.FindWindowById( \
+                    self._layermanager.nviz.win['vector']['lines']['surface'])
                 win.SetItems(self.GetLayerNames('raster'))
             self.init = True
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2010-05-31 09:41:42 UTC (rev 42403)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2010-05-31 10:13:00 UTC (rev 42404)
@@ -23,6 +23,11 @@
 import wx
+import wx.lib.scrolledpanel as SP
+try:
 import globalvar
 import gselect
@@ -34,40 +39,21 @@
 sys.path.append(os.path.join(globalvar.ETCWXDIR, "nviz"))
 import grass6_wxnviz as wxnviz
-class NvizToolWindow(wx.Frame):
-    """!Experimental window for Nviz tools
-    @todo integrate with Map display
+class NvizToolWindow(FN.FlatNotebook):
+    """!Nviz (3D view) tools panel
-    def __init__(self, parent = None, id = wx.ID_ANY, title = _("GRASS GIS 3D View Tools"),
-                 pos = wx.DefaultPosition, size = wx.DefaultSize,
-                 mapWindow = None,
-                 style = wx.CAPTION|wx.MINIMIZE_BOX|wx.RESIZE_BORDER):
+    def __init__(self, parent, display, id = wx.ID_ANY,
+                 style = globalvar.FNPageStyle, **kwargs):
+        self.parent     = parent # GMFrame
+        self.mapDisplay = display
+        self.mapWindow  = display.GetWindow()
+        self._display   = self.mapWindow.GetDisplay()
-        self.parent = parent # MapFrame
-        self.lmgr = self.parent.GetLayerManager() # GMFrame
-        self.mapWindow = mapWindow
-        self._display = mapWindow.GetDisplay()
+        FN.FlatNotebook.__init__(self, parent, id, style = style, **kwargs)
+        self.SetTabAreaColour(globalvar.FNPageColor)
-        wx.Frame.__init__(self, parent, id, title, pos, size, style)
-        # icon
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_nviz.ico'), wx.BITMAP_TYPE_ICO))
-        # dialog body
-        mainSizer = wx.BoxSizer(wx.VERTICAL)
         self.win = {} # window ids
-        # notebook
-        self.notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
         self.page = {}
         self.win['settings'] = {}
         self.win['settings']['general'] = {}
@@ -92,31 +78,16 @@
         self.mapWindow.render['quick'] = False
         self.mapWindow.Refresh(False)
-        mainSizer.Add(item = self.notebook, proportion = 1,
-                      flag = wx.EXPAND | wx.ALL, border = 5)
         # bindings
         self.Bind(wx.EVT_CLOSE, self.OnClose)
-        self.notebook.Bind(wx.EVT_NOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
+        self.Bind(wx.EVT_NOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
-        # layout
-        self.SetSizer(mainSizer)
-        mainSizer.Fit(self)
-        #        self.SetSize(size) #this produces a size that is consistently too small for the controls
-        self.Layout()
-        self.notebook.Update()
         self.Update()
-        self.SetPage('view')
-        self.CentreOnScreen()
+        # wx.CallAfter(self.SetPage, 'view')
     def OnPageChanged(self, event):
         new = event.GetSelection()
-        self.notebook.ChangeSelection(new)
+        # self.ChangeSelection(new)
     def PostViewEvent(self, zExag = False):
         """!Change view settings"""
@@ -125,10 +96,11 @@
     def _createViewPage(self):
         """!Create view settings page"""
-        panel = wx.Panel(parent = self.notebook, id = wx.ID_ANY)
-        self.notebook.InsertPage(0, page = panel,
-                              text = " %s " % _("View"),
-                              select = True)
+        panel = SP.ScrolledPanel(parent = self, id = wx.ID_ANY)
+        panel.SetupScrolling(scroll_x = False)
+        self.InsertPage(0, page = panel,
+                        text = " %s " % _("View"),
+                        select = True)
         pageSizer = wx.BoxSizer(wx.VERTICAL)
         box = wx.StaticBox (parent = panel, id = wx.ID_ANY,
@@ -253,12 +225,13 @@
     def _createSurfacePage(self):
         self.page['surface'] = {}
         self.page['surface']['id'] = -1
         self.page['surface']['panel'] = panel.GetId()
-        # panel = scrolled.ScrolledPanel(parent = self.notebook, id = wx.ID_ANY)
+        # panel = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY)
         # panel.SetupScrolling(scroll_x = True, scroll_y = True)
@@ -541,7 +514,8 @@
     def _createVectorPage(self):
         self.page['vector'] = {}
         self.page['vector']['id'] = -1
         self.page['vector']['panel'] = panel.GetId()
@@ -785,7 +759,8 @@
     def _createVolumePage(self):
         self.page['volume'] = {}
         self.page['volume']['id'] = -1
         self.page['volume']['panel'] = panel.GetId()
@@ -1004,10 +979,12 @@
     def _createSettingsPage(self):
         """Create settings page"""
-        self.notebook.AddPage(page = panel,
-                              text = " %s " % _("Settings"))
+        self.AddPage(page = panel,
+                     text = " %s " % _("Settings"))
@@ -1533,7 +1510,7 @@
     def OnApply(self, event):
         """Apply button pressed"""
-        if self.notebook.GetSelection() == self.page['settings']['id']:
+        if self.GetSelection() == self.page['settings']['id']:
             self.ApplySettings()
         if event:
@@ -1572,12 +1549,12 @@
         self.OnApply(None)
             fileSettings = {}
             UserSettings.ReadSettingsFile(settings = fileSettings)
             fileSettings['nviz'] = UserSettings.Get(group = 'nviz')
             file = UserSettings.SaveToFile(fileSettings)
-            self.lmgr.goutput.WriteLog(_('Nviz settings saved to file <%s>.') % file)
+            self.parent.goutput.WriteLog(_('Nviz settings saved to file <%s>.') % file)
     def OnLoad(self, event):
         """!Apply button pressed"""
@@ -1708,7 +1685,7 @@
         UserSettings.Set(group = 'nviz', value = nvsettings)
         file = UserSettings.SaveToFile()
     def OnBgColor(self, event):
         """!Background color changed"""
@@ -1722,7 +1699,7 @@
         self._display.SetBgColor(str(color))
-        if self.parent.statusbarWin['render'].IsChecked():
+        if self.mapDisplay.statusbarWin['render'].IsChecked():
     def OnClose(self, event):
@@ -1783,7 +1760,7 @@
         event = wxUpdateProperties(data = data)
         wx.PostEvent(self.mapWindow, event)
     def SetMapObjUseMap(self, nvizType, attrb, map = None):
@@ -1863,14 +1840,14 @@
     def OnSurfaceResolution(self, event):
         """!Draw resolution changed"""
         self.SetSurfaceResolution()
-        if apply and self.parent.statusbarWin['render'].IsChecked():
+        if apply and self.mapDisplay.statusbarWin['render'].IsChecked():
     def SetSurfaceResolution(self):
@@ -1924,7 +1901,7 @@
     def OnSurfaceModeAll(self, event):
@@ -1953,7 +1930,7 @@
     def _getColorString(self, color):
@@ -2546,11 +2523,11 @@
                 self.FindWindowById(self.win['view']['height'][control]).SetValue(hval)
         elif pageId in ('surface', 'vector', 'volume'):
-            current_page = self.notebook.GetSelection()
-            if self.notebook.GetSelection() != self.page[pageId]['id']:
+            current_page = self.GetSelection()
+            if self.GetSelection() != self.page[pageId]['id']:
                 for page in ('surface', 'vector', 'volume'):
                     if self.page[page]['id'] > -1:
-                        self.notebook.RemovePage(self.page[page]['id'])
+                        self.RemovePage(self.page[page]['id'])
                         self.page[page]['id'] = -1
                         oldpanel = wx.FindWindowById(self.page[page]['panel'])
                         oldpanel.Hide()
@@ -2559,12 +2536,12 @@
                 self.page['settings']['id'] = 2
                 panel = wx.FindWindowById(self.page[pageId]['panel'])
-                self.notebook.InsertPage(n = self.page[pageId]['id'],
-                                         page = panel,
-                                         text = " %s " % _("Layer properties"),
-                                         select = True)
+                self.InsertPage(indx = self.page[pageId]['id'],
+                                page = panel,
+                                text = " %s " % _("Layer properties"),
+                                select = True)
-            self.notebook.ChangeSelection(current_page)
+            # self.ChangeSelection(current_page)
             if pageId == 'surface':
                 self.UpdateSurfacePage(layer, data['surface'])
             elif pageId == 'vector':
@@ -2572,7 +2549,7 @@
             elif pageId == 'volume':
                 self.UpdateVectorPage(layer, data['vector'])
+        self.Update()
         self.pageChanging = False
     def UpdateSurfacePage(self, layer, data):
@@ -2844,7 +2821,7 @@
     def SetPage(self, name):
         """!Get named page"""
-        self.notebook.SetSelection(self.page[name]['id'])
+        self.SetSelection(self.page[name]['id'])
 class ViewPositionWindow(wx.Window):
     """!Position control window (for NvizToolWindow)"""
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2010-05-31 09:41:42 UTC (rev 42403)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2010-05-31 10:13:00 UTC (rev 42404)
@@ -292,7 +292,7 @@
             self.parent.toolbars['vdigit'].OnExit()
         if self.parent.toolbars['nviz']:
             self.parent.toolbars['nviz'].OnExit()
     def Enable2D(self, enabled):
         """!Enable/Disable 2D display mode specific tools"""
         for tool in (self.pointer,
@@ -1353,18 +1353,11 @@
     def OnSettings(self, event):
-        if not win.IsShown():
-            self.parent.nvizToolWin.Show()
-        else:
-            self.parent.nvizToolWin.Hide()
+        """!Show nviz notebook page"""
+        self.parent.parent.lmgr.notebook.SetSelection(3)
     def OnExit (self, event=None):
         """!Quit nviz tool (swith to 2D mode)"""
-        # hide dialogs if still open
-        if self.parent.nvizToolWin:
         # set default mouse settings
         self.parent.MapWindow.mouse['use'] = "pointer"
         self.parent.MapWindow.mouse['box'] = "point"
@@ -1372,7 +1365,7 @@
         # disable the toolbar
         self.parent.RemoveToolbar("nviz")
 class ModelToolbar(AbstractToolbar):
     """!Graphical modeler toolbar (see gmodeler.py)
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2010-05-31 09:41:42 UTC (rev 42403)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2010-05-31 10:13:00 UTC (rev 42404)
@@ -54,7 +54,10 @@
     import wx.lib.agw.customtreectrl as CT
 except ImportError:
     import wx.lib.customtreectrl as CT
+try:
 sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
 from grass.script import core as grass
@@ -81,6 +84,7 @@
 import gui_modules.menu as menu
 import gui_modules.gmodeler as gmodeler
 import gui_modules.vclean as vclean
+import gui_modules.nviz_tools as nviz_tools
 from   gui_modules.debug import Debug
 from   gui_modules.ghelp import MenuTreeWindow
 from   gui_modules.ghelp import AboutWindow
@@ -203,11 +207,11 @@
         cbStyle = globalvar.FNPageStyle
         self.gm_cb = FN.FlatNotebook(self, id=wx.ID_ANY, style=cbStyle)
         self.gm_cb.SetTabAreaColour(globalvar.FNPageColor)
-        self.notebook.AddPage(self.gm_cb, text=_("Map layers for each display"))
+        self.notebook.AddPage(self.gm_cb, text=_("Map layers"))
         # create command output text area and add it to main notebook page
         self.goutput = goutput.GMConsole(self, pageid=1)
-        self.outpage = self.notebook.AddPage(self.goutput, text=_("Command console"))
+        self.notebook.AddPage(self.goutput, text=_("Command console"))
         # create 'search module' notebook page
         self.search = MenuTreeWindow(parent = self)
@@ -219,7 +223,21 @@
         self.gm_cb.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CLOSING, self.OnCBPageClosed)
         return self.notebook
+    def AddNviz(self):
+        """!Add nviz notebook page"""
+        self.nviz = nviz_tools.NvizToolWindow(parent = self,
+                                              display = self.curr_page.maptree.GetMapDisplay())
+        self.notebook.AddPage(self.nviz, text = _("3D view"))
+        self.notebook.SetSelection(self.notebook.GetPageCount() - 1)
+    def RemoveNviz(self):
+        """!Remove nviz notebook page"""
+        # print self.notebook.GetPage(1)
+        self.notebook.RemovePage(3)
+        del self.nviz
+        self.notebook.SetSelection(0)
     def WorkspaceChanged(self):
         """!Update window title"""
         if not self.workspaceChanged:
